DC-Fix Diffusion Film Sale
446 posts / 0 new
ReManG
Last seen: 5 months 7 hours ago
Got mine in, thanks! I am impressed, most of the accessories like this seem overhyped, but the DC Fix works very well. I think I will be using this on more than I thought, including o e of my BLF A6’s!
MountainKing
Last seen: 2 weeks 5 days ago
How do you ‘stick’ it up on the lenses? Thanks
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
jacktheclipper
jacktheclipper's picture
Last seen: 8 hours 54 min ago
Remove lens from light . Clean it with alcohol . Cut a piece of film slightly larger than the lens . Peel backing off film and apply it to the lens , making sure to get all of the bubbles out . Use a razor blade to trim the film by cutting flush against the edge of the lens at a 45 degree angle .
I usually put the lens back in with the film on the inside . This allows the bezel O-ring to seal properly .
Any questions ?
What I do
Lord_Niksidor
Last seen: 7 months 2 days ago
I’ve got a kinda throwy headlamp currently XM-L T6 that I want to put a 365nm UV emitter into but would like the beam to be more floody… has anyone tried using this film on UV lights before?
MountainKing
Any questions ?
Could not be more well explained than this. Perfect and thanks _
Boaz
Boaz's picture
Last seen: 10 hours 36 min ago
Nice Jack !… Thats the proper way to do it . I usually just take out my socket set ,find one that fits inside the bezel and use it to trace a circle , Carefully cut it out and stick it on the outside of the lens .You want to do a pretty good job so you don’t have any light leaking around the diffuser .
ReManG
I now have this on my BLF A6, the one I have an XPL HI swapped in place of the stock emitter. The previous hotspot is now well blended into the edges of the beam. It really does give a good smoothing to the beam profile.
DavidEF
DavidEF's picture
Last seen: 3 days 39 min ago
Wait a minute…
You swapped out the stock emitter for a XPL HI (tighter spot, more throw) and then negated your efforts by affixing DC Fix to the lens? (obfuscated spot, more flood)
Tell me how that makes sense, please. I don’t understand.
- The YKK Philosophy
zipelgas
zipelgas's picture
Last seen: 5 hours 37 min ago
Any info how much heat can this thing take? I would like cover some spotlights around the house running from mains voltage. It’s probably not designed for that kind of abuse.
Overkill is just about enough!
DavidEF
DavidEF's picture
From the website:
Quote:
WHAT TEMPERATURES CAN D-C-FIX® WITHSTAND?
d-c-fix® can comfortably withstand temperatures between -10°C and +50°C
Edit: Oh yeah, this too.
Quote:
IS D-C-FIX® HEAT RESISTANT?
d-c-fix® is heat resistant up to 75°C for short periods of time
ReManG
DavidEF wrote:
Wait a minute…
It is a V3 2D XPL HI. Better tint than the blueberry infused stock 1A for starters. The “increased throw” is just a bit tighter hotspot, it still has that now, but the edges blur into the spill. It does cut the throw some, but still better than stock….
Not to mess with you, but all this is for experimentation anyway, sorry to leave you scratching your head at my follies.
I am contemplating a hole in the center of the DC Fix to see what that would look like…
1dash1
1dash1's picture
Last seen: 2 years 5 months ago
ReManG wrote:
. I am contemplating a hole in the center of the DC Fix to see what that would look like…
I’d be curious about the results.
My guess is that the edge of the hole would be an “artifact magnet”, creating a highly visible point of discontinuity in the beam profile.
Rule 1-1 as it applies to life, take it as it comes.
ReManG
I will have to look for one of those hobby stamps or cutters that cuts about 1/2” circle with jagged edges. I think that it will be hard enough to line up on center, but a jagged edge should minimize this somewhat…
I will post pics if I do this, but I do not know if I will have time.
DavidEF
DavidEF's picture
In a reflector light, the hotspot comes from around the edges and the spill from the center area. You would be adding a little spill, possibly, and a few new artifacts to the otherwise smooth beam profile, and not much else. If you really want to play experiment, instead of having a hole in the center of the DC Fix, you could add another color to the center to replace the rainbow effect that Cree forgot to install into the XPL’s. Silly
Anyway… So, are you saying that the difference of a tighter hotspot that you got from changing to the XPL HI is bigger (stronger effect) than the difference in the other direction that you got from putting DC Fix on the lens? I’ve never used DC Fix, so I’m trying to learn about it.
ReManG
Yes, I switched the DC Fix lens to my Eagle Eye A6 with a Nichia 219C and the flood is more than with the XPL HI on the BLF A6. I like the profile of the EE A6 with the DC Fix more, it is not as bright as the BLF A6 and makes a great flood as well as a more neutral tint.
Like I said, the XPL HI with the DC Fix was good, and still throws about like a regular XPL, with a brighter middle and less defined (but still brighter) hotspot. So the DC Fix is not a total wash for throwers either. I may order an extra C8 lens to experiment with…
I really like the DC Fix on the optic of my DQG Tiny III 18650, now it is a flood…
cabfrank
Last seen: 4 hours 57 min ago
Got mine, thank you Jeff!
ReManG
Had a chance to try it yet?
Boaz
Boaz's picture
Cabfrank,you’re welcome ….
Yes i still have plenty left.
Lets just say ..they had to shut down one production line to run some more .. Everyone knows what I’m getting them for Christmas .. because I wrapped presents with it .
ReManG
Ok, so no one here that has purchased has felt like posting about their impressions on DC Fix?
I like mine the best on the optic in my DQG Tiny III 18650….
pilotdog68
pilotdog68's picture
Last seen: 5 months 3 days ago
I haven’t actually used any of mine yet….
ohaya
Last seen: 3 years 5 months ago
Mine just arrived. I have a couple of headlights that I think are too spotty, and I’m going to try it on one of them, if I can cut it correctly.
Thanks,
Jim
jacktheclipper
It has not been mentioned in this thread yet , but this film will also even out the tint shift , or 'Cree rainbow' effect .
What I do
ohaya
Thanks,
Jim
Ok, I tried this with one of my headlights. It’s a 3xAA Rayovac that I like using for close working. It has a TIR lens, but it’s got a really/ugly-shaped beam and very bright/distinct hotspot.
My wife cut a piece of the DC-fix to fit over the TIR, and I just peeled the backing off and stuck it on the front of the TIR.
The beam is much “nicer” (no more ugly shape and weird artifacts), and the hotspot doesn’t seem as intense as before. I still can’t use it on high mode for really close up work, but the medium is very useable now.
Splott-Light
Splott-Light's picture
Hi Boaz,
Many Thanks once again for “Bulk Buying” this for us.
Been wanting to try some of this for ages!
I ran a quick test with a Lucky Sun P26650 I had modded (warmer tint LED on Noctigon, and 105C driver), and diffusion-filmed as I wanted a more “spill” beam, and used some generic privacy film for house windows, purchased off eBay.
Readings off light meter at 1 meter using old film were:
Low 03 Medium 09 High 24, and This Film:
Low 05 Medium 15 High 43,
so (if my math is right) +67% for Low and Medium, with High +75%
Good result and still has slight “hotspot” definition with great “Spill” too. I’m Very Happy with the results.
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
Boaz
Boaz's picture
Thanks for the info splott. 75% better than your old generic film is impressive ..This just reaffirms Selfbuilts numbers .
i did some quick seat of the pants tests on two BLF A6’s
– Stock light at 36” inches off the floor the edge of the spill hits the floor at about 4 and a half feet
-With DC-fix it hits the floor at 6 inches
increases the flood so wide i’m always blown away . perfect for headlamps . I use diffuser film on lights in place of lanterns or a traffic wand diffusers because they cause way too much glare . diffuser film is much easier on the eyes .
siata94
siata94's picture
Last seen: 2 days 15 hours ago
I’ve tried DCFix Sand on 2 lights; 502b and X6, both for mountain biking.
Without DCFix, they were not ideal for MTB as hotspot too intense with no spill. With
DCFix, both were perfectly smooth and floody beam, tried both on handlebar
as well as helmet. Thanks Boaz.
cabfrank
Unfortunately, I haven’t had time to try it yet. I think it will be great for an older light I use on my bike, when I get a chance to play.
ReManG
I do not remember who called this stuff “Mag-fix” for being able to de ring stock maglite beams, but they were absolutely correct… My Mini Mag beam looks awesome and as soon as I find my 2D, I will hit it up too….
Cula
Cula's picture
Nitecore HC50, BLF A6, Convoy S2 XP-L red, thanks Boaz.
Ronin42
Ronin42's picture
I used the DC-FIX on three lights
  1. my “working” aka less then perfect (reflector dull) P36 a it is a definite plus!, but I am in no rush to use it on my shelf queen versions. High power lights are nice when you can see that they have punch.
  2. on a project s7 triple nichia 219C 5k, used it on the medium flood TIR and compared it against the full flood TIR version (more below).
  3. on a solarforce 3.04 amp 3C XML2 emitter, for me makes the light much more friendly and usable.
Something I noticed is that it really will not make a thrower, a flooder. But it does seem to blend (a lot) and broaden (a little) the hotspot out nicely with any light. Again it does not turn a thrower into a mule.
As far as #2 the (before) medium flood is/was brighter then the full flood (which takes a lot more juice, but for me the full flood is a nicer profile if you have the power).
(after) the full flood is now brighter then medium flood with DC-FIX. the medium flood is now more like the full (but still not as even as the full flood) but at the cost of not being as bright and focused as before (makes sense if you think about it). Wink
So in total I like using DC-FIX but it is not for every light. But for lights with “issues” it is a great way to make them more friendly and usable.
I think it should be a given for headlamps with enough umph.
As far as application I did not follow the instructions Wink I just popped out the lens to be covered, cut a square large enough to cover the lens. cleaned the lens and pealed and stuck the DC-FIX on to the lens, then I just used scissors to trim off the excess DC-FIX, no sweat easy peasy.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
