DC-Fix Diffusion Film Sale
459 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 4 hours 1 min ago
I just added some to a TackLife that I got. Pop the front glass, cut a disc exactly to that size but just a hair smaller if need be, and pin it against the glass with the reflector.
Obviously, it’s not gonna be a thrower anymore, but for heading into the basement/attic/barn/whatever, it’s about perfect.
phouton
Last seen: 3 hours 13 min ago
Funtastic wrote:
How would you apply this one when it has no adhesive?
^ That’s how I did it.
Funtastic
Funtastic's picture
Last seen: 15 min 30 sec ago
Excellent, thank you
I tried to remove the bezel on my SP40 but it’s way too tight, maybe they glued it
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
phouton
Mine was tight too, but not glued.
What worked for me was to use a large flat rubber band, like the kind that is used to bunch broccoli or other vegetables. I put the flat parts against the bezel to give my thumbs more grip to unscrew it (holding the light vertically, bezel facing me, left thumb pushing down on left side of bezel, right thumb pushing up on right side of bezel), and then it wasn’t bad. I used the same technique in the opposite direction for tightening the bezel when reassembling.
Btw, on my SP40 the bezel does not sit perfectly flush with the body of the flashlight. There is a very slight gap. Is that the case for others too? I think it was like that before adding the film, but I wondered if the added thickness could have had an effect. I’m a bit too lazy to remove the film and check for the gap again. Silly Hopefully it doesn’t affect the water resistance.
LEDicrous
Last seen: 9 months 2 weeks ago
Hi experts,
Just learn about diffusion film thanks to your discussion in Review Sofirn SP40 Can you please help for some beginner’s questions?
Q1. What a diffusion film look like? Link to photos/videos?
Q2. How to use it? Reading in a few posts above it looks like there are two solutions: adhesive on the outside or disassemble the glass and put it inside.
Q3. Does the diffusion film has any influence on the color temperature?
Q4. Reading above, for Sofirn SP40, film #7 is the most suitable. What is the reason?
thefreeman
thefreeman's picture
Last seen: 9 min 5 sec ago
1) plastic sheets of variable thinkness and patterns
2) yes, or adhesive inside, or non adhesive outside if there is something to hold it, whatever suits best each cases.
2) look at my beamshots in the previous page, some lower the CCT a bit, especially #10 but also #13 and #14, all of the others too it seems to me, but it’s very faint (even on top of an already diffused beam, so not tricked by the uniformisation of the tint)
7) #7 is a strong diffuser (like #1), good if the goal is a floody headlamp, and thin, so good to go behind the glass
LEDicrous
How big is the sheet? Like a “Letter size” paper? Or a same dimension as a post card?
Looks like film #7 is a good choice. Just for safe, I would like to attempt an adhesive version of that file #7, can you please suggest a model?
thefreeman
Sizes are given in the 1st post. #1 (dcfix) is adhesive and also a strong diffuser, I just put some on a h600fw on which I replaced the lens (by a clear one because I didn’t find frosted lenses), adhesive was needed because there is no space inside even for the 0.2mm thickness of #7 (or #1), it had to be put outside.
chrisddo
Last seen: 1 month 1 week ago
Can’t wait to receive my filter sheets!
Boaz
Boaz's picture
Last seen: 19 hours 45 min ago
thefreeman wrote:
I made some flux loss test in an integrating shoe-box™ and with a smartphone luxmeter (with ceilingbounce app from Zak) This is what I got : nothing :106% lens : 100% lens + 1 : 91% 2 : 96% 5 : 95% 7 : 90% 10 : 94% 13 : 95% 14 : 94% lee minus green 1/8 : 86 % 1/4 : 82 % 1/2 : 69 % And some beamshots, I tried to find the worst beam I had but it's not a really bad beam so... would have been better with a really terrible beam for demo. https://imgur.com/a/msFKecD (zoom on the pics because otherwise there is some color banding) I couldn't beamshot all diffusers because some samples were too small for this flashlight, I also had a sample 1cm wide... can't test it on any lamp... on the other hand, #5 is supposed to be a sample, yet it's a full sheet Smile I didn't beamshot #1 either because it's adhesive, and since I wont put an adhesive one on this flashlight.. I would have to waste some #1 . #7 is directional !! like 5 but less pronounced... #2 seems like the weakest diffuser (but the one with the least light loss) Minus green's are pretty cool Thumbs Up I'll decide between 1/8 and 1/4 for this lamp. edit (added #1) : stock : !{width:30%}https://i.imgur.com/eMryWWX.jpg!:https://i.imgur.com/eMryWWX.jpg #1 : !{width:30%}https://i.imgur.com/SSG3et5.jpg!:https://i.imgur.com/SSG3et5.jpg #2 : !{width:30%}https://i.imgur.com/2Dsflnl.jpg!:https://i.imgur.com/2Dsflnl.jpg #5 : !{width:30%}https://i.imgur.com/CbfkHfi.jpg!:https://i.imgur.com/CbfkHfi.jpg #7: !{width:30%}https://i.imgur.com/1z2B5NO.jpg!:https://i.imgur.com/1z2B5NO.jpg #13 : !{width:30%}https://i.imgur.com/LeqYLfG.jpg!:https://i.imgur.com/LeqYLfG.jpg 1/8 : !{width:30%}https://i.imgur.com/jR7ZbSb.jpg!:https://i.imgur.com/jR7ZbSb.jpg 1/8 + #2 : !{width:30%}https://i.imgur.com/nBzzctM.jpg!:https://i.imgur.com/nBzzctM.jpg 1/4 : !{width:30%}https://i.imgur.com/Wan62p2.jpg!:https://i.imgur.com/Wan62p2.jpg 1/4 + #2 : !{width:30%}https://i.imgur.com/7rX3a4P.jpg!:https://i.imgur.com/7rX3a4P.jpg 1/2 : !{width:30%}https://i.imgur.com/oNmBB56.jpg!:https://i.imgur.com/oNmBB56.jpg[/quote]
 Great pics that deserve a re-post . They can be clicked on twice to be made bigger & then bigger yet .. Thanks for these !!
Epic  !
Geronimo
Last seen: 2 months 9 hours ago
Thanks man! Received mine in the mail today , fast shipping and good communication. Will try a beamshot comparison on my zerbalight sc700d.
Emisar d1s 3a. ZL sc700d,sc64w hi,H600c,Streamlight tlr1-hl, Astrolux mfo1s 4k/purple. Olight I3t Eos black. Ylp 2m cri.ZL sc64le, k1 xhp35 hi in 4k.
Williamskw86
PM sent to you, Boaz. Thank you.
Geronimo
My camera is acting up ,but here is a after and before. Didn’t think there was this big of a difference in tint, definitely on smoothing out the hotspot, but the pics tell the truth.
Geronimo
captainkirk
Last seen: 5 hours 33 min ago
I also got a special package from Boaz, and while I have no beamshots, I am quite pleased with the results. I put the original dcfix on an old thrunite t10 I use for a bedside light and it evened out the tint shift and smoothed the hot spot into the spill. I used some #7 on the inside of a s2+ 2700k convoy to flood things even more. Good stuff indeed, I just need to work on my cutting skills (even with trace around sockets and all).
Thanks for a great product and quick shipping Sir, I need to find a place to use the sheet of#5 thrown in for good measure. ;0)
This space for let.
troutpool
Last seen: 9 months 5 days ago
My order arrived yesterday. Thank you, Boaz. Now I can smooth out the beams of my Malkoff dropins.
mbp
Last seen: 7 hours 40 min ago
Sent PM, I would like to purchase some.
nick779
nick779's picture
Got my film a few days ago and subsequently forgot to post beamshots……
My wife has a Cricut that we use for cutting vinyl and paper to do crafts and make shirts. Its basically a cheap consumer computer guided knife. It cuts perfect circles =D
Ive so far added DC-Fix #1 to my Acebeam H40 which did exactly what I wanted it to. It smoothed out and made the hotspot bigger.
I also ordered a sheet of regular Zircon minus green. That went in my green SST20 5K D4S (v1) and it made a HUGE difference in tint. Its a good bit rosy, I almost wish there was a less aggressive filter option but im just nitpicking.
Great stuff overall and Boaz was great to work with!
Boaz
Boaz's picture
  Thanks Nick ;
I appreciate the feedback
Nice to be able to kill off nasty green tints
DHart
Last seen: 9 months 6 days ago
Wow am I L A T E. to the par-tay! But I got here as quick as I could.
Need to get me some a that to fix my JetBeam throwers than I now wish were flooders.
DHart
Ordered up some:
  1. with adhesive, significant diffusion, 91%
  2. Lightest diffusion, no adhesive
  3. Playing card thickness, no adhesive
  4. Fine frosting, no adhesive, 90%
#F2 minus 1/4 green
Dekzter
Anybody know how easy it would be to install this in a Thrunite T1? I can’t wait to get rid of that nasty green.
SammysHP
SammysHP's picture
Last seen: 2 hours 28 min ago
You can just put it on from the outside. Works with every flat TIR or glass.
thefreeman
The T1 is relatively easy to open, there is some threadlock but not the hard stuff, I used pliers+rubber but considering how easy it came it would probably have come by hand. So you can put the diffuser inside if you want.
Dekzter
Awesome, thanks!
Any idea about the Sofirn SP40?
thefreeman
Sorry I don’t have that one.
goshdogit
goshdogit's picture
Last seen: 6 hours 19 min ago
My SP40’s bezel unscrewed without much effort. It had no glue.
gchart
gchart's picture
Last seen: 7 hours 45 min ago
I just received a nice envelope from Boaz with a bunch of sample pieces of the various offerings. I’m hoping to run through and measure the effect each one has on lumens and intensity.
My interest was piqued a little bit back to help fix some Cree rainbows like on the Sofirn SP33 V3 with the XHP50.2. The original DC-Fix did wonders! I can’t wait to see how these others compare.
TimMc
TimMc's picture
Last seen: 3 hours 54 min ago
Thanks Jeff!
I added dc-fix #1 to one of my Sofirn C01R torches and my Olight i3T.
HustleHabit
Last seen: 1 year 1 month ago
PM sent. Looking forward to testing out some DC Fix #1 on a Sofirn SP40 and SC31 pro. I’ll post some pictures after with the results.
If the people in power won't give you freedom; the only way to freedom is through power. - Nelson Mandela
