Test/Review of 40W 5V/8A 5-Port Family-Sized Wall Charger
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 13 hours ago
DSC_9482
Official specifications
  • Output:5V/8A
  • Power consumption:40W
  • Dimension:92 x 60 x 27mm
  • Cable length:Approx.155 cm
  • Color:White
  • Weight:242 g
I bought this from ebay dealer ec-sell1
DSC_9480
DSC_9481
DSC_9483
DSC_9484
DSC_9485
DSC_9486
DSC_9487
Measurements
  • All outputs are in parallel, but with fuses on each output.
  • Idle power 0.15 watt at 230VAC
  • All USB outputs has automatic coding with Apple 2.5A as maximum.
5%20port%2040W%20%231%20load%20sweep
5%20port%2040W%20%235%20load%20sweep
Output voltage is stable and the efficiency is around 80%, all the usb outputs looks the same, but I am missing overload protection on each port (It do exist, but triggers at a higher current).
5%20port%2040W%20load%20sweep
Running all outputs in parallel I can test the full current of the power supply, without to much loss in the cables.
It looks very nice with overload protection kicking in at 8.5A.
In the tear down it can be seen that there is a small fuse for each output, but it does obvious not blow at the currents I used for testing.
5%20port%2040W%20load%20test
One hour with 8A load is not a problem.
The temperature photos below are taken between 30 minutes and 60 minutes into the 1 hour test.
Temp1783
M1: 57,8°C, M2: 62,3°C, M3: 61,4°C, HS1: 73,8°C
Generally the box get fairly warm, this is unavoidable with the amount of power it handles and the compact size.
The hottest spot here is the two rectifier diodes (HS1), the heatsink for the diodes (M2), the transformer and the heatsink for the main switcher transistor (M3).
Temp1784
M1: 58,3°C, M2: 57,7°C, M3: 59,6°C, HS1: 76,0°C
Again the heatsink for the rectifier diodes can be seen (M1)
Temp1785
M1: 58,0°C, M2: 46,7°C, M3: 58,6°C, HS1: 66,8°C
The circuit board is warm below the heatsink for the rectifier diodes, especially where the diodes are mounted (HS1)
Temp1786
M1: 64,2°C, M2: 45,7°C, M3: 53,9°C, M4: 51,4°C, HS1: 65,6°C
The heatsink on the rectifier diodes does also warm this side of the box (HS1), the transformer (M3) do also add a some heat.
10ohm
The rms noise is low, but there is some spikes: 15mV rms and 440mVpp at 0.5A.
2.5ohm
At 2A the noise is 24mV rms and 700mVpp
1.2ohm
At 4A the noise is 24mV rms and 630mVpp
0.6ohm
At full power (8A) the noise is up to 45mV rms and 1200mVpp
Tear down
DSC_9731
The box was closed very well, I had to cut it open (Very good).
DSC_9722
Due to the heatsink it can be difficult to see some of the parts. I found a fuse, common mode inductor, bridge rectifier, mains switcher transistor, opto feedback, safety capacitor, two rectifier diodes.
DSC_9724
DSC_9726 DSC_9728
DSC_9727
DSC_9723
On the bottom is the mains switcher chip (A small 6 pin IC marked U1). The F2 to F6 is small fuses protecting the outputs The chips U5 to U9 is the automatic usb coding..
DSC_9729
DSC_9730
There is a good distance between mains and low volt side on the circuit board.
Testing the mains input with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This power supply/charger looks acceptable, it has lots of power, good isolation between mains and low volt side, stable output voltage and can charge just about anything, only "problem" is the spikes in the output voltage. This may make some equipment malfunction.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Lord_Niksidor
Awesome, this is that ebay one you mentioned ages ago, I can’t recall which one you thought it might have been a copy of. Happy I bought the blitzwolf one given the spikes.
HKJ
HKJ's picture
Probably, I do have a few usb charger reviews in queue that are getting a bit old. I do also have some never in queue, but I will try to publish the old ones first.
I can't recall which one you thought it might have been a copy of.
Me neither, but both Anker and Blitzwolf 5 port looks very much the same, but has better noise performance.
