BLF ReyLight Titanium Flashlight 3*Nichia
195 posts / 0 new
jack-bkk
Last seen: 1 year 9 months ago
but you can easily flash the attiny with many ok tks firmware like cyperus 2 i did that but moon will always be brighter as a single led moon i guess
maukka
maukka's picture
Last seen: 10 months 1 week ago
I’ll take one
Option 2 – $95 = green trit in the tail switch
akhyar
akhyar's picture
Last seen: 4 hours 22 min ago
Thanks for your suggestion.
Any post or thread on how and what needed to flash the firmware?
I’m fine with changing the mode in BLF A6, BLF Kronos X5/X6 but flashing the firmware in the stock driver for flashlights is something that I haven’t done and any tips or guidances are very much appreciated.
While I do like this flashlight, the lowest mode is just too bright for my preference and comparing side by side with my Sinner Tri-EDC, it’s almost like the lowest mode is about the same as the medium mode (ML, L, M) on my Sinner.
cheers,
FmC
FmC's picture
Last seen: 11 months 2 days ago
Start by reading through Hoop’s thread.
akhyar
akhyar's picture
Thanks for the link.
On first glance, not for the faint hearted.
Maybe I’ll be better off replacing the driver with FET+1 as I already have soldering station and some tweezers Silly
Tooreal
Tooreal's picture
Last seen: 2 years 8 months ago
Hey Rey,
Since mine has not shipped out to me yet, I’d like to Buy 1 More of these, Please.. Option #1 would be Fine! I will wait for your response before I send the payment..
Interested in repairing my JetBeam TC-R1, (I’m lacking knowledge and a Novice) Wires broken between LED and Double Stacked Boards below. I soldered New wire to LED (Brass LED Base is loose, not glued or secured). 1 wire is Broken just above the top of the
ReyLight
ReyLight's picture
Last seen: 2 hours 13 min ago
Tooreal wrote:
Hey Rey,
PM replied.
Tooreal
Tooreal's picture
Hello Rey,
Any ideas on when the Ti Flashlights will ship out to us? I am chomping at the Bit to Tryout this Awesome Flashlight. Big Smile
I feel like a Kid about to turn 9 just waiting to open my Birthday Present …
Thanks in advance for your Help and Hard work on this Awesome Flashlight.. Smile
ReyLight
ReyLight's picture
Tooreal wrote:
Hello Rey,
Hi,
It is shipped. I will get the tracking and send it to you later today.
steven17601
Last seen: 5 years 9 months ago
Hey, are these still available? I’d love to buy option #2 with blue tritium if possible
ReyLight
ReyLight's picture
Yes, available, you might paypal to vivian2c326@sina.cn
GeoFong
Last seen: 5 years 4 months ago
I would be in for 1 with option 3 please, Paypal sent!
  1. with Blue
  1. with Green, Ice Blue & Yellow
Thanks Rey!
aplaudatu
Last seen: 11 months 3 days ago
I just received mine ( funny ,2 days between Beijing-Amsterdam and 5 days for 1,1 km between collecting point and me.Yay ,PostNL ).
Quick impressions :
-indeed the engraving on the button is not centered – and i like this , it’s personal ;
-threads perfect after some grease
With apologies for the flashlight market i will not buy another one for the next 5 years ,i see no reason . For the price i payed i consider it a gift from Rey.
Now i am collecting money for 11 trits ,not because i am a big fan but i respect Rey’s design&vision ,and this one deserve trits….after i anodize it blue and some tumbling.
Thank you,Rey.
maukka
maukka's picture
I got mine. Measured CCT 4940 K and a CRI of 84 and CRI of 27.
Only some of my 30Q’s fit and they are very tight. Have to push them in. Also my flat tops won’t work without a magnetic button top. Efest 18350’s fit fine, but also need an additional magnetic button.
How’s the output on your lights? Mine only produces similar lumens to an Astrolux S1. With a 30Q 1250 lumens at startup. 1080 lumens with an efest 18350. At 30 seconds about 900 on both. I thought it was supposed to reach 2000 lumens.
Tailcap button is wonky. I have to press it right in the middle for it to push down. Doesn’t feel nice at all. The engraving is well centered enough.
aplaudatu
25R flat top no problem ; with it the output is slightly better than a nitecore rated for 1000 lumens with the same battery.
le: play with the 2 threaded rings,one outside and the one from inside ,you can adjust it .
ReyLight
ReyLight's picture
PM replied.
maukka
maukka's picture
And not to sound too negative, the tint is absolutely fabulous and the beam smooth and floody. Perfect.
Although the high pitched and loud whine is quite annoying on low and medium…
maukka
maukka's picture
Some graphs. Fantastic!
djozz
djozz's picture
Last seen: 6 hours 41 min ago
I’m pretty sure that Rey did not measure the output of the light as-sold. First it is still not completely which led he used, he said 219B, then 219C, and now in the OP the 219C is not mentioned anymore, but you mention 84CRI, which does suggest 219+C+. The numbers he got from me (2700lm at start-up, 2000 at 30 seconds) were from my triple 219+C+ mod, and it has bypassed springs and the ledboard soldered to the pill (makes just a little difference). If the light that he sells has 219+B+ high CRI leds, the output will be nowhere near that.
Which is all too well btw, I think I damaged the leds in mine by running it too long too hot, the output at startup is now under 2000lm. In an aluminium light I can easily feel on the outside when it is time to step the output down, in this titanium light the leds can cook before you notice much on the outside. even at the 1000 lumen output that you get you have to be very careful not to run the light at the higest setting for more than say 30 seconds. (it is not mentioned, but does Rey use a Noctigon in this light?) edit: the pictures show the use of a Noctigon alright Smile
akhyar
akhyar's picture
Sorry to hear about your unit.
On my unit, the flat top 30Q, NCR-GA and LG MJ1 all can work.
Swapping to 18350 tube, the AW IMR button-top and Keeppower flat top both can work, so most probably your issue is due to samples’ variation.
Regarding the tint, I compared the beam with my Sinner Triple 219B, and I notice the beam on my Reylight is whiter and slightly brighter than my Sinner, so I just takes the word frm Rey that the emitters are 219C.
I can hear the whine on low and medium modes, but it dissappears on Turbo
Solaris
Solaris's picture
Last seen: 5 years 8 months ago
is there any visual difference between 219B and 219C?
SUREFIRE 6P - TRIPLE NICHIA 219C
Brett H
Last seen: 1 year 8 months ago
Mine seems to heat up very quickly. Is this pretty common with this light?
b1uedeath
Last seen: 5 years 7 months ago
Hi, can I still join this? Would like one option #3 if possible!
ReyLight
ReyLight's picture
The heat is normal.
ReyLight
ReyLight's picture
PM coming.
Biker1-
Biker1-'s picture
Last seen: 9 months 4 weeks ago
I’m interested in Option #3 w/9 ice blue/green trits alternating + green trit in tail.
Is this 219B?
Are issues all worked out?
What is the turn around time?
Thanks.
Firelight2
Firelight2's picture
Last seen: 1 hour 10 min ago
Yes.
219B – most are high CRI (90+ CRI), and 4500K. Color temperature is warmer than the 219C and color rendering is better.
219C – much, MUCH brighter than 219B, but typically cooler 5000K color temp and not high CRI.
redinzane
Are there still any left? If so, I’d like Option #2 with a green Trit in the Tail cap.
ReyLight
ReyLight's picture
Yes, available, PM coming.
MCT
MCT's picture
Last seen: 2 weeks 2 days ago
Please PM me and let me know if these options are still available:
Option #3
- Ice Blue/Red/Blue trits
- Red in tail cap
Total cost to deliver to 93737 (California) and expected delivery time.
Thanks – MCT
