Test/Review of Imren IMR18650 2500mAh (Purple)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
DSC_1977
Official specifications:
  • Brand: IMREN
  • Weight: 50g
  • Capacity: 2500mAh
  • Length : 64.99mm
  • Diameter: 18.24mm
  • Voltage: 3.7V
  • Excellent high-current discharge performance
  • Model: 18650
  • Material: Li-Mn
  • Discharge rate: 40A
Imren%20IMR18650%202500mAh%20(Purple)-info
A fairly high capacity cell with very high current rating.
DSC_1976
DSC_1978 DSC_1979
DSC_1980
DSC_1981
DSC_1982
Imren%20IMR18650%202500mAh%20(Purple)-Capacity
The cells are not perfectly matched, but fairly close. I do not believe the 40A rating, the 30A looks like it is too much for this cell.
Imren%20IMR18650%202500mAh%20(Purple)-CapacityTimeHours
Imren%20IMR18650%202500mAh%20(Purple)-Energy
Imren%20IMR18650%202500mAh%20(Purple)-PowerLoadTime
Imren%20IMR18650%202500mAh%20(Purple)-TripCurrent
Imren%20IMR18650%202500mAh%20(Purple)-Charge
Conclusion
It is an acceptable cell, but I would not go above 20A on it.
Notes and links
The batteries was supplied by Imren for a review.
Compare to 18650 and other batteries
Milan
Last seen: 2 days 8 hours ago
these people don’t even bother using correct SI prefixes
mAh written as MAH
so 2500 MEGA-Amp hours-thats a new record…
lame
Shadowww
Last seen: 4 hours 16 min ago
HKJ, are you planning to upgrade your testing equipment in order to test above 30A (e.g. for 26650 IMR cells)?
HKJ
HKJ's picture
I have not seen any batteries yet where there really was a requirement for more than 30A discharge. I have equipment to do 60A, but I need a bit software work to use it and it will not be 100% compatible with the rest of my testing (Charging and discharging would be on other equipment).
At the current time I am looking on including temperature and full 4 terminal measurement (i.e. getting rid of the few mOhm i have in my clamps). This means that high current curves will look better, than in my current test.
