Quad 24mm Copper TPAD DTP
170 posts / 0 new
welight
welight's picture
Last seen: 5 days 23 hours ago
Hi Guys
Been asked by many of you for a quad TPAD P60 etc
Just wanted some feedback if what we have covers what you need
Cheers
Mark
Cutter Electronics Pty Ltd
Web: https://www.cutter.com.au
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 10 hours ago
I have some of these in the older non-DTP aluminum and they don’t have locator holes for either the Carclo quad or Khatod quad optics as R1-R4 are in the way.
Scott
welight
welight's picture
No sure I understand, the existing 24mm has holes for 106xx series, with room for resistors? or do you mean this new design, if so yes it will have holes, this was just to get a sense of the drive options
Rufusbduck
My bad, the holes for the Carclo optic and the LED pattern fits both Carclo and Khatod optics but to use either optic the holes would need to be slotted out to the Khatod pin locations. I like the Khatod optic as it is deeper and also has a 35mm option. The choices are nice but I would guess that 4p and 2s2p are the most poular options.
Scott
DB Custom
DB Custom's picture
Last seen: 2 days 15 hours ago
I was looking all over your site just last night, didn’t find this kind of quad board nor the HI emitters I was looking for to populate it.
5A huh? I’m afraid that’s not going to be sufficient. My Quad Nichia 219C pulls 21.1A from an LG HE-2.
Even the little tube light quads I make pull around 12A through XP-L emitters. If the traces can do 5A per emitter, then that should be fine. Is this what you’re meaning?
Any idea when these will become available? Or if there will be a 32mm version for the 35mm Ledil CUTE-4 optic?
cajampa
Last seen: 5 years 3 months ago
1+
Nice to see these coming along, thanks for the update welight Smile
welight
welight's picture
DB Custom wrote:
I was looking all over your site just last night, didn't find this kind of quad board nor the HI emitters I was looking for to populate it. 5A huh? I'm afraid that's not going to be sufficient. My Quad Nichia 219C pulls 21.1A from an LG HE-2. Even the little tube light quads I make pull around 12A through XP-L emitters. If the traces can do 5A per emitter, then that should be fine. Is this what you're meaning? Any idea when these will become available? Or if there will be a 32mm version for the 35mm Ledil CUTE-4 optic?
Yes its 5 amp per led.
Best place to start is search by PCB Size with leds on
http://www.cutter.com.au/categories.php?cat=Leds+soldered+on+Printed+Cir...
then jump to Leds on 24mm Round MCPCB
http://www.cutter.com.au/products.php?cat=Leds+on+24mm+Round+MCPCB&pg=2
if you can see what your after, no problem, if not there are so many available permutations, email me and if I have the emitters, we will make them for you.
I was planning on this PCB and the 20mm triple and then the 35mm Quad
Cheers
Mark
welight
welight's picture
I hear you, the issue with this design is the PCB is a 2 layer Copper PCB, so traces embedded may run under the slot locations, not sure thats the case but will check with design on when the traces run and see if doable
Cheers
Mark
DB Custom
DB Custom's picture
I saw all those and painstakingly looked through all of them that had any emitter I would care to use (I have no problem with removing the emitters and re-flowing my own) but everything I saw said aluminum base, I’ve gotta have copper.
cajampa
What? Is the new cutter 24mm quad not a copper DTP mcpcb? :~
If that is true then we are back at square zero Sad and still don’t have an proper high performance 24mm quad mcpcb available.
I really hope the quad 35mm will be copper DTP otherwise why even bother?
EDIT
I am so confused now in the reply to Rufusbduck welight speaks about the 2 layer copper pcb…….so are the quad 24mm copper DTP mcpcb just not released yet then?
EDIT2
No the picture clearly looks like alu Sad i guess it is only the traces that are copper……
DB Custom
DB Custom's picture
He may very well have copper mcpcb DTP Quads cajampa, I am just having difficulty finding them.
I’ve recently made a $230 purchase based on site declarations of specs that were false. I bought a knife with a stated “0.20” blade thickness, only to receive a 0.13” blade thickness (standard if you will). Not only that but the so called “buttery smooth flipper action” didn’t function either, and the blade was not shaving sharp.
So yeah, I’m being very particular about the specs. The listed specs on an item are all we, the consumer, have to go by in order to make our purchase, right? So all I’m seeing are the “2 oz copper trace” statements and the claim of aluminum base. I’m not finding the copper mcpcb with DTP. Probably just me. I can be rather dense when looking for things online. Especially full of Turkey and Pecan/Pumpkin pie.
cajampa
No i think you are right unfortunately Sad
This picture does not look lika a copper DTP mcpcb to me at all, if it where shouldn’t the base look copper or gold like the noctigons do?
EDIT
But then the thread title is “Quad 24mm Copper TPAD DTP” :~ ……..i am so confused :~
EDIT2
I hope this is just some misunderstanding and they already had alu quads for sale, but are soon going to release a quad copper DTP version, but haven’t done that yet. And this thread where just to ask for feedback before they do just that.
DB Custom
DB Custom's picture
Me too, and it kind of reads that way, getting an approval as it were before putting the new copper mcpcb quads online.
I’ve got quite a few of the original copper quads on hand already, so the 20mm version with 24mm optic really isn’t what interests me, and a 24mm star won’t fit a lot of smaller lights, but the 35mm Quad for a CUTE-4, that’s what I’m waiting on! (Tired of trying to align 4 individual stars)
cajampa
Hmm do you mean the cutter supposed “24mm” quad is bigger than the old limited run quad copper DTP board? Or do you mean that the 24mm quad optics won’t fit a lot of smaller lights?
Agree about the 35mm CUTE-4 quad, that is really what i am most interested in Smile
The quad copper DTP 20/24mm mcpcb is just very nice to even have available on the market again, i missed out when they where available before so even if i wanted i couldn’t use one or plan a build around one.
DB Custom
DB Custom's picture
The Quad boards I have are 20mm, it’s the optics that are 24mm. Typically, the tube lights have a 16mm star in them but the spacer needed to take up the space left over in the exchange between reflector and optic is fitted to the 16mm emitter shelf and sits higher than the top of the pill, so the 20mm star fits ok. A 24mm star might not fit in the tube in a lot of these, depends on whether or not the spacer clears the top edge of the pill.
Look, on this A6 tube light I accepted a challenge… someone (I won’t say TK’s name) said that the triple star wont’ fit in a tube light without the spacer, so I turned the star down to fit in the 16mm shelf and then trimmed the head down to fit, instead of using a spacer to lift it up and take up the difference. I had to cut half the optic support legs off on the outside to allow the optic to sit down into the space left over, but I did manage to make it work with as little change to the host as possible. Smile
On this larger small light, the X5 sample from Krono’s group buy, I was able to actually make a copper spacer that enclosed the 20mm triple Noctigon as well as the 24mm optics, almost like a P60 drop-in. The copper sits on the emitter shelf and actually fills the bezel all the way to the glass lens, acting to also hold it in place.
As with the tube light, the emitter shelf on this one is for a 16mm mcpcb, a 20 won’t quite fit, but a spacer would be made to fit into the shelf and then fill the head such that a 24mm mcpcb would actually fit (maybe, I should check the opening in the pill area, it might not take 24mm. Ahh, it won’t, it’s 22.2mm with the quad sitting almost flush with the top of the pill, so it’d have to be fitted or the pill would have to be enlarged at the top.)
pyro1son
pyro1son's picture
Last seen: 7 months 3 days ago
I’m after 20 and 35mm copper quads
Pastebin                                      &nbs
cajampa
Nice pics, thanks Smile someday i want to do me a shorty head shorty tube A6 triple.
But i think i will use a sanded down mcpcb or something to raise the shelf to the upper shelf so i don’t have to sand down the triple noctigon.
Ok, but i am still unsure if cutter triple “24mm” quad is a 24mm mcpcb for 24mm optics, or a 20mm mcpcb for the same 24mm optics :~
welight
welight's picture
DB Custom wrote:
I saw all those and painstakingly looked through all of them that had any emitter I would care to use (I have no problem with removing the emitters and re-flowing my own) but everything I saw said aluminum base, I've gotta have copper.
May have been less than clear on my first post. Please note on my first post this was a question about the topology of the board. The board is to be built in Dec and is not yet available, but I wanted your feedback about whether I had everything that you needed/wanted
cheers
Mark
welight
welight's picture
cajampa wrote:
Nice pics, thanks Smile someday i want to do me a shorty head shorty tube A6 triple. But i think i will use a sanded down mcpcb or something to raise the shelf to the upper shelf so i don't have to sand down the triple noctigon. Ok, but i am still unsure if cutter triple "24mm" quad is a 24mm mcpcb for 24mm optics, or a 20mm mcpcb for the same 24mm optics :~
24mm PCB's are all quad boards for Carlco 106xx optics and 20mm triple board will be for 105xx/Ledil Satu etc
Cheers
Mark
welight
welight's picture
pyro1son wrote:
I'm after 20 and 35mm copper quads
will be doing the 20mm triple and 24mm quad together
what optics would you use with 35mm board?
Cheers
MArk
welight
welight's picture
cajampa wrote:
No i think you are right unfortunately Sad This picture does not look lika a copper DTP mcpcb to me at all, if it where shouldn't the base look copper or gold like the noctigons do? !http://www.cutter.com.au/prodimages/minw10621_medium.jpg! EDIT But then the thread title is "Quad 24mm Copper TPAD DTP" :~ ........i am so confused :~ EDIT2 I hope this is just some misunderstanding and they already had alu quads for sale, but are soon going to release a quad copper DTP version, but haven't done that yet. And this thread where just to ask for feedback before they do just that.
correct
welight
welight's picture
DB Custom wrote:
Me too, and it kind of reads that way, getting an approval as it were before putting the new copper mcpcb quads online. I've got quite a few of the original copper quads on hand already, so the 20mm version with 24mm optic really isn't what interests me, and a 24mm star won't fit a lot of smaller lights, but the 35mm Quad for a CUTE-4, that's what I'm waiting on! (Tired of trying to align 4 individual stars)
ok got it, so what drive options on a 35mm Quad?
Cheers
Mark
welight
welight's picture
This is our standard 32mm quad, so what drive options
parallel?
2s2p?
all in series?
which optics?
cajampa
I think we all are looking to use CUTE-4 optics on a 35mm quad and most will probably use one of the many now available FET drivers for them and run them in parallel. I guess you could use the LD-2 also or just any other linear driver if you are not looking for max output.
Agree with pyro1son, that it is really a 20mm quad that would be more interesting. + we already have access to 20mm noctigon triple mcpcb’s.
It is the 20mm quad that is unavailable, but i guess one could maybe sand down a 24mm to 20mm but it is a hassle to do.
DB Custom
DB Custom's picture
I use parallel as most of my quad builds are in the Eagle Eye X6 format, which is a single cell light. The 35mm head works great with the CUTE-4 and CUTE-3 optics from Ledil.
I think the nominal mcpcb size is 32mm in the ones I’ve been using, and even those have to be filed down a bit to make the 31.7mm inside diameter of the pill in that light. Of course, there are bigger lights and bigger options, I’ve got a 50mm triple optic that I’d like to use in a Convoy L2, not sure what would fit that.
I wonder if a triple MT-G2 board would be feasible? Or triple XHP-70? Probably with the 50mm optics, as these big boys would prefer larger individual TIR’s inside the optics. I’ve got a BTU Shocker running 3 of your 9V MT-G2 emitters at about 10,000 lumens, absolutely love this light! (triple reflector works perfectly with the big MT-G2’s)
Gotta be tough designing these as we all expect different things, use different lights, have different styles.
welight
welight's picture
DB Custom wrote:
I use parallel as most of my quad builds are in the Eagle Eye X6 format, which is a single cell light. The 35mm head works great with the CUTE-4 and CUTE-3 optics from Ledil. I think the nominal mcpcb size is 32mm in the ones I've been using, and even those have to be filed down a bit to make the 31.7mm inside diameter of the pill in that light. Of course, there are bigger lights and bigger options, I've got a 50mm triple optic that I'd like to use in a Convoy L2, not sure what would fit that. I wonder if a triple MT-G2 board would be feasible? Or triple XHP-70? Probably with the 50mm optics, as these big boys would prefer larger individual TIR's inside the optics. I've got a BTU Shocker running 3 of your 9V MT-G2 emitters at about 10,000 lumens, absolutely love this light! (triple reflector works perfectly with the big MT-G2's) Gotta be tough designing these as we all expect different things, use different lights, have different styles.
He if we can get triple XML/XHP50 on 20mm, we can do most thingsCool but optics define this
yes our quad is 32mm. triple MTG2, what optic would you use?
Triple xhp70 sounds possible, but need to lock an optic down
Cheers
Mark
welight
welight's picture
cajampa wrote:
I think we all are looking to use CUTE-4 optics on a 35mm quad and most will probably use one of the many now available FET drivers for them and run them in parallel. I guess you could use the LD-2 also or just any other linear driver if you are not looking for max output. Agree with pyro1son, that it is really a 20mm quad that would be more interesting. + we already have access to 20mm noctigon triple mcpcb's. It is the 20mm quad that is unavailable, but i guess one could maybe sand down a 24mm to 20mm but it is a hassle to do.
20mm quad, parallel?
cajampa
Yes parallel, i don’t think it exist any serial high amp capable driver for single cells, so i have only seen parallel use around here.
Maybe Dale can show an picture of the old limited run copper DTP 20mm mcpcb’s for reference.
I don’t even remember what they was called either, only that some russian guy showed up here and said he was doing a batch of them, and now they have been sold out for months and as far as i know there haven’t been any talk of them returning to market.
DB Custom
DB Custom's picture
I can adapt, I’ll use whatever optics fit the board and shave the dome off of MT-G2’s so they’ll fit under the optic. Smile Obviously, gotta have copper under triple 6V emitters, I’d try pushing all the current possible, I run 12A+ to a single MT-G2 now…
welight
welight's picture
cajampa wrote:
Yes parallel, i don't think it exist any serial high amp capable driver for single cells, so i have only seen parallel use around here. Maybe Dale can show an picture of the old limited run copper DTP 20mm mcpcb's for reference. I don't even remember what they was called either, only that some russian guy showed up here and said he was doing a batch of them, and now they have been sold out for months and as far as i know there haven't been any talk of them returning to market.
yes I think I recall seeing them. I did not realise they were 20mm. I will review with our design team next week and advise
Cheers
Mark
welight
welight's picture
DB Custom wrote:
I can adapt, I'll use whatever optics fit the board and shave the dome off of MT-G2's so they'll fit under the optic. Smile Obviously, gotta have copper under triple 6V emitters, I'd try pushing all the current possible, I run 12A+ to a single MT-G2 now...
ok will look at it next week and see what makes sense
Cheers
Mark
