DQG Tiny 4
45 posts / 0 new
Vitaliy Korotkov
DQG Tiny 4
A description of management:
SC – single click, DC – double click, TC – triple click, LC – long click
From OFF state
SC = LO
DC = MED
TC = HI
LC = TURBO. No preflesh to LO, directly go to TURBO after 1s
From ON state
LC – switching between LO-MED-HI. Switch works only in one direction.
SC – OFF
DC – Turbo
From Turbo SC always translate to the previous mode of operation, if any, was not (the lamp was turned on by LC) that translates in the LO
All activities except LC occur when the button is released
Turning the lamp occurs in about 0.1 s after the first press of the button. When the delay is palpable with powering to LO mode by the SC, powering to HI mode seems that flashlight power on instantly.
Switching modes is activated at about the same delay as the powering on, ie almost instantly.
On personal feelings switching modes close to the ideal, because all modes are available from OFF state.
Dont worry about accidentally pressing the button, it is not necessary, why – is clear from the gallery:
Group photo with other my flashlights
Photos of disassembling
All parts at one photo. Very thin back cap
Thickness of negative post. Insulator thickness around 1.3mm so back side has near 1mm.
Head without besel. Button front view. It is recessed relative to the ring around it.
Head without besel. Button side view. Button move around 1mm. Accidental pressing unlikely
lens with a step
Head without lens. Standart microswitch
Back side of the head
And at last v4 has heatsink layer!
Driver removed from head with heat and not so brute force push from lens side. just pushed it with toothpick
It has no thermal compound on heatsink. Heatsink are super thin.
Inside adhered at two locations on the gray thermally conductive adhesive.
However, the thermal conductivity will be much better than in the third version since battery presses pill to the head of fl. And if we add thermal compound on the edge, it will be absolutely wonderful moderately good. But this pill is no substitute for normal pill, no.
As a design feature in this case it is necessary to note the presence of foam insulator required by the (+) as it plays an important role in the pressing pill to a head and, in addition, does not allow to push the positive contact of the battery. прижимать
There are serious suspicions that the heatsink is actually organized on the positive battery contact.
Beamshots and other tests on the way.
Edited by: Vitaliy Korotkov on 12/07/2015 - 15:01
ReManG
Great review! I think you are the first to be able to get one of the 18650 models apart! How hard was it to unscrew the head?
Any plans to mod this light?
Vitaliy Korotkov
Unlike the previous version v4 has much weaker locking thread. 3 min heating with hairdryer and it can be opened with bare hands.
I have plan to mod it to triple nichia with indicator light at button and Tamagotchi driver. But i will have trouble with unscrewing heatsink layer.
ReManG
That sounds like a nice mod for this light, please keep us appraised of your project!
Gunga
Gunga's picture
Last seen: 4 hours 22 min ago
Nice! I asked George to use less glue. Maybe he really did it! If I can use an alternative driver I may get one!
Firelight2
Firelight2's picture
Last seen: 2 hours 42 min ago
Awesome that they used less glue in the DQG4.
How wide is the driver?
Vitaliy Korotkov
Very easy to completely disasm this version of flashlight.
First post updated.
18mm
ReManG
Appreciate the updates on this Vitaliy Korotkov, how difficult would swapping just the emitter be in your opinion? I would be happy just having the choice of tints that buying a new emitter would bring.
Thanks and let us see the rest when you get time, great review!
Firelight2
I received my DQG Tiny 4. Beautiful light. I love it! Love The anodizing is perfect. It’s a little lighter grey and slightly less shiny than the anodizing on my Tiny 3s.
I really like it. It addressed a number of my main concerns about the Tiny 3:
  • The flush rubber button is much less likely to accidentally turn on in the pocket than the protruding metal button of the Tiny 3.
  • The designers added a shortcut to turbo from off (click and hold).
That said, like any light there are still areas that can be improved:
  • The tiny rubber button is completely flush with the body and compared to other side switch lights it is relatively hard to find by feel. My modded Tiny 3s with finishing washers around the button are much easier to find by touch and still well protected from accidental activation. Suggested solution: Add a raised ring around the button to make the button easier to find.. Also, the metal button of the Tiny 3 surrounded by a chrome plated finishing washer looks far classier than the rubber button.
  • Without the clip installed the light has no anti-roll device. It can easily roll off a table if laid on its side. Suggested solution: same as above. The raised ring also serves as an effective anti-roll device.
  • The light doesn’t get that hot on Turbo. Suggested solution: increase turbo timer duration from 1 minute to 2 minutes.
  • The tailcap on the Tiny 3 and 4 are interchangeable. However, in the Tiny 4 they removed the knurling and replaced it with a raised band with sparsely spaced ridges. This is purely a stylistic preference, but personally I prefer the Tiny 3’s knurled tailcap as it gives better grip.
I haven’t yet opened mine up, but from other reviewers it looks like they also added a very thin heatsink layer on top of the driver. I’m not sure how effective this will be given that the top of the driver has various SMD devices on it, but it is still probably better than nothing (the DQG3 had basically no heatsinking).
The switch internals also look a little different. The Tiny 3 had a microswitch pressed or glued into the side of the head with two tiny wires connecting it to the driver. the Tiny 4’s switch appears to be mounted directly to the driver.
This is a beautiful light right out of the box even without modding. I own multiple DQG 18650 lights, including the Tiny 1, 3 and now 4. This is the first one that I would consider carrying unmodded …. very rare for me since I usually only carry modded lights. This light is just that good. Unmodded I like this light even more than my Zebralight SC62w … a light that costs over 3x as much.
I haven’t yet decided whether I will try to mod my Tiny 4. I already have two modded Tiny 3s and the exterior of the Tiny 4 is very similar. If I mod this light into a triple, the internal heatsink layer probably wouldn’t help me since I’d want to add my own copper heatsink.
As these lights use a single board that contains both the driver and LED it probably isn’t possible to mod them with a different single emitter and driver due to lack of space. Fortunately, it is possible to mod them into triples as Carclo triple TIR optics are considerably shorter than the stock single-emitter TIR optic.
That said, in case I do decide to mod it I do have a 20mm e-switch FET driver from RMM standing by. I expect it should fit even if I need to file the edges slightly.
Firelight2
I confirm that separating the head from the body is much easier in the DQG Tiny 4. I was able to unscrew it using just my hands with no preheating. This light should be easier to mod than the Tiny 3.
sesgum
sesgum's picture
Last seen: 7 hours 50 min ago
Interested. Anyone has a nice coupon code and link to share?
Edit: never mind. I found the code from m4d m4x thread.
Jerommel
Jerommel's picture
Last seen: 1 year 4 weeks ago
Hey guys,
I just got one in today, a grey one (form Gearbest).
Good to see the PCB can be removed with some heat, because there are (indeed) some design issues that should be solved.
I love the tiny size though, it’s, well, it’s really tiny. Silly
The heat management is a joke though, and the switch is just waiting to break from the PCB by the looks of it.
I hope to find a satisfactory way to improve things and put a Nichia 219C in it, but that looks to be a real challenge.
Jerommel
Jerommel's picture
Well, that didn’t go quite as planned:
Oops…
finges
Last seen: 21 hours 26 min ago
In with new driver and triple mcpcb Wink
Jerommel
Jerommel's picture
I’ll try to repair it first.
Then take the XM-L2 off and see where we’ll go with this POS.
…i mean DQG.
Jerommel
Jerommel's picture
So, i guess this is one of my lucky days…
Just dropped a three legged black thingy on the floor and now it’s apparently gone to another dimension…
I don’t even have carpet here, but it’s gone…
wle
wle's picture
Last seen: 9 hours 6 min ago
i wish there was a better switch solution too but i can;t think of one
mine failed electrically, and broke off the pc board – at the same time!
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Jerommel
Jerommel's picture
I HAVE FOUND IT !!
Yesssssss !!!!
Soooo tiny….
Now back to reassembling the PCB
Jerommel
Jerommel's picture
wle
Yeah that sucks…
Mine came off too eventually, but i’m gonna fix it with grey epoxy.
No chance it will come off again.
It’s a shame this light is so poorly thought out regarding the PCB.
Jerommel
Jerommel's picture
Well, all the parts are back in place again.
Quick test showed it works, but not sure about the modes yet. (fumbling with tweezers as a switch)
I put the switch back on too with a bit more solder and a blob of grey epoxy.
Will be able to test in a few hours.
I’ll put up a pic of the result and how i secured the switch.
And if all is well, i’ll take off the XM-L2 and see if what can be done about the non existent heat management.
Jerommel
Jerommel's picture
That went faster than expected, so here is the picture:
And it works as it should too. Smile
Grey epoxy blob behind the switch.
I put some in between switch and PCB as well.
And now hope to find a proper solution for the total lack of heat management.
wle
wle's picture
lot of work!
curious what you can do about the heat problem, that is the reason it;s tiny after all..
if you get the heat out, then the outside will get hot(ter).
mine gets pretty warm just on high, not even turbo
wle
-Greg Lemond.
Jerommel
Jerommel's picture
wle wrote:
lot of work!
It took a while, yes…
Good Lord those SMD parts are tiny… Sick
Found another design flaw that really helps breaking the switch off the PCB too.
I will show you later.
My guess is they had better plans but it turned out to be too expensive to produce.
Either that or it’s just a bad design.
Not sure what to do yet, but i have some ideas.
Like a copper ring on top of the LED in contact with the shelf, and making the + pole a disc with a seal pad between it and the brass ring that now has the foam rubber on it.
Then a thermally isolated iron battery contact, but maybe that’s not necessary.
It’s a challenge..
That’s the idea of a thermal path, isn’t it?
Like this the heat is only transferred to the battery top and nowhere else.
Imagine how hot the LED will get… Facepalm
DB Custom
DB Custom's picture
Last seen: 2 weeks 6 days ago
Welcome to modding 101.
Some of these lights it seems like they spent more time designing mod defeats than actually worrying about the light. That emitter on board stuff is ridiculous, I don’t know why they haven’t figured that out yet.
Good luck! Smile
Jerommel
Jerommel's picture
It could have worked with a copper or even aluminium board, but it’s just regular epoxied fiberglass (or whatever PCBs are made of normally).
I can hardly imagine this was the original plan.
Firelight2
Good luck! Smile
DQG tends to try to make the smallest possible light for a given format. They can shave off several mm by putting the emitter and driver on the same board instead of using a separate star. Zebralights are built the same way.
Unfortunately, this does make them much more difficult to mod.
Jerommel
Jerommel's picture
Hmmm…. It seems the easiest way to solve cooling problems is making it a triple..
Make that R010 resistor a direct bridge for a bit more turbo and just put one of my Kaidomain 219C triples in there (when they arrive) and forget about solving impossible things..
Serp
Serp's picture
direct bridge give You ~2.3A at Turbo
FET also has a resistance
Jerommel
Jerommel's picture
Hmm.. 2.3 Amperes : 3 = 0.77 Amperes per LED in a triple.. That’s not much..
No, i will try to fix the thermal issues as it is now.
Keep it a single LED light.
Maybe i can make it work. Smile
Serp
Serp's picture
Just checked. With triple nichia (warm white from fasttech) turbo on a freshly charged battery 18650-25R is 2,08A… (R010 changed to the R000)
Jerommel
Jerommel's picture
Okay, that’s low…
But those are 219A Nichias.
219C has significantly lower Vf so will probably draw more current.
Either way, for a triple this driver is not powerful enough i.m.o.
I took off the XM-L2 anyway, and i will try to make a tiny 5 × 5 × 1mm thick DTP MCPCB to put one 219C on.
The TIR works better anyway when it is mounted over a 3535 in stead of mounted on top of a 5050, i just checked that out.
Wish me luck… Sick
