easiest way to FIX it is to …EDIT it instead .
.Just remake it into a totally different thread as soon as you realize you’ve made a mistake …
Change the title , change the question and voila
problem solved .
the short answer is you can’t delete a thread ….and having to ask mr admin. to do it for you is unnessesary when you can just
fix it yourself.
If you want your thread deleted, just edit the original post to a be called a bump thread. Then post some bump pictures that have clothed females in it. Your post will soon be deleted, problem solved.
… didn’t we end up with a thread with a few hundred pictures of furry squirrels and such that way?
It was right up there with the thread with no title.
Appears the welcoming antics of past are starting to resume. Mistakes by a member, especially a new one, do not justify the rudeness exhibited in some of the above posts.
Found the no-title thread. Had to view the html to get the link.
Can’t find the squirrel thread, but that might be a figment of my imagination, and/or the wrong forum
