Test/Review of goobay 44004 usb 1A
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 38 min 32 sec ago
goobay 44004 usb 1A
DSC_0188
Official specifications:
  • Mains voltage: 100-240VAC 50/60Hz
  • Output voltage: DC 5.0V
  • Output load: Max. 1000mA
I got it from av-connection.dk
DSC_0187
I got the charger in sealed a plastic bag with the charger and a universal instruction sheet.
DSC_0189 DSC_0190
DSC_0191
Measurements
  • Power consumption when unloaded is 0.2 watt
  • USb output is coded as HP touchpad.
goobay%2044004%20usb%201A%20load%20sweep
The charger is overload protected at 1.3A, this is a fine value for a 1A charger.
goobay%2044004%20usb%201A%20load%20test
Running with 1A for one hour did not show any problems.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp2136
M1: 41,8°C, M2: 42,7°C, HS1: 58,9°C
Temp2137
M1: 44,2°C, HS1: 76,6°C
Temp2138
M1: 41,2°C, M2: 41,1°C, HS1: 54,8°C
Temp2139
M1: 42,2°C, HS1: 44,6°C
10ohm
There is some noise with 67mV rms and 460mVpp.
5ohm
Increasing the current to 1A increases the noise a bit: 90mV rms and 490mVpp.
Tear down
DSC_2063
I needed the vice and a hammer, then it was easy to open.
DSC_2064
On the mains input is a fusible resistor (1W 10R) and 4 diodes for a bridge rectifier.
There is a safety capacitor between mains and low volt side. The diode on the low volt side is a round diode without heatsink. That is probably the reason for the yellow stuff on the circuit board (It is usual white as can be seen where the mains wires is connected). I.e. it turned yellow due to heat.
DSC_2065
On the other side of the circuit board is the mains switcher IC. This chip is designed to work without any opto feedback from the low volt side.
DSC_2066 DSC_2067
DSC_2068 DSC_2069
As usual the blue safety capacitor has a lot of approval markings on it.
DSC_2070
DSC_2071
No problem with isolation distance.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger is simple, but works fairly well.
I wonder about the coding on the usb output, it will probably confuse many smartphones.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
MRsDNF
MRsDNF's picture
Thanks HKJ for the review. The name itself made me smile.
