Product is no longer produced.
Sales thread:
http://budgetlightforum.com/node/39824
Useful links:
http://budgetlightforum.com/node/39673
LD-M2 is a high power version of LD-2 developed because of continuous demand for higher power drivers which could reliably drive new big emitters like MT-G2,XHP50,XHP70,and multiple XM-L2s,nichia 219C etc.
Idea was old as LD-1,and it's simple:put main source of heat-mosfet on separate board which could then dissipate that heat more easily.Last testing with mosfet on led mcpcb showed good results,much better than older idea of FR-4 with vias : http://budgetlightforum.com/node/39673?page=4#comment-809544
Disadvantage of that method is two separate boards,so stacking two boards was pretty logical solution.
LD-M2 has two boards,the bottom one is 1mm aluminum metal core pcb,70um copper,with MOSFET,NTC sensor,moonlight resistor and multicell support parts on it;the top one is basically LD-2 pcb without parts that are on bottom pcb.
Result is driver with identical features/specifications like LD-2 except that voltage,current and power dissipation ratings are higher.
Because of that,I will mention only differences compared to LD-2 specifications (you can find LD-2 full specification in LD-2 info thread):
- Input voltage: 2.8 - 19V (user must solder jumpers for proper operation,depending on number of cells in series)
- Output current on high: 6A or 12A, 4A - 20Amps possible by changing 0603 resistor
- Max. power dissipation: 15Watts@25C case temperature, 12Watts@60C case temperature
- NTC over temp. sensor,1S-4S cell support parts and moonlight parts are already soldered on MCPCB by default - no need for adding/changing any parts for 1S-4S cell operation,only jumpers soldering/desoldering
- less than 150uA of parasitic current in sleep mode for all 1S-4S settings (slightly lower than LD-2 with multicell parts)
- Only two thick and one thin wire is needed for complete connection (optional,two additional thin wires for e-switch)
- Two big solder pads on MCPCB for up to 16AWG wire support
- 1mm bottom alu metal core PCB with 70um copper - bottom is electrically isolated so it can be mounted directly on flashlight metal surface
- 25mm diameter,~5.5mm height
Moonlight resistor note:
Moonlight current set: Rmoon=(Vbatt - Vled)/Imoon
For 2S,3S and 4S configurations moonlight current will be 2,3 or 4 times higher if stock 154Ohm resistor is used! Upper equation is still valid,but because (Vbatt - Vled) is 2,3 or 4 times higher,current is also higher for the same factor.To keep moonlight current at ~10mA in case of 2S,3S and 4S configurations,moonlight resistor should have next values:
1S - R~150 Ohm
2S - R~300 Ohm
3S - R~450Ohm
4S - R~600Ohm
As it can be seen from equation,current depends on battery voltage,so it will drop as battery voltage drops.Typical Vled values for high power white LEDs at very low currents are 2.6-2.7V.
Setting operating voltage: 1S-4S solder jumpers
Driver supports 1 to 4 Li-ion cells in series,and to ensure proper operation,some solder jumpers must be shorted,deepening on cell number:
1xcell (1S) - jumper 1S soldered,others unsoldered
2xcells(2S) - jumper 2S soldered,others unsoldered
3xcells(3S) - jumper 2S and 3S soldered,others unsoldered
4xcells(4S) - jumper 2S, 3S and 4S soldered,others unsoldered
Note: driver comes with all solder jumpers unsoldered,so user must solder jumpers depending on his application.
Warning!
Driver configured for "N" cell operation should not be used with "N+1" cells!
Driver cannot protect itself from too high voltage,so it will burn if it’s connected to higher number of cells in series in that case.
Connection diagram:
Diagram made by BLF member Andi,thanks!
Example:
Applications:
- driving single or multiple emitters - XM-L2,XP-l,XP-G2,Nichia 219C,MT-G2,XHP50,XHP70,big color leds like SST-90,etc. in bigger flashlights (well in every flashlight with place for 25mm driver:)
Reserved.
led4power.com
As a first subscriber I hope I can get a sample for (well, I don’t have proper testing equipment so I will say) for my own pleasure
great evolution of the LD-2!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Sweet!
KB1428 “Live Life WOT”
Subscribed
Aspiring Fhashlightaholic!
I would love to see it in 22mm, but 25 is useful as well. Now to just get ahold of one!
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
Looks great, it is a beast. Great work Neven, as always. Count me in for one or two at least.
Courui D01 -Mod ZY-T08 Small Sun -Mod Shadow JM30 Mod - copper edition Brinyte 158B mod - copper brass hybrid
Small sun ZY-T08 Mod II - The Next Generation Small Sun ZY-T08 Best Of Both Worlds Warsun X50 mod - a complete makeover
Maglite 3C Mod - old school style
Put me up for one please!
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
Is it possible to solder the wire to the LED Anode (+) to the “big hole at 4 o’clock” in the your connection diagram – like with your LD-2 driver?
No, LED anode should be connected directly to contact PCB/spring/Batt+(it would make no sense connecting thick wire to driver and from driver to LED+ with this type of driver,this is just easier).
led4power.com
Nice new developement, I'm not a big flashlight addict, so it is not for me, but I'm sure many others will love this one!
link to djozz tests
So now that this driver is available for purchase, what are some good host options for this beast? I don’t think I own anything large enough to hold it…yet.
Yes, yes, yes.
This driver is getting my modding juices flowing. I want. I’ll figure out what I’ll do with it later.
One example is SD75:http://www.taschenlampen-forum.de/modding/43906-modding-lumintop-sd75-2.html#post616271
I'll mod SRK soon(3x6A).
Few other lights that come to my mind are Courui D01,TK75,BTU shocker,trustfires TR-J19,J20,Maglites?
led4power.com
Is it? What is the price?
19.99 USD shipped?
PLEASE NOTE
led4power.com
hey does this driver have LVP for whatever cell configuration that is chosen? just wondering..
Yes,based on solder jumpers setting driver knows number of cells.
led4power.com
I have made a wiring diagram with Contactplate for Batteries:
maybe it helps someone.
Thanks Andi!
- The YKK Philosophy
Super
Regards Xandre
Looking great,thanks Andi,
I’ll add your picture to OP.
led4power.com
Question, is this possible?….
…one cable for the E-Switch over “Ground”.
It should work fine.
led4power.com
Great, thanks!
2 questions:
- will it work with piezo switch? (short pulses)
- possible to change modes to have something like this: 100% -> 30% -> OFF ?
I’m not sure about piezo switch,since you can’t do normal/long presses.
Anyway,I will no longer produce LD-M2 (working on LD-M3,ETA is ~2 months).
led4power.com
ok, thanks
