Update Oct 3: PD68 TripleDown/TripleStack - Tri-Channel Driver
222 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 57 min 43 sec ago
You would probably need to change a few lines in tk-attiny.h in the section about “TRIPLEDOWN_LAYOUT”.
It may help to have the attiny reference manual open, to see which pins have which internal names.
Also note that the PWM on pins 5/6 works a bit differently than on pins 2/3, so you may also need to edit the first page of main() if you move any parts from one of those groups to the other.
LightRider
LightRider's picture
Last seen: 3 years 5 months ago
Ok. I wil give it a try. Thanks! Smile
LightRider
So… In the attiny.h file do I need to mess with the output compare register if I change the pins? All three pins need changing. FET is on pin6, 8×7135s on pin5, and 1×7135 is on pin3.
And also, In the .c file, do I need to mess with the PWM counter in some way?
ToyKeeper
ToyKeeper's picture
Let’s see… I think you can just rotate the assignment of names to values like this…
#define PWM_PIN     PB0     // pin 5, 6x7135 PWM
#define PWM_LVL     OCR0A   // OCR0B is the output compare register for PB0
#define ALT_PWM_PIN PB4     // pin 3, 1x7135 PWM
#define ALT_PWM_LVL OCR1B   // OCR0A is the output compare register for PB4
#define FET_PWM_PIN PB1     // pin 6
#define FET_PWM_LVL OCR0B   // output compare register for PB1
… and then I think it should work. But with 1×7135 on pin 3 (second PWM counter), your moon mode is probably going to suck. IIRC, that channel is locked at 31 kHz but moon usually needs to be significantly slower than that. If the lowest PWM level is too low, you’ll need to recalculate the ramps. And the lowest levels will probably still be more voltage-sensitive due to the short pulse time.
LightRider
Thank you TK! I will give it a try.
pilotdog68
pilotdog68's picture
Last seen: 5 months 1 day ago
Introducing the TripleStack.
I am getting tired of springs not fitting on the little pad in the middle of the 17mm drivers, so I’m going to give this a try.
It’s basically a TripleDown Rev1 with some of the parts/configuration added that DEL has found give greater stability. It’s also only 15.5mm wide, which should fit inside the pill of a light that takes a 17mm driver (as long as the pill is tall enough too). The idea is that you then use a 17mm contact board, which is also linked below, allowing a normal sized spring to be used. Building it will be tight, but I was able to keep the components as all 0805 size. You should order the driver board in the 2oz/0.8mm option.
I’m also copying the info for my X2R adaptation from the other thread:
Quote:
Alright, I’m about ready to place the first order as long as nobody finds any errors. It’s wired mostly the same as a TripleDown so it will work with the same firmware as the other TripleDown and Texas Avenger boards. The only differences are the addition of R3, which DEL found to greatly help stability, and the smaller LFPAK33 FET. The third pin on the X2R isn’t needed so I omitted it to save space. I am relying on the 2 other pins to carry all of the Batt+ and GND current, which is not ideal but I think will be fine for single emitters. I couldn’t see any way to fit bypass holes. The large exposed pad on the bottom is directly above where the micro-usb port is on the charger; the thought is that we might get a bit lower resistance by using that as an extra ground point.
Oshpark Order Link
I highly recommend ordering with the 0.8mm thickness option.
Texas_Ace
Texas_Ace's picture
Last seen: 5 days 4 hours ago
Interesting idea. I have had some slave boards for awhile that I have considered using in place of the backside 7135’s but never actually tried it yet.
Tom E
Tom E's picture
Last seen: 7 hours 53 min ago
Nice PD68!! Soon to be ordered wink
pilotdog68
I should add, there are non-ground pads very close to the edge, so before inserting in a pill you will probably want to wrap some kapton around the circumference
ImA4Wheelr
Last seen: 1 week 4 days ago
Wow, I’ve missed out on a great thread thread. Guess I’ve been avoiding drivers and FW for quite some time now.
EDIT: 7135’s like to be kept cool. Especially, on fresh cells. You may want to think about moving them to the top of the bottom board where they will have a better heat sink path.
pilotdog68
Good tip, but that would mean i addition to the two batt+ wires and grnd wire, I would have to run two pwm wires too….
I think I’ll try it like this for now and see what happens. What I really should do is source some of those square brass pins for a more stable stack.
pilotdog68
How many solid header pins do you think it would take to carry the same current as 18awg stranded wire?
Edit: one standard 0.025“header pin is the equivalent of a 21awg. So for those of you that would actually use this, is it better to have a big hole to feed some silicone wire through, or 2-3 holes for these pins? This is for the ground connection between driver and contact board.
LightRider
My thought is that the pins will give it better heat management. It would also provide a good structure for a potted driver.
ImA4Wheelr
pilotdog68 wrote:
Good tip, but that would mean i addition to the two batt+ wires and grnd wire, I would have to run two pwm wires too…. I think I’ll try it like this for now and see what happens. What I really should do is source some of those square brass pins for a more stable stack.
I should have been more specific. Only the large set of 7135’s should be moved down to the bottom board. One or two on the top board should be able to dissipate their heat via the surface area of the upper driver and through the copper wires connecting to the bottom board. The bottom board doesn’t need a Batt+. You can just run Batt+ straight from the spring to the top board/LED. Both the top and bottom board need Batt-. So that wire would remain. All you need in addition to that is PWM feed and LED-. So 3 wires total.
pilotdog68
Oh.
Normally I try to make my drivers as useful as they can be for people other than myself, but I thought I would be the only one who liked the idea of the pins. So I did it “my way”. This involved reducing the driver size by 0.5mm (15mm now), removing 2 of the 7135’s (I usually only use 3 anyways), and removing the FET pulldown resistor (I’ve yet to need one, and they’re easy to stack on the FET pins themselves) . You can use just about any 0.025” header pins you want, but I ordered these just now.
LightRider
Why did you have to remove the 7135s? You could split the placement of the three pins. 1 or2 where they are now. 1 at the via for r2. And one at the via for the bleeder resistor. You would need to move the bleeder via and the fet output just a bit to make that happen. The ground ring on the bottom of the driver board should be enough to carry the signal. What do you think?
ImA4Wheelr
Guessing those pins will be gold coated steel. If so, they will be rigid, but will conduct heat and electricity less efficiently. That much rigidity doesn’t seem needed. Some flex will help protect the solder joint from breaking. 22 gauge solid copper wire will be a tad over .025”. Here is a chart showing the diameter of various gauge wires:
https://www.tedpella.com/company_html/wire-gauge-vs-dia.htm
pilotdog68
I was under the impression the pins were brass. They come in either tin plated or gold plated. Even so, I’m assuming they will have more resistance than copper wire (which is partly why I thought the whole idea was going to be unpopular).
I had to remove one of the 7135s, and I chose to remove another one just because I personally never use more than 4 and I didn’t think anyone else would be using this board. I wasn’t even planning on posting it here to be honest.
I don’t think I can move the vias for the pins. To put them where the other smaller vias are would mean I have to make the driver bigger again, which will push the pins more outside, and I think that would cause clearance issues where the contact board sits on the shelf of the pill.
LightRider
You should know that if you build it they will come Wink all your work seems to dictate the BLF fads. Just saying people like what you do Smile
pilotdog68
I think this was the hardest puzzle I’ve ever done. Things are very tight to say the least. Still an even 15mm for the top board, but we are back up to 5 total 7135’s. Most of them are on the bottom board for better heatsinking, as is the FET. The FET pulldown resistor (R4) is back and C2 from the Q8 has been added (it is optional) to go with the input resistor (R3). The bleeder resistor is gone but I can count at least 3 places you can stack one if you need to. This version uses 5 header pins, but none of them will carry more than 380mA. Your emitter wires will be mounted to the spring and contact board and will bypass the stacked board entirely. This one should be easier to get a programming clip on, and it consists of two single-sided boards for easier reflow. Both boards are required for function but I left them as separate files so that you can order the bottom board thick and the top board thin.
LightRider
Wow! Very nice! I think this board will be perfect for the d80. I have 25 d80s to modify. The driver has to be one sided on these lights because of the retaining only thing that would be nice is an 18.5mm contact plate. That’s just for my purpose though.
pilotdog68
I wasn’t happy with how messy those traces were, so I cleaned some things up. I think I’m about to order; the OP will be updated too. Feel free to follow this maze to check the circuit if you’d like to. It’s not my prettiest, but should be functional.
Order Links:
15mm Top board
17mm Contact board
18.5mm Contact Board
20mm Contact Board
LightRider
Thanks PD! I will order some. Will lpak56 fet fit on the contact board or what fet is needed?
pilotdog68
Yep, standard S08 FET pads like most of my boards
Texas_Ace
Texas_Ace's picture
The funny thing is, what we consider ugly and sub-par is actually quite good by most compact PCB standards.
Good work!
pilotdog68
Really? That’s surprising. Just having the MCU tilted to one side at an odd angle drives me nuts. I’m the type of person that likes things to be uniform and symmetrical if possible.
pilotdog68
I also just realized this one would be even easier to drive a secondary LED (like red) than the original was. Just don’t connect a header to the top right via and use that for a second LED- wire instead.
Texas_Ace
Texas_Ace's picture
Yep, it also annoyed me at first then I started looking at some other compact PCB designs and realized that most appear to just use the auto-placement / auto-router and thats it.
As I am sure you know, the auto-placement and auto-router are just beautiful things to behold (for everyone else I am being sarcastic, they are downright ugly to look at).
Fact is those setups work just fine even with 5 times more vias then they need and traces 3x longer then can be done.
So I decided after that to just get it on the board and make it as pretty as was possible in a reasonable time frame. Once it is in the light I only care about how it works anyways.
pilotdog68
“auto-placement and auto-router”? … never heard of her. Silly
I lay every trace using either the line, circle, arc, or square tools.
Though I must admit, this was a lot easier when we had 7 parts on our drivers, they all easily fit on one side of 17mm, and it didn’t matter where they were in relation to each other. DEL’s scope has made my life so much harder Big Smile
I just have to laugh though. Between the few revisions I did that was the most difficult board I’ve ever done, and it was all just so I can use a bigger spring….
Texas_Ace
Texas_Ace's picture
LOL, I guess eagle doesn’t have any automation features for placement or trace routing? They are no good for small boards like this in diptrace but I messed around with them at first, downright ugly layouts but it worked.
So eagle just sees the layout as a picture not much different then MSpaint? I guess that is why I could not get the hang of it.
Diptrace sees each pad, trace, copper pour and via as there own part and it knows exactly what should connect to everything else. so while I still have to layout the placement and traces manually it takes care of all the small things because it knows what goes where.
I will agree that the extra parts make things a lot more interesting, thats why I went with 0603 resisters, they are not much harder to work with, even hand soldering and are just as good as the 0805 versions for a performance standpoint for our uses.
