Hi guys.
I’m pretty new at this hobby, but have been doing some readings in here for quite a while but I have a few questions.
I have been given a full box of old laptop batteries by a friend from a computer store and I have been harvesting quite heavily lately. Some of them are pretty old, from the battery model some were operating in laptops that are 8-10 years old. Others are “newer” but nothing younger than 4 years I think.
I decided it’s good to have a analyzer/charger around so I purchased the LiitoKala Lii-300 and I am pretty happy with it. Decent build quality ( the plastic seems pretty sturdy ) and the features are great.
How to the analyze thing work - you put the batteries in the charger and select Discharge - now the charger doesn’t discharge right away but first tops off the batteries, then starts discharging to 2.8 - 2.9V while measuring the capacity and then re-tops the batteries so in the end you have a full charged battery and also have the capacity on the display.
Now …as far as current goes - I only have the option of selecting either 500mA or 1000mA but this is just for the charging part, the discharging part always takes place at 500 mA.
I always went on with 1000mA to save up some time considering I have about 40-50 batteries to go through.
My observation is that the batteries get pretty hot while discharging ( @500mA ), I can still ( kinda ) hold them in my hand - and slightly warm when charging, although the charging current is twice as fast ( 1000mA ).
Is this normal ?
If the batteries get hot on a 500mA discharge, what happens when I use them in a light that’s drawing 1A - 2A ? Is there any danger in using them in a torch ?
Regarding batteries … as I said, some of them have probably been resting for years and years.
After I take them out of the big laptop battery I check the voltage with a DMM. Some older ones are under 2V so I put them aside and plan on recycle them at my local supermarket ( they have a huge box to collect old batteries ).
Some newer ones have over 3V and are in good shape. Some are at about 2.5 - 2.7V but I bite the bullet and tested those as well and noticed they quickly jumped to 3.2 - 3.3 in just a few seconds after putting them in the charger. My best ones are some ICR18650-28A Samsungs - which turn out to have a 2200-2300 mAh capacity which is not bad at all considering they were made in 2010 ( according to the code on them ).
Roughly all Samsungs are good - they all come close to the 2000 mAh mark ( even some pink ones from 2008 ).
One particular odd thing happened to one green ICR-22F Samsung - after a complete cycle - the charger indicated a total capacity of 2975 mAh. Is this even possible ??
I also found some green Sony and these tend to get a bit hotter while discharging compared to my Samsungs.
Is it dangerous to try and re-rive batteries that are under 2V ? I understand their capacity may not be all that great, but is it dangerous to put them in the charger due to their low voltage ? I have a friend that told me not to recycle as he wants to try and use them as is. I can offer to give him some good ones ( I have to many as it is ) but he still insists on trying the old under 2V ones as well :laughing:
Any inputs are greatly appreciated.
Thanks
