What did you mod today?
9977 posts / 0 new
XXX-Man
XXX-Man's picture
Last seen: 7 hours 54 min ago
Thank you Smile
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
DB Custom
DB Custom's picture
Last seen: 1 week 8 hours ago
I made a duplicate of the Titanium plate they put in my neck. I have a PDF document from the maker of the plate that lists a couple of dimensions, this let me size it based on the X-Ray of the actual plate itself. Never milled anything before, especially not on a lathe! Some of this was hand work, I thought it’d be somewhat easier on commercially pure grade 2, it wasn’t…
The very small slots I didn’t put in because my 2mm 4 flute bit wasn’t up to it. And I still should probably refine the “+” pattern windows, but that’s file work and I’m done today! Silly
I did it for a pocketable conversation starter. Big Smile It weighs a mere 4 grams and isn’t as cut-out as the actual plate, so in reality the plate weighs even less than that. It’s 2.1mm thick, 1.5mm in the center, 18.4mm wide and 38mm long. This is an Xtend plate from Global Medical, made to be able to add an extension into the middle groove and the small slots are locators for this extension. (My Dr. is probably figuring more work will need to be done above the existing plate, hence, the add on style Xtend plate)
Their picture…. yeah yeah yeah, CNC machines rule! Silly
thulfiqar
thulfiqar's picture
I modded a 1$ Skywolfeye Zoomie to UV 365nm LED
I’m Happy with the output Smile
Lexel
Lexel's picture
Last seen: 6 months 5 days ago
Lol a 3.7V LED with 700mA and only 35-60mW luminous intensity?
Any aerious LED puts out 700-800mW at that power
Even a cheap Epileds is better and cheaper
https://www.aliexpress.com/item/3W-3535-High-Power-LED-UV-Light-Chip-365nm-395nm-Emitter-Diode-Ultra-Violet-DIY-With/32762365038.html
thulfiqar
thulfiqar's picture
I didn’t use a nichia UV led before but the output of this led to me looks good and illuminates things well
I think that the “80mw” was a typo in the description, Maybe ?
Of course I looked for a nichia led but couldn’t find one unfortunately
ToyKeeper
ToyKeeper's picture
Last seen: 17 hours 13 min ago
That’s so metal.
You are now officially Too Metal To Headbang.
DB Custom
DB Custom's picture
I have 4 UV lights, each with a different emitter. 3 of them are Nichia. 1 is LED Engine LZ1. The top of the line Nichia was the most difficult to acquire. It’s not as obvious the differences between these 4 as I would have thought, especially considering the price of the top of the line emitter, but it sure cure’s optical adhesive in a hurry!
Convoy S2 18350 NVSU233A (this one has a weird Silicone add on dome from Nichia, works, but looks funky as it’s really big)
Copper X6 with NVSU333A
Jaxman U1 with NCSU276A
Solarforce L2M (18350) with LEDEngine LZ1 (this one has an AHorton aspheric)
Lexel
Lexel's picture
The Nichia NVSU233B is also great, even less visible light output and more UV output
Only downside is the higher Vf
AlexGT
AlexGT's picture
Last seen: 7 hours 38 min ago
Modded a Thrunite TN-31 with a SST-40, already had the light with bypassed resistor mod and on turbo it gives the XHP-35 Hi led on the AceBeam K70 a run for its money. It’s blindingly bright!!!
DB Custom
DB Custom's picture
Dangit TK, I was all prepped to rock out with some April Wine! (uh, 1979 head banger music?) [memory… sudden ancient flash of Alesha in her ’78 Trans Am with Lightning Rod shifters, literally head banging in the car, driving, to April Wine. Scared me! She was a bad driver when she was watching the road! And along with that memory, another time she …. nm… suffice it to say the police were involved and it wasn’t music.]
10fp
Sledgestone wrote:
Just finished putting together a dedomed Sst-40 with a TA bistro driver in a Convoy C8. Man, this thing is a little beast! 158kcd and really, really bright! And this is before fine tuning the focus..
158 kcd awesome , Hey Sledge, whats the tail amps, ?
BLF A6 S2+ SST40, GT Micro
a few C8`s , C8+ SST40, M21A SST40
HS 802, dd SST20 5k @4.6 amps,
P30,
Emisar D1S xp-g2 dd S4 2b
EC01
S70s,
UT02 - 5 amps and luv it ! with E2 3C
Klarus G35
Maxtoch New Sniper M24 dd U3
MF02 ,
FT03 SST40
Emisar K1
i think iv got it covered ! Wish list SP70 , SP36 BLF
Sledgestone
Thanks!
I haven’t tested it on a full cell yet, but I got 8. something with a cell with unknown voltage. I’ll check later today with a fully charged VTC6.
ToyKeeper
ToyKeeper's picture
I built my first driver from scratch (well, from oshpark and a bag of parts) and it worked!
Even better, I got it to do 4-channel PWM for red, green, blue, and amber LEDs. With an e-switch to control it.
I had thought the 3rd PWM channel was weird, but no. The 4th channel is. The attiny85 doesn’t have direct support for 4-channel PWM (the hardware does channel 3 OR channel 4), so I had to do it semi-manually by chaining an extra interrupt off the PWM timer and using that interrupt to manually turn the 4th channel on and off.
Also, for some reason the 4th channel is inverted so 255 is off and 0 is full brightness. I’ll have to see about fixing that.
But anyway, woot! This means that soon I can start on the fun parts.
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 3 days ago
Nice TK !
Feels good to make your own drivers , especially when you can also create a new firmware for every flashlight Big Smile
solRNY
Last seen: 2 months 4 weeks ago
thought this would be a fun zoomie host to play with.
updated the stock triple color led to a single sst-40, driving it at 5.5A with a east-92 driver, powered by a littokala 26650.
djozz
djozz's picture
Last seen: 1 day 1 hour ago
What zoomie is that, solRNY?
djozz
djozz's picture
I swapped 4x XP-L2 4000K 90CRI leds (from Mouser) into my black Emisar D4. A partly succes.
The jay:
  • unlike XP-L’s, the XP-L2 fits under the commonly used Carclo optics (tight but alright)
  • the beam is good. I have the XP-G3 version of this led in a Carclo triple and it has the intense yellow corona, the XP-L2 in combination with this type of TIR has a larger spot but also better blended tint.
  • the output is great. Despite this high CRI version being just a U6 bin, it puts out 4300 lumen OTF at start-up, 3800 at 16 seconds when thermoregulation (set at max) kicks in. The current draw is 14.9 A with a 30Q at 4.11V, same current as my D4 219C version.
The meh:
  • the tint is similar to the 4000K 90CRI XP-G3, so nothing rosy in there, on the green side of white. Still a matter of taste, the colour reproduction is good.
    As a FYI, I also had a couple of 4000K 80 CRI XP-L2 leds from Mouser, bought a bit earlier, and that tint is simply wonderful. I tend to like them better in a flashlight despite the lower CRI.
Here is two white wall shots. Do not look at the actual tints, first because the pictures are made with auto whitebalance, and second my phone camera is damaged by UV-light so the center of each picture is brighter and slightly more pink than the edge Sick .
Left Carclo 10507 (S2+) with XP-G3 4000K 90 CRI, right Carclo 10621 (D4) with XP-L2 4000K 90 CRI.
D4 with XP-L2 compared to D4 with Nichia 219C:
solRNY
Not sure what brand, found it here: https://www.ebay.com/itm/391826526309
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 3 weeks 3 days ago
Looks like this flashlight: https://www.banggood.com/de/Warsun-X50-XM-L2-3Modes-1200LM-Zoomable-LED-Flashlight-p-1020998.html
djozz
djozz's picture
Thanks for the link. The description says Boruit. Is the lens glass?
solRNY
ha, you reminded me that I have a glass lens from a project years ago! found it, and was excited to test it, but it did not work out well. the focus was lost mid way thru extending the tube.
the stock lens is in the middle and is not glass, it is the biggest lens of all my zoomies.
I like most everything on this host except for the pill, the thermal path needs a lot of work.
khas
Last seen: 1 month 1 week ago
Made a new “walking the dog” flashlight.
Eagle Eye A6 host
BLF A6 driver
Smooth S2+ reflector
pflexpro Micro-Textured lens
De domed SST-40
Eagle Eye X7 de-domed SST-40(left) Eagle Eye A6 de-domed SST-40(right)
It has a nice wide beam and still puts out some lumens, not as much as a quad or triple but is has more “throw”. It pulls 8.45A from a fresh VTC6, settling @ a mere 3.22A after stepdown.
I also swapped the emitter in a Sofirn SP31 to a XP-L HD 5A3 :
Sofirn SP31 XP-L HD 5A3 (left) Eagle Eye A6 de-domed SST-40(right)
luminarium iaculator
luminarium iaculator's picture
Last seen: 18 hours 4 min ago
Djozz killed Darth Wader light, There is no fun in that any more Smile
So Djozz said: Wader… You shall not pass!
Anyway fantastic mods guys…
KawiBoy1428
KawiBoy1428's picture
Last seen: 50 min 9 sec ago
Eagle Eye A6 host
BLF A6 driver
De domed SST-40
How about making one for your dog? Kodi loves his! Big Smile Thumbs Up
KB1428 “Live Life WOT
ToyKeeper
ToyKeeper's picture
This is why I’m a bit concerned about the FW3A’s optic and emitter choice. It risks making an ugly multicolor beam with lots of artifacts.
khas
Great picture, I do have a Sofirn SF10 that could work.
Sledgestone
Finally had the time to test the amps. It draws 8.45 at the tail.
10fp
cheers
P30,
EC01
S70s,
Klarus G35
MF02 ,
FT03 SST40
Emisar K1
Geuzzz
Geuzzz's picture
Last seen: 1 hour 53 min ago
As probably most of us I was always using 1D’s or 1A’s for dedoming. As I have replaced the 3D xp-g2’s in my Emisar D4 for 5D I had some 3D’s to play with.
I dedomed them and really like the tint. Put one in my otr i3 and one in my B158. Liking this much much better Beer
Sledgestone
No green?
