What did you mod today?
10923 posts / 0 new
djozz
djozz's picture
Last seen: 1 hour 20 min ago
Thanks for the compliment Steve!
(you always make me feel guilty for not showing as much appreciation for other people’s work as you always do!)
Ouchyfoot
Ouchyfoot's picture
Last seen: 10 months 3 weeks ago
Great light djozz. I got worried when I saw you were using the stock LED board, but then relieved when I saw you jumpered the traces. Every time I kept the stock SRK LED board, and boosted the juice, I kept losing emitters. Yup, the traces kept burning up on me faster than I could repair them.
will34
will34's picture
Last seen: 7 hours 24 min ago
Awesome mod djozz, it’s always nice to see something that wasn’t designed to be good, being improved massively like this.
Today I modded a Maratac copper AAA with Richard’s 12mm single side FET driver (gruppydriv rev.2 fw) and Nichia 219C.
The driver is currently on sale here: http://budgetlightforum.com/node/46408
Stock LED and driver:
Before vs After, In the photos the 1.6mm thick driver is shown, but I actually ended up using the 0.8mm one. I had to reflow the nichia 219C into the stock mcpcb because the 10mm sinkpad couldn’t clear the reflector base:
Not necessary, but I added a solder blob top and a ring of solder to improve ground contact.
This is the 5000k 70CRI+ version of the 219C, as you would expect the tint is not as nice as the warmer high CRI one but I used this because of the low Vf, it allows it to pull higher amps on a 10440 compared to a XP-G2. According to my ceiling bounce test it makes about 750lm with a fresh efest 10440, on turbo the heat can be felt immediately.
RMM
RMM's picture
Last seen: 1 year 11 months ago
will34 wrote:
I had to reflow the nichia 219C into the stock mcpcb because the 10mm sinkpad couldn't clear the reflector base:
I haven't done a Maratac AAA, but I know that Vinh uses the Sinkpad on them so there's got to be a way.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
18sixfifty
18sixfifty's picture
Last seen: 2 years 3 months ago
MRsDNF wrote:
Amazing mod djozz. Loving your work.
Times Two!
Great mod djozz! Glad you posted this and great pics!
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
leroycp
Last seen: 3 weeks 6 days ago
Triple 219bt 45K 90+ CRI w/ CU spacer both from mtn into an S8. I used a med frosted carclo but did not like it. Switched to clear narrow and much much better. Mtn 17DD + 1 w/bistro. L2 brown box clone XHP N4 1C and TR 100 driver. Momentary and Turbo only. Ba#ls to the wall serious only.
CRX
CRX's picture
Last seen: 1 week 6 days ago
I installed an XP-L HI emitter in a thrunite ti, upgraded the wires and repaired the mode switch tab which had broken off by soldering a copper bridge over the outer contacts, works two modes again.
Then an 11mm FET driver & tiny alu heatsink into a thrunite ti xmas edition, pulls around 3.8A on startup. Smile
Finally Nitecore EX11 v2 triple 219c all black with copper heatsink.
Henk4U2
Henk4U2's picture
Last seen: 45 sec ago
djozz wrote:
A white wall shot at 4 meter distance. The camera was on auto-exposure to show the beam pattern, in reality it is an impressive wall of light:
I think this light is a succes, at least very impressive and I love the tint. I will not likely be doing another mod as expensive as this one, XP-L Hi’s are nice, but there are other very nice leds out there that are 3 times as cheap.
If the light keeps working as it is doing now, it is a candidate for swapping in some future amazing BLF-originating SRK-type driver!
a/ impressing mod.
b/ Late Night Show Smile
c/ nice collection
d/ is that a 12” Remington Standard?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
FmC
FmC's picture
Last seen: 11 months 3 days ago
Some nice modding going on here!
I think there's quite a few here that deserve their own threads as well.
djozz wrote:
My second Bestfire 9-led mod, my first serious high output one, and by far the most expensive mod I have ever done. It is a bit scary to put 50 dollars worth of XP-L Hi's in a light fully risking to blow them all up at some point.
I'm planning a "Poor Man's M43" build, but it's not so "poor" when you start adding up all of the emitters, & then realize that they could all go "pop" money-mouth
jescereal
jescereal's picture
Last seen: 11 months 5 days ago
I reflowed an XM-L2 5C onto a DTP board and put it into my Kronos X6. The tint is great, and the beam pattern is perfect.
I modded my B158.
I swapped in an XP-L HI 3B reflowed onto a Sinkpad, added 22 gauge wire, a MTN-17DDm driver, lighted tailcap, and bypassed springs.
That was my second reflow ever, and I’m so happy I didn’t mess it up!
I painted the top of the pill a flat black to minimize any artifacts (Thanks pilotdog68 for the paint brand!). Man is it hard to use that stuff without ruining the finish.
I get 5.5-7 amps at the tail from it, and 169600cd. So about 824 meters of throw.
lampyris
lampyris's picture
Last seen: 3 years 8 months ago
CRX you are seriously busy at the moment, great work!
All I did today was centre the led in two BLF A01…
Does this count as a mod?
djozz
djozz's picture
It is a Remington Standard, it does not say 12” anywhere but perhaps the 16 means it is a 16” ?
Found it on the street 10 years ago, still works, my son finds it much fun, he is just starting learning to read!
leroycp
S2+ with a qlite (mtne) + 7 7135s (double) 16mm XHP50 U4 1C 2 keeppower 750s. You can’t keep it on high very long but it sure will give you a laugh. L/MedHigh/TurboHigh. A LOT of light. I am still laughing. Carry some batteries for backup! File, file, and file the driver retaining ring. Everyone should have at least one.
DB Custom
DB Custom's picture
Last seen: 3 weeks 2 days ago
I learned to type on one of those, over 40 years ago. The letters were worn off the keys, still have it as a matter of fact. Now I have to go look to see if it was a Remington or an Underwood….
Henk4U2
Henk4U2's picture
I’m having a hard time not to write something like: if you show me yours ……….
I found it somewhere eating dust and disassembled and cleaned every last detail of it.
Then I lend it to my kid-brother so he could write his thesis. Got it back a short while ago.
Apparently he could not be bothered to put a cloth over it Facepalm Angry
-X3-
-X3-'s picture
Last seen: 2 weeks 1 day ago
I tried a 219C on a filed Noctigon in my Olight S2…that was a fail !
Artifacts everywhere in the beam, the TIR does not focus the light properly Sad
So I swapped the stock CW emitter for a nice warm T4-7A and called it a day…
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
CRX
CRX's picture
Much improved Nitecore Tube XM-L2 4C
-X3-
-X3-'s picture
Did you chopped an MCPCB ? Do you have some internal pics ? CUrrent ?
How, and wow, great job as usual Big Smile
CRX
CRX's picture
No MCPCB at all, it’s just a bare LED with a tiny copper block soldered onto the thermal pad & rigid wires directly to the emitter.
Stuffed a bit of that silicone cube stuff around it too but there’s really not much current to cause much heat. I should have took pics and measured current, but i didn’t LOL
This one was a little more difficult, i accidently dedomed the XR-C while working on it so i’ve covered it with UV setting glass glue for protection.
I’m obviously running out of lights to mod, down to nitecore tubes now… LOL
-X3-
-X3-'s picture
You obviously have too much time in your hands Party
Keep it going, I love seeing original mods !
CRX
CRX's picture
True, and thanks LOL
-X3-
-X3-'s picture
It’s only the beginning : S10R II triple XP-G2 3C combo from KD
leroycp
X3…looking good already. I like!!
unknown00101
Last seen: 2 months 2 days ago
Well that was stupid.
I just fried a dedomed xpg2 (I hope it was just the LED….). I spent the last few hours modding a UF-1508 aspheric with a dd xpg2 and a 5.5A MTNMAX driver. The 1508 has a bit of an odd pill and a threaded parabolic piece that screws down onto the mcpcb. After several failed attempts at getting the LED leads soldered flat enough I switched over to flat copper sheet. It worked eventually, just a pain to work with such tiny pieces of metal. So I screw down the securing piece to secure the mcpcb and I think to myself “don’t forget to pull this back off before testing”…….. I hook up the driver pop in two cells and a flash of light followed by utter disappointment as I instantly realized my mistake. Facepalm
-X3-
-X3-'s picture
Also swapped my second SRmini’s emitters :
7A on the left and 4C on the right
DB Custom
DB Custom's picture
unknown, I thought I was the only one that did stuff like that! Silly
Ouchyfoot
Ouchyfoot's picture
I just ruined three brand new XP-G2 S4 2B mounted on a triple noctigon. Not going into details.
giorgoskok
giorgoskok's picture
Last seen: 1 month 5 days ago
But we want details Big Smile
DB Custom
DB Custom's picture
I put a stacked resistor on an L2 and forgot about reflector clearance when soldering the leads back in, shorted it and fried the driver. I did have Kapton tape on the base of the reflector, but it tore. I’ll be happier with the Bistro driver anyway… Wink Still, was hoping to find out what the stock driver was capable of. Sad
Ouchyfoot
Ouchyfoot's picture
Well I for one am extremely proud of myself. I stacked some chips!
I have never been able to stack chips. I’m a pretty good solderer, but stacking chips has always been disastrous. I have stacked one chip before, but trying to stack a second chip always turned into the ruin of me. Every once in a while I give it a go until I ruin a perfectly good Qlite, and give up.
I have a triple deep red rebel mod coming up, and need between 4A-4.5A, so I got out another driver and managed to stack four 380 7135 chips. Maybe my confidence has improved?
It’s an ugly looking mess, but everything has continuity, and nothing got bridged. It’s that little leg in the center that always gave me grief, so I just cut it off.
I haven’t tested it yet. It should be okay, but I’m afraid if it ends up not working, I’ll break into tears. Tomorrow.
This is it. Please don’t laugh.
