What did you mod today?
10589 posts / 0 new
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 21 min ago
MRsDNF wrote:
Orsm job KB. Beer
Big Smile Beer
KB1428 “Live Life WOT
DB Custom
DB Custom's picture
Last seen: 6 days 3 hours ago
Changed the Utorch UT02 from a boosted XHP-35 thrower to a totally different kind of light… built a Zener modified FET driver with 8.4V LVP and 7 modes with reversing action through the e-switch, stuck it in the UT02 with an MT-G2. Big Smile
Edit: On a pair of 26350 cells fully charged it makes 3600+ lumens. Big Smile
Edit II: Tail current shows 5.96A from the little fat half cells.
contactcr
Last seen: 2 days 2 hours ago
Since my C8F white flat re-flow didn’t pan out I put some shaved dome SST-20 4000K’s in an 18650 C8F.
I got 50kcd and ~1,700 lumens
It doesn’t look very centered to me so i’m sure there’s a better result if you just had to have a 95CRI thrower.
Henk4U2
Henk4U2's picture
Last seen: 49 min 14 sec ago
Do these cell’s make my tail look fat?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
DB Custom
DB Custom's picture
LOL, I think they’re cute but YMMV….
contactcr
Built a C8 to try out a single unique XP-L HI I bought a while ago.
XPLAWT-H0-0000-000LV20E3
It’s an XP-L HI 75CRI 5000K…when I compare it to a V2 3A I guess I would say it’s about the same spot along the BBL but it’s slightly cooler white?
Anyways, got around 1,270lm and 108kcd.. believe it or not my first C8 mod. The LED is nice but I probably wouldn’t spend $7.35 on it again cause the usual suspects seem good enough (V2 5D and V3 1A)
nick779
nick779's picture
Last seen: 1 week 4 days ago
DB Custom wrote:
Well yeah nick, you’re not really going to get throw from a tiny TIR in a multi optic. Black or White Flat either one… the TIR is just too small. You might decrease the hot spot size, but it’s still going to be rather floody, especially outside where distance gobbles up light.
The light in my Avatar has 8 LH351D, 4 of which are W6 power bin 70 CRI and 4 of which are U6 in 80 CRI, there are also 4 XP-L HD and 4 XP-L HI as well as the center de-domed and sealed SST-40. They all work in unison though. Tint overall is quite pleasing, beam quality is somewhat dependent on power level, quite well suited to walking in the lower modes and dang near a stadium light when fully powered up. Smile
Yes, I have HD and HI emitters under the same quad optic, a D4S Ledil Angie in fact. Almost went with some Black Flats but they’re just too low powered. Effectively each of the 17 emitters present here are making 1500 lumens. Might be intersting to use separate drivers and a switch panel….
There is a Zanflare light with 4 independently adjustable heads with switches that allow each head to be turned on or off, perhaps different emitters could be used and different angles set up on the heads to create the flood/throw mixture you’re asking about?
Edit: Nick, have a look at the Zanflare F4 HERE
That F4 is a freaky light.
I was only mentioning the Olsons because of a recent post I saw of a D4 converted to them. The beamshots looked quite throwy for what it was. I just thought it may be interesting to have a small form factor tube light with two different optics and emitter options to give a potentially more versatile light depending on task.
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 6 days ago
Today I stacked a Convoy C8 driver up to 12× 7135 in total. Flashed with my modified Babka firmware and replaced XP-L HI led with Osram white flat 1mm2 led and Astrolux C8 smooth reflector because it is a tiny bit better than Convoy reflector. Focus almost perfect first time and it throws very well Big Smile
MRsDNF
MRsDNF's picture
Nice mod Zozz. You must have terrific soldering skills. Smile
ZozzV6
ZozzV6's picture
Thanks! I solder at work every day for almost 14 years now. You can minus 3 years from that at another workplace so 11 years of soldering left. But I think I soldered first when I was 8-9 years old Big Smile
ZozzV6
ZozzV6's picture
The C8 with White flat:
And our Christmas tree at work by one of my collegue:
Tree with the C8:
-X3-
-X3-'s picture
Last seen: 4 days 18 hours ago
That Christmas tree is adorable ! Party
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
DB Custom
DB Custom's picture
For you modders, a battery test… I used the 458 Ham’r with it’s 17 emitters and 5 MOSFET’s to just find out what cell gives what… Big Smile This is a single cell powering the Ham’r, 10 top cells, couple of surprises…
1. Samsung 21700 30T ————- 30.3A
2. Samsung 18650 25S ————- 28.0A
3. Golisi 26650 Gold ————— 27.0A
4. Sony 18650 C5A ——————- 26.2A
5. Samsung 18650 30Q ————- 24.9A
6. Sanyo 20700A Red —————- 24.5A
7. Efest 20700 3000mAh ———- 23.4A
8. iJoy 21700 3750mAh ———— 20.4A
9. LiitoKala 5000mAh (Black) – 19.5A
10. LG 18650 HG2 ——————— 16.7A
ZozzV6
ZozzV6's picture
Dale Where can I get Samsung 25S that will ship to Europe? I need some for a very high power build Big Smile
Wieselflinkpro
Wieselflinkpro's picture
E.g. Here https://www.akkushop.de/de/samsung-inr18650-25s-2500mah-max.-35a-36v-37v...
But I didn’t found the country “soldering iron” in the list of countrys they ship the items.
Agro
Agro's picture
Last seen: 2 min 18 sec ago
That’s very bad for HG2! Were the cells old, abused or something?
Henk4U2
Henk4U2's picture
Wieselflinkpro wrote:
E.g. Here https://www.akkushop.de/de/samsung-inr18650-25s-2500mah-max.-35a-36v-37v... But I didn’t found the country “soldering iron” in the list of countrys they ship the items.
He’s a hungry person.
Wieselflinkpro
OK, I knew somwhere in east europe.
Shipping is expensive, but possible: Ungarn:14,90 €
Henk4U2
Henk4U2's picture
Ungerne, aber doch Wink
ZozzV6
ZozzV6's picture
Yes! Hungary. Thank you!
DB Custom
DB Custom's picture
A friend of mine that uses the HG2 also thought that read was low, he expected it to be as good or better than the 30Q. I have two of these, neither are very used cells, but not new either. The 30Q in this test was brand new, first time charged. I’ll recharge both HG2’s I have and test them both again to see if I just got something wrong…
DB Custom
DB Custom's picture
Wieselflinkpro, I think SolderingIron is still a subsidiary Country located in the great Sahara, as a high desert country it’s population is low so shipping quotes may be difficult to find. Nice try though! Wink
ZozzV6
ZozzV6's picture
Big Smile
DB Custom
DB Custom's picture
A recap on the LG cells…With both of my LG HG2 cells fresh off the charger I see 16.7A and 17.0A from the two cells as tested before on the 458 Ham’r.
Wieselflinkpro
I got delivery with some drivers from @Lexel today.
I modded the following flashlights:
- Astrolux MF04S with 8A Narsil Buck-Driver and Mod of battery-carryer. For the battery-carryer I used copper foil instead of a wire to make the new connection.
- Sklilhunt H03 with 3 channel FET + 7 + 1 Narsil
- Haikelite MT09R XHP35HI Sand/Tan with 7,5A Narsil Buck-Driver (for sale in TLF in the next days)
Better he is hungry as he is thirsty. Without food you can survive more days as without something to drink.
DB Custom
DB Custom's picture
Facepalm
Language barriers, Aaaaagghh!
Bucket
Bucket's picture
My favorite flashlight of all time. The Streamlight SL20X.
I think I finally did it right. Direct drive. XHP50.2 5700K
“If you don’t read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed.”
—Mark Twain
Bucket
Bucket's picture
After a couple of attempts, I think I finally did it right. Direct drive. XHP50.2 5700K.
Raw aluminum version
Original Incandescent vs LED Drop In. Camera on full manual, same settings.
—Mark Twain
Tom E
Tom E's picture
Last seen: 2 min 33 sec ago
For 18650, VTC5D and 25S... The Best!
I got 30T's and 40T's - need to compare head to head.
MRsDNF
MRsDNF's picture
You milled the adaptor?
