What did you mod today?
10301 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 8 sec ago
nice 18350 mod
I like the bezel too Thumbs Up
e1000
Last seen: 1 day 17 hours ago
Thanks Jon! I’ve been racking my brain on how to easily do this
jon_slider wrote:
nice 18350 mod I like the bezel too Thumbs Up
CRX
CRX's picture
Nice idea Thumbs Up
e1000
Thanks!!
CRX wrote:
Nice idea Thumbs Up
Agro
Agro's picture
Last seen: 4 weeks 1 day ago
CRX wrote:
Nice idea Thumbs Up
I like it as well. Smile
id30209
id30209's picture
Last seen: 22 min 40 sec ago
I have 17670 Novatac body without the spring. Need to find some other solution. Maybe brass 0.5mm thick sheet with bent tips for contact.
WTB Titanium 4sevens 2xAA tube
NeutralFan
NeutralFan's picture
Last seen: 2 days 17 hours ago
Made a S2+ shorty with a Nichia 219B 3000K LED (from azhu) and a Convoy V.2 driver. Added a 470 ohm bleeder resistor for the aqua (mix of green and blue 0805 SMD LEDs) lighted tailcap. The tailcap takes just 0.15 milliamps so lasts almost a year on the 18350 Keeppower 1200mAh battery.
I’d rather use my flashlight around the house than turn on the lights.
jon_slider
id30209 wrote:
17670 Novatac body… brass 0.5mm thick sheet with bent tips for contact.
brass bar mod info here:
http://budgetlightforum.com/node/63046
nick779
nick779's picture
Last seen: 3 hours 51 min ago
Nothing too spectacular, but I was able to reflow a 4500k 219B into my Wuben E05 this weekend.
The only thing I had issues with was tapping the excess solder out. Once the MCPCB was hot enough I slid the old emitter off and tried to tin the pads just a little with some thin, rosin core 63/37.
Then I let the board and hot plate cool to ~75C(to slowly heat the emitter up), placed the emitter on the board and reheated to 220C.
Emitter centers itself, I tap it, solder balls pop out and I get some excess at the middle of each side of the emitter. Problem is that it sucks back under the emitter after a few seconds. Id imagine thats not great for thermals and consistent focus. What I ended up doing is placing a roll of tape next to the hot plate and placing a silicone backed ruler half on the roll of tape and the tip on the emitter to put gentle, even, centered pressure on it as it cooled. I cleaned the dome with some rubbing alcohol after but I didnt know if there was a better way to do this.
contactcr
Last seen: 32 min 13 sec ago
I wouldn’t apply pressure as it cools. Get rid of the excess using a toothpick or something to flick it away. It will settle on its own
Unheard
Unheard's picture
Last seen: 22 min 8 sec ago
Tap harder. You probably have still too much solder between pads and LED.
How’s the beam of the E05 with the 219B?
I have the E05-I with Samsung Emitter. Guess the 219B would make the spot even smaller, so I’m hestitant.
Smile, you cannot kill them all.
nick779
nick779's picture
I was giving it a good solid thunk, but I wasnt quick or dexterous enough with the toothpick. The datasheet stated to not keep it at 200C for more than 2 minutes and up to 260C for 1 additional minute. I didnt want to damage the emitter so I was trying to be quick.
Overall, the beam is ever so slightly narrower, but the spill seems brighter and more usable. There are some minor beam artifacts in the hotspot, but nothing noticeable in real world use.
NeutralFan
I’ve experienced the same issue as you when tapping the LED and having the solder creep right back under the LED. That seemed to happen when trying to remove the last bit of extra solder.
I now hold the LED down with a cotton swab and then swipe away at the extra solder with a toothpick. I split the toothpick to make the end smaller and flatter to help with the swiping.
Congrats on your reflow! And if you’re concerned about the extra solder, just heat it back up again to give it another shot (quickly).
jon_slider
EX10 Ti, with sw45k mod
low 1 lumen (16340 same as CR123)
max 225 lumens (16340), 150 lumens (CR123)
w original XR-3
low 0.3 lumens (16340 same as CR123)
max 79 lumens (16340), 75 lumens (CR123)
fwiw EX10 runs regulated on LiIon
EX11.2 does not hold steady output on LiIon
centering ring/reflector spacer for xp LED
16mm xp compatible mcpcb
e1000
very nice! I think I have the same silicone work mat
jon_slider
thank you Smile
you have very good taste … lol
Firelight2
Firelight2's picture
Last seen: 2 min 22 sec ago
Well not yesterday, but happened within the last week. I performed the following mods on my blue anodized Lumintop LM10:
  • O-ring switch mod. Exactly the same as for FW3A. Made even simpler since the bag of o-rings I got from Amazon for my FW3A probably contained 100 o-rings of the right size.
  • File anodizing off bottom of switch pill. The LM10’s tailcap contains a pill that screws in from the back. This pill holds everything in place and feels very secure. However, I noticed that with my blue anodized LM10, the light wasn’t as bright as my FW3A. I thought this might be because all the threads were also anodized where main current needs to pass through. A very light sanding to remove anodizing on the bottom of the switch pill seems to have fixed this issue.
The LM-10 is pretty nice. Feels much more solid than an FW3A. Note that my “blue” LM-10 is actually dark grey with the barest hint of blue tint. Looks nice, but not at all like the pictures.
gchart
gchart's picture
Last seen: 35 min 13 sec ago
Back in December I picked up a couple Utorch UT01’s from eas. He described them as “These are intact lights with the flakey UT01 driver. They’ve seen a bit of use. These are probably only useful to someone who likes to make tiny drivers.” Well, that was back in Dec 2019 and I made the drivers right away, but kept running into problems. I thought something was buggy with firmware, and I set it aside for 5 months. Well, I just dusted them off yesterday and finally got it working. As it turns out, I had mis-wired the switch. Facepalm
I used the top board from the stock driver, so I could assure proper placement of the switch and it keys into slots in the driver cavity to keep it from spinning. I crafted a new (li-ion only) driver using a linearly controlled FET via a QX7138, run by a attiny412 running RampingIOS (D4V2 UI). I should have thought ahead and used a attiny816 (now that I have Anduril running on the 1-Series) because Anduril is just too big for 4KB. I could use another FSM firmware though, like Baton which will fit easily. Now this is truly an e-switch 14500 light worth using!
Oshpark link
PS – oddly enough, everyone seems to have blamed the original issue on the switch being flaky. The switch is the only original thing I’m using and it seems to work perfectly fine for me on drivers that were known to have the “switch” issue. Weird.
Agro
Agro's picture
Are getting full 3 amps from this? Smile
Do you have the possibility to direct drive it as well?
gchart
gchart's picture
I need to double check with my clamp meter, but yes… I should be getting 3 full amps. Not set up for direct drive, though a FET+1 driver would be pretty easy to design for this. FETs are ok, but I don’t need this to be an absolute hot rod.
contactcr
Don’t forget, for FET you can buy a GT Micro driver from Lumintop aliexpress that drops right in. I couldn’t get Anduril working when I tried to re-flash it though but the stock GT Micro firmware works fine.
Agro
Agro's picture
How is the MOSFET cooling? Smile
gchart
gchart's picture
It sits on top of a fairly large copper pour which should hopefully spread the heat out and into the body. And with it being limited to 3 amps, hopefully the FET won’t be needing to dissipate more than 2.4 watts or so (4.2V battery, ~3.4 vF LED… so 0.8V dropped across the FET at 3 amps = 2.4 watts… if I have my math right). That’s a far cry from the 15+ amps that a lot of people are trying to put through a FET.
I just put this thing together at 2 AM. I still need to put it through it’s paces (thermal testing, etc).
EasyB
Last seen: 4 hours 41 sec ago
Very cool, gchart. I really like these linear regime FET drivers. Have you found any higher current regulator chips?
I looked on their AliExpress and couldn’t find any drivers. Do you have to ask for it specially?
contactcr
Yes, asked for it via chat and did custom order
jon_slider
Bling!
A light that tics a lot of boxes for me:
Rotary with stepless ramping
High CRI sw45k
Sapphire lens
eSwitch
multi fuel: Cr123/16340/AA/14500
Tritium locators
Firefly of less than 0.005 (as low as an RRT-01)
max of 200 High CRI Lumens
Geuzzz
Geuzzz's picture
Last seen: 25 min 11 sec ago
jon_slider wrote:
Bling!
![img]https://i.imgur.com/WhacGC5l.jpg[/img]!
Wow Jon. Where do you find all these gems?
Geuzzz
Geuzzz's picture
18350 tube.
SS bezel.
3000k sst-20 with zircon minus green filter.
Red Glow.
Agro
Agro's picture
I see, thanks for the answer. Smile
Scallywag
Scallywag's picture
Last seen: 9 hours 38 min ago
jon_slider wrote:
Bling!
High CRI sw45k
Sapphire lens
eSwitch
Tritium locators
How can you possibly have the trits showing in that photo? UV light applied to them?
