What did you mod today?
10282 posts / 0 new
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 4 min ago
Chatika vas Paus wrote:
Solarforce!
Black L2P with T head. Luxeon V2 4000k
Blue L2P. LH351D 5000k 90cri with cut and polished lens. I did it first time with this led and I can say that this is the easiest led to cut to dome.
Both have “Biscotti” 5A driver.
I think I used too long copper stripe for blue L2P because I had a serious problem to push it. I hope I won’t have to pull it out because I don’t know how to do it.
I did this build before Barkuti described a problem with “Biscotti” driver, and I didn’t even notice it. But everything works.
You can use plastic tubing 18-18.5mm diameter or what will clear the I.D of the battery tube, that will only contact the base of the aluminum pill and just pound/press it out…
KB1428 “Live Life WOT
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 1 day 12 hours ago
I’m going to get such a tube.. Once I used to take it out using 18350 and 18650 batteries, but this one sits so tight that I’m not going to risk it.
TMaxxJJ
Last seen: 15 min 1 sec ago
Solarforce!
That dedoming looks impeccable! Did you do it for tint or beam profile?
Chatika vas Paus
Actually both. I was hoping the tint would get a little warmer and it happened. Although not much.
Chatika vas Paus
MascaratumB wrote:
Wow, great work, the look beautiful Wink
That dedoming is top!!!
Beamshots demanded when possible Innocent
My first outdoor beamshots (blue and black).
Sorry for the blurry picture.
KawiBoy1428
I like this one the best…
Good job Thumbs Up
Chatika vas Paus
L2 several posts back. My first thrower. I even like it, considering I prefer flooders.
MascaratumB
MascaratumB's picture
Last seen: 52 min 14 sec ago
Thanks for the beamshots Wink
I like the Luxeon V2 effect more than the Samsung , but they both look great Wink
Well done Thumbs Up
hodor
hodor's picture
Last seen: 3 hours 57 min ago
MascaratumB wrote:
The EagleEye X3R is a micro-USB rechargeable flashlight…
Looks great MascaratumB! Did the driver drop straight in? What size is it and does USB charging still work? Tempted to pick one up.
MascaratumB
Thanks hodor! Wink
Well, the led4power driver fitted in without issues, as the original driver also has 17mm diameter (with 2 small flaps that fit the “pill”, to avoid rotation).
There is no USB charging , because the new driver doesn’t have it. The charging port is implemented in the original driver, so when I took it out, it stopped working.
The rubber cover is still there, though (I may need to glue it to prevent eventual water infiltration).
Even without charging, this is a great host to make a DIY pocket thrower with an Osram led (Convoy 18350s tubes fit Silly ).
It may be kind of hard to center it correctly in case you don’t have appropriate gaskets. The beam is not 100% perfect due to that, but it throws a lot Wink
http://budgetlightforum.com/comment/1666542#comment-1666542
hodor
hodor's picture
You’re a bad influence on my wallet
MascaratumB
Ahaha, thank you for the compliment Cash Evil Innocent
If you need any more info, let me know Thumbs Up
contactcr
Last seen: 20 hours 43 min ago
In those pics the EagleEye light looks like it has the best focus of all of them. Not sure if that is due to the smaller die and camera settings or if you are just being modest but I cant see anything wrong with it.
MascaratumB
Thanks contactr !! Thumbs Up
I guess it has to do with small die led and the bigger reflector (if compared with the S2 and S2+ and the leds they are using). Camera was in auto, if I recall correctly
However, my point is that it is very hard to center the Osram W1 and make a “perfect” pencil beam .
Below you can see that the “flower” shape is not completely uniform, and believe me that this was the best I could do without proper centering gaskets.
I un/screwed the bezel/reflector dozens of times and tried at least 3 different gaskets to make it look well. I ended up “blackening” the white gasket to avoid more reflection and artifacts and it also improved a little Wink
gchart
gchart's picture
Last seen: 1 hour 41 min ago
After reviewing the Wurkkos TS70, I knew that I really liked it for it’s heft, solid build, and brightness. However, I wasn’t really a fan of the UI. Hold-for-off really gets on my nerves.
So… brain transplant! I took out the PIC and put in a attiny412 with a tweaked version of RampingIOS / D4V2 UI:
  • When powered up, the light comes in on turbo instead of the usual double blink then off.
  • Swapped tactical and lockout modes so that lockout is 4 clicks instead of 6
  • Added momentary moon and secondary low from lockout (inspired by Anduril)
Oh, and while I had it apart, I gave the XHP70.2 a slice. Overall, I like it much better now!!
DarkShot
DarkShot's picture
Last seen: 1 week 3 days ago
Moderately simple mod yesterday, did an emitter swap on an Olight S1R II, that nice limited purple colorway. 3000k, 90CRI XM-L2. Looks real pretty.
Gonna swap the other S1R II with the same emitter and fix the misaligned bezel on the first soon too, but pretty happy with this choice of emitter.
Rayoui
Rayoui's picture
Last seen: 6 hours 3 min ago
Just a simple emitter swap. I dropped a sliced/polished dogfart in a D80v2.
From reading other people’s experiences with slicing the LH351D, I expected the CCT to shift a little bit more than it did. I measured 5200K pre-slice and 5000K after. Perhaps I didn’t remove enough of the dome.
The tint is very nice with a slightly pinkish hotspot and a little bit of a yellow shift in the corona. I can see some slight artifacts around the hotspot on a white wall but outside it’s not noticeable at all.
A couple test shots. The beam is very nice.
xevious
xevious's picture
Last seen: 50 min 27 sec ago
Nice work! I have a Olight S1 Titanium that could use a better emitter. I found one video that starts disassembly (removal of bezel) but haven’t seen anything after that. Did you follow a site or other video for removal of the pill to access the emitter?
gchart
gchart's picture
Finally got around to doing an emitter swap on my beloved ReyLight Ti LAN. I’ve gotta say, it’s an interesting MCPCB but one that I hope to never see again.
Before: Nichia 219C 4000K
After: sliced Samsung LH351D 5000K 90CRI
Reassembled
contactcr
You had a flux party and didn’t invite us?!
gchart
gchart's picture
Hahaha… thanks for the laugh. Yeah, it was 1 AM and I was rushing a bit. I cleaned up as much as I could and then moved on with my life.
hodor
hodor's picture
Tbh that mcpcb can be a tricky sob and needs all the flux it can get!
DarkShot
DarkShot's picture
The process is essentially the same as this video that person you linked also posted, and is pretty much what I followed. I used an old frying pan to remove the old emitter and reflow the new one on however
NeutralFan
NeutralFan's picture
Last seen: 14 hours 34 min ago
!{width:60%}https://i.imgur.com/9vQtPDD.jpg!
When I sliced my triple Samsung LH351D 5000K CRI90 LEDs I also was expecting the CCT to be noticeably warmer, but it appeared to remain at around 5000K. I also thought that maybe I could’ve sliced a little more, but any more seemed to be dangerous. I do like the tint overall and the extra throw the slicing gave.
I’d rather use my flashlight around the house than turn on the lights.
hcanning
I finished off the modifications of my Q8. It’s now very much one of a kind. I had previously:
- Stripped the anodisation
- Flashed it with Anduril
- Bypassed the springs
- Swapped the glass for AR
- Fitted brass screws
- Changed the switch LEDs from green to warm white
And today, for the pièce de résistance, my Q8 MCPCB with 4 × 3V XHP50.2s arrived from Sofirn (a custom order which they were happy to oblige).
It’s an absolute weapon now. In my Maukka-calibrated lumen sphere it went from 6,400 lumens with the old XP-L HDs to 16,600 lumens with the XHP50.2s. That’s just over a 10,000 lumen increase! Not bad for $20 Big Smile
Now to wait for it to get dark so I can take it for a proper test drive.
Notable lights: Q8 with 4 x 3V XHP50.2, bypassed springs, brass driver and tailcap screws, Anduril firmware, removed anodisation, AR glass, warm white switch LEDs (16,800lm)  |  Convoy S2+ with triple Luxeon V 4000k, Led4Power B4 Driver, Carclo 10507, bypassed springs (2900lm)  |   D18 in sand  |  D4V2 in sand  |  D4S in grey  |   FW3A with warm white XP-L HI  |   KR4 Mule in blue
Unheard
Unheard's picture
Last seen: 6 min 6 sec ago
Wow Shocked Thumbs Up
Smile, you cannot kill them all.
Tom E
Tom E's picture
Last seen: 9 min 31 sec ago
It looks battle ready. Nice job!
mountainair26
mountainair26's picture
Last seen: 2 weeks 6 days ago
@chatika Vas Paus
what method do you use to polish your lens on your L2 Mod? very nice work, how does it throw? Thank you
Two and a half years ago I bought the L2 host. Finally I put something in it. Sst40 with a cut and polished lens and TA fet+1 driver with bistroHD.
Chatika vas Paus
Sandpaper 600>1000>5000
This is my first thrower, so I have no comparison, but I’m (still) impressed. Shines much better than C8 with xpl hi, due to easier led centering.
See the Lexel thread on this scalping method.
Nicolicous
Nicolicous's picture
Last seen: 6 months 5 days ago
nice work hcanning
how did you strip off the anodisation…. chemical method?
It looks clean
Nico -.-
