What did you mod today?
10600 posts / 0 new
Crafity
SST20 4000k vs
contactcr
Last seen: 17 hours 33 min ago
Crafity use a new image host! Its like the 90s again waiting for image to load line by line
Crafity
sorry , test again please.
raccoon city
raccoon city's picture
Last seen: 13 hours 49 min ago
For the curious:
Crafity's image was only 639 kilobytes, which is reasonable, so the fault is/was with the image host.
I expected the image to be at least 20 megabytes considering how slowly it loaded.
Geuzzz
Geuzzz's picture
Last seen: 9 min 51 sec ago
Copper TK16 with the beautiful 219b sw30 9080 (from azhu, recommended -> http://budgetlightforum.com/node/68168).
And some glow of course.
Scallywag
Scallywag's picture
Last seen: 8 hours 6 min ago
My SOIC8 clip came today, a day later than expected.
My D4 has Anduril now, and the games have just begun. Now I have to figure out how to compile slightly-customized Anduril, for example to get a build that ramps properly on FET+1+15.
Edit 20 minutes later: My FW3A has fresher Anduril now, but I wasn’t a fan of having to unsolder the MCPCB to get to the ATTiny85. My D4 had just enough length on the leads to turn the driver sideways and clip on – likely because I replaced the MCPCB at some point, Hank probably had shorter leads before.
Yokiamy
Yokiamy's picture
Last seen: 22 min 34 sec ago
I modded my GT to a GT90!
http://budgetlightforum.com/node/74032
Scallywag
Scallywag's picture
I remembered when I finally finished modding my L6 about two years ago, I swore I would never open it again. I decided to throw Anduril on it, and it decided to remind me why I said that.
My recollection was that I’d mostly pulled off the Switch+ pad on Lexel’s lighted switch board, and had managed to barely solder the wire onto a remaining fragment of that pad. Well today when I pulled/tilted the driver out juuuuust enough to clip onto the ATTiny85, that lead pulled loose and the remainder of the pad went the way of a fart in the wind.
After some frustration attempting to re-attach to that pad (or rather, where that pad used to be), I decided to file a notch into the switch PCB and route the SW+ signal wire to the leg of the momentary switch itself on the front. It all worked great until my arrogance got hold of me: I assembled it all back together and got factory reset as soon as I applied power! I was sure I knew which leg was which on the button and didn’t double-check… so now I had to re-disassemble, file another notch on the other side, and solder to the proper leg of the switch button.
But now my L6 has Anduril, at least. I’m really never opening it again unless I have a replacement lighted switch board in-hand.
Weird question: Does RampingIOS (or, from MTNE, “D4 UI V2”) measure voltage differently than Anduril?
Edit: Yeah, I’m definitely going to be opening it again. Battery check only gives me 5.2v. I’m also gonna have to figure out how to compile my own build, since TK helped me in another thread figure out how to disable the turn-on blink
Edit note: Screwed up this post editing it when I meant to quote it, and had to re-write.
contactcr
I modded a On The Road Z821 zoomie, twice:
From 15kcd to 39kcd to 64kcd+
Scallywag
Scallywag's picture
Continuing the saga. I’ve been reading quite a bit about how to do all the things. The L6 looks like it’s going to give me a challenge. For the FET+1+15 driver in the M6 (3xXHP50.2 3V), I just shot FW3A firmware at it after figuring out the pinouts were the same. Decent hardware match, paralleling 3xXHP50.2/4×30Q/16×7135s against 3xSST-20/1×30Q/8×7135. Tested with my only button-top unprotected and it’s working great. Excited for my 4x button-top 30Q order to arrive Monday (~ish, with how USPS is these days). It will maybe hold the heat better than the FW3A, so I may eventually do a custom build with tweaked…uh, what was it again… #define THERM_FASTER_LEVEL in cfg-fw3a.h. Hey, maybe if I get good at this I’ll even tweak the ramp levels on it, since that one’s so easy to open. (A bit hard to clip to, though, since my reflow of the ATTiny85 isn’t the best.)
As for the L6, what I’ve figured out so far is that it probably uses a voltage divider (or something?) on Pin 7 to read the voltage. No idea how LVP works yet though.
Edit: Update: Chopped up a hwdef file from a D4 (for ramp levels and FET+1 stuff) and a GT (for voltage divider stuff), disabled blink at power-on, and adjusted THERM_FASTER_LEVEL on my L6; built and flashed successfully. Voltage check is working, although not my preferred behavior (gives voltage of a single cell, rather than total voltage). Bedtime. I’m sure I’ll dive back in tomorrow.
David1207
I fixed some of my gadgets having some issues since few days.
contactcr
Changed up my EagleEye X6
I got some mystery bin “Boost HX” (CULPM1.TG) from aliexpress. The light had a LED4Power 4× 4040 board with Luxeon V in it and Angie optic (same one from Emisar D4S) so I thought it would be smooth sailing; it wasn’t. I kept getting shorts after the reflow. The separation between pads is so small with this board and after more than an hour fooling with just that I gave up. I had one 4XP 33mm Noctigon I use for slicing 4 LEDs at a time (so WELL used) and I figured i’ll give it one shot reflowing them onto the 3535 board. First try was a success! The next problem is that board is 1mm larger than the LED4Power one so I had to cover the LEDs and grind down that huge PCB to fit the spacer. I would have done this first but I had no faith in my ability to reflow the board on the first try and just assumed it wouldn’t work.
End result:
~77kcd
~4470lm @ 3s
5500K CCT
CNCman
CNCman's picture
Last seen: 13 hours 9 min ago
Scallywag wrote:
CNCman wrote:
Unheard wrote:
CNCman wrote:
If it is lead free, do you know how to save the led ? I did not know anyone was using lead free for led to mcpcb’s.
Not sure if I got you right, the LED should survive the higher temperature.
. I did not know how well the lead free reflow solder and lead reflow solder mix. I just burned up a XHP70.2 and that may have caused it. Is there a way to tell the difference ? .
In my experience, a touch of good ol’ 60/40 or 63/37 mixes in quite well and drastically improves the performance (melting point and eutecticity) of most of the RoHS-compliant solder I’ve encountered.
However, given that LEDs can be in RoHS-compliant devices, I don’t think they should have an issue being reflowed with lead-free. And the solder mixture of lead-free and not- shouldn’t affect thermal properties enough to burn out your LED. Did it burn up on a long turbo run or very quickly after being powered? For XHP70.2 I’d be more worried about the heat-sinking of the MCPCB, since they can happily consume 150+ Watts.
“ Scallywag “ It burnt up on the first turn on and ramping up to about 50% power, poof. I had just installed ‘ Lexels ‘ driver. The led was working perfectly normal with the stock Haikelite driver, but I had modded the mcpcb to 12v and probably got some crossover voltage in the mcpcb. I have not had time to address it since then, busy on another build and I just received a few more mcpcb’s to mod to 12v. So new leds are ordered and soon will be back with an update. Thumbs Up
CNCman
CNCman's picture
Yes, I see you !!
You may want to post a few pics here. I’m afraid many may miss out on your mod, Great Mod !! Thumbs Up
Danthemanz
Last seen: 8 months 3 weeks ago
I finally reflowed some new emitters onto my Sofirn IF25 (the one with shifting CCT).
I used 2 × 219b 4500k (SW45k) & 2 × 219b 3000k.
I cant believe i wated this long to do it. The light’s been sitting half undone for months on my shelf, i just hated the stock LEDs ssssooo much that i couldnt imagine it being as good as it is.
The CCTs blend well together. The optic is quite throwy which is a nice change for a R9080. pretty decent mass to the light, USB-C. Im quite happy. If they just fixed the hold off in the UI….
Personally im not overly fond of the SW45k, not that i dont like the rosy tint, but 4500K is just not my thing indoors.
I think i found a way to get close to my favourite 3500k but with more rosy tint Thumbs Up
Will give it a decent run over the next few nights before i add it to my standard rotation, but maybe its the perfect light to take away when you only have 1 light. Any indoor CCT i want and USB-C charging!
Scallywag
Scallywag's picture
Welp, my 30Qs arrived today. Threw them in my M6 and… as soon as they connected, it turned on.
I assumed my fix for the reflector shorts broke, so I checked for shorts there… but nothing. Just to be sure, I removed the reflector, and eventually pulled the driver completely out of the light. I double checked all the pinouts for the driver, including probing it out with a DMM, and compared it to the Anduril version I flashed – no issues there. I’m not sure what path current is flowing through. I eliminated the single-7135 channel by removing it. It’s probably the FET, but in my test rig the 15×7135 channel is probably just doing direct drive too, and I’m not sure how to test which gate is being opened with a DMM.
And apparently, all I had to do was give up and post here. I went over every solder joint on the board that I could see… But just now, typing this, I decided I’d double-check that the issue wasn’t somehow with the MCU/firmware (by removing it). I’ve got a silly quick way to do it, by laying the tip of the iron across one set of legs and rocking it up, then doing the same to the other side. But just now I gently applied flux to each quartet of legs. When I first laid the iron across the legs, I noticed how the visible portion of the solder joints got a lot neater… And on a hunch, did the same to the other side. Re-tested and it appears to be giving me the “blink for on”.
I think the most frustrating part of all of this is that the light was working without issues yesterday with the single 30Q out of my FW3A. All it did was sit on the desk, empty (no batteries) since yesterday evening. I’m going to go fully reassemble the light and make sure it still works.
Tested more, seems to be working. Re-assembled… Still working. Definitely the brightest light I own now, though I have no way to actually measure. But ceiling-bounce around the room compared to my L6 definitely gives the M6 a slight edge. It also gets hot way faster on turbo. But the difference between “10K” and “7K” lumens (this is what my M6 and L6 should be doing, but again – I can’t actually measure) isn’t impressive. Probably because the way the eye sees it, it’s less than 20% increased perceived brightness (perceived brightness is doubled when lumens are quadrupled).
I don’t think I need to build any more high-lumen lights, unless I find a way to do about 40k lumens at this point. And, judging by what Acebeam and Imalent are doing, that just means stuffing as many 70.2s as I can in something, which doesn’t really sound any more interesting than my M6.
jon_slider
jon_slider's picture
Last seen: 32 min 36 sec ago
Thrunite Ti3 Ti Xmas
CREE XP-E2 Green
on aaa Eneloop
0.1 lumens
10 lumens
70 lumens
Green light emitting diodes accelerate wound healing
Nitecore EX11.2
CREE XP-E2 Green
on 16340:
0.6 lumens
ramping to
150 lumens
on CR123:
0.04 lumens
ramping to
70 lumens
Firelight2
Firelight2's picture
Last seen: 6 hours 10 min ago
Added a pocket clip to an Imalent LD70 today.
I found one slip-on clip that worked and was in no danger of coming off the light. But the clip tension wasn’t the greatest and it stuck out from the light more than I liked. I removed it and replaced with a screw-in clip. Fortunately, the wall of the light where I drilled was thick enough that the screws did not penetrate to the inside.
I don’t have any experience or equipment for tapping screw threads. Instead I just drilled a couple small holes with a hand-held pin-vise drill and let the screws tap their own threads.
Playing around with these clips did scuff up the light a bit though. Darn.
contactcr
Practiced heating some Ti before I torch a full light, turned out pretty good.
EasyB
Last seen: 13 hours 58 min ago
End result:
~77kcd
~4470lm @ 3s
5500K CCT
Nice perseverance and result! I don’t think I’ve seen an Angie in an X6 mod before. Is it the same height as the CUTE-3 or do you use a different spacer?
jon_slider
contactcr wrote:
nice gradient Thumbs Up
will look nice when polished
contactcr
It’s different, LED4Power sold them with his special 32mm 4x boards.
Angie is beautiful optic for modern LEDs and the large spacer really gives some good runtime on turbo.
contactcr
It’s a bit of luck the method I used. I could do smooth(ish) even gradient with torch but I wanted these timascus looking lines and spots.
It was lightly heated to bronze gold throughout with only slight color on just the very tip and then dipped in acid etching solution (ferric chloride) and it instantly (re)oxidizes to this gnarly pattern.
jon_slider
ah, missed it the first time.. yes, very cool
Scallywag
Scallywag's picture
Looks like lightning to me. Pretty cool.
contactcr
Well stay tuned. Next week I’ll ruin a perfectly good polished FW3T
Scallywag
Scallywag's picture
If you “ruin” it and it looks like that clip when you’re done…
I’ll cover postage so I can personally dispose of it responsibly Wink
scalpel_ninja
Last seen: 1 week 2 days ago
I buffed the optics for my KR4 today. I like the extra throw and it doesn’t seem to affect the tint too much for the E21A 4500K emitters. I also like how the aux LEDs are brighter points of light, rather than the fuzzy ring of color.
When I bought this Ti/Cu version, Hank’s site still had the frosted optic listed as an extra part along with the 18350 tube, tritium, etc. Within hours of ordering, he announced the frosted optic will be standard. So I ended up with two frosted optics, one in the light and one in a tiny ziploc bag.
Current Collection:
Inova X5 | Maratac Titanium Inspection AAAx2 XPL-G2 swapped to Nichia 219B sw45K | Wowtac A2S NW | Noctigon KR4 Ti/Cu E21A 4500K + 18350 tube | Thrunite Ti3 NW | Wurkkos FC11 x2 swapped to Nichia 219B 3500K | FW3 CuTi XPL-HI 5000K + 18350 tube | Olight I1R EOS (de-anodized) | Convoy S2+ 7135x8 T6-3B | SkyLumen LEPvn | HDS Rotary Nichia 219B 4000K | Nitecore Cu TINI | Fraz Labs Tiny Tank 18350 | TnC Aluminum Deep Red
NeutralFan
NeutralFan's picture
Last seen: 1 day 13 hours ago
I made a pair of Nichia Optisolis triple S2+s. One is 5000K and the other 6500K. I usually don’t like cool white LEDs, but I thought it would be “cool” to have the highest CRI LEDs currently available. The 6500K has 99 CRI and 99 CRI R9 – it don’t get much better than that!
I got the LEDs from Virence and the triple boards from Adventure Sport Flashlights.. I wanted to limit the current to less than 2.25 amps so I got some 6×7135 drivers from Simon at the Convoy flashlight Store. I also installed lighted tailcaps so I had to add 470 ohm bleeder resistors to the drivers.
When I put everything together, there was some artifacts in the beams, so I sanded the lenses to make them frosted and the beams turned out great. With 10511 Carclo Narrow Spot Optics the flashlights have some throw.
I was expecting some greenish tint due to the positive Duv test results on the Virence website, but I don’t notice any at all. The 6500K certainly appears bluish on a white wall, but both appear to have some rosiness to them. I’m very pleased with the tint and how the flashlights turned out.
I’d rather use my flashlight around the house than turn on the lights.
jon_slider
NeutralFan wrote:
Impressed I am! Thumbs Up
Cool is Cool
Optisolis 6500k color separation is outstanding
Good color temperature for daywork
