What did you mod today?
10589 posts / 0 new
Microa
Last seen: 11 hours 43 min ago
Thanks for your prompt reply. I have just received my ATtiny416-XNANO for testing. Your advice is very helpful for the beginner writing codes. You are subscribed.
WallKiller
WallKiller's picture
Last seen: 1 day 19 hours ago
Fw3a mod
- main xp-l hi 5000k
- additional Nichia e17a 3000k
MascaratumB
MascaratumB's picture
Last seen: 1 hour 28 min ago
For a very long time I’ve been looking to do a mod, inspired by this thread of g_damian, and this CRX thread, and this Firelight2 thread, and even some comfychair mods I once managed to see.
To all of you, thanks for the tips and and descriptions of the work done, as it was a tremendous help Beer Hat
What I wanted to do was a “shortened” Convoy S2+, triple, using a Jaxman 18500 battery, and using an 18650 battery!
This week I received the tube and yesterday I took some time yo make it happen Big Smile
I had to “dismantle” the blue S2+ that I put together sometime ago here and I used an extra S2 pill I had for the job! Used a file, and my Parkside tool (dremmel like) with a cilinder of sandpaper and a drill for the middle hole.
The leds are Luxeon V2 3000K Love , under a Carclo 10511, and powered by a TA Bistro HD OTSM driver from Lexel . The retaining ring was made by kiriba-ru, the FC switch is from Convoy. The pocket clip is from Nitefox ES10K, and the blue tailcap from the LHT store at AliExpress. The GITD gasket is from CRX Wink
I put some adhesive tape to mark the limit I wanted to file/sand, and also to protect the other threads, as sometimes it hard not to damage something.
Then I did the filing/sanding work until the top of the pill was flat and until I had taken enough material from the threads so that the pill could get it but still make “contact” with the walls of the head. Then I drilled the hole in the pill.
And the the rest was soldering and putting things in place.
The 18500 tube colour matches pretty well with the S2+ colours, and only the knurling is slightly different.
Vs XP-G2 S4 3C (5500K) >>>>>>> Vs Luxeon V 4000K >>>>>> Vs the glow gasket of my Convoy S6 Big Smile
Convoy S6 > Convoy S2+ Desert Tan > Convoy S2+ black > Convoy S2+ blue > Convoy S2 18350 > Convoy S2+ DT 18350 > Convoy S2+ black 18350 > Convoy T2
JaredM
JaredM's picture
Last seen: 16 hours 23 min ago
Nice work! I like the proportions of it, always thought the std is too long, and 18350 too short. Beer
g_damian
g_damian's picture
Last seen: 6 hours 22 min ago
Nice mod and pics, MascaratumB! Thumbs Up
MascaratumB
Thanks Beer
Yup, the size of it is quite nice this way. To be even better, it could be slimmer to take 16650 cells (which have a reasonable capacity, even if not so good for high-drain). THAT would be cool Wink
Thanks g_damian Beer Your work inspired me much in this mod, so thanks for your details too Wink
This will be a “user” for sure, as it has a great tint, a UI that I like an can configure, and also takes a good capacity/high-drain cell Wink
Thumbs Up
Scallywag
Scallywag's picture
Last seen: 11 hours 34 min ago
MascaratumB wrote:
Thanks Beer
Thumbs Up
Great mod. I especially like the pocket clip; one major obstacle for me to carrying my S2+/Jaxman E2l these days is the horrid clips I’ve got for them.
They also lose out on size to much better lights, but that’s another story.
CNCman
CNCman's picture
Last seen: 17 min 26 sec ago
I modded a MT35 Plus with SBT90.2 a few weeks ago. Here is the thread if you want to look. https://budgetlightforum.com/node/76083
22 amps on turbo
1,829,513cd
5800 lumens
2700 meter throw
NeutralFan
NeutralFan's picture
Last seen: 11 hours 16 min ago
I like your mod MascaratumB. Nice job!
I’d rather use my flashlight around the house than turn on the lights.
MascaratumB
Thanks Scallywag Beer
Yup, that pocket clip is quite nice, smaller and thougher than the “screw in” clips that Simon and other stores sell. AliExpress sells some nice clip, you may wanna take a look there. They are bigger than this one, though.
I forgot to mentuon that the clip was previously used in th Jaxman E3, and by that time I “flamed” it with a lighter, hence that blueish colour.
Thank you Neutral Fan Beer
Turned out quite nice, I guess, doesn’t it ? Wink
Not a very difficult mod, but with a nice result!!
NeutralFan
I reflowed Nichia E17As onto a VR16SP4m board! Mic drop…
Never again will I attempt to do this. The board is a little beat up due to breaking the original E17As that were perfect from Virence, trying to reflow other E17As that went horribly bad, and then super gluing an LED spacer as an experiment.
I put very, very little soldering paste onto each of the 4 LED pads, but it was still too much. So I removed the extra solder with a toothpick while positioning each LED into place, but then 2 little solder blobs got between the LEDs. Argh! Once the board cooled down, luckily I was able to split a toothpick and pluck them away.
Henk4U2
Henk4U2's picture
Last seen: 46 min 5 sec ago
About super-gluing led spacers. I use a different approach.
- first I superglue a 2-3mm long part of a plastic tube around the led.
On the search for a suitable tube the outer diameter is paramount.
The outer diameter shoud fit (not tight but snug) in the hole of the reflector.
Any attempt to bring the diameter down is (in my case) a risk of it not staying circular..
The inner diameter of the tube is less critical for me as I have plenty objects to enlarge it.
I try to make the inner diameter as large as the diagonal of the die.
That should be enough to CENTER the led properly.
Then I will look for a piece of plastic to make a “shim” that I can place on the leadboard.
With the above mentioned tube poking trough. The reflector rests on the shim.
Find the correct thickness for the shim and you are able to FOCUS the led.
As a bonus, such a shim prevents the leads to short with the base of the reflector.
Unless you find the ideal centering ring it is always a bit of a wiggle to CENTER and FOCUS.
My method divides that time consuming chore into 2 separate (quite easy) actions.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Chicken Drumstick
Last seen: 7 months 1 week ago
Been wanting to build something like this for ages, although made a slight mistake as the driver I wanted to use were 20-22mm. So I had to find an alternative 17mm to use. Lower amps, but hoping it’ll still be quite nice. Unless anyone knows of a similar sized host that uses larger drivers?
Convoy M1. I have an original when Simon first launched these, the current version is nicer. Shorter overall, more matt anodising and different machining.
Matched with a 17mm driver and a 5000k Cree MT-G2. A big LED in a relatively little torch Big Smile
Wires soldered up:
Tidied up and driver seated and retained:
The reflector gets quite close, so to avoid any shorts some insulation of the contacts:
The reflector needed no mods, the hole was big enough for the MT-G2. Centring was a little challenging as I’m not using any kind of gasket or ring. A few tweaks to the star and screw down tight and probably a fair does of luck and it doesn’t look too bad Smile
The LED dome fits well in the OP reflector.
Final touch a deep carry pocket clip:
And we’re done!
Will have to wait until it gets dark to try it out and I’ll see if I can get come cd/lumen readings. I’m not expecting it to be a lumen monster due to the driver choice. But the beam is looking quite nice so far. I wanted something with a nice bright even beam, but with more throw than a flood TIR or aspheric lens.
MascaratumB
Cool, will be looking for those beamshots Wink
NeutralFan
I’d be interested in seeing some pics if you have them.
I found super gluing the regular LED spacers, with the ends cut off, works very well.
MascaratumB
I envy your soldering skills NeutralFan! Looking good Wink
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 6 hours 3 min ago
The Boruit BC07 is an interesting flashlight. The quality of workmanship surprised me. Although I do not like zoom flashlights, I will probably leave this one for myself.
Boruit BC07
Chicken Drumstick
Difficult to get decent beamshots to really show the difference.
Thought I’m compare to an XM-L2 Convoy M1:
The beam is a lot more even on the MT-G2, which was my aim. Make it more useful at closer ranges and less intense hotspot when out walking.
XM-L2:
MT-G2:
XM-L2:
MT-G2:
It still has more throw than your average tube light too. Although clearly this is a long way from a thrower.
On my setup at home I’m getting PEAK readings of
Convoy M1 MTG2 = 1209 lumens and 6358cd
For reference:
Convoy M1 XM-L2 = 745 lumens and 11,988cd
BLF A6 XP-L = 876 lumens and 5416cd
Lumintop FW21 Pro 3 x XHP50.2 High mode = 1380 lumens and 2951cd
NeutralFan
Nice mod Chicken Drumstick. And interesting how much the M1 has evolved. I have the M1 host in my Convoy Store cart along with a bunch of other goodies.
Agro
Agro's picture
Last seen: 18 sec ago
Boruit BC07
Interesting, thank for showing this. Smile
Henk4U2
Henk4U2's picture
Sorry I can’t help you right now. At “le moment suprème” the battery of my camera was empty.
In the meantime I would like you to refer to this POST where I tried to explain the build of my Fandyvoy (Fandyfire STL-V6 + Convoy C8). After charging I will try to re-take the left picture of the pill a bit better.
NeutralFan
That post helps a lot. No need to take further pics.
Since I frost the lenses of my E17A flashlights to remove the donut holes, I don’t need to worry about focus. Does your technique work on E17As?
Henk4U2
Henk4U2's picture
Too late Silly
The blackened nylon ring takes care of the centering.
A shim around the nylon ring takes care of the focussing.
This shim I have cut out of the bottom of a yoghurt cup (indeed pushing the technology envelope).
Have no experience with E17A. Only XM-L, XP-L, SST40, SST20 and white flat.
EasyB
Last seen: 15 hours 25 min ago
I’m trying to put an attiny85 and Anduril on a qlite driver and am running into a weird problem.
I made a few mods on the driver so the 85 would fit. I got rid of the voltage divider resistors since the 85 gets the voltage right from pin 8. But the battcheck mode in Anduril would read very high and erratic voltage readings. So then I did some creative soldering to emulate the resistor and capacitor filtering that the D4 and D1S FET+1 drivers have, where there is a 4.7ohm resistor between battery pos and the diode, and a capacitor to ground on either side of the diode. This worked and the voltage readings were stable and right on.
I was still in the process of bench testing and getting the ramp table right when the driver stopped working. It would not turn on; only giving a small blink as the button was released. Disconnecting and reconnecting power did not fix it, but letting it sit for several minutes did fix it. However, it keeps happening after a minute or so of playing with/testing the driver.
I don’t think it’s anything in the code since the problem happens with unaltered code that works fine in my D4. I also tried a different attiny85 and the same thing happens.
Anyone know what would cause this behavior?
EasyB
I think my issue is resolved. I had a hunch it was a power issue; that the attiny85 was getting voltage spikes or something causing it malfunction. I was bench testing using a power supply and using a battery, but both using relatively long wires. I decided to just put the driver in my headlamp and see what happens, and it seems to be working with no problems yet. I guess the extra inductance of the long wires led to voltage spikes?
Similar problems have been observed.
https://budgetlightforum.com/comment/908038#comment-908038
gchart
gchart's picture
Last seen: 15 hours 2 min ago
Glad you got it working!
TimMc
TimMc's picture
Last seen: 6 hours 7 min ago
Sofirn SC31 Pro with Cree XMLBWT 2700K
TimMc
TimMc's picture
Wurkkos WK01 with Nichia 219B sw45k D200 R9080 from Bob_McBob
jon_slider
jon_slider's picture
Last seen: 1 min 5 sec ago
Thrunite Ti3 AAA mod to N219b 3500k 9080 from azhu. Very nice tint imo Smile
pinkpanda3310
pinkpanda3310's picture
Last seen: 5 days 14 hours ago
Slow colour change for fw3a aux. The one on the far right
