What did you mod today?
9888 posts / 0 new
gchart
gchart's picture
Last seen: 2 hours 34 min ago
Ok, pinkpanda… do tell. How did you accomplish that?
CNCman
CNCman's picture
Last seen: 8 hours 42 min ago
I second that !! Cool
But that’s a secret recipe we may never know. Wink
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 4 hours ago
Damit 3 times I’ve tried to reply now. Work keeps getting in the way Flat Stare
It’s not that techy. You know I’m not good with code so I did a work around. I had an original fw3a with a lexel aux board installed (fixed colour). I removed the board and soldered this led in place – https://m.globalsources.com/LED-component/RGB-SMD-LED-1170310432p.htm
It’s the same kind of led l4p uses in his rgb tails so there is no control over the colours. The low brightness setting isn’t enough to light up the blue led when that colour cycles around but on the bright setting there is no problems.
gchart
gchart's picture
I wondered if that’s what you did, but they seem to stay in unison. I figured with multiple LEDs they’d end up fading to different colors at different times.
I remember djozz trying out something similar with tailcaps. Now that I go back and look at it, it is pretty cool even if they aren’t synchronized.
djozz wrote:
Supfire S1 small 16340 tube light, fixed BLF-A6 driver with 460 Ohm bleeder, 219C R9050 SM353, switchboard with 50K pot under the spring, lighted ring with 3× 3.3 kOhm and 6x slow colour change 0805 rgb leds from ebay.
Fun is that the leds are not completely autonomous, they slightly influence each other’s timing and actions so that the cyclus becomes partly chaotic.
pinkpanda3310
Yeh it’s lava lamp style with multiple leds out of sync.
The trick with this fw3a – i didn’t replace LEDs on the board rather I removed the whole board and soldered the control wires directly to a single rgb led. So technically it’s floating loose in the head.
TimMc
TimMc's picture
Last seen: 31 min 23 sec ago
Sofirn C01S Green with Cree XP-E2 Green
MoreLumens
MoreLumens's picture
Last seen: 10 hours 29 min ago
jon_slider wrote:
Thrunite Ti3 AAA mod to N219b 3500k 9080 from azhu. Very nice tint imo Smile
![img]https://i.imgur.com/qeFSnffl.jpg[/img]!
I think that will be my next thing with Nichias. Loving those 4500k’s, tried SST20 2700k which was a bit too orange for me, but 3500k seems to be just the thing. Maybe Sofirn C01S for the host or maybe some AA light.
NeutralFan
NeutralFan's picture
Last seen: 38 min 17 sec ago
I made a pair of S3 quad E17As 21700 flashlights – one with 2700K and the other 5700K. I got the S3 hosts from Kaidomain, the 6 amp drivers from the Convoy Store, and the Nichia E17As from Virence.
This time I used 26AWG Teflon wires (vs 24AWG silicone) which were much easier to solder to the VR16SP4m boards and to curl up into the driver cavities. The effective gauge (Wirebarn) of 2 26AWG wires is 23AWG, so good enough capacity given the 5cm lengths. I super glued the reflector spacers on to the boards to prevent any damage to the delicate E17As. The 2.5mm thick shelves do a great job dispersing heat which can be felt almost immediately when on high. There were some burrs on the shelf holes, but other than that, the hosts with included pocket clips and lanyards are of high quality.
The 21700 size is starting to push it for carrying in my pocket, but still acceptable. I had to frost 1 side of the lenses to remove the donut holes. The resulting beams have noticeable hotspots and the tints and outputs are impressive. So is the extra capacity of the 5,000mAh batteries. I’m torn as to which flashlight I like better, but I’m leaning towards the 5700K despite my tendency for warmer temps.
I’d rather use my flashlight around the house than turn on the lights.
id30209
id30209's picture
Last seen: 7 hours 18 min ago
NeutralFan wrote:
I made a pair of S3 quad E17As 21700 flashlights - one with 2700K and the other 5700K. I got the S3 hosts from "Kaidomain":http://kaidomain.com/Flashlight-DIY-and-Tools/diy-flashlight-shell-or-fl..., the 6 amp drivers from the "Convoy Store":https://www.aliexpress.com/item/4000961062843.html?spm=2114.12010612.814..., and the Nichia E17As from Virence. This time I used 26AWG Teflon wires (vs 24AWG silicone) which were much easier to solder to the VR16SP4m boards and to curl up into the driver cavities. The effective gauge ("Wirebarn":https://www.wirebarn.com/Combined-Wire-Gauge-Calculator_ep_42.html) of 2 26AWG wires is 23AWG, so good enough capacity given the 5cm lengths. I super glued the reflector spacers on to the boards to prevent any damage to the delicate E17As. The 2.5mm thick shelves do a great job dispersing heat which can be felt almost immediately when on high. There were some burrs on the shelf holes, but other than that, the hosts with included pocket clips and lanyards are of high quality. The 21700 size is starting to push it for carrying in my pocket, but still acceptable. I had to frost 1 side of the lenses to remove the donut holes. The resulting beams have noticeable hotspots and the tints and outputs are impressive. So is the extra capacity of the 5,000mAh batteries. I’m torn as to which flashlight I like better, but I'm leaning towards the 5700K despite my tendency for warmer temps.
 Great build!
 Would you mind posting a beamshot?
WTB Titanium 4sevens 2xAA tube
NeutralFan
Here you go. I’ve alway struggled with white wall beamshots since they never look as good as what I actually see, but I understand why people want to see them. I’m sure my next iPhone will be much better, but that may be awhile.
id30209
id30209's picture
Looks great. I don’t see and donut in the beam. Can you confirm it’s not visible also in longer distances?
jon_slider
jon_slider's picture
Last seen: 4 hours 38 min ago
agree,
to get rid of the donut, he had to frost the lens, though the photo looks like it was taken before frosting
Very nice modding work, and great photos! Thumbs Up
Artiet59
Last seen: 5 hours 22 min ago
What an awesome build ! Nice work! Love the 21700 host version.
I just picked up my first s3a NW and what I nice host. I did an emitter swap in my first E03 today and it was tough due to the small size but came out good. I was proud of myself and going to post it here until I just saw yours, coincidentally in a similar host LOL. I’ll admire yours and just mention mine . Nice job
Artiet59
I recieved my first e03 this week. Supposed to come in with NW, but accidentally shipped to me in CW. Figured I’d mod it with an extra sst20 high cri. I was surprised when I opened it in and saw a 4040 emitter in the 14mm (?) mcpcb. I should’ve know but I didn’t, so I threw in an extra sst40 5000k I had around. It’s now brighter then all of my newer 14500 lights. Looks great.
Side note- weirdly I think the ui order changed to L-M-H. I’m pretty sure it was M-L-H when I got it. I don’t know why that would’ve happened, but it’s definitely L-M-H. Also, there is a significant difference between the three modes, and originally M and H were so similar I couldn’t distinguish between the two. Anyway, love the light more now.
Original pic- compared to my NW S3a.
Now, compared to the same NW S3a (this pic was taken today, the “original” comparison was taken days ago, at night – hence the different looking cct. The emitter is the same in all of these pics in the S3a on the right)
E03 on turbo vs S3a on turbo (hard to tell, but e03 is brighter now. Again, this pic taken today during daytime)
Thanks for looking, and appreciate any feedback!
Tom E
Tom E's picture
Last seen: 7 hours 19 min ago
EasyB wrote:
I think my issue is resolved. I had a hunch it was a power issue; that the attiny85 was getting voltage spikes or something causing it malfunction. I was bench testing using a power supply and using a battery, but both using relatively long wires. I decided to just put the driver in my headlamp and see what happens, and it seems to be working with no problems yet. I guess the extra inductance of the long wires led to voltage spikes? Similar problems have been observed. https://budgetlightforum.com/comment/908038#comment-908038
After early struggles with huge caps, etc., DEL finally solved the problem properly, first appearing in the Q8 driver, and his own OSHPark drivers --> you really need that 4.7 ohm resistor on Batt+ coming into the 85. We have it before the diode. Everything is happy after that on the scope. All new 85 drivers since 2017 have that resistor. I see it duplicated in all the Chinese Anduril, and custom firmware drivers, even many non-85 drivers.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 30 min ago
Odd. Sounds like it’s needed almost (if not exactly) like a terminating resistor on a transmission line. Current spikes might cause reflections at the end of the line, screwing with the voltage the little beastie sees.
NeutralFan
There definitely aren’t any donut holes at any distance. The frosted lens takes care of it remarkably.
Here’s where I tested just to see if I got lucky with this reflector, but the donut hole still appeared.
Here are the frosted lenses and a pic to check to make sure the reflector is centered.
NeutralFan
Thanks Artiet59. And nice job on your emitter swap!
EasyB
Last seen: 4 hours 39 min ago
Tom E wrote:
After early struggles with huge caps, etc., DEL finally solved the problem properly, first appearing in the Q8 driver, and his own OSHPark drivers —> you really need that 4.7 ohm resistor on Batt+ coming into the 85. We have it before the diode. Everything is happy after that on the scope. All new 85 drivers since 2017 have that resistor. I see it duplicated in all the Chinese Anduril, and custom firmware drivers, even many non-85 drivers.
I have the 4.7ohm resistor with capacitors layed out the same as the D4 driver and still saw that behavior. But I’m not sure what the capacitor values are and the physical positioning of the components on my driver is different so maybe it is not suppressing the spikes as well.
Tom E
Tom E's picture
That's strange. The resistor has been the single thing to make the big difference. Looking at the Lumintop EDC18 driver (same design as the FW3A) last night. I noticed 3 caps of 3 different sizes to ground - this is a common for reducing spikes. The one cap, we use across the MCU V+ and V- should be as close as possible to the pins - I know DEL emphasized that, posted here:
https://budgetlightforum.com/comment/949338#comment-949338
This refers to C2,  the 0.1 uF cap, schematic:
A lot is explained in DEL's driver thread's OP here: https://budgetlightforum.com/node/52397
g_damian
g_damian's picture
Last seen: 12 hours 25 min ago
C8F 21700 + D4v2 driver + dedomed dogfarts Smile
Depending on battery max current draw is between 8A and 12A.
Reflector of 21700 version seems to be worse than 18650 version, there are some faint rings (visible only on white wall):
It does not look a lot bigger than 18650 brother but it feels more chunky because of diameter and tube texture:
Difference in tint is obvious:
Work in progress pics:
Button leds are connected to red channel:
D4v2 driver was 1mm too wide, so almost drop in replacement Wink And the main feautre – flashing pads!
Here is the test with old 30Q and temperature limit set to 50C. Turbo lasts over 4 minutes. It stabilizes around 2A:
Album with all pictures
I managed to modify configuration so lighted button works, dim in first 4 levels, can be configured dim or bright in lockout mode. hwdef-Emisar_D4v2_c8f.h and cfg-emisar-d4v2-c8f.h
EasyB
Tom E wrote:
That’s strange. The resistor has been the single thing to make the big difference. Looking at the Lumintop EDC18 driver (same design as the FW3A) last night. I noticed 3 caps of 3 different sizes to ground – this is a common for reducing spikes. The one cap, we use across the MCU V+ and V- should be as close as possible to the pins – I know DEL emphasized that, posted here:
A lot is explained in DEL’s driver thread’s OP here: https://budgetlightforum.com/node/52397
Thanks. My attiny85 on qlite mod had mostly been working fine, but there were a couple instances of strange behavior where I had to disconnect the battery for awhile to let it “reset”.
Here is how I made the circuit to emulate the D4 driver.
That C1 is in the same position as the C2 in your diagram; it’s connected right to pin 8. But I found that it is a 10uF instead of the 0.1uF that is recommended. So that could have contributed to the bad behavior; it would not filter the spikes as well. I switched it out for a 0.1uF and hopefully it fixed it. I cannot reliably reproduce the bad behavior so it’s hard to tell for sure if it’s fixed. If I still see problems I will increase the R5 resistor to 10ohms.
Quadrupel
Quadrupel's picture
Last seen: 12 min 51 sec ago
C1 and C2 is in parallel, so i removed in my drivers 10uf as useless
EasyB
I’m no expert, but from my reading, putting different capacitors in parallel can be useful for decoupling. They act at different frequency ranges.
https://techweb.rohm.com/knowledge/emc/s-emc/03-s-emc/7669
Quadrupel
Quadrupel's picture
Im using like this for E-switch
DDm-DEL
Its kind off snuber .Best way is to connect oscilloscope to see real picture.
And if you have no fet in circuit so i think you dont need that snubber at all
EasyB
I don’t have an oscilloscope so unfortunately I can’t see exactly what’s going on. I was seeing lots of bad behavior when I was testing on the bench with longer wires. Then it got much better when I put it in the light. So it made me think it was a voltage spike issue. But yes, it is only 8×7135 driver so I’m not sure what’s going on.
Artiet59
There are some awesome mods on here, very inspiring stuff.
Im back with some more LED swaps..
1. Installed a CULPM1 in my Copper Noctigon KR1 – amazing emitter for this light, doesn’t get hot because of heavy copper.
2. Installed a xhp50.2 in my Aluminum Noctigon KR1 – great all purpose light, lumens must be around 3,000.
3. Installed a Osram CSLPM1 Green emitter in my Astrolux C8 – WOW! thats a lot of green, must throw 800 meters too, with a lot of spill.
will upload pics asap.
Crossover Cable
Last seen: 1 month 1 week ago
Yesterday I was going through my ewaste trying to salvage parts to make a flashlight test board for firmware and reflector/optic testing. And then I got sidetracked by a discovery.
It turns out those harbor freight $1 on sale flashlights use Omten 1217 clones, meaning I was able to repair the tailswitch of my old Lux Pro flashlight today instead of trying to get Fasttech to reship an order seemingly lost during CNY and finally getting the switch who knows when.
As for the test board, I have everything but the 18650 holder already, so I’ll have to post pics once I get a holder in and get it fully assembled.
Skylight
Skylight's picture
Last seen: 10 hours 27 min ago
I modified a green Sofirn C8F with three 6V XHP50.2 5000K 90CRI and the XHP70 boost driver of the Convoy M21C-U.
I had to drill the holes of the reflector to 8mm diameter and cover the back with Kapton Tape. The retaining ring was filed on the inside to not touch the outer parts on the driver.
The driver needed some filing as well to fit. I covered the outer parts with white thermal glue to prevent shorts.
At the moment I can use only 18650 batteries because the brass button crushes the top of 21700 cells. I will replace it with a shorter button or a spring. The leds are slightly off center. I may add centering rings as they risk accidental dedoming if I turn the bezel.
The M21C-U driver allows soldering switch leds as well. With the green leds it looks almost like the original C8F. The beam is a nice neutral white and even a bit rosy. The tint shift is not too disturbing. I really like the flashlight this way. The low mode is a bit bright and the ramping is irregular but I got enough Anduril flashlights for that.
MoreLumens
Nice C8F. Those big fat XHP50’s looks so good in it. Thumbs Up
