What did you mod today?
10051 posts / 0 new
NeutralFan
NeutralFan's picture
Last seen: 1 day 2 hours ago
I have the 219B sw30 D180 and sw35 D200 LEDs from azhu. They are very nice!
And I also got my sw45k D200 from Bob McBob. Agreed, highly recommended.
Have you tried the sw40 D200 from Illumn? I have them in a quad Convoy M2 and I think it’s probably my favorite CCT/tint of all my flashlights. Love
I’d rather use my flashlight around the house than turn on the lights.
jon_slider
jon_slider's picture
Last seen: 4 hours 57 min ago
NeutralFan wrote:
Have you tried the sw40 D200… it’s probably my favorite CCT/tint of all my flashlights. Love
congrats on finding love Wink
I had not tried the D200 sw40, I have a D220 sw40 and I wish is was more pink.. Thanks for the tip! Thumbs Up
I do have sw35 D200 from azhu, but it is not a favorite.. “too green”.. lol
WTB Novatac Pocket Clip
NeutralFan
If you want a nice rosy 3500K, try the Nichia E17A SM353 from Eurekatronix (Virence).
Here’s the sw35 D200 on the left vs the quad SM353 on the right:
jon_slider
thank you for the comparison photo,
that E17a 3500k looks very nice,
I had not seen it before
and the tint looks nice for my pink preferences
what light is that in.. curious about the optic
NeutralFan
They’re in a pink S2+ host with a frosted lens. Here are some pics:
jon_slider
NeutralFan wrote:
They’re in a pink S2+ host.. with a frosted lens.
great photos
looks very nice..
is there an Anduril driver option? Wink
NeutralFan
I’m just using a Convoy driver. The safe max current for these quad E17A LEDs is 4 amps.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 34 min ago
Nice mod NeutralFan! And always clean Love
Hum, to help answering jon_slider’s question about Anduril driver, would I be wrong saying that: to use a driver with that firmware in a Convoy S2+, it would need some major mods (inner tubes, eventual pill adapting, different switch, ….) to make it work, and that to use this kind of driver (FET) with those leds, it would need some “throttling” to maintain the max current on/under 4A?
Thanks for showing again Thumbs Up
thefreeman
thefreeman's picture
Last seen: 6 hours 54 min ago
Hum, to help answering jon_slider’s question about Anduril driver, would I be wrong saying that: to use a driver with that firmware in a Convoy S2+, it would need some major mods (inner tubes, eventual pill adapting, different switch, ….) to make it work, and that to use this kind o Silly f driver (FET) with those leds, it would need some “throttling” to maintain the max current on/under 4A?
Or a piston drive Silly , which I assume isn’t much simpler to achieve Big Smile .
Anduril isn’t limited to FETs (which indeed would burn the E21As E17As) 7135s can be used for constant current, also linear FET or buck/boost.
Mike C’s B17 clicky boost driver would be more suitable, while not Anduril I imagine his UI will be much more advanced and configurable than Convoy’s, it is also much more efficient, with proper moonlight, regulation for the full battery etc… a very nice upgrade for an S2 and compatible with quad E21A/17A since those can be configured as 3, 6 or 12V.
Nice mod indeed NeutralFan.
MascaratumB
Anduril isn’t limited to FETs (which indeed would burn the E21As) 7135s can be used for constant current, also linear FET or buck/boost.
Thanks for the correction and further information thefreeman Wink
I wasn’t considering MikeC’s driver as it is not “comercialized” as other drivers with Anduril, but it is too an option for mechanical “clicky” flashlights!
A piston driver such would also imply some modding too so I guess that it would be no different from the e-switch in terms of work! Silly
contactcr
Last seen: 11 hours 14 min ago
One of my favorite lights in my collection that I will never part with got a new shorter tube to try on.
Quite awkward to hold with 18350 but I had to see. Thorfire C8S Switch, Convoy 18350 C8 tube, kiriba-ru heatsink head + his mods and spacer to turn it into ANNA-6 (not pictured), SS bezel ground down by kiriba-ru as well. It legos, not as smooth as the Thorfire tube but it works.
NeutralFan
Wouldn’t it be great to get a constant current driver with Anduril and limit it to the current you specify?
With my E17A flashlights, I’m using a Convoy Driver for SST40 ,12groups which maxes out at either 5 or 6 amps depending on the size. I then set it to group 8 which limits the current to 50%, so either 2.5 or 3 amps.
Ideally it would be nice to go up to 4 amps, but with the 4 modes up to 50%, I’m very happy with the driver and the flashlights get plenty bright. The 0.1% moonlight mode is very low and the driver accommodates a lighted tail switch without a bleeder resistor, which is also very nice.
g_damian
g_damian's picture
Last seen: 6 hours 43 min ago
It’s possible to specify current limit, but requires rebuild and reflash. Here’s an example of 2A configuration: https://budgetlightforum.com/comment/1704396#comment-1704396
thefreeman
If you change the 10mΩ (R010) resistor to 15mΩ on the 6A Convoy driver you’ll get 4A. On a constant current Anduril driver that uses a current sense resistor like lume1 or noctigon for comercially available ones, current can be changed the same way, or like G_damian mentionned by modifiying the ramp.
id30209
id30209's picture
Last seen: 13 hours 10 min ago
I have swapped emitters in my FWAA.
Now running Osram CSLNM1.TG
WTB Titanium 4sevens 2xAA tube
PeyoX
PeyoX's picture
Last seen: 7 min 27 sec ago
Recently I bought some 5A/6A Convoy drivers (17mm/20mm simple 4 mode and the 12 groups). They installed single R020 instead of the older ones with R010, I don’t know if another parts might changed too, but it still managed pulling 5-6A at the tail. So you need to make sure before changing the resistor.
Limited English, still working on it.
jon_slider
great photos
great improvement in throw
congrats Thumbs Up
JaredM
JaredM's picture
Last seen: 1 hour 12 min ago
If Osram could just move down to 4500K… NM1s make a great EDC beam in triples.
id30209
id30209's picture
jon_slider wrote:
 great photos great improvement in throw congrats :THUMBS-UP:
Thx Jon!
id30209
id30209's picture
JaredM wrote:
If Osram could just move down to 4500K... NM1s make a great EDC beam in triples.
Oh i agree
NeutralFan
Mine also have the R020 resistors. So it appears changing the resistor (like to R030) with these newer drivers won’t reduce the max current?
thefreeman
No you can :
Vsense = R * I
Vsense = Rnew * Inew
Rnew = R * I/Inew
As you said Rnew = 30 mΩ for Inew = 4A if I = 6A.
NeutralFan
That seems way too complicated to me. Crying
I’m fine with just having the Convoy SST40 drivers max out at 50% for my E17As.
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 hours 14 min ago
I reprogrammed the tail in my v11r. Due to the slow pwm it screwed with the camera and i couldn’t get an accurate video representation. In person it looks like a burning ember (kind of a sped up candle flicker)
Geuzzz
Geuzzz's picture
Last seen: 53 min 6 sec ago
!{width:30%}https://lh3.googleusercontent.com/pw/ACtC-3eL-qCQwlIxN-0NbPGfebtbEvsnUr5...!
Very nice. What clip do you have on your v11r?
pinkpanda3310
It’s an mcbrat clip. Some clearer pics here
Sari33
Last seen: 20 hours 41 min ago
What better and fast method to make the surface of the shelf lapping and remove those residual steps?
I thought first file the edges of the pill (2mm height of material) and then get to the shelf with fine sandpaper
djozz
djozz's picture
Last seen: 7 hours 25 min ago
I never found an easy and good way to lap a surface inside a cavity, just tedious imperfect ways. But on some occasions when that was no problem I have indeed removed the entire edge of a pill, then it is easy to make a perfect surface.
pinkpanda3310
Looks like that pill screws in from the front of the torch. So it relies on the ‘lip’ to stop the pill screwing in too far.
So long as you don’t completely remove that lip or the tweezer holes, it’ll be easiest to cut back the edges like you mentioned.
andrx
andrx's picture
Last seen: 8 hours 51 min ago
