What did you mod today?
10052 posts / 0 new
Sari33
Last seen: 4 days 19 hours ago
Yes,pill it’s from old C8 with glued 16mm Led…that I would mod with 3A driver + SST20 or 5A XP-G2.
At least the shelf is not concave,but have machine marks and lacks screws that hold mcpcb.
I’m afraid that the pressure of the plastic reflector isn’t enought for heat transfert,
I have also a spare Alu reflector,but it will require a 20mm mcpcb to avoid short circuit and enlarge holes cables
andrx
andrx's picture
Last seen: 7 hours 21 min ago
in this flashlight i have a SST40 driver 5000 Ma and a XHP50.2 3v and no reflactor because it’s a zoomie, no heat problem
contactcr
Last seen: 3 hours 8 min ago
andrx wrote:
Sari33 wrote:
Yes,pill it’s from old C8 with glued 16mm Led…that I would mod with 3A driver + SST20 or 5A XP-G2. At least the shelf is not concave,but have machine marks and lacks screws that hold mcpcb. I’m afraid that the pressure of the plastic reflector isn’t enought for heat transfert, I have also a spare Alu reflector,but it will require a 20mm mcpcb to avoid short circuit and enlarge holes cables
Zoomie’s usually have screwed down mcpcb and/or a threaded shroud over the pill that presses on the centering ring/mcpcb. These things serve the same purpose as bezel pressing down on reflector/mcpcb.
pinkpanda3310
pinkpanda3310's picture
Last seen: 4 days 1 hour ago
Added some glow … sorry ‘turbo glow’ to the fwaa tonight. (apparently you can’t just say glow anymore, it has to be turbo Wink )
andrx
andrx's picture
yes i know, for me works without any
MascaratumB
MascaratumB's picture
Last seen: 3 hours 23 min ago
Cool! Cool May I ask where did you get it or how did you do it?
pinkpanda3310
It’s not that hard. Just a bit of glow tape stuck to the inner circumference of the head Crown
MascaratumB
AHHH! Big Smile The same kind I normally do Silly
I just thought it was a “triple” glow gasket and was wondering if they were for sale out there!
I need to order some more GITD tape so I can “turbo glow” it Wink
Sunnysunsun
Sunnysunsun's picture
Last seen: 50 min 46 sec ago
I added a red channel for someone to their FW3T. It’s running Anduril 2 with the stepped ramp replaced with a smooth red ramp.
I think someone has done this before to an FW3A. I recall seeing something similar a long time ago but can’t find the post.
MtnDon
MtnDon's picture
Last seen: 2 hours 38 min ago
Thumbs Up
contactcr
No details? What red LED? Is the red on 1×7135 like similar builds? How difficult was editing firmware to make two smooth ramps? No MCPCB pics? Smile
Sunnysunsun
Fair, I forgot to take photos for a lot of the process.
It’s a sst-20-dr 660nm because it’s what I could get with 1 day shipping from digikey. The footprint of the sst-20-dr seems to be only available in the B120 version which isn’t our usual 3535 footprint but has smaller pads. I only noticed after the LED wasn’t bouncing during the reflow like the other sst-20s. It’s not an issue with just the 350mA from the 1×7135 that’s powering it.
I cut the traces from the bank of 7135s and was originally feeding the red led 7×7135s but the dimmest mode was too bright so I removed 6 of them.
There was also a leaky 7135 or two on the board since the red led was dimly illuminated even when the light was off but the battery was connected. Removing 6 of the 7135s helped stop the leaking and helped make the lowest red mode dimmer than the white and the red led is still really bright with just a single 7135.
I did this mod for someone who is a pilot instructor and they wanted a red light to stop them from being blinded when flying across open water in the darkness so I made all the changes to anduril with not blinding them in mind. The light switches between the red and white modes with a triple click, and always starts on low when the modes are switched. I also added a shortcut to the red mode while the user is in the white mode.
I’m not familiar with C or anduril 2 so it was hours of trial and error, changing one value then flashing it and seeing if it was the right parameter until everything was perfect.
jon_slider
jon_slider's picture
Last seen: 1 min 46 sec ago
Sunnysunsun wrote:
I did this mod for someone who is a pilot instructor and they wanted a red light to stop them from being blinded when flying across open water in the darkness… The light switches between the red and white modes with a triple click, and always starts on low
Thumbs Up
nice work!
WTB Novatac Pocket Clip
Sunnysunsun
The guy I modified it for really liked it which was a good feeling after the hours of work I put into perfecting it. Big Smile
jon_slider
Excellent FW3P Beer
make more, you will soon be rich and famous Crown
BOO5TED
BOO5TED's picture
Last seen: 1 hour 51 min ago
Any beam shots of the dual emitter? Curious how/if it changed the beam.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
contactcr
It’s still quite round and nice. I have a video with similar setup somewhere in this thread
g_damian
g_damian's picture
Last seen: 7 hours 20 min ago
Convoy C6
Of course it’s just plain old C8 with an aluminum spacer
Leds are the mix of 3000K and 5000K Luxeon V2.
The led4power’s 6A driver in DD mode gives 8.5A on tail, so I’m guessing around 3000lm.
The build process:
I don’t know if it’s the case of an old type C8 host, but mine shorted leds wires, so I had to isolate the screw:
… and also the fully tightened bezel gave me this:
Tint comparision between K9.3 SST-20 4000K (left) and C6 (right):
Album with all pictures
thefreeman
thefreeman's picture
Last seen: 17 min 26 sec ago
Nice, what optic is that ?
JaredM
JaredM's picture
Last seen: 1 hour 41 min ago
Ledil Anna 40-6
thefreeman
Thanks JaredM.
flightless22
flightless22's picture
Cheap eBay microscope got an upgrade
The little coin cells finally died but instead of replacing them I replace the whole thing with a QX5252 circuit that is powered by a single AAA battery. The cool white emitter has also been replaced with 4000k rngwn 5mm
flightless22
g_damian wrote:
Ouch. Did the optic survive that?
NeutralFan
NeutralFan's picture
Last seen: 2 days 3 hours ago
Ouch! It seems every mod has its own challenges, but glad you figured it out.
I’d rather use my flashlight around the house than turn on the lights.
jon_slider
this:
contactcr wrote:
FW3A w/ 1x Osram Red Flat (as secondary) and 2x Samsung LH351D (as primary) flashed with Anduril 2
FW3Pilot
g_damian
g_damian's picture
flightless22 wrote:
Yes, it did. I was surprised how heavy anna optic is in comparison with carclo quad.
BOO5TED
BOO5TED's picture
jon_slider wrote:
this:
FW3Pilot
Awesome, thanks.
jon_slider
BOO5TED wrote:
thanks.
Im glad you asked.. I also wondered
the video shows the beam is still very nice…
Impressed I am. Thumbs Up
BOO5TED
BOO5TED's picture
jon_slider wrote:
BOO5TED wrote:
thanks.
Agreed.
MascaratumB
My Sanremu knives!
I bough 2 “spyderco-like” pocket clips and some screws/rivets and finally gave them deep carry clips Cool
