What did you mod today?
10923 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 1 hour 48 min ago
Tinkered with my TCR-01 last weekend.
  • Swapped OP reflector for a TIR. I used a TIR reflector from a DQG Tiny III. I had to file down the upper edges of the TIR to get it to fit. The beam has a few rings and is uglier, but the central hotspot appears more intense so throw is probably improved. Also the spill just gradually fades out. No sharp ring where the spill just ends like with the reflector. This should also be more durable than stock since there is no glass lens to shatter. I may well revert to the OP reflector for the smoother beam profile, but for now I’ll try this TIR.
  • Replaced the clip with a modified Convoy clip. Clip length is now just below the control ring. The new clip’s color matches the polished Ti light better than the steel or brushed Titanium Jetbeam clips. And it is thicker and feels more secure. It is longer than the short Jetbeam clip, but shorter than the long Jetbeam clip.
KyleGates
Last seen: 7 hours 34 min ago
jon_slider wrote:
> Does anybody know where I can find a decent 3535 Green LED
XP-E2 Green
These are what I used in my green S2+ build
https://www.ledsupply.com/leds/cree-xlamp-xp-e2-color-high-power-led-star
Lotus_Darkrose
Last seen: 1 hour 38 min ago
I had already posted these on BLF back in 2015, but that was before this thread was started and I still use both of these lights regularly.
3x XP-L SpiderFire C2
https://budgetlightforum.com/comment/804024#comment-804024
Coast HP1 3x Nichia 219C – Original mod had an older type of Samsung LED and I upgraded it some time after this thread.
https://budgetlightforum.com/node/39948
I’m currently working on a few lights, including swapping out the XP-L HI in my Sunwayman V10R for a 219B sw45k, and swapping out the 4x XP-L HI in my Emisar D4 for 4x LH351D 5000k.
Firelight2
Replaced the glass lens in my Acebeam TK17 Ti with a UCL acrylic lens.
I found it a little strange that a light that looks like it is built like a tank had a 20mm glass lens that was just 1mm thick. Seemed very fragile. I chose a UCL acrylic lens as I knew I could file down the edges so it would fit in the available space while being a lot more resistant to impacts.
I lucked out with my order from Flashlightlens.com too. I ordered 2 lenses, but they sent me 4. Cool
Incidentally, the only other flashlight manufacturer that I know of who uses 1mm thick glass lenses in anything larger than the tiniest keychain light is Zebralight.
Rayoui
Rayoui's picture
Last seen: 17 min 4 sec ago
ArtieT59 wrote:
also, I wonder if mouser still has that bin? I have come to understand that (I think) 5d-1 abd 5d-4 are the nicest tinted xpl-hi 4000k (rosiest I mean, also maybe cooler than) while 5d2 and 5d3 are more yellow, and warmer.
same with 5a.
habk recently had told me in an email he has (had?) 5d2… yellowish I can confirm.
the Nicest xpl-hi 5d I ever got was from Hank this past February, Perfect rosiness. By the time I got the light, I ordered another with the same xpl-hi and they were yellow. The buns obviously change often. Or hIs do.
I got some pretty nice ones in my dt8 and bare ones for my E07x from Hank this July.
both of which I didn’t know to ask if it were 5d1, 5d2, 5d3, 5d4. ..
does mouser distinguish which it has like this? Thanks!
Mouser doesn’t differentiate tint bin codes, just Mfr part numbers. It’s luck of the draw. The ones I ordered were XPLAWT-H0-0000-000BV20E5 (highest flux bin; 70 CRI min).
jon_slider wrote:
Im finding it very useful.. here is one example, that shows me the Tint DUV of 219b 3500k, which I have always found lacking in pinkness.. now I have a number to show that the Tint DUV is not below the BBL, and it all makes better sense:
The sw35 in my Bob McBob SC64c is quite pink.
CCT: 3500K | Ra: 97 | R9: 94 | Duv: -0.003
Getkong
Last seen: 2 weeks 5 days ago
flashed fw1a, 2x fw3a with my fork of anduril 2, and reflowed from xpl hi 6500k -> 219c 5000k in fw1a, and 219c 4000k -> 219b sw45k in fw3t.
djozz
djozz's picture
Last seen: 1 hour 8 min ago
I modded my heat block today because it broke.
4.5 years ago I made a tiny heat block for reflowing leds and driver boards, from a block of aluminium, two cheap heating elements meant for 3D-printers and banana plug connectors to power it from a power supply. I posted about it here. It looked nice back then:
It has served me extremely well but after 4.5 years and countless refows, the wood has burned and recently has cracked. And I already was not happy that it was so tiny and instable that it was permanently clamped into a vice to be usable. So I disassembled the parts and made a new housing for the heat block. Here is what is leftover from the wooden housing:
And here is the new housing.
It has quite some improvements over the old version. 1) it can be used without the vice, 2) the wood is thermally further away from the heat block, so it will not likely char/disintegrate, 3) the block is mounted sturdier overall, 4) it provides some working-surface directly next to the block, to prepare and cool off the ledboards, that was really missing in the previous version.
It appears that I can use the same power supply setting as before, i.e. my standard 2.8 A for reflows (~18W) still gives around 200 degC in steady state. Apparently the heat loss speed in this new housing has not much changed.
This will work for many years to come Smile
Firelight2
That looks great Djozz.
Much better than my setup. Whenever I want to do a reflow I stick a wooden clothespin in my adjustible mini-vise. I use the clothespin to hold the side of the star.
I use my left hand to hold the heat gun from my reflow station underneath the star blowing upward. I use tweezers in my right hand to manipulate the LEDs.
My setup may not be professional, but it is fast. I can heat up and reflow stars in 30 seconds to 1 minute with no need to preheat anything.
Scallywag
Scallywag's picture
Last seen: 9 hours 7 min ago
I use my left hand to the heat gun from my reflow station underneath the star blowing upward. I use tweezers in my right hand to manipulate the LEDs.
I’ve seen it done with candles or BIC lighters. I’ve done it like you once but I use my hotplate every time now. It’s just too easy. If I can come up with a way to do something with the hotplate instead of hot air or iron I’ll always choose that method.
It has quite some improvements over the old version. 1) it can be used without the vice, 2) the wood is thermally further away from the heat block, so it will not likely char/disintegrate, 3) the block is mounted sturdier overall, 4) it provides some workspace directly next to the block, to prepare and cool off the ledboards, that was really missing in the previous version.
Looks great! If I made such a homegrown solution I’d probably ruin the beautiful simplicity by trying to add a thermostat or at least a temperature readout.
Lightbringer
Lightbringer's picture
Last seen: 2 min 36 sec ago
Absolutely!
djozz
djozz's picture
Before I had my block I did reflows with a small blowtorch under the board, worked like a charm, but using the heat block it feels good that the led never exceeds specified reflow temperatures. And having two hands free during reflows is always handy.
I have all the stuff in house to make a version with thermostat and tempeature read-out, but I just can’t be bothered building it. If I need to reflow a led, I go for 2.8A, if I need a bit hotter (for led testing I place the ledboard on a small aluminium plate and put them together on the hotplate so that the temperature rise is more gradual, more according to the reflow specs. This requires a bit hotter heat block) I go for 3A. I monitor with the infrared thermometer.
JaredM
JaredM's picture
Last seen: 2 hours 36 min ago
Sounds like you should make a little mount to hold the IR gun hands free Smile
Looks great though. I love this kind of stuff
https://fundrazr.com/osturaband
No affiliation, just a fan.
Haukkeli
Last seen: 21 min 23 sec ago
I built Convoy L6 quad with 4 XHP70.2’s and fet driver. Reflector and leds are from Kaidomain. Driver nd switch from MTN Electronics. I made aluminium spacer for 4 20mm mcpcb’s. It took lot’s of measuring and patience to get everything to fit together. Finally it’s done to be never used. Big Smile
Rdubya18
Rdubya18's picture
Last seen: 4 days 23 min ago
It looks good and I got a chuckle from your honesty . Wink
djozz
djozz's picture
Very nice work haukkeli! That must generate a serious amount of light!
Haukkeli
Here is the reflector if some else wants to build similar. Spacer is from 50mm round stock. I machined grooves for pcb’s for easier assembly and made the spacer so that it gradually narrows towards the original shelf. I also bolted the spacer to reflector with leds in between, so that I could drop the whole package in. Cable management was the most difficult part of this project.
Haukkeli
I haven’t actually tried it outside yet. Seem’s to be bright. Batteries are the limiting factor. Enerqic 5200mAh with 18A continuos discharge.
Lotus_Darkrose
Nice work, Haukkeli!
Last night I successfully swapped a 219b SW45k into my Sunwayman V10R. I like it better than the cool white XP-L HI that was in there, and is still plenty bright. The low now goes down so far, I have to look at the LED to tell that it’s on.
Lotus_Darkrose
Today, I swapped emitters in the Drop Blue Titanium AAA I received a couple days ago in the mail, which unfortunately wasn’t the 219C version. The XP-G3 it came with was one of the worst tints ever. Now it has a 219C 4000k and is much more useful. Head was glued so heated it up with a torch first and it loosened up.
NeutralFan
NeutralFan's picture
Last seen: 6 hours 2 min ago
Looks good Lotus_Darkrose. Where did you get the 219C 4500K from?
I’d rather use my flashlight around the house than turn on the lights.
Lotus_Darkrose
Thanks, and good catch, lol. It’s actually 4000k, just edited my post. It’s from mtnelectronics.com, I bought several.
I also worked on a few more flashlights today. I swapped in a 219C 4000k into a AAA Coast G22 flashlight, and added a diffuser as the reflector had an ugly beam.
I had a SS SingFire 14500 flashlight laying around, and also put a 219C 4000k into that, along with a 45 degree TIR.
NeutralFan
Ahh bummer. I was hoping there was a 4500K 219C out there for my next flashlight mod that I wasn’t aware of.
gchart
gchart's picture
Last seen: 4 hours 54 min ago
LED swap in a Skilhunt H300. Previous LED was cold white and low CRI. Used an XHP50.3 4000K 90 CRI from Digikey. DUV is a little positive (slightly green) but overall much nicer.
The stainless bezel had little divots, but I couldn’t get it unscrewed using normal tools so I designed and 3D printed a tool to remove it. Worked perfectly! Big Smile
Note: picture was taken before the swap
Calculated DUV: +0.0069
Rdubya18
Rdubya18's picture
Wow great thinking !
JaredM
JaredM's picture
Awesome! So these are 12V configuration?
gchart
gchart's picture
I would guess they’re 6V, but the 6V/12V LEDs are the same I believe, it’s just a difference in which pads the MCPCB uses.
Firelight2
Attempted to fix my Eagletac DX3B mini.
Nice handy little light, but mine had some flaws:
  • Gigantic parasitic drain. So much so that I suspect the light was defective. It would actually drain a full 18350 in less than 24 hours while off. This is pretty gamebreaking, because the only way to avoid it is to do a tailcap lockout, which I hate doing.
  • Charging port hatch cover is poorly designed. It sticks out, is flimsy, and doesn’t lock into place securely. Not a big issue since the cover is optional. The port itself is waterproof according to Eagletac so the cover is just there to keep lint out.
I noticed that current flowed between the positive and negative pads on the bottom of the driver when the head was not connected to power. I got around 400 ohms resistance, which seemed high.
I managed to remove the driver, but in doing so I ripped off the 3 tiny wires for the charging port. Oops! Even worse, they were so tiny that even after spending 15 minutes with a magnifying glass I could only find one of the bondpads that they were attached to. I ended up permanently disabling the charging port by clipping off its wires.
This light was a royal pain to reassemble. I have no idea how they managed to assemble the thing at the factory. The plastic jacket that sits inside the rubber switch presses so firmly against the switch on the driver board, I was barely able to get it in even after filing the corners down.
Without the charging port attached, resistance between the positive and negative pads on the bottom of the driver jumped to 685,000 ohms. Hopefully, this means less parasitic drain. My cheap mini DMM doesn’t measure current so I’ll stick a cell inside tonight and see what the charge looks like tomorrow.
Guess I’ll also epoxy over the charging port since it’s no longer functional.
luminarium iaculator
luminarium iaculator's picture
Last seen: 3 days 20 hours ago
djozz wrote:
Before I had my block I did reflows with a small blowtorch under the board, worked like a charm, but using the heat block it feels good that the led never exceeds specified reflow temperatures. And having two hands free during reflows is always handy. I have all the stuff in house to make a version with thermostat and tempeature read-out, but I just can’t be bothered building it. If I need to reflow a led, I go for 2.8A, if I need a bit hotter (for led testing I place the ledboard on a small aluminium plate and put them together on the hotplate so that the temperature rise is more gradual, more according to the reflow specs. This requires a bit hotter heat block) I go for 3A. I monitor with the infrared thermometer.
I like it but I would like it better if it could have proper MCPCB fixation. I mean is it possible to have absolutely firm MCPCB with some kind of magnet or other type of fixation?
Yes 2 hands are better than one but only if mcpcb is fixated… If mcpcb is wandering around on touch(emitter centering, final tap press) it is still better to do Old Lumens method with small benchvise and big soldering iron tip beneath mcpcb (regulation over soldering Iron station is possible).
But I would like your system better only if there is possibility of MCPCB fixation. Because we don’t actually have 2 free arms if I got to hold MCPCB with one hand and then centering with other (for emitter centering and final tap or press)?
Firelight2
A magnet would not work as copper stars are non magnetic. You would need some kind of clamp or screws.
Yes you are right! I would like Djozz system but with any kind of MCPCB fixation method.
