What did you mod today?
11500 posts / 0 new
smurcod
Last seen: 7 hours 6 min ago
Yokiamy wrote:
smurcod wrote:
Modded a KDIY K12 SST20 4000k CRI95 to accept a 20mm LED PCB with a LH351D 5700k CRI90. Not a planned mod, I stuffed up the LH351D order and it was the only flashlight I wasn’t satisfied with that I could fit the 20mm board in… Stock size is 16mm, I filed down the 16mm recess on the brass pill until the surface was flat and elongated the holes for the wiring from the driver. That allows the 20mm board to fit.
It’s looking really promising- a more neutral colour, brighter and more spread. I’ll try it outside tonight.
FYI the KDIY was easy to pull apart- nothing glued. Even the LED board had grease rather than adhesive. http://kaidomain.com/KDIY-K12-SST-20-1000-Lumens-LED-Flashlight
Update- it was well worth the effort. Same driver, but the LH351D has more spread and more throw than the SST20. That was probably my first and last SST20.
Stock pill 16mm SST20 400k CRI95
Pill recess for 16mm driver removed, holes for driver wires elongated to clear 20mm LED PCB
20mm LH351D 5700k CRI 90 LED fitted
!http://www.users.on.net/~murcod/flashlights/KDIY_K12_20mm_LH351D5700k90C...!
Why did you file down the pill, couldn’t you use a 16mm mcpcb instead ?
I made a mistake with the order- I meant to order the 16mm size for a different flashlight. The K12 had a 4000k SST20 in it (that I wasn’t impressed by) and it was the only flashlight the 20mm LED could be fitted into. It worked out well in the end- better colour temp, more spread and throw- using the same driver.
Getting LEDs , drivers etc. in Australia is frustrating and involves long wait of over 4 weeks. Plus the Aus $ isn’t fairing well against the US $.
djozz
djozz's picture
Last seen: 10 hours 30 min ago
I’m still in my flashlight modding sabattical, but I did mod another knife today.
I inherited my mother’s spinach chopping knife, with which she has been making spinach for more than 40 years. She also used it for cutting out the weeds between the grass in the back garden.
The state of the knife was better than it looks, the wooden handles had rotten/broken so they are gone, not sure what happened to the pins, and under the handles some deep pits had rusted in, but the blade is in good shape and so is the side of the handle section. And it is still dead straight.
So I made a new french oak handle for it.
I started this weeks ago, and bought some brass screws on aliexpress, that came in today. The screws are 4mm diameter so I had to ream the holes in the knife with a 4mm drill. The hole most to the back was easy, but the other two were a pain, the steel was almost as hard as the dril bit! They did a good harden job back in the days.
The wood and the tang of the knife were treated with boiled linseed oil to preserve the knife.
It was not a great precision job, the first time I made a knife handle this way, and the screws are a bit larger than I imagined, but it is a working knife again, and the not so great handles fit the old knife well enough I think Smile
I thought of sharpening it again, but I have enough sharp knives so for the moment I keep it this way.
jon_slider
jon_slider's picture
Last seen: 3 hours 1 min ago
very nice handles, and relic knife.. thanks for the pics..
the handles look like they are upside down though…. must be my perspective..
Yokiamy
Yokiamy's picture
Last seen: 1 hour 26 min ago
Looks nice Djozz ! Although they do not look 100% symmetrical in the last pic Cool
I did notice your lower than usual amount of modding posts, but didnt know you have some sort of flashlight sabbatical , any specific reason for the sabbatical ?
supergron
Last seen: 17 hours 33 min ago
i finally learned how to swap emitters in my fraz; tried about 4 in there so far once i figured it out…
djozz
djozz's picture
Not one reason:
*my motivation for the hobby was in part coupled to the lightning fast development of leds from 2011-2018, developments since then are much slower, not much gain anymore. Except for LEP but LEP modules are expensive, are difficult to mod with and are already fairly optimally used in stock lights (not like back then, we made throwers that throwed more than twice as far as any stock light). I may have a go at those though.
*several big developments in the world make me worry, for me worries are not good for hobby.
*our son’s health has been pretty bad for half a year. But he is much better now Smile
jon_slider
My heart goes out to your family, best wishes for your son’s continued recovery.
Yokiamy
Yokiamy's picture
Sorry to hear, dont worry too much Jos, if you need a listening ear, you can always contact me.
Health always goes first, good to hear that his healthyness is improving!
Correllux
Correllux's picture
Last seen: 1 hour 55 min ago
What a nice way to breathe new life into something with such sentimental attachment and a real working history!
You could put a nice high CRI emitter on the front end of that handle, you know…. Smile
DB Custom
DB Custom's picture
Last seen: 3 weeks 1 day ago
… with a pressure switch. Smile
Chop veggies in a dark room, let the kiddo sleep. Wink
contactcr
Last seen: 2 days 18 hours ago
Found a mod I may attempt this winter and thought you may enjoy this one: https://gaggiuino.github.io/
Arduino controlled espresso maker mod. I know we have quite a coffee thread going on here with some connoisseurs.
bobvoeh
bobvoeh's picture
Last seen: 3 hours 11 min ago
I’d like to see how this comes out. I have a Rancilio Silvia that I modded with a PID kit. Been using it every day since 2006, still going strong.
vwpieces
vwpieces's picture
Last seen: 2 hours 39 min ago
Long time… years… since I did anything FL related.
My modded L6 went to a better home a long time ago and while I had the parts I never did make another.
L6 with 70.3 4000K and Mtn Fet+1 D4 ramping. Also made the E-SW light. But still to bright IMO. Kinda quit after 6 resistor swaps. Kept the OP reflector but I do have SMO to try again. Wasn’t happy with last SMO on the stock light.
Took the L6 apart and this was the first thing I found. Emitter shelf has black anno and someone took a grinder to the emitter base surface. GRRR this build just got Longer.
Got it lapped flat after some time…
E-SW still a bit too bright in complete dark
But not that bad in day in daylight.
ML is nice with 4 squares looking even.
Pretty happy with the Spot. Pulls 17A at tailcap for over 15sec till it starts dropping, Old Lii50A black. Haven’t messed with thermals and probably wont.
DB Custom
DB Custom's picture
Nice VWP, the L6 is a very sweet host! I too just put one together, mine is a stubby with a single cell tube from an L2 and utilizing an SFT40 emitter. Richard built the driver, I flashed it with Anduril.
Intended to use an 90.2, 20mm shelf needs to be larger. Not up to doing that at this time hence plan B. Lol
Makes me realize just how much work I used to put into lights!
jon_slider
vwpieces wrote:
Pretty happy with the Spot…
Looks very nice, congrats! Beer
vwpieces
vwpieces's picture
More playing with the L6…
Trying to flash Anduril to the MtnE 30mm Fet+1 tiny85 for 2S config. I tried the “anduril.2021-12-13.emisar-d4.hex” file and could not get it to run full turbo. Was only drawing about 4A with on and 2C. Tried again with “anduril.2020-03-18.emisar-d4.hex” file and got it back to 17A on full turbo.
Was like it wasn’t kicking in the Fet…
Any hints here?
Anyway it seems fine now.
SammysHP
SammysHP's picture
Last seen: 2 min 45 sec ago
Is one Anduril 1 and one Anduril 2? Turbo behavior has changed in Anduril 2. To get turbo, first ramp up to ceiling, then do 2C. It can be changed in the config menu, check the manual.
vwpieces
vwpieces's picture
Hello Sammy, I tried the ramp to top and 2C but there still was no change in brightness. Same files again on another light with another MtnE 17mm Fet+1 tiny85, but this light is a triple running 1S. Flashed it back to the 2020 file and it will run turbo ON and 2C. Same problem on 2 different lights with same files used.
I did check the Anduril2 directory of files and there were none that match these dates. I do see the “Anduril2” files in that folder do not use the “2” in the names but I did not get these from that directory. This Anduril is new to me and thanks for the tips.
Just finished this one today. Old C8F 18650 host. Now has XPL-HI 5000K and the MtnE Fet+1 on Anduril.
More old parts getting used up.
contactcr
padded case takes up too much space, best I could come up with for drawer storage
jon_slider
vwpieces wrote:
Very nice looking beam profile, congrats on your mod.
Thrunite Ti3 Ti Hi Beer
stock:
mod to sw45k:
vwpieces
vwpieces's picture
Thanks Jon, that TI3 is looking pretty sweet now.
Little more thought on my firmware flash after reading all the recent posts on Anduril “issues”. The newer version just might flash to muggle mode with no turbo. But I’m still learning Anduril so I would bet that I am the Issue. Wires on the C8F and the L6 are just barely long enough to get the driver flipped and clipped for flash. Will try again.
Need to ditch the Green SW LED on the C8F anyway… back to the bench.
jon_slider
tickled Pink I am w the Ti3, thanks Beer
hope you make good progress w your mod and Anduril learning curve
happy to brainstorm Anduril Options, PM any time
vwpieces
vwpieces's picture
Thanks for the offer Jon. I tried again on the 2021 file and also tried to to see if it was Muggle mode. I was able to access other functions so I am inclined to think it was not in Muggle mode and NO Turbo once again. 6C, same same… Just went back to the 2020 file I know works.
Went white behind the smoke black button. I like it…
Hand soldering.
djozz
djozz's picture
I modded my BLF LT1 lantern with a new board from Lampman who restarted his business in Norway, much fun, more details here:
https://budgetlightforum.com/comment/1887213#comment-1887213
Marc E
Last seen: 1 week 8 hours ago
The posts i see are about someone’s personal issues with Anduril 2 rather than issues within the firmware.
Anduril 1 had muggle mode, Anduril 2 is quite different and is built around 2 UIs, Simple UI and Advanced UI. Simple UI is a properly performing UI with more functions than muggle mode, possibly including those functions you accessed.
In Anduril 2, if you’re not at the top of the ramp 2C will take you there. Once you’re at the top of the ramp 2C will take you to turbo in Advanced UI, but there is no turbo in the Simple UI so 2C will not change the brightness level from the top of the ramp.
If you’ve just flashed the firmware it will have defaulted to Simple UI (intentionally) which would give you more functions than muggle mode and no turbo, which sounds similar to what you experienced.
Also, 6C is only relevant to Anduril 1, it does not switch between UIs in Anduril 2. (That’s 10H for Simple -> Advanced, and 10C for Advanced -> Simple.)
Is it possible there’s a misunderstanding with how the new firmware functions rather than a fault with the firmware itself?
Here are some UI flow diagrams for Anduril 2:
https://budgetlightforum.com/node/76941
This is a link to the text version of the manual:
https://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
TK’s Anduril 2 thread:
https://budgetlightforum.com/node/73470
jon_slider
good info.. some caveats
1. not all anduril 2 lights default to Simple, some default to Advanced
the way to tell which one youre in, is to do 3C from off.. if the voltage reads out once and turns off, that is Simple Mode. If instead the voltage blinks repeat until switched off, that is Advanced
2. In some Anduril 2 lights, simple mode ceiling is set to 150/150.. iow, the same as if it was on Turbo
3. In advanced, from On, 2C gives ceiling, another 2C will NOT go to Turbo, it drops back to the previous output.. Unless you get into the manual and configure the Turbo Style.. the default way to get to Turbo from On is to Ramp up to ceiling first, and then do 2C to reach Turbo
otoh, from Off, 2C does give Turbo, unless it is disabled, in which case it gives ceiling.
best advice is to Read the Manual Wink
vwpieces
vwpieces's picture
Was a Long night but you both nailed the “problem”. I am new to Anduril let alone Andruil 2. I even went as far as rewiring my clip, reloading USBASP drivers to make sure they were correct before I realised the files were A2. But in my defense the files were Not taken from the A2 directory. Facepalm
Anyway, lessons learned. The L6, C8F triple and 2 original Q8 are now on Andruil 2.
Marc E
Makes sense, if you think it’s Anduril you’d expect it to behave like Anduril. Cool you’re up and running with some nice lights to have it on.
That 17A at the L6 tailcap, is that with one or two batteries?
And you can set turbo for the Simple UI, or you can set the ceiling to turbo level and ramp all the way there and back. Just in case you don’t know.
vwpieces
vwpieces's picture
2S batts. And that was with the ranpingIOS. Haven’t tested it again with Anduril2. Also have not played with the voltage or thermal cal on the L6 since A2 flash.
Thanks for the turbo in simple tip, I would still want it at 2C. Would it still go to turbo at 2C if I set it at the top of the ramp too?
jon_slider
There is no Turbo in Simple, only Ceiling.. and 2C gets you there.. so, if the ceiling is set to 150/150, 2C gets you the ceiling of 150/150=Turbo
top of ramp = turbo
simple goes to top of ramp w 2C.. there is no separate Turbo in Simple
so if you set simple ceiling to 100/150, then thats all you get from 2C in Simple..
otoh advanced has an independent Turbo.. available in addition to whatever ceiling is.. but Turbo still equals top of ramp, IF ceiling is set to 150/150, then Turbo will look exactly the same
there are now 4 turbo styles.. look in the manual for the section that says:
“Item 4: Configure Advanced UI’s turbo style”
