What did you mod today?
10619 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 week 2 days ago
Dude, it was a low hanging one, you’ll be fine, you’re lucky it was over the pool. Wink
Firelight2
Firelight2's picture
Last seen: 1 hour 14 min ago
jescereal
jescereal's picture
Last seen: 8 months 5 days ago
DB Custom wrote:
Sirius9, if you have a clamp meter you can pull a true current reading off the top end by making a loop between the end of the negative lead and the mcpcb. This works fine without making the driver bump down. I have quite a few working Bistro’s that won’t read current at the tail, have some that will, usually have to resort to the emitter amperage up top though.
It seems like there’s a balance somewhere between a hot 18350 and a good 18650. A hot 18650 simply allows for more power than the ATTiny25 likes with these Manker built Bistro’s and some scratch built ones. Something about going from 11A to 15A… Wink
That’s a freaking great idea! Thanks! I also have a triple xp-l x6 that does the same thing, and I’ve always wondered how many amps it was drawing. I just couldn’t tell due to the driver bumping down.
jescereal
jescereal's picture
So I measured 8.6 9.4 amps on turbo. How cool that I can measure it now. Thanks DBCustom!
Sirius9
Sirius9's picture
Last seen: 9 hours 32 min ago
I often use measuring LED current draw when everything is in pieces, disassembled but I just went straight to putting this thing together, used thick, very short wires, hard to solder so I kinda wanted to avoid dissasembling it. I did try it out with only protected cell I had (NCR18650B) and it seams it works, but It was a short test, cell was mostly depleted. Next one that I will make will be triple XP-L, will measure that one for sure Smile
DB Custom
DB Custom's picture
You’re welcome. I like that it’s real amperage up top, at the emitter, after any driver losses.
I make sure to use the negative lead because if it manages to touch the walls of the head while testing it will only bypass the driver and go direct drive off the cell. If using the red positive lead and it shorts, sparks and smoke and damage done in that same split second your heart and stomach meet jumping out your ….. Wink
Sirius9
Sirius9's picture
Thanks for the tip DB, and yes, those “ups I reversed the polarity” moments can be “interesting”, I fried my tablet like that (internal battery life diminished rapidly so I tosed it out and left just two leads for external battery pack) along with several step up converters that I often use for different things like driving 12V COB leds or 12V fans etc…
Mike C
Mike C's picture
Last seen: 2 days 16 min ago
Spontaneous headlamp mod…
So I was walking down the isle of my local “home depot” style shop and saw a cheapo $8 3xAAA headlamp that looked like it could fit a triple, and as I have dual headlamp project ongoing I though I’d have a shot at making a prototype triple headlamp to see if it’s worth pursuing.
I ripped out the LED, resistor and small switch, and stuffed some triple optics to see if it would fit nicely. It fits but not perfect, the hole is a little too large so I slopped on some glue:
I stuck a S2 spacer on the back with artic aluminia adhesive:
I didn’t want to glue everything in place and at the same time didn’t want the hole thing to fall part with flashing new firmware versions so I kept the original battery case and put a hole in it for the spacer and wires, and stuffed in one of my G-16 programmable constant current / PWM hybrid drivers. I didn’t want to use my FET based F8, it would probably melt the plastic a little too quickly. It’s just an initial trial so 6 amps from 16 × 380mA 7135s is enough:
With my ongoing dual LED headlamp project I’ve gotten annoyed with the wires sticking out. So when I was just walking down the isle of the shop I happened to see this:
It says max 10 amps on the description and is long enough for two projects. I chopped it in half, took a 18650 case from another cheapo headlamp, soldered it in and it was good to go! Funny I didn’t think of this before, it’s a pretty simple solution and more than enough for a prototype:
I couldn’t use the original crappy small switch so I installed my own. I squeezed it in using the existing plastic as support:
The downside was that the rubber switch cover wouldn’t fit under. As this is just a prototype test I slopped on some epoxy and stuck it on the outside. I don’t expect it to stay there for long, but it should last long enough for me to evaluate if I want a headlamp with a triple in it:
So here it is, my triple XLP-HI headlamp prototype… spontaneously made within two days of simply seeing a cheapo headlamp in the store:
Ouchyfoot
Ouchyfoot's picture
Those are the most fun mods because there isn’t anything to lose. If it fails, no big loss, but when it works…it’s that feeling of accomplishment.
Mike C
Mike C's picture
I’d have to agree, fun indeed. First time I’ve done this kind of “quicky”. Everything except glued optics can be re-used again.
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 2 days ago
Very nice mod Mike !
Another impressive one .
How it handles heat ?
MRsDNF
MRsDNF's picture
Nice, Mike now go do something constructive. Oh yeah, forgot this is a hobby and this is what hobby’s are about.
Seriously this really is a sweet mod. Smile
Mike C
Mike C's picture
Thanks. I haven’t had it long enough to melt plastic yet, but as it’s a plastic host I can’t feel how hot it is. Once the copper spacer heats up it might melt it’s way out Big Smile
Because of the driver position I don’t expect the temp sensor of the 85 will be much help. Doesn’t matter though, the idea is to make a alu casing for my headlamp project once I find out what kind of configuration I want. It’s leaning toward the dual LED config though, will be updating that thread with new progress next week or so.
MRsDNF
MRsDNF's picture
So we end up with the strap left from the original light? Facepalm Beer LOL
pinkpanda3310
pinkpanda3310's picture
Last seen: 18 hours 58 min ago
A while ago I bought this lightcasltle then later sold it to a mate. He asked me recently to make it one mode. I considered just running DD but I figured he might let it run hot enough to desolder one of the leds. So I installed a single mode 9a driver The output may have dropped marginally but can’t really tell.
pinkpanda3310
I added rollers to my lathe steady tonight. Drilled and tapped the points. Made small washers to space the bearings off. Installed Cool
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 1 week ago
Cool, at first I thought you were going to notch the points and put the bearings there instead.
Scott
pinkpanda3310
Hey that’s a good idea. It never occurred to me since I was just mimicking what I had seen on the web. I’ll check if the material is thick enough to slot the bearing in. Thanks Smile
DB Custom
DB Custom's picture
I fine tuned the fitment of a heat sink I made for another forum member, boy is it hot out there! We still have 2 months of summer to go, easy….
I put an old mercury thermometer on the central support column the other day, big 4×8 wood beam, so the thermometer is in the center of the shop, away from exterior walls by about 20’ and some 12-13’ from the peak of the roof, directly behind the lathe. It’s 104º in the shade, no air movement at all. Wicked! That’s 39.5ºC for y’all that don’t do Fahrenheit. Wink
dehc111
dehc111's picture
Last seen: 1 month 1 week ago
my fav small sun mod
Head from a zyt13. Tube and tail from a zyt27.
Fet driver with an XHP70, extra copper, two IMR 18350’s and BINGO ……
The side switch is inoperable. Would like to find a good driver w/ e-switch that will fit in this thing.
Also an OP reflector would make it my fav id say.
Would be awesome weapon mounted.
I was bored today…
Rufusbduck
You could sputter the reflector and both DrJones and led4power have E switch compatible drivers. Some MtnE drivers are compatible as well.
Scott
Woytas
Last seen: 2 years 11 months ago
Finally today I made my first modded light:
  • Blue Convoy S2+ body
  • Nichia 219C 5000K
  • BLF X6 driver
  • Noctigon MCPCB
  • Soldered 3mm thick copper disc into the pill
It is bright, gets hot really quick. I spent a lot of time learning how to do things. Then about an hour to recognize that reflector was doing short circuit…from the temperature one spring collapsed due to hot, but fortunately – nothing else was burned.
Since I was using regular Convoy light – not the host – I had to desloder the driver from pill….that was really difficult. How do you do this?
Afer that – another challenge was to solder new driver in place…maybe you have also some hint for this?
ohaya
Last seen: 3 years 6 months ago
!http://i.imgur.com/u4Emiab.jpg!
Wow, nice job :)! The thing is, though, the parts (and work) you put into the modded headlight probably cost way more than the original one :)??
Mike C
Mike C's picture
Thanks.
Of coarse, but I’m designing a headlamp that will be made from aluminum (CNC machining). This is just a protoype test to see if I want to make a triple headlamp alu case. I don’t think so though, I’‘ll probably pursue my other expensive “cheapo” prototype: http://budgetlightforum.com/node/39404
pinkpanda3310
I made up an extension ring for a DQG 26650 to take a Khatod optic. I haven’t filled it with running gear yet. The thread onto the body worked out a little bit tight but I think it’s a good thing because I notched a groove in the extension ring for the optic to sit flat ie the optic has a nob on one side from manufacturing (I guess that’s what it is..?). Now the optic won’t try to spin when I screw the bezel on and off Cool
DB Custom
DB Custom's picture
Nice fix, you should have a noticeably tighter beam profile and it looks pretty sweet too. Wink
pinkpanda3310
BLAAH!! I only just realized the optic is nowhere near aligned with the switch Facepalm Tired
Oh well, I’m not gonna change it now Sad
DB Custom
DB Custom's picture
That’s gonna eat at ya like a bad burrito….
Edit: just rotate the optic some 60º and put a new slot in the adapter ring, lining up the TIR’s and still keeping the notch, albeit on a near opposite side. Wink
pinkpanda3310
Damned burrito’s. Yeh I might try your idea another day, thanks. Time for bed.
Ouchyfoot
Ouchyfoot's picture
It’s always something…
