What did you mod today?
10619 posts / 0 new
vwpieces
vwpieces's picture
Last seen: 1 month 1 week ago
giorgoskok wrote:
Vwpieces what did you use for the final polish ?
Wet sanded up to 2000 grit and Mothers mag aluminum polish on a paper towel.
Nicolicous
Nicolicous's picture
Last seen: 9 months 3 days ago
vwpieces wrote:
S2+ “Color” triple got a face lift and a magnet
very nice.
did you strip off anodize and polish to get it shinny?
Nico -.-
-X3-
-X3-'s picture
Last seen: 17 hours 21 min ago
djozz wrote:
For the Ti version, I understand the cooler tint.
(is it flashoholism in an advanced detoriated stage to match the led tint to the flashlight instead of the owner’s preference?)
I think so, but I totally agrre with you…
My S1 alu is equipped with a “T6”-6C from FT and find it too warm…on the other hand my CNQG brass beauty got some XP-G2 R4 7A that totally fit the sweet brass host…
We might have a problem
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
EasyB
Last seen: 3 hours 59 min ago
Flashy Mike wrote:
EasyB wrote:
I had trouble dedoming this particular XPL V6 1A. I have dedomed 6 others and the dome came off easily after 30-60 minutes of soaking in warm gas. With this one an “outer dome” came off easily but there was a large piece of silicone stuck to the die that would not separate easily. I ended up taking it out of the gas and carefully scraping the silicone off with a blade. Has anyone experienced this behavior with dedoming XPLs?
Yes, me, but not with 1A:
http://budgetlightforum.com/comment/1000859#comment-1000859
Are all your 1A from the same shipment? I ordered new ones and hope I will still be able to dedome them in aceton. I’m not good in scraping at all.
Thanks for linking that discussion; I thought I remember reading someone having this problem but could not find it again.
The V6 1As that dedomed well I ordered a month ago from MTN as bare LEDs flowed onto XP32s. The recent V6 1A I ordered from MTN a few days ago on a 20mm MCPCB. So it’s possible that they came from different times or batches or something.
vwpieces
vwpieces's picture
Nicolicous wrote:
very nice.
Yes, was blue. Wanted the metal switch cap and thought blue was something I could get used to. Nope. I used a solution of Sodium Hydroxide (lye) with warm water. Works well but wear gloves. Some oven cleaners contain Lye also.
pilotdog68
pilotdog68's picture
Last seen: 6 months 5 days ago
Did you have to take it out and scrub at all, or did the lye do all the work for you? How long did it take?
kiriba-ru
kiriba-ru's picture
Last seen: 3 days 16 hours ago
I wonder how patient are those who are taking off stock anodozing. Have anybody tried to contact Simon to get some bare hosts without anodizing? It shouldn`t be hard for him.
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 2 days ago
It’s very easy to remove anodizing.
It’s done with a chemical way , some members will tell you the exact name (liquid used to unclog pipes , i used “tuboflo” in water , that can be found here).
vwpieces
vwpieces's picture
Clean the grease and oils from threads etc. Or those areas take longer. Time depends on the strength of solution and temp of it. Can ‘ve done in 10 to 15 minutes. Definitely wash and brush it clean after to help stop the future corrosion. Too harsh or too long the aluminum will blacken. The black can be cleaned off with wire brush but its effecting the aluminum at that point. I guess a light acid like vinegar would also help neutralize the Base, Lye. I just wash it with dish detergent with an old toothbrush.
Some other harsh, Base cleaners would work too. Ex
Zep industrial purple, or another called Red Devil. Etching type of mag wheel cleaners may work too. All these are strong Base. Also read on here someone using household bleach. Just do not leave it unattended and do not mix your own solution. Strong base are just as dangerous as Acid.
pilotdog68
I used concentrated Greased Lightning cleaner on my S8 (link in signature), but it took hours, I had to take it out and use a wire brush every 30min or so, and it still didn’t get all the ano out of the fins and crevices.
I’ll have to try lye if I do it again. I’m thinking maybe an EE X6
MtnDon
MtnDon's picture
Last seen: 4 hours 12 min ago
If you use lye (sodium hydroxide) there are a few things to be very aware of. If you have the dry type of the chemical ALWAYS add it to water. NEVER the other way around. Also start with cold water. Dissolving sodium hydroxide in water causes an exothermic reaction; heat is produced. Water into dry can create a steam explosion the exothermic reaction is that strong. There are also fumes released that are not good to breathe. The sodium hydroxide solution will burn skin on contact; very bad for the eyes. I use sodium hydroxide in making bar soap. I wear heavy duty rubber gloves and eye protection. I always mix outside and let it cool before bringing it into the shop. Do not mix in an aluminum container; therewill be a chemical reaction. Use glass or stainless steel. FYI, crystaline forms of drain cleaners that foam and bubble usually contain aluminum fines just to make the bubbles so the consumer thinks it’s working good. Pure marketing, the bubbles serve no useful purpose.
Strange how something so nasty makes great soap when combined with the proper amounts of fats or oils.
If you leave the aluminum light in the solution too long the aluminum will be eaten away. In fact I think when used for removing anodization it will leave the aluminum with an etched surface. Not shiny in other words. I am not sure on that. I have never removed anodizing on a light but was curious once about how caustic it was and tried soaking a piece of bronze anodized aluminum window frame. Yup, it works and the aluminium was dullish. I don’t recall if it was pitted, satin, or whatever.
djozz
djozz's picture
Last seen: 17 hours 21 sec ago
If you clean the flashlight very well beforehand and keep the flashlight or lye solution in motion, the anodising layer is removed very evenly, and there is a quite distinct moment that all the ano is gone and the aluminium is not being eaten away yet. If you rinse the flashlight/parts (last time I dunked the complete flashlight in the lye) at this moment, the surface can be quite smooth and be polished fairly fast. The longer you wait the more etched the surface is.
pilotdog68
So it’s best to watch over it the whole time, not just put it in and let it go?
Good info from all of you, thanks. I always wanted a shiny X6, but didn’t want black remnants in the grooves.
vwpieces
vwpieces's picture
Last I checked one could buy Sodium Hydroxide crystals on Amazon.
Also been having thoughts on an EE X6. The Lye solution will get into the deep fins on the X6. HMMM again… I have an Ultrasonic cleaner with a heater, bet that will make short order of de-anodisation. As you can see in this pic, same S2+, de-anodised, but with a brushed finish, before I polished it. Brushed look really showed scratches easily.
There are still darkened areas, kinda yellow, in the knurling. I think that a second dip in the ultrasonic with some dish detergent and touch of Lemi Shine (citric acid) may be a no touch, strip and clean. Should get any discoloration out of the X6 fins because Dish detergents have metal brighteners and the citric acid does the same. Will neutralize the Lye also.
Another thought I have for the X6 was to only sand the high or flat surface areas, leaving the flat black in the fins and knurling. May look cool and if I FUD it up I’ll just strip it clean. I have a couple more X6 hosts on the way, we’ll see what happens when they arrive. Plans for both were XP-L HI single and triple.
vwpieces
vwpieces's picture
Thanks MtnDon. You did a good job explaining the hazards and how to avoid injury. Better than I could. Be careful.
With the solution I started with one tablespoon to a Quart of water. I have a 1/2 gallon that I have been reusing for some time and not only on flashlight anodize removal. Strengthen the solution 1/4 Tbs at a time if your not satisfied. Warming the solution makes a huge difference in its effectiveness. I have been using an old ceramic coffee cup as it holds the dismantled parts of the lights I have done. I can also just heat that cup of solution in the microwave for a minute to warm it before using. Keep your solution in a plastic milk jug or glass jar. You can reuse it Many times.
CRX
CRX's picture
Last seen: 6 months 3 days ago
Did some more tweaking of the Atom triple XP-L HI today, now the momentary tail switch can be activated while the light is in the magnetic keyring holder, which is handy.
viperbart
viperbart's picture
Last seen: 10 months 1 day ago
That looks more like an EDC ring than a key ring.
CRX
CRX's picture
Don’t show your keys on the internet Wink
Nicolicous
vwpieces wrote:
Nicolicous wrote:
very nice.
Thanks vwpieces
I have tried oven cleaners but didnt work well and the chemical reaction is too slow.
Will try Sodium Hydroxide but im scare i might do it wrong and it could be harmful
Nico -.-
vwpieces
vwpieces's picture
most oven cleaners dont clean ovens very well either. This solution would do that better too.
do a cheap ebay light first. Just keep water pan near to rinse the light. Dont use your bare fingers to fish out the parts from the solution. Solution cold is relatively mild and is slow to react. Warming it makes all the difference. So if a cold solution works its too strong, add water.
lostheplot
lostheplot's picture
Last seen: 7 months 4 weeks ago
Not much of a mod had a x6 host laying around so I cooked it (my first cook)
then fitted a xml u3 on noctigon with blf driver.
the bezel and tailcap changed quite a bit the body and head about halfway.
strange but looks better then the pic.
sorry all images down
thanks photobucket
MRsDNF
MRsDNF's picture
For hard to roast anodizing I’ve put parts directly on an electric stove element for different results.
khas
Last seen: 2 weeks 3 hours ago
Today I put together my Jaxman X1 host :
BLF X6v2 Jaxman X1
With a XHP35 HI D4 1A and a 22 mm boostdriver
Jaxman X1 XHP35 HI 1A (left) BLF X6v2 XP-L HI 3D (right)
I don’t have way to measure lumens/lux but the throw is at least 700 M.
Edit : Beamshots
Dawn shot
Control
Imalent HR20 Nichia 219C D320 5000K
X1 XHP35 1A
EasyB
Both the X6 and the Jaxman X1 have the same emitter? It’s interesting that their hotspots are so close in size.
Edit: oh now I see they probably don’t. The X6 has an XPL HI?
khas
Sorry Facepalm yes the BLF X6v2 is a XP-L HI 3D edited my post
pilotdog68
Anywhere to get it locally?
I wonder how well THIS would do, it says it’s 30-50% lye
Edit: This is cheaper and 100% Lye , so I’ll just do that
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 1 week ago
You can also mask areas to keep the ano and colors are removed more easily than black.
Scott
mattlward
mattlward's picture
Last seen: 3 hours 54 min ago
Hey PD… in an XM-L2 I love the 4C, but in the XP-L I am really liking 5A3 and in the XP-L Hi I really like the 5A2. I have finally really found the sweet spot for me, when not using a 219B SW40.
pilotdog68 wrote:
Rufusbduck wrote:
… Or get/make a longer tube and use an XHP-50 3D with a couple 18500’s.
I’d rather it be less floody if I can, and I actually plan to use an 18350 tube with it sometimes
I actually just ordered on of the 4B HI’s from KD, so hopefully they aren’t green. I’ll probably put the 4000k XPG3 back in it for now, the “3A” XPG3 is way too cool for me. I’ll probably use it to try a dedoming idea I have.
edit:
just got home, put the 5a XP-L in it aaaaaand… its perfect. No way is this emitter leaving this light. My L2 will just have to wait for the 4b when it get’s here.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
EasyB
Modded Convoy L2.
OK, I guess this one is not quite finished and this is a teaser. There will be 7x dedomed XPL V6 1A emitters behind narrow TIR optics. I estimate there will be 8000+ lumens OTF and 130+Kcd.
will34
will34's picture
Last seen: 1 day 11 hours ago
For a second I thought it was going to a be a single LED Big Smile
Can’t wait for the result.
