EA41 blue indicator light flashes while in turbo - anyone else confirm?
5 posts / 0 new
OrionLight
OrionLight's picture
Last seen: 4 years 5 months ago
I noticed something new today while using my Nitecore EA41. It’s the before 2015 version topping out at 960 lumens. While it’s on turbo, the blue indicator under the buttons flashes. I thought at first, it was the flashlight’s way of saying it’s about to run out of juice, but when I turn it off and hit the mode button to check the general voltage reading, it still flashes 3 times, meaning it’s around full charge. Can anyone else confirm this happening to their EA41?
- edit – Sorry folks. I guess it really is an indicator for reaching 50%. I guess that’s the downside for a general voltmeter.
Admin, feel free to delete this post.
Edited by: OrionLight on 01/11/2016 - 22:48
Lonelydad
Lonelydad's picture
Last seen: 1 week 56 min ago
Location: Formerly of Western Iowa, now Kansas City, USofA
Actually, the three flashes on battery test tell you that you have 'at least' 50% capacity left.
The fast flashing while running means, basically, 'you're killing me here'. Usually it occurs under high drain after the cells have moved away from a full charge. That is why you can get the fast flash and still have over 50% left when you check. At least, that is when it usually happens to me. It will also occur when you are close to reaching that 10% mark. I really do miss having a real volt meter available, like the EA4 had.
You don't really need a parachute to skydive. But you DO need one if you want to skydive twice!
Old Mate
Last seen: 1 year 8 months ago
+1 to Lonelydad comments,
Just to add another possibility , it could also be a sign of high internal resistance of a nimh cell or as you did not reveal what type of cells you are using , alkaline cells will struggle to power your light in turbo for to long.
Old Mate
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 3 min ago
i noticed mine doing that the other day when i was out fishing.
I am sure it is because the cells where drained not empty but maybe a little less then half way used!
tekwyzrd
tekwyzrd's picture
Last seen: 1 week 19 hours ago
I noticed the blue blinking in turbo with freshly charged nimh.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
