Test/Review of Aukey USB Turbo charger PA-U28
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 13 min 42 sec ago
DSC_2872
Official specifications:
  • Input: AC 100-240V ,
  • Output: 5V/2.1A, 9V/2A, 12V/1.5A
  • Dimensions: 3.8 x 3.2 x 0.9 inches (9.7 x 8.1 x 2.3 cm)
I got it from dinodirect sku:X0001BQWLN
DSC_2814 DSC_2815
I got this charger in a fairly plain cardboard box with a white wrapper.
DSC_2867
The box contained the charger, a usb cable and a instruction manual.
DSC_2874 DSC_2875 DSC_2876
DSC_2877
Measurements
  • Power consumption when idle is 0.03 watt
  • QuickCharge port is coded as DCP, and will switch voltage when connected device sends a QC request.
Aukey%20USB%20turbo%20load%20sweep
At normal usb output the charger can deliver 2.2A, then the overload protection cuts in. This fits very well with the 2.1A rating.
Aukey%20USB%20turbo%209V%20load%20sweep
At 9 volt Quick Charge the output can deliver slightly above 2A, before the output drops and overload protection cuts in at 2.2A.
Aukey%20USB%20turbo%2012V%20load%20sweep
At 12 volt Quick Charge the output can deliver slightly above 1.5A, before the output drops and overload protection cuts in at 2.2A.
In all cases the efficiency looks good.
Aukey%20USB%20turbo%20load%20test
There is no problem maintaining the output for one hour, the noise at 45 minutes is because I moved the charger around to get the IR photos.
Aukey%20USB%20turbo%2012V%20load%20test
Running with 12V output works just as well.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp2810
M1: 47,3°C, M2: 47,7°C, M3: 47,7°C, M4: 38,2°C, HS1: 49,5°C
With 5 volt 2 A output. HS1 is the rectifier transistor, M2 is the controller IC and M3 is the snubber diode.
Temp2811
M1: 46,7°C, HS1: 55,0°C
HS1 is the transformer.
Temp2812
M1: 43,2°C, HS1: 49,8°C
Temp2813
M1: 40,4°C, HS1: 47,9°C
HS1 is the rectifier transistor and the heat on the usb connector is probably from this transistor.
Temp2814
M1: 55,0°C, HS1: 57,0°C
With 12V 1.5A output. HS1 is the snubber diode and M1 is the controller IC, both get warmer with higher output power.
Temp2815
M1: 55,0°C, HS1: 65,6°C
With 12V 1.5A output. HS1 is the transformer, it gets warmer at this higher power output.
10ohm
The noise is very low with 13mV rms and 140mVpp
5ohm
A slight increase in noise with 1A load 18mV rms and 150mVpp
2.5ohm
Even with 2A load the noise is low 23mV rms and 170mVpp
5ohm9V
Same with Quick Charge at 9V: 24mV rms and 190mVpp
10ohm12V
And at 12V: 18mV rms and 180mVpp
Tear down
Aukey has published a rendering showing the inside of this charger, but it is fiction and would not pass any safety test. The points that is listed for the charger is present in the charger and can be found below, many of them just look different than the rendering.
DSC_3041
I mounted it in my vice and hit it a few times with the mallet to open it.
DSC_3042
At the mains input there is a fuse and a common mode coil (partial hidden in the white stuff). There is an inductor close to the black wire (Also partial hidden in the white stuff).
Beside the trafo is a safety capacitor.
DSC_3044 DSC_3045
Here the blue safety capacitor (CY1) is easier to see.
DSC_3046 DSC_3047
The red block is the 2A input fuse, both the inductor and the common mode coil can be seen.
The black part at the black wire is surge protection.
DSC_3043
U1 us a SC1223K that is a mains switcher and has output for controlling synchronous rectification (Q1). The chip has very low standby power and is tested with 6000 volt, but it do not have any support for QuickCharge. This must be provided by U2 (PHY100).
In addition to these parts there is DB1 that is the input bridge rectifer.
DSC_3048
DSC_3049
It looks like the isolation distance is 6.4mm.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a good USB charger with Quick Charge support, it has low noise and deliver exactly what it is supposed to do.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
light-wolff
Last seen: 1 week 18 hours ago
Looks quite good, thanks for testing.
It seems Aukey just implemented Power Intregration’s reference design for the SC1223K InnoSwitch chip. It looks exactly the same: http://www.burnon.com/upfile/datasheet/20150403125423_824.pdf
Here is the SC1223K datasheet
Can’t find it on PI’s homepage though.
