Ordered the ES03 Friday - good price! Used the BLF coupon code. Wish they had 4000K tint though. 6500K may be the least popular here.
Says will ship today -- can you confirm?
Seems like a decent buy, any idea what LEDs it uses mate?
SST-20's - it said in the BG listing - their listing is more complete, but you pay for it. FT has a good price for now, but of course it's risky for this "Smiling Shark" branded version. For me, gonna swap the LED's and driver anyway which eliminates some risk but I still won't know the quality and if the dims match up perfectly. The optic they use is a risk as well, but might be able to swap in something better.
4*Cree XP-L HI / 2-mode (stepless/step dimming) / 5000LM / cool white / 3*18650 / USB-C rechargeable / IPX7 waterproof
Intelligent temperature control
Voltage: 3.7-4.2V
Head diameter: 56mm
Tube diameter: 46mm
Tail diameter: 50mm
Charging: 5V / 3A fast charging (When flashlight is charging, the switch lights up red; when charging is complete, the switch lights blue)
FASTTECH - LED Flashlights, Lasers and Electronics
Ordered the ES03 Friday – good price! Used the BLF coupon code. Wish they had 4000K tint though. 6500K may be the least popular here.
Says will ship today — can you confirm?
Hi Tom,
Your order is waiting to be packaged now, which will be shipped out as soon as possible. If there is any concerns, please feel free to contact us in ticket, we will do our best to help. Thank you.
Voltage: 3.7-4.2V
Head diameter: 28mm
Tail diameter: 26.5mm
1m impact resistance
Side key lock function
High-efficiency constant current circuit, intelligent temperature control, to ensure maximum safety and stable performance
Battery power detection function, keep abreast of the remaining battery power
The farther the distance, the greater the projection that the sunset light can project on the wall or ceiling. The light casts amazing colored circular lights on the wall, ceiling and floor.
Powered by USB 5V/5W, 1.5m long cable with switch.
Adjustable Height: This lamp is for ambiance! It can not only be place on your desk but also be adjusted to place on the floor! It casts a wonderful ray on the wall. No matter when you leave it on, it lights up the walls with the sunset-/sun-liked/rainbow light.
180 Degree Adjustable: The light projector can tilt 180 degrees according to your needs and stand upright or project in different directions. Perfect for creating a warm and romantic ambiance. It is a perfect gift for you, your lover, your family, your friend, etc.
3mm wire diameter
"JETBeam KO-02 LED Flashlight":https://www.fasttech.com/p/9738205 1*Cree XHP35 LED / 6-mode / 2000LM / cool white / 1*21700/1*18650 / USB-C rechargeable / clip / lanyard / IPX8 waterproof (2m underwater) Voltage: 3.7-4.2V Head diameter: 28mm Tail diameter: 26.5mm 1m impact resistance Side key lock function High-efficiency constant current circuit, intelligent temperature control, to ensure maximum safety and stable performance Battery power detection function, keep abreast of the remaining battery power !https://img.fasttechcdn.com/973/9738205/9738205-1.jpg! !https://img.fasttechcdn.com/973/9738205/9738205-5.jpg![/quote].
What's the UI on this one?
Click for ON/OFF or hold?
Also, are the modes from High to Low or "normal" L-H?
I had to goggle it, and acto the bmengineer review, it’s kinda bad.
Green beam (hey, it’s a Jetbeam, so whaddya expect? ), and a horrible UI that always starts on turbo and you gotta click to get down to moonlight (after being sufficiently blinded by turbo).
I had to goggle it, and acto the bmengineer review, it's kinda bad. Green beam (hey, it's a Jetbeam, so whaddya expect? ), and a horrible UI that always starts on turbo and you gotta click to get down to moonlight (after being sufficiently blinded by turbo).
1*Luminus SST-40 LED / 6-mode / 1*21700/1*20700/1*18650 / 1380LM / cool white / USB rechargeable / IPX8 waterproof (2m underwater)
Intelligent temperature control system to maximise the lifespan of LED
360’ rotation to adjust beam angle for different applications
Power indicator function to know power level at anytime
Voltage: 3.7-4.2V
1700 lumens maximum output (1300 lumens spotlight + 400 lumens floodlight).
Compatible with 4 AA Ni-MH/Alkaline batteries (charging is prohibited).
Separately controlled dual switch for easy and fast operation.
Lockout function avoids accidental activation. USB Type-C charging port with 2A fast charging, 3 hours for full charging.
60 degree tilt mechanism directs the beam where needed.
Made of quality plastics and aluminum, integrated die-casting for better heat dissipation and safety performance.
2m impact resistance
1*Luminus SST70 / 12-group/55-mode / 4000LM / pure white / 1*21700 / lanyard / IPX4 waterproof / intelligent temperature control
Voltage: 3.7-4.2V
Head diameter: 55mm
Intelligent temperature control: When the temperature of the flashlight reaches 55’C, the temperature control system will continuously automatically adjust the output current, and return to normal output when it is lower than 55’C
15 layers of heat dissipation, fully protect the internal circuit
12-group/55-mode:
The flashlight enters the flashing state, flash 1 time, then turn off the flashlight, select the first group; flash 2 times, turn off the flashlight, select the second group; flash 3 times, turn off the flashlight, select the third group; and so on.
Optional gear group: (where biking is a beacon, battery check is a battery capacity test, each flash represents 25%)
0.1% / 1% / 10% / 35% / 100% / strobe / biking / battery-check
100% / 35% / 10% / 1% / 0.1%
1% / 20% / 100% / strobe / biking / battery-check / sos
1% / 20% / 100%
100% / 20% / 1%
0.1% / 1% / 10% / 50% / strobe / biking / battery-check / sos
50% / 10% / 1% / 0.1%
100% / 20% / strobe
100%
Fenix TK35 LED Flashlight
1*Cree XHP35 HI / 7-mode / 1300LM / neutral white (4700K) / 2*18650 / lanyard / IP68 waterproof
Light Reviews
Cheap Flashlight Durability Test
Ekoras R7 review
Multiband radio review
YouTube Reviews
Astrolux FT03 Luminus SFT40 Beamshots
Luminus SFT-40 test output + candela tested
Ekoras S21 Review
Scratch builds
6th Annual Old Lumens Scratch build entry
7th annual Old Lumens scratch build entry
Post #1000!
(at the moment)
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread
1*LED + 1*COB 7-Mode 2500LM LED Flashlight w/ Focus Zoom
pure white(6500K) & red light / 2*18650/2*26650 / USB output / IPX4 waterproof / window hammer / LED power display
Head diameter: 60mm
Tail diameter: 35mm
HaikeLite HK04 Anduril UI Super Bright LED Flashlight
Voltage: 3.7-4.2V
Head diameter: 56mm
Tube diameter: 46mm
Tail diameter: 50mm
Hi Tom,
Voltage: 3.7-4.2V
Head diameter: 28mm
Thanks!
You guys are killing us with the 6500K LED tints - all the HK04 options are 6500K
FastTech New Arrivals! USB Powered Rainbow Projector LED Night Light Atmosphere Floor Lamp
3mm wire diameter
WTB Titanium 4sevens 2xAA tube
I googled that too but it’s V1 in the test.
This one is V2 if i’m not mistaken
JETBeam BR10 PRO LED Flashlight Bike Bicycle Front Light
Voltage: 3.7-4.2V
HaikeLite HK4S LED Flashlight
4*Luminus SST20 LED / stepless dimming / 4000LM / cool white / 1*26800/1*26650/1*21700 / lanyard / IPX7 waterproof
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
Spring: Copper alloy silver-plated spring with ultra-low internal resistance
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
4*Luminus SST40 LED / stepless dimming / 7000LM / cool white / 1*26800/1*26650/1*21700 / lanyard / IPX7 waterproof
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
In Stock! Manker T02 LED Flashlight
1*Cree XHP35 LED / 6-mode / 1500LM / IPX8 waterproof / 2*14500/2*AA / power display / overdischarge protection
Beam range: 144m/211m (AA/14500)
Voltage: 1.5-3.4V/5.4-8.8V
Current: 1A
Ordered a HK4S, SST-40, brown - good price!
Is that a candidate for a QB26800 cell retrofit?
Review: 150 Million Candlepower Military Xenon Arc Battlefield Illuminator (AN/VSS-3A)
My new collection of 50+ Chinese knives
No, it just fits with the provided extra short spring
I'm planning to swap in XHP50.2 3V's since I already have an SST-40 version.
I see the spring is not mentioned in the listing but should be there.
Wait... I think I forgot I had to do a mod - swap a driver side high brass button for a low one... I'm loosening it, COVID/hospital in between...
Yeah, here: https://budgetlightforum.com/comment/1746811#comment-1746811
Thanks Tom E. I just caught up with your posts in the HK4S group buy thread. Nice work!
JETBeam RRT-M1X White Laser LED Flashlight | UP TO 31% OFF
Use coupon code MAP, get up to 31% off
1*WP-T2 LED / 5-mode / 480LM / pure white / 1*18650/1*21700 / lanyard / IPX8 waterproof (2m underwater)
Reflector diameter: 53mm
Head diameter: 61mm
Tube diameter: 28.3mm
Tail diameter: 28.3mm
Voltage: 3.7-4.2V
IMALENT R60C LED Flashlight | UP TO 28% OFF
Use coupon code MAP, get up to 28% off
6*Luminus SST-70 Gen2 / 6-mode / 18000LM / pure white / 3*21700 / USB rechargeable / IPX8 waterproof (2m underwater)
Reflector diameter: 66mm
Head diameter: 74mm
Tube diameter: 51mm
4*Luminus SST40 LED / stepless dimming / 7000LM / neutral white / 1*26800/1*26650/1*21700 / lanyard / IPX7 waterproof
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
1*Cree XHP35 LED / 6-mode / 1500LM / neutral white / IPX8 waterproof / 2*14500/2*AA / power display / overdischarge protection
Current: 1A
Fenix HP16R Outdoor LED Headlamp
1*Luminus SST40+1*Cree XP-G3 S4+1*Everlight 2835 / 9-mode / 1700LM / white/neutral white/red light / 1*battery pack/4*AA
PIONEMAN U8A Tactical LED Flashlight
Voltage: 3.7-4.2V
Head diameter: 55mm
12-group/55-mode:
1% / 20% / 100%
100% / 20% / 1%
100% / 20% / strobe
100%
Limited Clearance! Save Up to 94%! 1700+ Pcs From $0.59! First Come, First Served!
Time Limited Offers Important: offers must be purchased using the “add offer to cart” button on this page.
