FastTech New Arrivals & Promotion
1225 posts / 0 new
fasttech
fasttech's picture
Last seen: 3 days 11 hours ago
3PCS SMILING SHARK K07 LED Headlamp
1*LED + 2*COB / 4-mode / 80LM / pure white / USB rechargeable / IPX6 waterproof
FASTTECH - LED Flashlights, Lasers and Electronics
fasttech
fasttech's picture
Upgraded Solar Powered Rotating Color Projection Lamp for Outdoor Garden
3*LED / 2-mode / RGB / IP55 waterproof / 2400mAh battery
Solar panel: polycrystalline 6V 250mA 1.5W Rotation method: reflective prism rotation (will not break) Switch position: 2 mode switch (winter and summer mode) Illumination range: 3-4m Light-emitting mode: RGB (red, green and blue light motor rotating lens emits alternating color light)
fasttech
fasttech's picture
3*LED / 1-mode / RGB / 500mAh battery
Solar panel: Polycrystalline 5V 80mA 0.4W Rotation method: lamp bead plate rotation Switch position: 1 mode switch Illumination range: 1-2m Rotating motor: 3V long life, brushless DC motor Working principle: It is dark, the light is controlled to start, the motor drives the red, green and blue lamp beads to rotate, and the light passes through the reflective lens to project a rotating colored light
fasttech
fasttech's picture
Convoy M21B LED Flashlight
1*Luminus SST40 LED / 4-mode / 1500LM / neutral white / water resistant / 1*21700/18650 / anti-skid body Head diameter: 35.7mm, Tail diameter: 27.1mm
fasttech
fasttech's picture
Convoy M26C LED Flashlight
1*Luminus SST40 LED / 4-mode / 2300LM / natural white / IPX8 waterproof / 1*26650 / anti-skid body
Voltage: 3-4.2V
Head diameter: 55mm
Tube diameter: 33.5mm
Tail diameter: 33.5mm
fasttech
fasttech's picture
fasttech
fasttech's picture
New Arrival! 5*LED 4-Mode 9900LM LED Headlamp
pure white / 1*18650 / 90’ up & down adjustable / IPX46 waterproof
Voltage: 3.7-4.2V; -7’C cold & altitude 5000m challenge
fasttech
fasttech's picture
Convoy M3-C LED Flashlight
1*Cree XHP70.2 LED / 4-mode / 4300LM / 5000K / 1*IMR26650/IMR18650 / IPX6 / built-in temperature protection Reflector diameter: 40mm Head diameter: 48.1mm Tube diameter: 35.6mm Tail diameter: 38.1mm Voltage: 3.7-4.2V
fasttech
fasttech's picture
Convoy S12 LED Flashlight
3*Luminus SST-20 LED / 4-mode / 2300LM / neutral white / water resistant / 1*21700/18650 / anti-skid body
Head diameter: 34.6mm; Tail diameter: 27.4mm
fasttech
fasttech's picture
Today’s new arrival flashlight—-YUPARD Diving LED Flashlight
1*LED / 1-mode / 350LM / pure white / 2*26650 / 50m diving depth Head diameter: 64mm; Tail diameter: 38mm
fasttech
fasttech's picture
1*LED+1*COB 4-Mode 350LM Handheld LED Flashlight
pure white / micro-USB rechargeable / 3500mAh power bank function / power display / water resistant
fasttech
fasttech's picture
Red Light Therapy Device for Face Body Skin
deep red 660nm / 338*LED
This product treats the whole body with light, reduces wrinkles and strengthens collagen. 338pcs LED, super size, relieve muscle soreness, etc. Enhance energy, better sports performance, help build muscles and increase strength. Helps sleep deeper and reduces anxiety. It is recommended that the time of use should not exceed 10 minutes each time, and the number of times of use should not exceed 2 times a day. Please wear black goggles when using it to reduce the discomfort of the light on the user’s visual pupils during work.
fasttech
fasttech's picture
Convoy T2 LED Flashlight
1*Nichia 219C LED / 4-mode / 320LM / neutral white / 1*AA/1*14500 / IPX8 waterproof
Head diameter: 21mm
fasttech
fasttech's picture
I recommed you a small gadget Key Shaped Mini Outdoor LED Flashlight Keychain
1*COB / 15LM / white light / 2*CR2032
Voltage: 3V
Application: cave exploration, daily carrying, camping, patrolling, teaching, hunting, hiking, search, night fishing, night riding
fasttech
fasttech's picture
TANJE S828 Handheld LED Flashlight
2*LED / 3-mode / pure white & yellow light / 1*18650 / double head / water resistant
Head diameter: 46mm Tail diameter: 46mm Voltage: 3.7-4.2V
fasttech
fasttech's picture
New Arrival SMILING SHARK FB-L18 LED Flashlight
1*LED / 5-mode / 500LM / pure white / 1*18650 / IP66 waterproof / window breaker / power display / heat dissipation
Head diameter: 35mm
Voltage: 3.7-4.2V
Double control tactical switches
fasttech
fasttech's picture
SMILING SHARK K225 LED Headlamp w/ Focus Zoom
1*LED / 3-mode / 1200LM / yellow light / 2*18650 / IPX6 waterproof / 90’ up & down adjustable
Spotlight mode: 1500m beam range Floodlight mode: 50 square meters light area
fasttech
fasttech's picture
USAMS US-CD166 LED Flashlight Mobile Power Bank 4000mAh
2400mAh rated capacity / 4-mode (low/high/SOS flash light/360’ ambient light) / 350LM / pure white
fasttech
fasttech's picture
SMILING SHARK E666 LED Flashlight
1*LED / 3-mode / 420LM / pure white / USB rechargeable / water resistant / heat dissipation
fasttech
fasttech's picture
New Arrival 5*LED 4-Mode 9900LM LED Headlamp
fasttech
fasttech's picture
fasttech
fasttech's picture
K34 3*LED+1*COB 8-Mode 800LM LED Headlamp
pure white & red light / USB rechargeable / water resistant / angle adjustable / LED power display
fasttech
fasttech's picture
New Arrival Flashlight TANJE HX508 Handheld LED Flashlight Searchlight
4*LED+1*COB / 4-mode / 200LM / pure white / 1*18650 / USB rechargeable / water resistant / power display
fasttech
fasttech's picture
1*LED 3-Mode 1500LM Diving LED Flashlight
pure white / 1*18650/1*26650/3*AAA / lanyard / 50m underwater / IPX8 waterproof
Head diameter: 58mm Tail diameter: 35mm
fasttech
fasttech's picture
New Arrival Falshlight——TANJE HST006 Handheld LED Flashlight
1*LED / 3-mode / 320LM / pure white / USB rechargeable / water resistant
Notmyrealname
Last seen: 2 hours 6 min ago
Perhaps you are misunderstanding the “budget” part of Budgetlightforum. We are flashlight enthusiasts who enjoy good quality flashlights. Most of what you present here is of no interest to me and I feel safe to say to many or most of us. The Tanje HST006 “falshlight” is a $7 plastic 320lm flashlight that I can’t imagine anyone here buying as with many of the flashlights you show here. It would be better for your business if you showed lights we would be interested in.
I don’t mean to speak for others or for the forum. My apologies to anyone enthralled with the Tanje HST006.
I feel sorry for people who don't have a hobby or interest to escape to.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 days 6 hours ago
Actually, I wonder if fasttech was able to offer some more of the latest craze. Lately, I discovered that on Chinese flashlight communities (e.g. Baidu) there are lots of interesting new models from Nightwatch, OnTheRoad or Amutorch. Some of them use latest LEDs like SFT40 or Chinese emitters like SFN55.2 or SFS80. All these models are listed on Taobao only. I doubt there's any chance for non-Asian customers to buy these. The only retailer who sometimes offer one or two of these new lights is Neal Zhang (nealsgadgets.com) but I would be happy to see more buying options.
fasttech
fasttech's picture
Thank you for your opinion and suggestion. We will try the best to update more good quality flashlights to our customers in the future. Would you mind telling us in which brands of flashlights you are interested? We can update regularly the new arrival of these brands.
fasttech
fasttech's picture
Lux-Perpetua wrote:
Actually, I wonder if fasttech was able to offer some more of the latest craze. Lately, I discovered that on Chinese flashlight communities (e.g. Baidu) there are lots of interesting new models from Nightwatch, OnTheRoad or Amutorch. Some of them use latest LEDs like SFT40 or Chinese emitters like SFN55.2 or SFS80. All these models are listed on Taobao only. I doubt there’s any chance for non-Asian customers to buy these. The only retailer who sometimes offer one or two of these new lights is Neal Zhang (nealsgadgets.com) but I would be happy to see more buying options.
Thank you for providing us the information. I will forward this to our product team for marketing evaluation. We also want to offer more and various flashlights to our customers. Your information and suggestions are valuable for us. Thanks.
fasttech
fasttech's picture
SMILING SHARK T10 Mini LED Flashlight
1*LED / 6-mode / 1200LM / pure white / USB rechargeable / IPX6 waterproof / LED digital display / magnetic adsorption / heat dissipation
