authentic / 8*Cree XHP50.3 HI LEDs / 7-mode / 1160m throw / 336800cd / 3*21700 / USB charging / IP68 / fan powered heat shield
IMALENT RS50 is a rechargeable searching LED flashlight with a compact size that blasts a max output of 20,000 lumens and a max beam distance of 1160 meters. The amount of light that the IMALENT RS50 flashlight emits is truly remarkable, a wide beam angle and strobe function are quite ideal for Search and Rescue with eight pieces of American Cree XHP50.3 HI LEDs.
Extremely small for a flashlight with this much power, with the fan-powered heat shield and built-in two heat release fans, this flashlight can keep the body temperature at about 40 degrees, which makes it the perfect tool for exploring, searching, and rescue. Once you see the raw power of a 20,000 lumens flashlight, you will never feel troubled at night adventures, such as searching, caving, patrolling, etc.
Ultra-long throw distance flashlight
Utilizes eight pieces of American Cree XHP50.3 HI LEDs. The lifespan is up to50,000 hours with a maximum output of 20,000lumens.
Instant turbo output by double-pressing the side power switch button while triple pressing the side power switch button, can get the lowest output.
High efficient circuit, can be constantly on at 6,500 lumens.
Built-in thermal control module, and equipped with a fan-powered heat shield, it will automatically adjust the brightness output according to the working state and outer temperature, keep using comfortably.
Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment.
The fan-powered heat shield has a charging interface: Users can charge the flashlight and fans battery directly without removing the shield.
Head diameter: 74mm
Tube diameter: 51mm
Peak beam intensity: 336800cd
Impact resistance: 1m
Waterproof: IP68 (Submersible to 2m)
Cooling time: 1 Hour 45 Minutes
Charging time of fan-powered heat shield: 2 Hours
Battery capacity of fan-powered heat shield: 1000mAh
FASTTECH - LED Flashlights, Lasers and Electronics
Controller: Indoor temperature protection management
Driver Instructions:
Modes: 0.1% -3% -30% -100%
Its biggest advantage is that you cannot see frequency in any mode, and there is a temperature control.
You can control the flashlight temperature not higher than 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is above 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
New Arrival! Klarus XT21X Pro 4400LM 6500K LED Flashlight
authentic / Cree XHP70.2 LED / 7-mode / 336m throw / 19506cd / 1*21700/1*18650 / USB-C charging / IPX8 / power bank function / window breaker
Head diameter: 41mm
Tube diameter: 29.2mm
Waterproof: IPX8 (submersible to 2m)
Beam intensity: Max. 19506cd
Voltage: 2.8-4.2V
Cellphone charger mode: USB Type C to USB Type C charging compatible, from 0% to 100& on a single charge
Battery: 1*21700 (not included), the length of the battery is not more than 71mm
12 groups:
Click the switch to turn on / off the flashlight, touch the switch to select the mode
If the flashlight is on, tap the switch 20 times quickly to enter setup mode. (In a visual interface, whenever you click an option, it means that the option is selected. The flashlight has no visual interface. It blinks to represent an option, and “touch the switch in the process of blinking” means to select the option. )
Option 1 (normal-flash 1 time + buzz-flash): Touch the switch to enter the sub-option to select the mode group, if the user has no operation. Configuration mode will enter option 2.
Sub option 1.1 (normal-flash 1 time): Touch the switch to select mode group 1 (0.1%, 1%, 10%, 35%, 100%, strobe, beacon, battery check)
Sub option 1.2 (normal-flash 2 times): Tap the switch to select mode group 2 (0.1%, 1%, 10%, 35%, 100%)
Sub option 1.3 (normal-flash 3 times): Tap the switch to select the mode group 3 (100%, 35%, 10%, 1%, 0.1%)
Sub option 1.4 (normal-flash 4 times): Tap the switch to select mode group 4 (1%, 20%, 100%, strobe, beacon, check battery, SOS).
Sub option 1.5 (normal-flash 5 times): Tap the switch to select mode group 5 (1%, 20%, 100%).
Sub option 1.6 (normal-flash 6 times): Tap the switch to select mode group 6 (100%, 20%, 1%).
Sub option 1.7 (normal-flash 7 times): Tap the switch to select mode group 7 (0.1%, 1%, 10%, 50%, strobe, beacon, battery check, SOS).
Sub option 1.8 (normal-flash 8 times): Tap the switch to select mode group 8 (0.1%, 1%, 10%, 50%).
Sub option 1.9 (normal-flash 9 times): Tap the switch to select mode group 9 (50%, 10%, 1%, 0.1%).
Sub option 1.10 (normal-flash 10 times): Tap the switch to select mode group 10 (1%, 10%, 35%, 100%).
Sub option 1.11 (normal-flash 11 times): Tap the switch to select mode group 11 (100%, 20%, strobe).
Sub option 1.12 (normal-flash 12 times): Tap the switch to select mode group 12 (100% only).
Option 2 (normal-flash 2 times + buzz-flash): Tap the switch to activate the mode memory or inactive, if the user has no operation. The flashlight will enter the last mode.
W35A is lightweight throwing rifle rail tactical light. The white light beam can reach 653 yards! The light intensity is as high as 89,600 candelas!
The light head is only 32.5mm (1.28 inches) in diameter, short and powerful. There are 2 mounting holes on the body, Various types of rail mounts can be installed, Such as Weltool PM4. Therefore, the W35 series tactical lights can be installed on M-LOK or Picatinny, KeyMod, MIL-STD-1913, STANAG 2324, STANAG 4694, Weaver, and other types of tactical rails. Suitable for most AR rifles and short-barreled rifles or carbines.
IP67 protection standard, waterproof and dustproof, shock and vibration resistance. Tactical switch, can lightly press the switch to light up silently, or it can be locked to be always on.
Use suggestions:
After the glass lens of the light head is damaged, you can replace the spare lens by yourself, take out the battery, and press the light head down on rough and soft leather or fabric, such as mousepads, anti-skid pads, and twist the light body counterclockwise. Unscrew the bezel and take out the damaged lens and replace it with a new one, and then tighten the bezel clockwise. In addition to this situation, please do not disassemble other parts, otherwise, the warranty will be invalidated and the product may be damaged.
When this tactical light is on, the internal heat will be discharged in time, so it is normal to generate heat during use;
Please check and replace the O-ring regularly to maintain the waterproof rating.
Please check and lubricate the threads regularly with professional lubricant.
Clean the contact surfaces regularly to keep the flashlight in normal operation. If irregular strobe or failure to turn on occurs, the contact surfaces may be dirty and require cleaning by using alcohol cotton swabs.
This flashlight is not intended to be used as a diving light.
Do not aim the flashlight directly at the eyes. Keep out of the reach of children.
Specifications:
Light intensity: 89,600 candela
Battery: Use 1 USB rechargeable 18350 high drain lithium-ion battery (not included), (cannot use 2 lithium ion batteries or 2 lithium batteries).
Switch: Tactical tail switch, rated for 50,000 presses.
Battery over-discharge protection function
No PWM, no noise, and temperature control protection function
Pass the 1-meter drop test
Head diameter: 32.5mm
Weltool W5 LEP search flashlight throwing distance up to 2807 meters! The luminous flux is 699 lumens, and the beam intensity reaches 1,970,000 candela. It uses two 22500 or 22430 lithium-ion batteries. You can also purchase an extension tube and use two 21700 lithium-ion batteries to increase runtimes. High-quality temperature control driver chip, constant current drive and ensure that the flashlight will not overheat.
W5’s LEP light source has high energy density, and after passing through a special lens reflection system, it forms a dazzling beam of light. High and low brightness modes, side-press electronic switch, with battery indicator light, and lock function. W5 has almost no spill, suitable for field search, sea rescue, long-distance indication and other purposes.
Instructions:
First install the battery correctly.
The flashlight has a polarity protection function. If the battery is installed incorrectly, the flashlight will not be damaged, but it will not light up. Please check the battery in time.
After installing the battery, when it is not turned on, press the side switch once, the battery indicator on the switch turns on for 5 seconds and then automatically turns off (full battery: green light, low battery: red light, ultra-low battery: red light flashing)
Press the switch for a long time to turn on or off the flashlight. When the flashlight is turned on, the battery indicator will be on (full battery: green light, low battery: red light, automatically turned off after 5 seconds), and the red light will always flash when the battery is ultra-low. Short press the switch to switch the mode, the default is low light mode when the flashlight is turned on.
During use, if the battery power is low, the battery indicator will show a red light, and it will turn off after 5 seconds. When the battery is ultra-low, the indicator light will keep flashing. Before the battery power is exhausted, the main flashlight will flash to indicate, and then it will stop working at any time.
Switch lock and unlock function:
In the off state, press the switch more than 5 times to lock or unlock:
The main light flashes quickly 2 times to indicate that it is locked;
After unlocking, the main light will light up in low light mode.
After being locked, the flashlight will memorize the locked state. At this time, it needs to be unlocked when the battery is replaced and used again.
Specifications:
Reflective system: Double convex lens
Beam divergence angle: 1.8’
Light source: Special LEP module, wavelength 400-700nm, lifespan is about 10,000 hours
Switch: Side-press electronic switch with lock function to prevent accidental touch
High efficiency constant current drive circuit, no noise and no PWM
Temperature control protection: When the temperature of the flashlight is too high, the flashlight will automatically reduce the brightness to prevent overheating
Low voltage reminder function (battery indicator + main light flashing reminder)
With battery over-discharge protection
Wear-resistant thread
Double O-ring waterproof, protection level can reach IP67
Head diameter: 60.5mm
Body diameter: 30mm
Head diameter: 44.5mm
Tube diameter: 25.2mm
Controller instructions:
Now we offer another controller version, which has 4 simple modes to switch, which is very suitable for normal users.
Modes: 0.1%-3%-30%-100% (the maximum current output is 4800mA).
Its biggest advantage is that you can not see frequency in any mode and there is temperature control.
You can control the flashlight. The temperature should not exceed 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is higher than 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
GT Nano is the 10180 battery version in the classic BLF GT family. It is a super tiny yet ultra throw keychain flashlight. With a length of 52.5mm and 17g in weight, this tiny flashlight can burst into a max of up to 450 lumens output and up to 300 meters amazing throw. The included 10180 Li-ion battery and a Micro USB charger allow the flashlight ready to use and easy to be charged. Defaulted smooth ramping UI, optional advance settings, IPX8 waterproof, GT Nano is a must-have for your EDC collection.
Specifications:
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
By default the GT Nano is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.Driver: Texas Avenger FET driver
Button: Tactile with back-lit rubber boot
Reflector diameter: 20.8mm
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 24mm
Light intensity: 23400kcd
IMALENT MS03 LED Flashlight
authentic / 3*Cree XHP70.2 / 6-mode / 13000LM / pure white / 1*21700 / USB-C rechargeable / lanyard / IPX8 waterproof (2m underwater)
Enter coupon code MAP on the shopping cart page to get $43.25 off
Voltage: 3.7-4.2V
Head diameter: 36mm
Tube diameter: 27mm
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature.
Battery level indication
1.5m impact resistant
The VAT is not included in the prices. If you want to have the VAT pre-paid, please tick the “Opt-in to pre-pay EU VAT for hassle-free deliveries” option in step 3 of the checkout.
Please feel free to contact us if you have any other questions.
Can Fasttech ship 18650 batteries to Malaysia and Singapore now?
I am sorry that we still can’t ship 18650 batteries to Malaysia and Singapore at present. We keep searching for other couriers and will update it on our website if it is available in the future. Hope you can understand. Thank you.
Dear Fasttech, it seems your shipping partner died.
Everything was OK until mid of December. Since then I haven’t received any of 6 ordered packages. For comparison, Banggood free shipping door to door takes no more than 10 days. Aliexpress shipping takes 4 weeks at most.
I gave up ordering at FT and waiting for any delivery from yours. This means you’re loosing money, because I switched to other shops that has no problems with deliveries.
1.
Order Placed:
Saturday, November 6, 2021
Order Number: D110676174
2.
Order Placed:
Saturday, December 11, 2021
Order Number: D121147088
3.
Order Placed:
Sunday, December 12, 2021
Order Number: D121283214
4.
Order Placed:
Tuesday, December 14, 2021
Order Number: D121428891
Order Total: $45.64
5.
Order Placed:
Monday, December 27, 2021
Order Number: D122782221
6.
Order Placed:
Tuesday, January 4, 2022
Order Number: D010485823
Nah, you’re just a bit of unrealistic and impatient
Sometimes. But more often month – month and half. (with the exception BG EU warehouse orders)
Sometimes. But more often 2 months. Sometimes even more.
And yes, I live in the EU too.
I don’t see anything out of order in your shipments above. Maybe this first one from november, but then again … 11.11. sales, christmas sales, new years sales, worldwide covid situation, cancelled flights, lockdowns … so please, stop overreacting about “no more 10 days from China” please. You’re not new into all this and you should know it better when you order from China.
I can’t get even one simple shipment from not so distant Poland to Slovenia in less than 10 days or so nowaday.
My black Friday (end of November) order came two weeks ago to Canada.
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
1.
Order Placed:
2.
Order Placed:
3.
Order Placed:
4.
Order Placed:
Order Total: $45.64
5.
Order Placed:
6.
Order Placed:
I am sorry for the delay in shipping your orders and the negative experience you have had on our website.
Due to the peak season and the overload volume of packages in the China postal service, packages shipped through registered airmail by China Post are severely delayed since late November. We have realized it and kept searching for other faster couriers.
We just checked the tracking information of your orders, among the 4 orders placed in December, 3 orders arrived in Poland on Jan 20, and one order arrived on Jan 25. Please wait one more week for the delivery or further updates. If you still haven’t received it after one week, please feel free to contact us. In the meantime, we will keep monitoring them and let you know once we have any news from the post office. The tracking information of the order placed in November was stuck on Dec 3 and hasn’t been updated for a long time, we have submitted an investigation to the post office. Please rest assured that if the post office confirms that it is lost or returned, we will contact you immediately and resolve it according to our company’s policy. Your understanding is highly appreciated.
The newest order placed on Jan 4 was just shipped on Jan 22, we will chase the post office to update the information on the tracking website as soon as possible.
Should you require any further assistance, do not hesitate to contact us.
Only Manker E02H LED Flashlight has a coupon sale this time. But we are planning to launch a promotion for Manker Flashlights within a week or so. We will update this thread. Please stay tuned.
Annie
IMALENT RS50 20000LM 6500K LED Flashlight
Light Up 2022! New Year Flashlights & Batteries Incredible Deals – UP TO 33% OFF
Time For Celebrations! FastTech 2022 New Year 7% off Site-wide Sale
Wish you a very Happy New Year! It’s time for Celebrations! We’ve prepared a 7% off site-wide promotion for you!
New Year Site-Wide Coupon
Offer: Site-wide 7% off
Valid Date: Jan 1st, 2022 – Jan 5th, 2022 (UTC-6)
Coupon Code: HAPPY2022
Customers can pay via Paypal or credit card for the gift card to get an extra 3% free value instantly.
New Arrival! Convoy L21B 520nm Green LED Flashlight
OSRAM KP CSLPM1.F1 LED / 1*21700 / 4-mode /IPX6 / 300m throw / 6A output
2.95-3.25 (2 flashes)
3.25-3.55 (3 flashes)
3.55-3.85 (4 flashes)
> 3.85 (5 flashes)
Convoy L6 3500LM LED Flashlight
5-mode / 2*26650 / IPX6 / 734m / 806m throw
Convoy Z1 520nm Green LED Flashlight w/ Focus Zoom
OSRAM KP CSLPM1.F1 LED /IPX4 / 300m throw / 6A output
Weltool W35A 686LM 6500K Weapon Mounted LED Flashlight
1-mode / 1*18350 / IP67 / 653 yards throw
Use suggestions:
Specifications:
I’m really liking all the recent Convoy flashlights being added to the store. I hope this keeps up going into the future!
I am glad to hear that you like the recent Convoy flashlights we added to our website. We will try our best to add more flashlights. Thank you.
Weltool W5 699LM LEP Flashlight w/2*22430 Batteries
authentic / 2-mode / 2807m throw / 1970000cd / 2*22500/2*22430 / USB-C charging / IP67
Instructions:
Specifications:
New Arrival! Convoy C8+ 449-453nm Blue LED Flashlight
OSRAM KB CSLNM1.14 emitter / 4-mode / 1*18650 / IPX6 / 100m throw / 4.8A output / SMO reflector
New Arrival! Convoy M1 LED Flashlight
I also recommend you another new arrival Lumintop GT Nano 450LM 6500K EDC LED Flashlight w/10180 Battery
OSRAM OSTAR Projection Compact KW CSLNM1.TG emitter / smooth/stepped ramping / w/Micro-USB charger / IPX8 / 300m throw
Specifications:
User interface:
Head diameter: 24mm
The prices include Europe VAT like Aliexpress?
[WTS] HID host: http://budgetlightforum.com/node/68693
[WTB] Interesting LEDs:http://budgetlightforum.com/node/68968
FastTech 2022 CNY 10% off Site-wide Sale
Dear Valued customers,
The Lunar New Year is coming. Hope the rising sun will bring with it bundles of joy, health, wealth, happiness, and luck. Happy Chinese New Year!
We’ve prepared a 10% off site-wide promotion for you! It’s time to save more!
CNY Site-Wide Coupon
Offer: Site-wide 10% off
Valid Date: Feb 1st, 2022 – Feb 3rd, 2022 (UTC-6)
Coupon Code: TIGER2022
Customers can buy gift certificates Paypal or credit card to get an extra 3% free value instantly.
1.
Order Placed:
2.
Order Placed:
3.
Order Placed:
4.
Order Placed:
Order Total: $45.64
5.
Order Placed:
6.
Order Placed:
The Journal of Alternative Facts™
Light Up Your Outdoor Adventures – UP TO 22% Off
Limited offers, don’t miss out!
COUPON CODE: DEALS
More of these, please…
XHP50.3 HI LED
Joeholmanonline.com
Any Manker coupons?
Thank you for your suggestion, Joe. We will list more related flashlights and LED Emitters to our store as soon as possible.
And ch1ir,
Annie
D.Q.G Hobi Plus 120LM 3200K LED Keychain Flashlight w/10180 Battery
authentic / Cree XP-G2 emitter / 3-mode / Micro-USB charging / 50m throw
