FastTech New Arrivals & Promotion
1384 posts / 0 new
Bort
Bort's picture
Last seen: 6 min 29 sec ago
raccoon city wrote:
I think Boaz suggest taking a box of cereal, cutting the box up, and using some of the thin cardboard to use as a spacer.
I mean, a plastic 21700 to 26650 adapter would be better, but if you can’t find one…
I was thinking of using crazy glue to fill in the empty space, the battery would then become a permanent part of the light LOL
Perhaps red loctite Cool
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
Correllux
Correllux's picture
Last seen: 2 hours 3 min ago
Bort][quote=raccoon city]I think Boaz suggest taking a box of cereal, cutting the box up, and using some of the thin cardboard to use as a spacer. I mean, a plastic 21700 to 26650 adapter would be better, but if you can't find one…[quote wrote:
2mm o-rings, or possibly 2.5mm in a smaller size that would be stretched more. I’ve looked for plastic tubing of the right size, even if it needed to be bored out a tad, but haven’t yet found any. The old brown 26650->18650 adapters could be used/bored, I guess.
fasttech
fasttech's picture
Last seen: 1 day 21 hours ago
FASTTECH - LED Flashlights, Lasers and Electronics
fasttech
fasttech's picture
300LM 4500K LED Headlamp Bike Bicycle Front Tail Light w/1.48Wh Battery
1*XPE white & 16*SMD red LEDs / 7-mode / USB-C charging / 90’ adjustment / w/hook & magnet
FLASHLIGHT MODES Red Light: Marquee Fast > Marquee Slow > Fast Flash > Slow Flash White Light: Hi > Lo > Strobe
fasttech
fasttech's picture
Baseus PIR Motion & Photosensitive Sensor LED Wardrobe Light
authentic / 3-mode / USB-C charging / magnetic adsorption
Details:
Rated input: 5V 1A
Rated power: 0.63W
Color rendering index: RA>=80
Operating temperature: -10 to 40’C
fasttech
fasttech's picture
6000K Car LED Headlight Bulb
3570 55mil chip / IP68 / fast heat dissipation
Details:
Service life: >50000h
Voltage: Wide voltage 10-32V
Heat dissipation principle: Double-sided copper substrate + double copper tube heat dissipation
Passed CE & ROHS certification
fasttech
fasttech's picture
Lumintop GTA 550LM 6500K EDC LED Flashlight
OSRAM OSTAR Projection Compact KW CSLNM1.TG emitter / 5-mode / 1*14500/1*AA / IPX8 / 585m throw / 85000cd
Details:
Waterproof: IPX8 (submersible to 2m for 30 minutes)
Impact resistance: 1m
Head diameter: 36mm
Tail diameter: 19mm
Beam range: 585 m
Flashlight modes: Lo > Mid > Hi > Turbo > Strobe
Lens Type: Double Side AR Coated Glass Lens
Mode memory: Yes
Reflector Type: Aluminum Smooth/SMO
Switch placement: Tail
Switch Type: Clicky
Tail stand: Yes
Bort
Bort's picture
Details:
Please don’t buy this for on road use.
Its not legal in most countries and its likely to blind other drivers which creates a safety hazard.
fasttech
fasttech's picture
Lumintop Frog 570LM 6500K EDC LED Flashlight w/10180 Battery
smooth/stepped ramping / USB-C charging / IPX8 / 135m throw / 4580cd
Details:
User interface:
By default the GT Nano is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
Driver: Texas Avenger FET driver
Body: Aluminum with Type III hard-coat anodizing
Button: Tactile with back-lit rubber boot
Optic: TIR optice lens
Waterproof: IPX8 (submersible to 2m)
Head diameter: 15.6mm
fasttech
fasttech's picture
Bort wrote:
Please don’t buy this for on road use. Its not legal in most countries and its likely to blind other drivers which creates a safety hazard.
Bort, sorry to hear about this. Is it because of the high lumen?
Lightbringer
Lightbringer's picture
Last seen: 1 hour 10 min ago
Most LED headlight replacements don’t (can’t, in fact) have the chips exactly placed where the filaments would be in a regular bulb. That throws off the focus, and you lose the sharp cutoff at the top of the beam. So there’s much more glare to oncoming drivers.
Even with “lowbeams” on, to oncoming drivers, the lights will look overly bright as if driving with “highbeams”. Easy way to get pulled over and cited. But just in general, it’s not very nice.
I have all LED bulbs in my exterior lighting except the headlights. I bought several different types of “bulbs” for front/rear turn-signals, marker lights, etc., and am using those which have a good appearance and brightness, essentially “cherrypicking” the good ones.
Headlights, though, nope nope nope. They might be bright as far as lighting up all of Hell’s Creation in front of you, but they’d also blind oncoming drivers. And I don’t want to risk getting a ticket, or worse, having my car impounded for “dangerous” equipment. ($$$)
fasttech
fasttech's picture
Dear Lightbringer, Thank you for your input. We will remove this Car LED Headlight Bulb from our website.
fasttech
fasttech's picture
Lumintop Thor 3 400LM EDC LEP Flashlight w/21700 Battery
white laser emitter / 2-mode / 1*21700/1*18650 / IPX8 / 2500m throw / 1562500cd
Details:
Temperature control protection: When the temperature of the flashlight exceeds 50 degrees, it will automatically downshift, and the brightness can be manually adjusted after downshifting.
When using 18650 Li-ion batteries, an 18650 conversion tube is required (not including 18650 battery and conversion tube).
Supports one pointed 21700 lithium battery with protective plate.
Waterproof: IPX8 (submersible to 2m for 30 minutes).
Switch: Rear E-switch with RGB light.
Head diameter: 59.3mm
Tube diameter: 25.4mm
fasttech
fasttech's picture
Check Out The Best Sellers Of May – Up To 35% Off
Coupon Code: DEALS
Ends on: June 20th
fasttech
fasttech's picture
Lumintop Ant Man Aluminum Alloy 165LM EDC LEP Flashlight
white laser emitter / 1-mode / 1*14500 / IPX8 / 590m throw / 87025cd
Lumintop Ant Man Stone Washing / SandblastingTitanium Alloy 300LM EDC LEP Flashlight
white laser emitter / 3-mode / 1*14500 / IPX8 / 700m throw / 122600cd
Details:
Head diameter: 22mm
Tube diameter: 19/20mm
Please note:
The intensity of the flashlight is extremely high, and it is strictly forbidden to shine directly into the eyes.
Keep away from children.
ArtieT59
ArtieT59's picture
Last seen: 9 hours 54 min ago
Fasttech - Any discount on fenix Ld22 v2?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
ArtieT59
ArtieT59's picture
Bort wrote:
I mean, a plastic 21700 to 26650 adapter would be better, but if you can't find one...
I was thinking of using crazy glue to fill in the empty space, the battery would then become a permanent part of the light LOL Perhaps red loctite 8^)
Convoy sells O-ring , they work really well. I use them for 21700 in my astrolux ft03. And before on mf01 mini.
Paul321
Paul321's picture
Last seen: 2 weeks 22 hours ago
Fasttech- Does this “Best Seller” XOSS G+ come with the accessories to mount to bicycle, charge battery , and the wheel sensors?
Paul-
Bort
Bort's picture
ArtieT59 wrote:
I was thinking of using crazy glue to fill in the empty space, the battery would then become a permanent part of the light LOL Perhaps red loctite Cool
Got link?
fasttech
fasttech's picture
ArtieT59 wrote:
Fasttech – Any discount on fenix Ld22 v2?
ArtieT59, the price of fenix Ld22 v2 is $56.93. We will have a site-wide anniversary celebration on June 15th. You can get the discount at that time. Thank you.
fasttech
fasttech's picture
Paul321, XOSS G+ has the rubber gasket, bile computer mount, rubber band, USB cable with it. We will add the details to the Specifications and upload a picture.
fasttech
fasttech's picture
Gravity Sensor Stepless Dimming 24*2835 SMD LED Night Light Table Lamp
Details:
Features:
Adopt SMD2835 high-efficiency chips, high brightness, low power consumption, low light decay, no flicker, soft light, energy-saving, and environmental, more than 85% energy saving than traditional halogen lamps.
Built-in gravity sensor, first turn on the light by touching the switch, tilt to the side with the touch switch, and the light turns on. tilt to the other side without the touch switch, the light turns off, and repeated operations will keep turning the light on/off repeatedly.
The unique appearance design and the seesaw-shaped lamp body design make gravity sensing operation more simple and convenient.
Multiple power supply methods. Built-in 400mAh battery, when the battery runs out, you can plug the USB cable into various USB device interfaces such as computer, power bank, USB adapter, etc. for charging, which is very convenient and practical (We give away 1 meter USB cable).
There is a touch switch on the lamp, long press can stepless dimming, and adjust the desired brightness according to actual needs.
Using ABS shell material, efficient heat dissipation, improves heat dissipation efficiency, effectively prolongs service life up to 50000 hours, and can work for a long time.
No installation is required, just place the light where you need it and use it. It is very convenient to use.
Applications:
This LED light can be used for a study desk, bedside, computer desk, living room, bedroom, kitchen, cabinet, bathroom, etc.
More specifications:
Voltage: DC 5V
Beam Angle: 270’
fasttech
fasttech's picture
2-in-1 Portable Camping Hanging Table Fan LED Light
3-mode / USB-C charging / stepless speed change / 270’ rotation / low noise operation
Power & Batteries
Batteries included: Yes
Battery capacity (MFG RATED): 5200 mAh
Battery type: Fixed
Input type: DC 5V
Power consumption: 1-6 W
Required battery count: 2
Estimated charging time: 4-5 Hours
fasttech
fasttech's picture
FastTech 10th Anniversary Celebration: 15% off Site-Wide Coupon Sale
Dear all,
Good News! On the occasion of this anniversary sale, FastTech has prepared many activities with big discounts for our customers. It will be the greatest sale event of the year and definitely maximize your savings! SHOP MORE, SAVE MORE! Don’t forget to set alarms ahead of time, so you won’t miss anything!
————————- Anniversary Site-Wide Coupon ———————————
Offer: Site-wide 15% off
Valid Date: Jun 15, 2022 – Jun 18, 2022 (UTC-6)
Coupon Code: FT2022
———————————— Anniversary Giveaway —————————————
Enter to Win
Ends on June 19, 2022 (UTC-6)
———————————— Anniversary Order Gifts ————————————-
Random Free Gift!
FIRST COME, FIRST SERVED!
—————————- Extra 3% value on gift certificates —————————-
Customers can pay via PayPal or credit card for buying gift certificates to get an extra 3% free value instantly.
The Gift Certificate is good as cash, a fast and easy way to check out, you can use it to get anything you like.
In addition, gift certificates can be used in conjunction with other site wide coupon promotions. And the gift certificates are valid for 5 years from the purchase date.
fasttech
fasttech's picture
Special Sale! Happy Father’s Day – Up to 25% Off
To the world, you are one person, but to one person you may be the world. Happy Father’s Day to all Fathers!
Let’s grab a present for father now!
Coupon Code: DEALS
Valid Date: June 19 – June 26, 2022 (UTC-6)
fasttech
fasttech's picture
1500LM 6500K LED Flashlight w/Focus Zoom
XHP70 LED / 3-mode / 1*26650/1*18650/3*AAA / USB-C charging / IPX4 / 200-300m throw / window breaker
Beam range: 200-300 m
Flashlight modes: Hi > Lo > Strobe
Lens type: Convex Lens
Mode count: 3
Switch placement: Side
Switch type: Clicky
Zooming: Yes
Rusty Joe
Rusty Joe's picture
Last seen: 3 hours 49 min ago
Mode count: 3
Switch type: Clicky
Zooming: Yes
Can this be turned on and off directly or do I have to cycle through all modes?
fasttech
fasttech's picture
Rusty Joe, The flashlight will turn off after a long press.
fasttech
fasttech's picture
SolarStorm D1E 800LM 6500K 80m Underwater Diving EDC LED Flashlight
L2 LED / 3-mode / 1*26650/1*18650 / 332m throw / 18500cd
Details:
Head diameter: 51mm
Tail diameter: 39mm
Beam range: 332 m
Lens type: High-Transparency Tempered Lens
Mode count: 3
Mode memory: No
Reflector type: Aluminum Smooth/SMO
Switch Placement: Side
Switch type: Clicky
Tail Stand: No
Thermal sensor/throttle: Yes
fasttech
fasttech's picture
IMALENT MR90 50000LM 6000K LED Flashlight w/4*21700 Battery Pack
authentic / 8*Cree XHP70.2 & 1*Luminus SBT90.2 emitters / 8-mode / IP56 / 1586m throw / 629000cd
Details:
High-efficiency constant current circuit will maintain constant brightness.
Built-in thermal control module will automatically adjust the brightness output, keep using comfortably.
Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface treatment.
Head diameter: 92mm
Tube diameter: 56mm
Beam range: 1586 m
Flashlight modes: Turbo > Hi > Mid II > Mid I > Mid Lo > Lo > Spot > Flood
Lens type: Double Side AR Coated Anti-scratch Optical Lens
Mode count: 8
Reflector type: Aluminum Textured/OP, Aluminum Smooth/SMO
Switch type: Clicky
Tail Stand: Yes
