FastTech New Arrivals & Promotion
1445 posts / 0 new
poohduck
Last seen: 6 hours 1 min ago
fasttech wrote:
poohduck wrote:
what currency are the advertised prices?
Hi poohduck,
All prices listed on our website are in US dollars. If your home currency is not US dollars, please note that your credit card issuer or bank does the final conversion. The rates that your bank uses are not controlled by FastTech. You can check our FAQ for more reference. Thank you.
Thanks Raccoon city and fasttech
fasttech
fasttech's picture
Last seen: 4 weeks 6 hours ago
Manker Timeback III 2500LM 6500K EDC LED Flashlight
authentic / 4*Luminus SST20 emitters / 8-mode / 1*18350 / 200m throw / multi-color ambient lights
Details:
Main light operation mode:
Moonlight mode: Long press the key for seconds to enter the moonlight mode (0.1 lumen)
Normal mode: Click the key to enter the normal mode (long press the key to switch between low light (46 lumens) – medium light (200 lumens) – high light (600 lumens))
Turbo mode: Double click the key to enter the turbo mode (2500 lumens-Automatic downshift one minute)
Special mode: Press the key three times to enter the special mode (press the key for a long time to switch strobe-beacon-SOS)
Tail light operation introduction:
Battery indicator: Automatically turn on the tail light, automatically turn off after 10 seconds (you can customize five display modes of power)
Customize five display modes: Long press for three seconds to enter the custom mode in the shutdown state (long press to switch five modes, and release to lock the current display mode)
FASTTECH - LED Flashlights, Lasers and Electronics
wle
wle's picture
Last seen: 14 hours 20 min ago
thanks
will never buy manker
terrible switch on earlier product, no warranty support, too expensive
sorry
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 49 min ago
Just wait a few weeks for Utorch to come out with a copy. LOL LOL LOL
fasttech
fasttech's picture
Klarus GL4 3300LM 6500K Tactical Rail LED Flashlight w/21700 Battery
authentic / Cree XP-L2 HD emitter / 6-mode / USB-C charging / IPX8 / 370m throw / 34240cd
Details:
Voltage: 2.8-4.2V
Impact resistance: 1.5m
Waterproof: IPX8 (30 minutes operation submerged 2m)
370m range can be easily adapted for both tactical and outdoor use
Professional cable switch setup for maximum versatility
1913 rail compatible
Please note: When attaching or detaching the GL4 light, unload and remove the magazines
Tactical/outdoor settings, different situations, different uses
fasttech
fasttech's picture
Manker MC12 II 950LM Green EDC Tactical LED Flashlight w/USB-C 18650 Battery
authentic / OSRAM OSTAR Projection Compact KP CSLNM1.F1 emitter / 3-mode / IPX8 / 650m throw / 97600cd
Details:
Powered by 1× 3.7V 2600mAh high-drain protected 18650 rechargeable lithium ion battery with USB Type C charging port (Included) 18650 battery built-in charging & reverse charging circuit with a USB Type C port. Plug the included USB Type C charging cable (integrated OTG), it can be charged (max. 5V/1A). And also reverse charged to other digital device, works as powerbank.
High efficiency constant current circuit provides a stable output (Non-PWM).
Electronic reverse polarity protection and over discharge protection.
User interface is simple and friendly. Only 2 modes + strobe, defaults on high mode.
Lens: Double-sided anti-reflective coated, 99% transmittance toughened glass lens + high temperature resistant total internal reflection (TIR) lens
Material: Constructed from aircraft-grade aluminum alloy.
Surface Treatment: Premium type-III hard-anodized anti-abrasive finish.
The anti-slip knurling on the tube guarantees a firm grip within your palm and offers better user experience.
Stainless steel pocket clip works on the pocket, belts, the backpack, and is molle system compatible.
Forward click tactical tail switch allows for momentary-on and constant-on illumination.
Specialized silicone button cap facilitates precise tactical operation with gloves.
IPX8 waterproof standard (2 meters under water).
Impact resistance: 2 meters.
Battery charging indicator: Plug USB Type C socket of the included charging cable into the USB Type C port of 18650 battery, and connect another USB socket to the adapter. 18650 battery has built in intelligent identified charging function. When battery is charging, the indicator will be red and keep flash. After battery charging is completed, the indicator will stop flash and red constant on.
Powerbank Indicator: Plug USB Type C socket of the included charging cable into the USB Type C port of 18650 battery, and connect another USB socket to the USB port of the digital device. 18650 battery built-in intelligent identified discharging function. When battery is reverse charging, works as powerbank, indicator will be blue constant on. When battery have not enough power to charge other digital device, blue indicator will turn off.
fasttech
fasttech's picture
Details:
Moonlight mode: Long press the key for seconds to enter the moonlight mode (0.1 lumens).
Normal mode: Click the key to enter the normal mode (long press the key to switch between low light (46 lumens) – medium light (200 lumens) – high light (600 lumens)).
Turbo mode: Double-click the key to enter the turbo mode (2500 lumens-Automatic downshift one minute).
Special mode: Press the key three times to enter the special mode (press the key for a long time to switch strobe-beacon-SOS).
Battery indicator: Automatically turn on the tail light, and automatically turn it off after 10 seconds (you can customize five display modes of power).
Customize five display modes: Long press for three seconds to enter the custom mode in the shutdown state (long press to switch five modes, and release to lock the current display mode).
Lightbringer
fasttech wrote:
Whoa, cute!
That looks like a little R2D2 from Star Track!
Auxilshunter
Last seen: 2 hours 44 min ago
Star Wars Wink
Lightbringer
Auxilshunter wrote:
Star Wars Wink
Naw, Star Wars had The Daleks.
fasttech
fasttech's picture
Jump Into Fall With Our Autumn Sitewide Sale 12% Off!
Offer: Site-wide 12% off
Valid Date: Sep 27th – Oct 1st, 2022 (UTC-6)
Coupon Code: SEP12
Customers can buy gift certificates via PayPal or credit card to get an extra 3% free value instantly.
fasttech
fasttech's picture
Convoy 3×21B 12000LM 6500K LED Flashlight
3*XHP70.3 Hi LEDs / smooth/stepped ramping / 3*21700 / USB-C charging / 529m throw / 70kcd
Details:
Low voltage warning: automatic power off
Required battery type: 3*21700 batteries (without protective plate)
Head diameter: 69mm
Battery tube diameter: 51.8mm
Please note:
Reverse polarity protection: None, all the positive poles should face the head, otherwise the battery will be burnt.
If you carry the flashlight in your bag, please loosen the battery tube half a turn to prevent the flashlight from accidentally lighting up and burning the valuables in the bag.
fasttech
fasttech's picture
Convoy M21G LED Flashlight
GT FC40 LED / 5-mode / 2*21700 / IPX6 / 500m throw / OP reflector
Details:
Switch: tail switch controls on/off, side switch controls the mode
LED: soldered on 20mm copper plate
Head diameter: 55mm
Outer diameter of battery tube: 27.9mm
Inner diameter of the battery tube: 22mm
fasttech
fasttech's picture
Convoy H3 1400LM- 2400LM 2700K-6500K EDC LED Flashlight Headlamp
Nichia 519A R9080 emitter or Luminus SST40 emitter / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw
Details:
Battery: 1*21700 lithium battery flat head without board (not included).
Drive: 6A output, with temperature control protection.
Switch type: electronic switch (with standby current, about 32 μA).
Tube diameter: 25.6mm.
Please note:
If the flashlight is placed in the bag, loosen the flashlight tail cover for half a turn or lock the flashlight by 10 clicks to prevent the flashlight from being opened by mistake.
If you do not use the flashlight for more than a week, take out the battery, or loosen the tail cover half a circle to prevent the battery from running out of power due to the standby current.
fasttech
fasttech's picture
Jump Into Fall With Our Autumn Sitewide Sale 12% Off Now!
Dear all,
After a fun-filled summer vacation, it’s time to unwind and enjoy the cozy weather of fall. Light breeze, colorful leaves, bare trees, discover how fun life can be at FastTech. Cool season, cool offers! Join our incredible 12% sitewide sale to celebrate the harvest.
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 15% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
Detail about gift certificate and user guide→
Coupon Code: SEP12
Paul321
Paul321's picture
PayPal payment is not available for my order – so I’m out . I’m not purchasing e-cigs or Li-ion products what goes on here?
Paul-
blueb8llz
Last seen: 1 day 7 hours ago
Website states invalid coupon for Sep12.
Edit* coupon is now accepted but it doesn’t change the price to my total. It does not deduct 12%.
Does the coupon not work with chargers?
fasttech
fasttech's picture
Early Fall Sale! – 7% Sitewide Off + 3% extra gift card
Dear valued customers,
We are preparing an Early Fall Sale during the National Day holiday! Let’s join the 7% Off Sitewide coupon sale now!
National Day Sitewide Sale
Offer: Site-wide 7% off
Valid Date: Oct 2nd – Oct 5th, 2022 (UTC-6)
Coupon Code: FALL7
3% extra amount by purchasing gift certificate:
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 10% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
fasttech
fasttech's picture
Hi Paul321,
You can contact our Customer service to manually create an order and send a PayPal link to you. Thank you.
fasttech
fasttech's picture
blueb8llz wrote:
Website states invalid coupon for Sep12. Edit* coupon is now accepted but it doesn’t change the price to my total. It does not deduct 12%. Does the coupon not work with chargers?
Hi blueb8llz,
If the item qty is above 3+, you will get the bulk price automatically. You can contact our CS to manually offer the 12% discount.
fasttech
fasttech's picture
Get Your Halloween Treats Early! 15% Off Sitewide Sale
Offer:15% Sitewide Off
Coupon Code: TREAT15
Oct 29th – Nov 2nd, 2022 (UTC-6)
fasttech
fasttech's picture
Nitecore NU05 V2 40LM 6500K & Red Ultra Lightweight LED Headlamp Kit
authentic / 4*LEDs / 5-mode / w/0.44Wh battery / USB-C charging / IP66 / PC construction
NU05 V2 can be attached to the headband or the back of the helmet for warning cars or people, aiming to guard your safety at night.
Utilizes 4 x high-performance LEDs
Dual white and red light sources
Built-in rechargeable Li-ion battery with a max runtime of up to 47 hours
Built-in intelligent Li-ion battery charging circuit with a USB Type C charging port
One-handed operable single-switch design
Available with 4 special modes
Built-in power indicator to indicate the remaining battery power
Constructed from durable PC material
Ultralight and compact design
Impact resistance to 1 meter
fasttech
fasttech's picture
Fenix PD36R Pro 2800LM 6500K EDC Tactical LED Flashlight w/21700 Battery
authentic / Luminus SFT70 emitter / 6-mode / USB-C charging / IP68 / 380m throw / 36600cd
The Fenix PD36R Pro rechargeable flashlight is a high-performance rechargeable flashlight that is sure to surprise you. Fitted with a Luminus SFT70 LED, this flashlight features an incredible performance by delivering a maximum of 2800 lumens to an impressive distance of 380 meters, all on the included 5000 mAh battery. The high-capacity 5000 mAh battery can be conveniently charged through the USB-C port on the flashlight. Operating this powerful LED rechargeable flashlight is simple with dual tail switches for momentary on/off, the ability to cycle through five lighting modes, and the activation of the instant strobe. Additionally, you will always be able to see the battery’s charge status at a glance with the external battery level indicator. The amount of power and runtime packed into this flashlight are unmatched for its handheld size. IP68-rated dustproof and waterproof, this flashlight is the perfect all-purpose lighting tool for those needing maximum brightness and long runtimes.
Features:
2800 lumens maximum output and 380 meters maximum beam distance.
Uses a Luminus SFT70 LED with a lifespan of 50,000 hours.
Included a 5000 mAh 21700 rechargeable Li-ion battery.
Instant activation and instant strobe with dual tactical tail switch.
Reverse polarity protection, to protect from improper battery insertion
Toughened ultra-clear glass lens with anti-reflective coating
Boot-up battery level indication and low-voltage warning.
Made of A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
1m impact resistance
The Proprietary APF system makes a super tactical flashlight.
Intelligent overheat protection (IOP) ensures that the surface temperature does not exceed 60’C to prevent the risk of burns.
fasttech
fasttech's picture
Fenix E-CP 1600LM 6000K EDC LED Flashlight w/18.5Wh Battery
authentic / Luminus SST40 / 6-mode / 18W fast charging & discharging / IP68 / 222m throw / 12400cd / power bank function
Party The Fenix E-CP is a high-output flashlight with a power bank that’s capable of projecting 1,600 lumens with a useful far-reaching beam of 222 meters. The built-in 5000mAh high-capacity battery can last up to 504 hours. This groundbreaking flashlight defines maximum versatility. Use it as an everyday carry light or a mobile power bank – it can handle either job confidently. Its tail is fitted with USB-A and USB Type-C interface, supporting 18W efficient fast charging, whether to charge the light itself or to charge external digital devices such as mobile phones. High-strength aluminum alloy body, IP68 rated protection, E-CP is built to withstand harsh environments, and it is the best choice for your daily use, outdoor activities, and gifts to families and friends.
Features:
1600 lumens maximum output and 222 meters maximum beam distance.
A Luminus LED with a lifespan of 50,000 hours.
Built-in a 5000 mAh rechargeable battery.
Anti-slip body design ensures a firm grip.
The light tail features a power bank function supporting 18W fast charging and discharging.
The electronic lockout function avoids accidental activation.
Made of durable A6061-T6 aluminum.
The flat tail makes tail-stand lighting possible, the power bank function supports emergency lighting needs.
fasttech
fasttech's picture
Fenix E-SPARK 100LM 6500K EDC LED Keychain Flashlight w/2.96Wh Battery
authentic / 4*LEDs / 5-mode / USB-C charging / IP24 / 30m throw / 225cd / power bank function / red signal light
Details:
The Fenix E-SPARK a rechargeable keychain flashlight with a power bank function. With the built-in 800mAh battery, it produces a maximum output of 100 lumens. Timely recharge the light through the USB Type-C charging port when you need constant illumination, and this light is capable of charging your mobile phone for emergencies. The functional red light and red flashing are perfect for signaling. Keep this light on your keys, in a pocket, or a drawer to always have a flashlight at your fingertips. Trust this keychain light for your everyday needs.
Features:
100 lumens maximum output and 30 meters maximum beam distance.
Four quality LEDs with a lifespan of 50,000 hours.
Built-in 800 mAh large-capacity Li-Polymer battery.
Power bank function for mobile phone charging with USB Type-C port.
Lockout function avoids accidental activation.
The tail protection cover can be used as a diffuser tip fitted on the light head.
Battery level indication for instant checking of remaining battery level.
Bright 5 lumens red light and red flash offer conspicuous recongnition for vehicles and fellow travelers, providing for safe activities in the dark.
The quality PC-made tail protection cover can be used as a diffuser tip on the light head for a softer dark-adapted vision.
1m impact resistance.
fasttech
fasttech's picture
Manker E05 Cu Bundle 400LM 6500K EDC LED Flashlight w/USB-C 14500 Battery
authentic / OSRAM KW CGLNM1.TG emitter / 3-mode / 1*AA / IPX8 / 250m throw / 15625cd / red copper construction
Impact resistance: 2m
Operation: User-friendly One Button Interface
Turn OFF/ON:
When the light is OFF, one click tail switch to turn the light ON.
When the light is ON, one click to turn the light OFF.
Mode Operation:
When the light is ON, half one click the tail switch to cycle through ‘low – High’. Quickly double half-one click to activate the hidden strobe.
When the light is OFF, one click the tail switch to turn on a low level, A single click after this urns the light OFF, and then one click to turn on the High level.
*Please note: *The flashlight is made of red copper. This material is easy to oxidize and turn black in the air, which is a normal phenomenon.
fasttech
fasttech's picture
Convoy H3 1400LM 2700K EDC LED Flashlight Headlamp
Nichia 519A R9080 emitter / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw
Battery: 1*21700 lithium battery flat head without a board (not included)
Please note:
Driver instructions:
Click to start up, enter the brightness before the last shutdown, long press the switch to enter step-less dimming (brightness increase), release the switch, and long press the switch again to enter step-less dimming (brightness decrease). When the step-less dimming range (1-100%) reaches the maximum or minimum, it flashes to indicate the maximum or minimum brightness. The brightness of the flashlight can be memorized after releasing the switch.
When the driving temperature reaches 55 degrees, the brightness starts to decrease slowly, and the flashlight will use the reduced brightness as the benchmark, and the reduced brightness will be used for the next startup.
Press and hold for 0.5 seconds to ultra-low brightness (0.2%) in the shutdown state, and click to shut down. If long-press, there will be no response (ultra-low brightness will not be memorized).
Double-click in any state to reach 100% extremely bright (the extremely bright at this time belongs to the part of stepless dimming, click to shut down, and long press for stepless dimming. With memory)
In the shutdown state, click the switch 3 times to enter the burst flash (50% brightness progress) without memory function, and click the switch one time to return to the original state. If long press, no response will be made.
In the shutdown state, click the switch 4 times to enter the tactical momentary on mode. At this time, there is only one gear 100%. Press the switch to directly turn on the extremely bright 100%, and let go to turn off the light. 4 click to exit the tactical mode. The tactical mode also has temperature control.
In any state, press the switch 5 times and the voltage indicator flashes at 1% brightness (count the number of LED flashes, corresponding to the voltage. For example, the LED flashing ***pause******* means that the voltage is 3.7V. Click to return to the original state.
In the shutdown state, click the switch 6 times, the stepless dimming will switch to the conventional four-gear mode (1%-10%-30%-100%), click the switch, and long press the switch to change gears. To switch back to stepless dimming, just click the switch 6 times after shutting down.
In the shutdown state, click the switch 10 times to enter the locked state. The light flashes twice at 1% brightness to indicate that it is locked. In the locked state, no matter the long press, short press, or double tap, it will flash once to indicate that it is in the locked state. The lock can be unlocked with another 10 clicks.
Note that this is the only unlocking method. Considering that the flashlight will be accidentally unlocked due to the special situation that the positive electrode of the battery will be separated from the driving copper column and the power will be cut off due to the violent vibration. The flashlight can not be unlocked by manually loosening the tail cover and removing the battery.
Low voltage protection function: when the voltage is lower than 3V, the stepless dimming and gear mode will automatically jump to 1% to work, except for ultra-low light. But it can also be dimmed. If it continues to be below 3V, it will jump back to 1%. It will shut down automatically when it is lower than 2.8V.
fasttech
fasttech's picture
Happy Halloween! 15% Off Sitewide Sale! Get Your Halloween Treats Early!
Happy Halloween! Our treat to you! All the witches are talking about this Sale. We launched a 15% discount with the code TREAT15. Don’t miss it!
Halloween Sitewide Sale
Offer: Sitewide 15% Off
Valid Date: Oct 29th – Nov 2nd, 2022 (UTC-6)
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 18% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
fasttech
fasttech's picture
WUBEN X-0 1100LM 6500K EDC LED Flashlight w/4.07Wh Battery
Samsung LH351D emitter / Titanium Alloy / 7-mode / USB-C charging / IP68 / 125m throw / 3920cd / magnetic tail cap / tritium slots for customization / 175’ floodlight
X-0 features a sturdy clip and magnetic tail cap, making it suitable for a range of indoor or outdoor activities!
Designed to also offer stress relief, this serves as a switch, as well as providing optimal water and dust protection for its USB Type C charging port!
Powered by a replaceable Li-ion 18350 battery, it can be fully charged in just 1.5 hours!
Tritium slots for customization
Waterproof: IP68 (submersible to 2m for 1 hour)
fasttech
fasttech's picture
Convoy 3×21B 12000LM LED Flashlight
Head diameter: 69mm
Please note:
Input voltage: 3-4.2V, maximum output current 15A
Click to start up, enter the brightness before the last shutdown, long-press the switch to enter stepless dimming (brightness increase), release the switch and long-press the switch again to enter stepless dimming (brightness decrease). When the stepless dimming range (1-100%) reaches the maximum or minimum, it flashes to indicate the maximum or minimum brightness. The brightness of the flashlight can be memorized after releasing the switch.
Press and hold for 0.5 seconds to ultra-low brightness in the shutdown state, and click to shut down. If long-press, there will be no response (ultra-low brightness will not be memorized).
In the shutdown state, click the switch 3 times to enter the burst flash (50% brightness progress) without memory function, click the switch one time to return to the original state. If long press, no response will be made.
In the shutdown state, click the switch 10 times to enter the locked state. The light flashes twice at 1% brightness to indicate that it is locked. In the locked state, no matter long press, short press or double tap, it will flash once to indicate that it is in the locked state. The lock can be unlocked with another 10 clicks. Note that this is the only unlocking method. Considering that the flashlight will be accidentally unlocked due to the special situation that the positive electrode of the battery will be separated from the driving copper column and the power will be cut off due to the violent vibration. The flashlight can not be unlocked by manually loosening the tail cover and removing the battery.
