Blitzwolf BW-LT5 lantern
45 posts / 0 new
Hobo
DBSAR wrote:
Just discovered that link is gone from GB now..
It’s not. My link got damaged because of the BLF update. I fixed it.
8) Lube Threads Everyday 8)
southland
southland's picture
What’s the run time?
Hobo
I did a runtime test with my unit. It shut off after 7 hours and 10 minutes at the high setting. You can turn it on again after it shut off automatically. I got another minute at high until it shut off again. You can do this again and again… At the moment I test how long it takes to charge.
will34
will34's picture
Last seen: 12 hours 32 min ago
Mine is modded with a Panasonic NCRB and I get close to 11 hours on high, and the amp draw at this level is ~300mA.
Hobo
I took mine apart and it has another battery than the one L4M4 has. It’s blue and actually says 2600mAh. No brand.
The battery has 4,17V when fully charged.
M4D M4X
M4D M4X's picture
Last seen: 2 months 3 days ago
code 12blitzw gives 10% to 17.99 USD atm
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Scorpia
Last seen: 1 year 9 months ago
Just saw this,
Preorder for the “pro” version,
Looks like the same thing with a panasonic 3350mah battery,
I ordered one as i was looking at the bw-lt5 normal edition but the pro is cheaper atm
http://www.banggood.com/BlitzWolf-BW-LT5-Pro-IP68-Waterproof-LED-Panasonic-3350mAh-Powerbank-Emergency-Camping-Lantern-p-1090454.html
angerdan
angerdan's picture
Last seen: 2 hours 11 min ago
Did anyone try to tear down the BlitzWolf BW-LT5 lantern?
I would like to know how easy it is to replace the 18650 cell.
dealgrabber2002
Last seen: 1 hour 47 min ago
angerdan wrote:
Did anyone try to tear down the BlitzWolf BW-LT5 lantern? I would like to know how easy it is to replace the 18650 cell.
One pic shows it seems like they solder the battery. Looks quite easy to upgrade to a better battery.
angerdan
angerdan's picture
Which image do you mean?
saypat
saypat's picture
Last seen: 2 hours 13 min ago
love this light, use it nightly on the low mode. Great light, great price!
pilotdog68
pilotdog68's picture
Last seen: 6 months 2 days ago
In this post
S53SG
Last seen: 3 years 6 months ago
L4M4 wrote:
The cell is unprotected, yes – but I hope that there is a protection circuit on the pcb Silly
The cell protection circuit is done by “classic” DW01-P IC (U4 in SOT23-6 case near micro USB connector) and dual MOSFET 8205A (U8 in TSSOP-8). The U2 seems to be an USB charging logic for battery, but I cannot found the datasheet.
Logic for driving the LED diodes is U3; microcontroller, which driving buck-smps in CC mode. So bad it’s some of unknown Chinese uC, beacuse I wanted to re-write SW to remove red strobo function and add more white LED current modes.
DBSAR
DBSAR's picture
Last seen: 1 day 20 hours ago
Just received mine from Banggood Great little light, well built. firs thing i’m going to do with mine is swap out the cool white SMD LEDs with some 4000K or 3500K higher CRI SMDs, or 5 or 6 Nichia 119’s.
