Olight 16340 RCR123A 650mAH (Cyan)
Official specifications:
Type: RCR123A-650mAh
Model No: ORB-163P06
Chemistry: Li-ion
Capacity (mAh): 650mAh
Voltage: 3.7V
Maximum Charge Current: 650mA
Maximum Discharge Current: 2A
Charge Current: 300mA recommended
Charging Cycle: 500
Weight: 17.7g
Dimensions (Diameter x Height): 17 × 34 mm
Olight CR123 rechargeable substitute (Read here about rechargeable CR123)
The two cells has different capacity, not really ideal for usage in series. They can easily deliver 1A, but 2A is more doubtful.
Conclusion
The cells has the rated capacity, but they do not match very well. Saying they are for high drain devices are optimistic, they are not high current cells.
Notes and links
Comparison to other LiIon batteries
