*BLF LT1 Lantern Project) (updated Nov,17,2020)
11492 posts / 0 new
will34
will34's picture
Last seen: 8 hours 24 min ago
Looks great, put me down for 1.
I’m only worried about the diffusing material. Looks too white instead of a frosted clear material (Like sticking DC fix to a clear lens). White semi translucid diffusers can degrade over time and turn the tint yellowish/greenish.
DBSAR
DBSAR's picture
Last seen: 1 week 1 day ago
Tally-ho wrote:
What is the height difference between the V2 and the sample ? Doesn’t seem way more than about 1 cm.
I just measured it, and the test unit is 6 Millimeters taller. ( 1/4” inch)
Tally-ho
Tally-ho's picture
Last seen: 1 day 2 hours ago
Wow, I didn’t expect that much. Thank you for measurements.
gotang
Last seen: 1 month 1 week ago
Lexel wrote:
BlueSwordM wrote:
Dont’ forget we are aiming for 4 chips per channel.
That means 8×7135 total.
No! 4 total
ToyKeeper wrote:
For anyone who missed the details earlier, the lantern has 14 of the 7135 chips, with 7 attached to each set of LEDs.
Apologies for being slow, but now I’m really confused – is the plan 14× 7135 chips on the board in total (i.e. 7 per channel) or 7×7135 chips on the board? Also, I’m glad to hear that all 7 chips are going to be populated – I think my soldering skills are up to forming a solder bridge, but probably not up to sticking an extra chip onto a PCB
Edit: Where are my manners?! Thank you to team LT1 – I am now ridiculously excited about this project. There’s already so much incredible work that you’ve put in, and I’m very grateful for it!
DBSAR
DBSAR's picture
Oops, typo, i meant 6 millimeters. Big Smile
Tally-ho
Tally-ho's picture
Big Smile
Right after your response I looked again at the pictures trying to figure what I didn’t get. My brain froze with confusion…how could it be 6 cm ?!?
Big Smile
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 14 min ago
Ah yes, I remember we discussed about it in PMs.
All of the 14 7135s will be soldered in.
However, only 4 per channel will be activated at the same time.
snakesnakington
Last seen: 1 year 4 months ago
I would love one. Thanks!
JermsMalibu
Last seen: 5 hours 55 min ago
That’s awesome that all the 7135s will be populated and that we just have to make solder bridges to bring the others “online”. Very smart and thoughtful of you all. Thumbs Up
BlueSwordM
That’s what we are planning.
We are planning to limit power via firmware, with only 4×7135 per channel being activated initially.
Edit: See, this is what happens when I’m confused.
sbslider
sbslider's picture
Last seen: 6 hours 36 min ago
BlueSwordM wrote:
That’s not what we are planning.
I don’t believe that is correct. The plan was to populate all 14 7135s (2 channels, 7 per channel), and allow folks to connect in additional ones by shorting pads. On the prototype all the pads came shorted. Like I think DBSAR said recently only 4 or 5 would be connected as “stock”.
ToyKeeper wrote:
For anyone who missed the details earlier, the lantern has 14 of the 7135 chips, with 7 attached to each set of LEDs. So it can make about 2.45A of warm white and 2.45A of cool white. For the middle tints, it tries to maintain a steady power level while changing the amount of power which goes to each channel. But exactly in the middle, it could also have a 4.9A turbo mode.
In the current prototype, middle tints actually decrease in power because the mixing formula doesn’t account for the non-linear PWM response curve. But I plan to fix that in firmware so it’ll maintain pretty close to a steady power level regardless of tint.
I think the plan is to set the default power limit to 1.4A or 1.75A. This increases the runtime without making it visibly much dimmer, and it also makes the light safer thermally. But those who want more power could simply touch a soldering iron to a couple spots on the battery side of the driver, and it would enable more of the 7135 chips. Creating a solder bridge like this is really quick and easy to do.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
DBSAR
DBSAR's picture
correct, that is the original plan. Have 4 or 5 connected from the factory by default, and the rest left open for those who want to push more output at a sacrifice of run times. I will be testing the maximum run times & amp draw loads with all 7 connected at first, then desoldering a couple of the 7135 bridges on each channel to get amp readings and run time comparisons then. The extra AMC chips are to be on the board for user modifications. (increase in output)
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 10 hours ago
Nope. The control chip doesn’t have the physical ability to activate individual 7135 chips.
There are two ways for the user to adjust the highest power level:
  • Physically connect or disconnect 7135 chips by adding or removing solder bridges on the battery side of the driver. This changes how much power is considered “100%”.
  • Use firmware to adjust the ceiling level lower than 100%, if desired. The firmware allows configuring the ceiling level, but it is set to 100% by default. If the user lowers it, 100% will still be available… but it is treated as “turbo” and is only accessible with a double click while already on a lower level.
Today there has also been some discussion of a “turbo plus” which would only work at 4000K color temperature… but I wasn’t planning to add anything like that.
Mr Excitement
Please place me on the interest list.
lmcmann
Last seen: 1 year 1 month ago
I’m already on the list for two, 688 and 689. Please add two more for a total of four.
I plan to pick up 4 full sets: lantern, batteries, case, etc, etc.
The first two are mine. Mine mine mine. The new ones are planned gifts. Depending on overall price, I can see picking up a couple more than four.
Amazing work, thank you.
One side note. I’ve been going out to Burning Man since the late 90s and have rigged up a ton of led solutions over the years. I’m the ‘light dude’ in our camp. This is exactly what I’ve been trying to make as far as a portable lantern goes. I’m not sure I want to be responsible for the possible carnage, but I think a post or three in BM forums would yield a great deal more initial orders. If that’s desired. At a risk of drastically lowering the S/N of this thread.
D10ten
D10ten's picture
I’m interested in one.
DBSAR
DBSAR's picture
There is no doubt this LT1 lantern can be a big interest outside for the general public eventually, as it fills a gap for a good quality area light/lantern that has recharability along with battery replacing, high CRI tint, functional design. portability, long-term off-grid uses, great modes, built out of metal (wont blow off the camp table like some plastic ones do i seen) the list goes on.
beastlykings
beastlykings's picture
Last seen: 9 months 3 weeks ago
Awesome, thanks everyone! Man this is cool. Put me down for 2 more, for a total of 4 please.
On the note of bringing in burning man people, I’m torn. I don’t want to bring more noise into this thread, but I do want people to appreciate this light. Maybe sofirn would be happier with us if we let the BM people pay full price? That sounds mean and selfish now that I say it. But I kind of feel that way, anyone else?
Also, just my opinion, I don’t think we should have a turbo+ mode. I don’t think there and be any mode that can overheat the head of this lamp. Because there is no efficient way to get heat to the MCU, correct? People could burn themselves. Unless we added a turbo timer? It’d have to be real short.
Maybe make it a config option in the source code? People adventurous enough to compile their own code, or find someone to do it, can be trusted with the extra power. In my opinion. I’m just worried about the people I plan on gifting these to.
BlueSwordM
Yeah, I agree with BM people having to pay the full price.
We have to respect Sofirn, and BLF itself.
lmcmann
No arguments, that’s why I tossed it out for discussion.
If you’re going to BM and are even remotely interested in leds, then you’ve most likely already found this place. If not, it’ll be a pleasant surprise.
Klocknov
Klocknov's picture
Last seen: 7 months 1 week ago
Add me for a third as well as the accessory kit with it. 1055 1056 are my first two. (Are you even tracking the accessory kits?)
ToyKeeper
ToyKeeper's picture
Correct.
The plan is to put a temperature sensor in the LT2, if there is one. Also, a constant current driver. This would require more pins though, so the driver would use attiny1634 instead of attiny85. Two pins per channel to control power, or four PWM pins total. Another for the e-switch. Another to control the button LED. Another for the temperature sensor. Another for a voltage sensor, since both the temp sensor and the constant current parts are incompatible with measuring voltage on the VCC pin. Plus ground, VCC, and reset. Etc. At least 11 pins needed.
I’m not looking forward to doing the math and the code involved in making tint ramping work with four power channels. It’ll be a bit tricky. I suppose the tiny1634 will have plenty of space though, so I can actually afford to do the math on the device itself instead of needing low-tech trickery to make it fit.
But first we need to finish the LT1. Smile
Yeah. The code is getting pretty messy with all the compile-time options though, and a “turbo plus” feature doesn’t easily fit into the abstractions the code uses. It all assumes the maximum power is 100%, with no means of going beyond that… but in this case, 200% is possible. So I probably need to figure out a clean way of enabling model-specific quirks like this which make no sense on other hardware. I also need to clean up the code in general.
sbslider
sbslider's picture
Definitely not at this point.
SIGShooter
SIGShooter's picture
Last seen: 1 hour 16 min ago
It wouldn’t be a lot of work to track accessory kits since it’s just an additional column in the table I created for the lantern buy. But as slider said it’s not being tracked and I have no plans to do so.
DBSAR
DBSAR's picture
Once we get the lantern ready for orders, we can start another topic GB I’m guessing for the accessory kit, as i still have to test some of the accessories I’m working on for the sample lantern.
ToyKeeper
ToyKeeper's picture
Yeah… tracking options which got added late in the project is a lot of work with questionable value for basically no reward. Not really worth it.
bc777
Last seen: 17 hours 40 min ago
Please add one more for me for a total of 2. I was #1205.
BlueSwordM
Yeah.
Other than the 4×18650s, accessories haven’t been really planned.
Stereodude
So is there going to be a second round of test units with fixes prior to production or is the plan to roll the fixes directly into production?
I’m interested to hear how the diffuser is affecting output since it looks pretty heavy.
Please add me to the list for a 2nd lantern. I’m currently on the list at #840
DBSAR
DBSAR's picture
I will be doing a test of the diffuser/lens (in comparison to the V1 & V2 tonight or tomorrow.
