*BLF LT1 Lantern Project) (updated Nov,17,2020)
11668 posts / 0 new
RobertB
RobertB's picture
Last seen: 1 week 2 days ago
All due respect, but it looks like a solution to a non-problem
sbslider
sbslider's picture
Last seen: 3 hours 21 min ago
SerenityNow wrote:
Just received this reflector from a gentleman on reddit. I think it’s gonna be awesome!!
I think I’ve experimented with reflection behind my LT1 and haven’t noticed a big difference in the illumination in the area where the reflected light would go. What’s your experience with this device? Too bad he didn’t do a better job applying the reflective tape.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
SerenityNow
Last seen: 1 month 1 week ago
The tape doesn’t bother me at all and doesn’t noticeably change anything, but i can always change it out if needed at some point.
I use my LT1 a lot for night time reading and from what I can see, it allows me to use a lower output than normal, and prevents “wasted light.”
Honestly (and it’s still daytime here so I haven’t been able to thoroughly test), it seems way more efficient to use, if I don’t need 360 degree light.
sbslider
sbslider's picture
I like the idea, do you mind asking how much it cost?
SerenityNow
I bought a “blemished” version for $5 + shipping, so maybe $15 all in.
He is selling black for $25 shipped and glow-in-the-dark for $30 shipped.
ReManG
Last seen: 2 months 4 weeks ago
!https://i.postimg.cc/G211g0ft/Polish-20201010-112501859.jpg!
Looks like a good way to walk around using the LT1 as an area light as well. Anyone that has ever watched a movie where they hold a 360 degree lantern up to see better should understand the fallacy of this, it puts as much light back in your face as you are getting from elevating the light… Facepalm
maba
Last seen: 5 hours 1 min ago
I have it, good job bro! Cool
Old Davo
Last seen: 2 weeks 1 day ago
Disappointed. Just got a message saying they cannot supply the orange lanterns.
The wait continues.
ossifrage
Just happened to be buying 2 LT1s for someone else and noticed the orange. Site let me order but quickly got an update from Sofirn that there’s no stock. The person answering messages didn’t know when colored lanterns would again be available.
MandM78
Yup. Same here. Took them 2 days to message me, but sadly, no more orange.
DBSAR
DBSAR's picture
Last seen: 5 days 17 hours ago
That looks awsome! Thumbs Up Big Smile
cedarman
I was using my lantern in my RV this past weekend and noticed something new that I can’t seem to find any reference to. My switch LED was flashing slowly in an orange color. What does this mean?
treellama
Last seen: 3 hours 51 min ago
You can set the indicator lights to high, low, flashing, or off. Seven clicks to change mode while not locked out, three clicks while locked out.
cedarman
Ah, okay, I see that now on the instruction sheet. I must have inadvertently changed it to flashing while locking/unlocking (which I do all the time). Thanks!
tornade
Hi! Did some search about flashing the lt1 in this thread and few others… Last info about that dated in 2019. Would like to know if someone achieve to flash anduril 2? I already flashed my D4V2 and KR1 with it and now using two different anduril version makes everything complicated for nothing… I’ve read that we need different programming kit than the D4V2 one… Last info found is we need to buy the HQ lexel progkey and build it yourself wich I don’t have the knowledge and equipment for… I’d like to buy a kit ready to use… Anyone have info where I can find that?
ToyKeeper
ToyKeeper's picture
tornade wrote:
flashing the lt1 … anduril 2? … need different programming kit than the D4V2 … HQ lexel progkey … Anyone have info where I can find that?
The lantern can also be reflashed with a SOIC8 clip… which is much easier to obtain.
Otherwise, yes, it can run Anduril 2. I’m using it on mine.
DBSAR
DBSAR's picture
Sad to hear, hope they can still build the Olive green, FDE, and bare aluminum models still.
cu42
Last seen: 8 months 3 weeks ago
I am still holding my breathe for olive green or something close.
I have not been on here for a long time.
Are there any accessory kits available or at least a reflector to block the back facing light?
Gessner17
Can someone help me out? I bought a new one of these, has Rev 5 board. I was going to bridge 6,7 pads but noticed none of my pads were bridged and from looking around it looks like all rev 5 pads are not bridged. Can anyone shed some light? I thought 4 and 5 were always bridged from the factory. Was v5 changed?
SIGShooter
SIGShooter's picture
Last seen: 10 hours 8 min ago
4 and 5 are now bridged with 0 ohm resistors rather than being soldered.
Gessner17
So if I want to bridge 6 and 7 I can still do so and it will work the same as it did before?
SammysHP
SammysHP's picture
Last seen: 6 hours 43 min ago
Yes.
Gessner17
Another question, does anyone know why it recommends not running it on high if only off USB (no batteries connected)?
iamlucky13
Last seen: 5 hours 55 min ago
Whining noise from the charge regulator chip, I believe.
niajef
Last seen: 3 days 3 hours ago
whats the ATL for the LT1?
TimMc
TimMc's picture
Last seen: 6 hours 13 min ago
LT1 arriving soon. Big Smile
Which Anduril firmware should I update it to?
I have a SOIC8 clip to modify a UT210E…
SammysHP
SammysHP's picture
The LT1 build of Anduril 2?
TimMc
TimMc's picture
Most up-to-date build of Anduril 1 is already installed on the LT1?
https://budgetlightforum.com/node/67518
DudeMan
DudeMan's picture
Last seen: 4 months 5 days ago
before flashing, see if there is a feature you want/need on it first?
mine came with SOS, long push from off gives low mode. i’m good Party
TimMc
TimMc's picture
DudeMan wrote:
before flashing, see if there is a feature you want/need on it first? mine came with SOS, long push from off gives low mode. i’m good Party
Good point. I’ll only flash it if there’s some bug that was fixed for a feature that I’d use. Beer
