*BLF LT1 Lantern Project) (updated Nov,17,2020)
11852 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 20 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
DBSAR wrote:
I have and still use/test the same original production prototype …
Yeah, it’s pretty nice overall. I think I actually prefer its more-plain top design with a simple curved handle and no O-ring or extra bumps. It works well.
As for the LT1-mini, I’m not sure how practical it will be outdoors — because of its narrow base and relatively small surface area for the diffuser. This makes it hard to place on uneven surfaces, and the higher surface brightness constricts the pupils more at the same lumen levels as a larger design. But it works well indoors, fits into a pocket, and would probably be good when clipped onto a belt or something. I’ve been using it a lot as a candle and for general illumination.
The LT1-stout seems interesting too, as a lighter alternative to the original LT1. Since it’s wide, it should be pretty stable and have lower surface brightness for less glare. But since it’s also short, it won’t be as good when placed on a table or something… it’ll generally need to be raised up on top of something else.
phouton
Last seen: 13 hours 16 min ago
SammysHP wrote:
Now it shows a different code for 30% that also doesn’t work.
Yes, it says “96M1P86TR2YN Get 30% off on orders over US $20.00”, but it does not work for the LT1.
I messaged them on AliExpress and was told it is suitable only for the Yakorsei GD12… if so, very irritating and misleading.
Torciofilo
hello, I recently received a new version blf lt1 with Power bank, firmware August 2021, I cannot in any way get the temperature calibration menu, the battery menu contains only the Beacon and SOS, even the reset with 13h does not work, has it happened to any of you? I reset by unscrewing the base but even if the reset is successful, the menu situation does not change. Ah, for the LT1S I created a container in 3d to insert it and hold it up (you can find it in thingiverse)
SammysHP
SammysHP's picture
Last seen: 2 hours 37 min ago
You are in simple UI. 10H to switch to full UI.
Torciofilo
no unfortunately it is not that, I am in the advanced ui
ToyKeeper
ToyKeeper's picture
Torciofilo wrote:
blf lt1 … cannot in any way get the temperature calibration menu
All temperature functions are disabled in the LT1 because the thermal sensor is too far from the LEDs to perform any regulation. Also, it needed the extra ROM to make tint ramping work.
If Sofirn produces a newer version with a bigger control chip, like attiny1616, it should include the thermal functions again, even if it’s still too far to use for regulation… because at least then it could work as a crude thermometer.
Torciofilo
so you also don’t have the external temperature calibration menu? it seems strange to me, moreover the 13h to reset does not work, I am thinking of having a faulty lt1
ToyKeeper
ToyKeeper's picture
All temperature functions are disabled in the LT1.
Different build targets have different configurations. The 13H reset has traditionally only been enabled on lights which can’t do the loosen-hold-tighten reset method.
It doesn’t sound like there’s anything faulty about your LT1.
Torciofilo
Thank you very much, very kind, okay, it amazes me that both the seller and whoever reviews on YouTube don’t know, I asked them too, thanks again.
Verodin
Last seen: 43 min ago
So today I finally removed the 0 ohm resistors to lower the brightness of the 2700K leds. The idea was to keep the 5000K ones. But the WW side is connected to the 5000K leds and NW to the 2700K. Why oh why!? At least the PCB solder bridges are a very nice addition and easily resolved the mixup. I did notice the same WW/NW mixup on the MCPCB in another LT1 that I took apart for an emitter swap. The silkscreen doesn’t match with the LEDs, so this one probably has the same mixup.
Btw, concerning the Anduril 2 driver. Compared to the rev 5.0 driver, does the hardware offer anything new other than power bank functionality? Was thinking of maybe flashing the rev 5 to Anduril 2 if possible.
DudeMan
DudeMan's picture
Last seen: 38 min 40 sec ago
was wondering this myself. my friend who isn’t an enthusiast is getting an Anduril 2 LT1. mine is an early release.
DBSAR
DBSAR's picture
Last seen: 2 days 10 hours ago
As Toykeeper mentioned, the temperature are disabled, as they are not needed in the LT1. ( The LEDs & heat sink are at the top (head) of the lantern & away from the driver & battery body area, meaning he driver & batteries are away from the LED heat.
DudeMan
DudeMan's picture
i have an early (first?) release LT1. i found 1 below the top level of stepped is sustainable. top level gets hot.
i don’t know what rev firmware i have, as tracking the flashing is tricky for my old eyes/brain.
phouton
story wrote:
I got the Sofirn v1.0 and BLF-LT1-A2.
BLF-LT1-A2
- The green power button light is on even when it’s in use. It’s necessary as it’s hard to find the button when you need to turn it off. It’s distracting.
- Power bank works with my USB-C to USB-A adapter for iPhone
Sofirn v1.0
- The amber light will be dim when it’s on. It’s too dim to be useful when I want to turn off my LT1.
- Power bank doesn’t work with my USB-C to USB adapter for iPhone
- Power bank works with USB-C to USB-C, I can power the SP36
- Anduril 1
I like the Sofirn v1.0 during standby. I keep this in the corner on a selfie stick with tripod mount. With the button towards the corner, it would reflect a very nice ambience light at night. It’s frankly easier to turn off the LT1 with my index finger when the button is away from me.
I will update it to Anduril 2 and see if the power bank will work for iPhone.
I just ordered an orange LT1, but that green light is making me change my mind.
My orange LT1 (box labelled Q8LT1) from Sofirn’s AliExpress shop shows BLF-LT1-A4. One difference from the BLF-LT1-A2 is that the indicator LED is now orange. Perfect. Any other differences?
I love how the indicator LED automatically adapts to the main light’s brightness: dim at low brightness, and high at high brightness. Such attention to detail, just fantastic!
The orange anodizing looks gorgeous to me. It looks slightly bronze-ish in some images below due to the camera, but it’s more orange in person. I was also very tempted by the green option, but figure a more visible color is useful to avoid losing it!
Some questions:
  • The only way I found to get out of momentary mode (5C from ON or OFF in Advanced UI) is to unscrew the lantern until power is cut. Is there another way? The UI map shows this mode is a dead end.
  • Sunset mode is reducing brightness in steps, even if the light is set to smooth ramping. Any way to have it decline smoothly?
It’s surprising how pleasant and nostalgic candle mode is, especially in the warmest tint.
Big thanks and congratulations to all involved in the LT1 project!
SammysHP
SammysHP's picture
Great! Too bad Sofirn used the green ones for a while.
phouton wrote:
* The only way I found to get out of momentary mode (5C from ON or OFF in Advanced UI) is to unscrew the lantern until power is cut. Is there another way? The UI map shows this mode is a dead end.
No, that’s by design. Momentary mode should allow blinking in morse code and other stuff and with only one button there’s no other reliable way.
phouton wrote:
* Sunset mode is reducing brightness in steps, even if the light is set to smooth ramping. Any way to have it decline smoothly?
It can get better (smaller steps) with a firmware modification, but not perfectly smooth.
phouton
Ah, makes sense, and in that case it’s actually a cool feature. The UI diagram should probably still indicate how to exit this mode, even if it’s physical vs electronic.
Other observations:
  • 2H from OFF in Advanced UI is a turbo momentary, unlike what the UI map shows.
  • The ramping seems to go all the way to max/turbo level. Maybe I misunderstood, but it seems the UI map shows ramping or 2C to reach the ceiling level, then a further 2C for turbo. Instead, a second 2C just returns to the previous brightness for me.
Btw, I’m looking at the 2021-08-02 revision of the UI map for the LT1.
As the saying goes, the biggest room in the world is the room for improvement. Fading in steps is a bit jarring, but I’ll survive. Big Smile
ToyKeeper
ToyKeeper's picture
Fading in steps …
The floor and ceiling levels are configurable. On the LT1, the default is to allow full power because it’s not a hotrod light. This can be changed though.
About fading in steps, it’s mostly because of the power circuit having coarse resolution at a hardware level. I’ve been thinking about ways to work around that, but the only solution I’ve come up with is really complicated and would require pretty major changes to the code.
Basically, the hardware allows for 256 total steps including “off”. When the light is at level 5/255 and needs to fade to 0 over the course of 5 minutes, it’ll slowly drop to 4 then 3 then 2 then 1 then shut itself off. These steps are quite visible.
To fix it, I’ve been thinking about making it alternate between levels very quickly, like at 16 kHz. So instead of dropping from 2 to 1 all at once, it would go 22221 for a while and then 21221 for a while, then 12121, then 11211, and then just 1. And each step there would last for only a fraction of a millisecond, so it would hopefully look smooth by eye. But to make it work, it would need extremely precise, consistent timing, and a bunch of math, and some core parts of the code would need to be completely rewritten.
So… for now, the steps are still visible during low modes.
At high levels, it doesn’t matter. Dropping from 240 to 239 isn’t a visible difference. But dropping from 3 to 2 sure is.
DudeMan
DudeMan's picture
were the green indicators in the description? the orange button is part of what makes the light great.
the momentary mode is indeed for Morse code. unscrewing is the only way i know of to reset.
phouton
I see, so that’s what it means when the UI map mentions that the factory default ceiling is 150/150. Now it makes sense. I confirmed that turbo works as expected if the ceiling is reduced. Interesting, and ultimately the default makes sense.
Thanks for that explanation. The proposed solution sounds clever. Before even trying to implement it in Anduril, has the eye’s perception of this strategy been tested?
In any case, it’s already amazing how much Anduril can do and how it spices up the LT1. Thanks for your efforts.
Spine Grinder
Spine Grinder's picture
Last seen: 10 hours 26 min ago
Can anybody help me out? I have been gone for so long that I don’t even know if I had a user name so I had to create a new one. I was here when this project started, but never bought the lantern. I am getting ready to buy one or two and the mini later. What is the current status of a 21700 version, distant future? Should I just get the current version? I am a bit confused on their Ali store because I remember the whole problem with the USB-C and want to get the latest version. I assume that is the one listed as New Anduril 2? The price is really good right now! Thanks for any help in advance.
SIGShooter
SIGShooter's picture
Last seen: 1 hour 28 min ago
There has been some discussions on a 4 cell 21700 version but not much more than that. If it was me I’d get the current version because it could be some time before a decision is even made on producing one.
Spine Grinder
Thanks for the reply. I decided on one plus 2 of the LT1S and a flashlight. Now I am remembering why I never order… they never have the pretty colors they show.
Lixivium
Lixivium's picture
Last seen: 1 day 5 hours ago
3*21700 in the center of a Nalgene sized, full-body diffuser with a third red channel in addition to the two tint ramping white channels. Waterproof and floats.
DudeMan
DudeMan's picture
sounds like a fisherman’s dream.
Bob_McBob
Last seen: 9 hours 27 min ago
I recently ordered a second LT1 from Sofirn which UPS promptly lost, so they sent me a brand new production light to replace it. This one is a BLF-LT1-A4 driver with the wonky flashing pad configuration, Anduril version 202108290621. The switch backlight is orange by default, and uses a blue/pink combo for charging and power bank, or solid blue while on and plugged in. It gets stuck using either blue or blue/pink while on for a little while after being unplugged.
This particular light arrived with a weird issue where the tint ramping didn’t work properly. It didn’t memorize the setting at all so it always turned on in WW, but every second turn-on it would go through a sequence where it immediately flipped to CW on the first attempt, flipped back to WW and smoothly ramped to CW on the second attempt, then worked properly on following attempts. A factory reset solved that issue and TK told me it was probably caused by incorrect values causing an overflow. Of note, 13H factory reset doesn’t work in this Anduril build, which was rather confusing since it’s included in the UI flowchart.
phouton
What is the factory reset on Anduril version 202108290621? Or is there none?
ToyKeeper
ToyKeeper's picture
It uses the original method:
  • Loosen tailcap (or in this case, the battery tube)
  • Hold the button
  • Tighten tailcap
  • Keep holding button until the strobing turn into a bright flash (about 3-4 seconds), then let go
If the user lets go before the flash, the factory reset is cancelled. It strobes in increasing intensity for about 3 seconds as a warning, sort of the flashlight equivalent of “Are you sure?”. Then it goes to full power to signal that the reset happened, and it quickly fades to off.
The factory reset animation originally came from my lightsaber firmware. It did the same thing, but in that UI, instead of “factory reset”, it was called “self destruct”.
phouton
  • Hold the button
  • Tighten tailcap
Thanks!
Barry0892
Barry0892's picture
Last seen: 4 hours 33 min ago
  • Hold the button
  • Tighten tailcap
Hi TK,
Sorry to ask here but it seems two prototypes of Q8 pro 1616 version ans SC21 Pro 1616 version were delivered.
Do you have them now? Would you please help confirm the firmware? It seems there are bugs there.
We are going to transfer all Anduril lights into 1616 version but waiting for firmware without issues.
Please help.
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
Verodin
Installing the new driver in an older LT1. But when screwing on the battery tube, it goes on full brightness and pressing the switch has no effect. The green switch LEDs toggle between dimmed and full on when pressing the switch. Anyone has any idea what might be causing this?
Update:
Solved. When putting it back together the CW wire ended up being squeezed and the insulation broke causing a short (direct battery connection?). Seems there’s no permanent damage.. phew…
