*BLF LT1 Lantern Project) (updated Nov,17,2020)
11500 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 12 hours ago
Another reason for only using 4 LEDs is the intercompatiblity with the BLF Q8 MCPCB.
I would love easy MCPCB swaps.
sbslider
sbslider's picture
Last seen: 7 hours 5 min ago
Kendo wrote:
I’m intrested
got ya at #820 on the interest list
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
O26Rcr
How about we let DBSAR continue down the road he has decided to travel with this light? Opinions are fine, (after all, this is one), but he has time, effort, and tangible results to show for his work. Impressive results at that.
Throwing suggestions out for lower power LED’s, or different numbers of them to make it easier for you to mod are kind of a slap in the face to the work he has done already. If you want a particular style of lantern, grab yourself a Q8 and have at it.
I’m quite happy with his intent to use 8 emitters, and having the ability to adjust the temp. If I wasn’t, I wouldn’t be on the list for four of them, (and possibly more before it’s in production).
djozz
djozz's picture
Last seen: 2 hours 14 min ago
I do not agree. The suggestions that I give are unrelated to the work that Den has done, his design ideas and field test have been very important for making a great BLF-lantern. But I think I can add genuine good ideas and think it is a chance missed if they have not at least been discussed in this thread.
I think BLF is all about freely and perhaps recklessly posting new ideas and then discuss them. It is how our present modding techniques have been invented and refined, and how the BLF designs take form.
DBSAR
DBSAR's picture
Last seen: 8 hours 10 min ago
BlueSwordM wrote:
I don’t think we should be doing an 8 LED MCPCB.
It would raise costs by quite a bit.
I think 2 Samsung LH351Ds 3000k and 2 Samsung LH351Ds 5000k would be just perfect.
Cost is definitely a factor we want to keep down.
DBSAR
DBSAR's picture
I take everyone’s suggestions & ideas as important as it helps make the project better and more of what everyone want to have in a lantern when possible Smile I have started the cross-section drawing to send to Thorfire and the specification perimeters for them to have a plan start to work on what they can do to make it into production.
fuzun
Will this light need pointed batteries?
sbslider
sbslider's picture
If you mean “button top” batteries, the answer is this is prefered. The positive contact is a trace on a circuit board, so the button top would make a sure connection here. I am hoping I can use old laptop pull batteries with the attached connection tabs foormed such that it will simulate a button top, we will see if that works or not.
ToyKeeper
ToyKeeper's picture
Last seen: 11 hours 41 min ago
djozz wrote:
The Samsung lh351d is not very expensive, at Digikey when ordering a reel it is 1.22 per led (cool white 70 cri, the high cri versions may be a bit more expensive). So 8 leds add up to about $10 worth of leds, I bet Thorfire gets them even cheaper. It is a significant part of production costs so 2warm/2cool may be more economical, but it is not impossible either.
Another option is doing what the whole lighting industry is doing for a good reason: skip the high power leds (which are developed for directed lighting which we are not doing here) and go with a whole bunch of midpower 3030 leds or 5730 leds. Cheaper per lumen, blending is even easier, ledboard is cheap (DTP not needed) and there’s plenty options for tint and high CRI.
Heck, you could use 3000K and 5000K Nichia Optisolis leds and beat everything existing in CRI.
That all sounds pretty reasonable. I’m glad I don’t really have to care what exactly the LEDs are, as long as they perform well enough. Smile
I just made some things a few days ago which used a bunch of cheap LEDs, and it all turned out pretty okay. Granted, soldering on each pixel individually was a bit of a pain, but the overall effect is nice.
Anyway, when we’re farther in the process, send me a prototype and I’ll make it work.
mattlward
mattlward's picture
Last seen: 4 hours 33 min ago
Put me on the list for 1 at this time!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
sbslider
sbslider's picture
you are now 821 on the interest list
interest list sorted by entry number
interest list sorted by user names
These links are always updated to the latest versions of the lists.
DBSAR
DBSAR's picture
So far the LH351D 4000K High-CRI LEDs are my favorites for a balance of efficiency, tint color, & CRI, Have not tested the 3000K 351Bs yet, but will be when i get to my east cast destination. Also adding a fourth 7135 AMC to the driver to increase output for testing. was curious if Samsung has the LH351D available in 5000K high CRI? (for that tint-blending option.
BlueSwordM
They do.
However, the only source I have found of 5000k 90CRI+ emitters in small quantities is Digikey.
nquinn
Last seen: 1 week 4 days ago
Is there a reason you don’t want to go to a lower temperature like 3000k? To me if I’m camping I want something close to fire light and as warm as possible.
DBSAR
DBSAR's picture
Candle/fire tints are around the 2000K range, I had one LED of that tint, but found it’s tint to be very yellow/orange, (close to that of a fire flame) and seemd to be somewhat not very efficient for higher outputs. I have a few Strawhat 5mm LEDs of the 2000K candle tint range that i swapped on some nightlights as they give that candle glow effect, but seems to be to yellow for a brighter lantern. 3000K is what is in the V1 prototype now.
nquinn
Agree that 2000 would probably be too low. I’d have to see it in person but from the prototypes I kinda like the 3000k over 4000k photo. Totally understand that the 4000k will have more brightness overall though.
DBSAR
DBSAR's picture
UPDATES: – I will be leaving on June,6th to drive to NovaScotia & Newfoundland. I have the prototype lanterns packed up, with the tools to do LED swaps & testing while there during camping trips. I will also finish the design cross-section drawing for the new lantern to send to Thorfire too there as i will have my laptop with me. Will post the drawings next week here for everyone to have a look at before i submit them to Barry at Thorfire to begin the work to get it rolling Smile
sbslider
sbslider's picture
Have a great and safe trip DBSAR! Big Smile Looking forward to the next round of field results.
dealgrabber2002
Last seen: 2 hours 58 min ago
Man, trip after trip. You, Sir, are living the good life. I envy you. Enjoy and have safe trip.
nick91900
I’m in for 2
goshdogit
goshdogit's picture
Last seen: 4 hours 10 min ago
Enjoy your trip, and take a few photos of your mobile modding workspace! Thumbs Up
sbslider
sbslider's picture
nick91900 wrote:
I’m in for 2
added to the interest list at 822 and 823
angerdan
angerdan's picture
Last seen: 13 hours 58 min ago
Again USB Type-C:
Memorandum of Understanding on the future common charging solution for smartphones
_USB Type-C™ to be the common charging interface for
other types of portable electronic equipment as mentioned in the Radio Equipment Directive 2014/53/EU (article 3.3a).
In furtherance of this end, signatories agree to gradually transition to the new common charging solution for Smartphones based on USB Type-C._
http://www.digitaleurope.org/DesktopModules/Bring2mind/DMX/Download.aspx...
https://www.heise.de/newsticker/meldung/Einheitliche-USB-C-Ladegeraete-in-der-EU-sollen-kommen-4069422.html
So maybe v2/batch two of the BLF Lantern could be equipped with Type-C port Don’t have to be USB 3.x electronically.
But support for programming with software would be a nice feature.
ToyKeeper
ToyKeeper's picture
It’d be awesome to have a usbasp inside, connected to the MCU for easy reflashing over USB. I don’t think it’ll happen though. Smile
Maybe a later version can use a beefier MCU with USB support built into a bootloader, and reflash directly over USB. That’s not attiny territory though; it’s more something I see on atmega chips.
Madtoffel
Last seen: 3 weeks 5 days ago
USB c sounds good, but I think that a normal micro USB 2A connection will be fast enough for the intended purpose of recharging the lantern with a small solar panel while you are camping. If you need to charge it faster you could still take out the batteries and charge them externally. Also I don’t know if many people would use usb programming because our current firmware seems to be nearly perfect.
Agro
Agro's picture
Last seen: 1 min 55 sec ago
Cool idea, but considering how few people would use it – I’d say it’s unnecessary cost.
angerdan
angerdan's picture
It’s just about the physical connector – no need for USB 3.0 protocoll or QC/PD.
And a firmware has no GUI and can’t show at once all settings/options.
severide
Last seen: 1 year 1 week ago
I’m in for one
sbslider
sbslider's picture
severide wrote:
I’m in for one
Indeed, I added you as #824 on the interest list.
Polyesterboy
Last seen: 2 years 8 months ago
I’m in.
