SALE: Low-cost copper pills, spacers, optics, drop-ins.
1846 posts / 0 new
Batch1
Last seen: 2 years 6 months ago
I received your kit a while ago. I receive my flashlight today : http://www.banggood.com/Convoy-M2-Upgrade-Version-DIY-EDC-LED-Flashlight-Host-1-x-18650-p-951513.html
new version without pill
The only problem I had to assemble it is with the ring with a groove that fit inside the flaslight over the optic, there were an asperity. I file it and everything fit nicely.
I put the o-ring that come with the flashlight inside the grove on this ring and the lens over it and screw the stainless steel ring over it. I have bought verything from you except the flashlihgt and the driver ( pill, leds, optic ) and no problem so far
Thanks
Robert
vwpieces
vwpieces's picture
Last seen: 1 month 1 week ago
Batch1 wrote:
I received your kit a while ago. I receive my flashlight today : http://www.banggood.com/Convoy-M2-Upgrade-Version-DIY-EDC-LED-Flashlight-Host-1-x-18650-p-951513.html new version without pill The only problem I had to assemble it is with the ring with a groove that fit inside the flaslight over the optic, there were an asperity. I file it and everything fit nicely. I put the o-ring that come with the flashlight inside the grove on this ring and the lens over it and screw the stainless steel ring over it. I have bought verything from you except the flashlihgt and the driver ( pill, leds, optic ) and no problem so far Thanks Robert
Does not appear that the M2 offered from BG is the ultra Flat black M2 with “TM” after the Convoy name.
I had no fitment issues with the same light host you have linked and used.
My Flat black Host came from GearBest and I have another assembled single emitter Flat Black “TM” light I received direct from Simon of Convoy.
Problems I experienced were from the ultra Flat Black M2 that Has the “TM” after the Convoy Name. This also Has the integrated emitter shelf and may possibly be the Newest offering from Simon.
The Quad I built is done and I used thermal epoxy for the Copper spacer in the host and I can not take it apart.
I am awaiting others that have used the Same host I have to report.
MAYBE… I received a mis made host that was rejected as a complete light due to fitment issues. I do not know.
I did what I saw fit to get my light built with the parts I had. Its Done and I am satisfied with it.
Batch1
The problem I had is not the flashlight, it was the copper ring with a groove on top in witch I put the o-ring that come with the flashlight. There was an asperity all around on the outside of that ring and that ring didn’t go inside the flashlight deep enough. I only tried if the parts fit and everything fit as it should. I took photos but I don’t know how to post it here !
Robert
vwpieces
vwpieces's picture
Sorry Robert,
I had several problems with a newer M2 host and was directing the issues I had in comparison to the host you used. My issues are in the What Did You Mod Today thread.
Yes the brass ring is tight because there are raised edges on the inside and outside of the ring from machining the tops and bottom after the OD/ID.
That ring does not fit the later M2 even after deburring the edges.
Batch1
vwpieces wrote:
Sorry Robert,
I had several problems with a newer M2 host and was directing the issues I had in comparison to the host you used. My issues are in the “what did you Mod today” thread.
raised edges the words I searched.
Thanks
Robert
kiriba-ru
kiriba-ru's picture
Last seen: 3 days 15 hours ago
Batch1, thanks for your fast reply.
Facepalm
kiriba-ru wrote:
2) Please DO NOT start to mill, sand, cut part if you see that it don`t fit. Just look why it don`t and measure dimentions of problem zone.
Robert
I have met this problems with SS rings in X5 set, 50% of manufactured were defects so I decided to use brass for such parts.
I`m checking all IDs to make sure there is more than 24.0mm to fit carclo quad inside, while external diameter is not so important because (as I thought) all hosts are same and 0.1-0.2mm gap will be enough. I hope all stock glass lens are same size (28.9mm), so I will make 28.6-28.8mm external ring diameter next time.
RotorHead64
RotorHead64's picture
Last seen: 11 months 2 weeks ago
I ordered a few X6 AL heatsinks on 5 Oct. I was surprised to receive them today 15 Oct. I’d say that was pretty quick shipping. The heatsinks look great. Thanks kiriba-ru
Ouchyfoot
Ouchyfoot's picture
Another package with more goodies from Russia arrived safe and sound.
Hmmmm…. What should I order next???
Kenjii
Kenjii's picture
Last seen: 7 months 2 weeks ago
kiriba-ru wrote:
Parts that will be available in a week: U11 quad conv. kit (?) imagebam.com
Hi,
any updates on the Manker U11 kit? I have a host waiting … i want just 1 piece.
Regards
Kenjii
kiriba-ru
kiriba-ru's picture
Lathe machining is made, now I have some problems with milling operator. Rings from brass are ready.
I will defenetly finish them but I cant promise deadline.
Kenjii
Kenjii's picture
And Eagle Eye X7 spacers?
kiriba-ru
kiriba-ru's picture
X7 Cu spacers, couple of P60 solid neck Al, couple of P60 solid neck Cu, second batch of M2 quad kits, few of F13 Cu spacers, few of P60 surefire-compatible RR quad drop-ins and S2+ Cu spacers are next to produce, I think this parts will be ready in the mid. of November.
giorgoskok
giorgoskok's picture
Last seen: 1 week 5 days ago
Can you say more for the “solid neck p60 AL” ?
Is this for triple or quad ?
kiriba-ru
kiriba-ru's picture
It is universal. Even single.
I wont show drawings because they do not show real proportions. Let it be made first.
vinte77
Is the solid neck p60 aluminum,the same as the ones that dsche used to make?
kiriba-ru
kiriba-ru's picture
No, it is different, but yes, idea is the same.
I have tried to make it most short. Copper insert have Convoy S threads (please take pills from this giveaway: http://budgetlightforum.com/node/49995 )
D10ten
D10ten's picture
Last seen: 2 weeks 18 hours ago
I want to get the Convoy M2 carclo quad copper spacer + brass liner. Just want to make sure that this is the whole kit right?
How about the M1 quad copper spacer? Can I order the whole kit as well?
Thanks!
kiriba-ru
kiriba-ru's picture
What do you mean by “whole kit”? With leds and pcb?
Do you already have M2 host?
D10ten
D10ten's picture
Sorry, I mean the optic, spacer, and liner for both the M1 and M2.
Yes, I have both host.
kiriba-ru
kiriba-ru's picture
No, optics is extra cost.
I dont have Khatod lens for M1.
Could you please check your M2 how it is described upper http://budgetlightforum.com/comment/1014935#comment-1014935 ?
kiriba-ru
kiriba-ru's picture
Few more optics in stock.
imagebam.com
Nicolicous
Nicolicous's picture
Last seen: 8 months 4 weeks ago
which optics are they ?
Nico -.-
kiriba-ru
kiriba-ru's picture
10507 20mm triple and cute-3ss 35mm triple.
Nicolicous
ill get some Carclo 10507 20mm triple Narrow Spot Plain on the next round order Big Smile
Nico -.-
hexcode
Last seen: 8 months 22 hours ago
If you can put together a kit for F13, I would like to get one from you.
kiriba-ru
kiriba-ru's picture
What do you mean “kit”? Solder leds to pcb and pcb to the spacer? When I have parts in stock I offer such services for free.
Anyway next parts will not be ready earlier than 3 weeks after this message.
hexcode
Nope, What I meant by kit was that I would like to buy complete set of parts.
Such as
MCPCB,
Copper Spacer,
Any rings for centering if needed
Optics.
I can do the build myself. Smile
kiriba-ru
kiriba-ru's picture
hexcode wrote:
MCPCB,
Yes, when XP32 board is in stock
hexcode wrote:
Copper Spacer,
Yes, when spacers are ready
I dont like when glass lens are pressed with the tir lens and when this is the only way to give pressure between o-ring and host, but X7 trasfotmation was designed this way. If it wont work and somebody will broke glass lenses, I will make rings between head top and bezel.
hexcode wrote:
Optics.
Yes, if CUTE-3 optics will be still in stock.
You (and other members too) can simply reserve parts when they are in stock. I will take plastic box, write your nick over and parts that were in stock at this moment will be waiting until you order could be full completed.
Mitko
Mitko's picture
Last seen: 10 months 1 week ago
I got some of those pills and they are great, i realy like the b158 one
Thanks m8!
I think its about a time for you to start offering custom hosts Wink
Texas_Ace
Texas_Ace's picture
Last seen: 9 hours 10 min ago
I just built 2x XP-G3 S2+ lights with your spacers, they work great! I am sure I will be ordering more.
Mixed tint triple = amazing.
