SALE: Low-cost copper pills, spacers, optics, drop-ins.
1839 posts / 0 new
Fc36
Last seen: 5 months 6 days ago
Actually, I just took another look at MTN and they don’t have any premade quad LED options, only triples. So I’ll have to stick with that. I’m looking at the carclo 10507 lens with a the noctigon 3x mcpcb with XP-L HI LEDs
kiriba-ru
kiriba-ru's picture
Last seen: 1 week 36 min ago
I think you can add quad pcb and 4 leds to the cart and check toolbox “solder options”.
Fc36
Ok so I’m back to quad then. Just added 4x XP-L HI LEDs and the standard MTN 4XP mcpcb to my cart at MTN. I also threw a carclo 10621 optic into the cart, but I’m still wondering if you think khatod would provide better temp protection and beam profile? Lastly, I already have an AR lens for the M1 that I’d like to put in front of the optic to protect it from debris. Afterall, firefighting isn’t exactly a profession that treats equipment nicely. Lol
kiriba-ru
kiriba-ru's picture
I have not seen anyone who could say why Kathod quad is better than 10621. I suppose this is the reason why I have not heard “khatod quad” for several years.
What do you mean by temp protection? If you need flashlight that can be heated from outside (fire), any plastic lens have similar melting point.
JaredM
JaredM's picture
Last seen: 4 min 32 sec ago
If you are trying to cut through smoke, you definitely don’t want a triple OR quad from khatod, carclo, or anyone. Your best option honestly might be the stock reflector and an Osram CSLNM1.FY (yellow-orange light) [available from Convoy Aliexpress]
You really want a narrow beam, ~4° and the narrowest/least intense spill (field) possible, and to achieve that in a light this size you need a single optic with a domeless emitter with 2mm² or smaller emitting surface area. Even the spill beam, though not intense, will blind you in the foreground and hurt your visibility. A very deep reflector or better a very narrow single TIR or even aspheric light is what you want. If you are ordering from MTN exclusively, he still has the UF-T20 host. Might be a good idea. It’s a glass lens – heavy but flame resistant. Try that XPL HI 2700k in there and compare to the quad setup you build and tell me if I’m wrong.
kiriba-ru
kiriba-ru's picture
You are right.
I think Convoy C8 with small warm led is also very good choice.
Fc36
JaredM wrote:
…or better a very narrow single TIR
Any chance you guys know a place to get a TIR that’ll fit the M1 or S2? For starters, I already have an extra M1 and driver just waiting for an LED and optic, so I’m going to stay away from the UF-T20 for now. Secondly, I’m currently running an S2 with a 3000K XP-L HI LED, OP reflector, and AR lens on my helmet, but it feels a little underpowered for what I originally wanted. I just worked a big extra alarm fire about two weeks ago and I had over an hour of runtime with it in extremely smoky conditions. Talk about trial by fire, all 3 floors were rolling with fire and here in Chicago, we rarely go defensive, so I was right in the thick of that fire and smoke ripping down ceilings and walls and “opening” windows for ventilation and overhaul. It was a great light, but in a few situations even on turbo I was hoping for a few more lumens and/or a little less spill from it. I’d love to upgrade the S2 with a TIR and also have an M1 quad/triple or single TIR as a backup.
Lightbringer
Lightbringer's picture
Last seen: 50 min 33 sec ago
Keep in mind that even a 2.8A S2+ will get too hot to even touch if left unattended even a few minutes. By “unattended” I mean not having an ungloved hand wicking away excess heat. Had one tailstanding for just 5min or so, and when I went to grab it to turn it off, I just dropped it, as it was like grabbing the business end of a curling iron. Needed to grab a shirt or something to use as an “oven mitt” to just get hold of it long enough to turn it off, and then drop it again ‘til it cooled off. Not Fun.
Tubelights have pretty lousy heat dissipation, no fins or anything to help with that, so build up heat fast.
“Smart” lights will throttle down on their own, but “dumb” lights will just keep going full-tilt ‘til the LED cooks, or even the driver pops, or worst case the cell itself overheats and vents.
You really need a bigger light for a) more thermal mass to soak up and spread out the heat, and b) way more cooling fins to dump that heat to the environment.
Fc36
Sorry to hijack the thread, but I really appreciate the help and advice from you guys. The S2 on my helmet is running a Bistro FET+7135 and the temp sensor is set to about 130°F (roughly hot water temp from the faucet) before turbo drops down. I also have it set with moonlight off (don’t need it on a helmet light in a fire) and 4 mode (25/50/75/100) light levels. It’s perfect for my needs, but I’m sure a TIR optic would improve the beam tightness. I was running it at 50/75 for most of the fire with no issues, but there were a few moments when I kicked it up to turbo for a specific task and it felt underpowered.
JaredM
JaredM's picture
I think you need more candela, not lumens (and the accompanying watts). Even running the same driver and led in the M1 will probably be a large improvement for you. Carclo 30 mm TIR could probably be made to work in the m1 with a custom spacer. It’s 14.3mm tall vs the reflector at 23.2mm. 7.2° beam with the HI and about 32cd/LM. ~25kcd would be pretty effective and sustainable IMO.
It happens someone here may be able to help with that Wink
kiriba-ru
kiriba-ru's picture
Hey BLF,
Today my thread celebrates 5 years.
And ATM it has almost 200000 views (which doesnt looks impressive nowadays, but I could never expect such numbers 5 years ago).
The BLF community was very kind to a random guy from non-friendly (toxic) area.
Here Ive got some good experience that I didnt had before. I was quite young and probably made many mistakes, but people here were so polite and rarely sent any negativity to my side.
This thread have helped me a lot, now its time to go further.
As some of you know, I was used to use someone`s else resources to make things. From one hand, I had people from whole over the world, that have high “internal quality” level and were happy to get parts if they are top notch. At the other hand, I had people that are hard to achieve great results with (even if they are doing their best) because of low “internal quality”. Ive tried my best to close this gap (learned so many measuring and hand work techinics, build many special tools and machines to mask machining imperfections), but at some point I started feel myself as gymnast in split position.
I cant say Im 100% ready but I just dont see other ways. I need my own cnc machine(s).
For this reason, I have not invested in materials and machining for a while, trying to minimize money frozen in parts. And thats why I wont restock parts for some time more.
I have removed sold out parts from the OP and each part amounts are updated.
From this message, I offer
25%
discount for any part from the OP.
Can also offer some parts that are not popular and not listed in OP:
Convoy C8TT heatsink head (bare with driver ring and o-rings) – $12 26pcs in stock
Convoy C8 stainless steel bezel (modified to flat top) – $4 6pcs in stock
Convoy C8 AR coated glass $2 24pcs in stock
S2+ (old threads) aluminium triple pill (with some dents) – $3 3pcs in stock
S2+ (old threads) copper single pill (no lip around pcb – for 20mm boards) – $5 1pc in stock
M2 aluminium quad spacer kit $5 1pc in stock
HD2010 copper pill $10 1pc in stock
Manker U11 aluminium quad spacer kit free 7pcs in stock
Brass contact rings for SRK style flashlights (BLF Q8 and etc.) free in stock
Please respect others and make a post if you want to get something (this way everyone knows how much is left).
KyleGates
Last seen: 1 day 19 min ago
I would be interested in a Manker U11 quad spacer kit but I would rather pay for it to help with your transition. Good luck with your new venture!
Agro
Agro's picture
Last seen: 1 month 3 hours ago
Congrats kiriba-ru. Party
Superstocker
Superstocker's picture
Last seen: 1 day 23 hours ago
Kiriba-Ru
I have placed a few orders with you and it has always been a great experience. Thank you for offering these parts and for your excellent service. I wish you the very best and look forward to new parts. I’ll take the M2 quad spacer and two U11 spacers from this list (If that is ok and I’d be happy to pay you some for U11 spacers, especially since I would be getting two), then I’d like to add 2 s21a spacers.
I’m hoping to see the maglite heatsinks come back and maybe a C8 6x spacer like Led4Power used to sell.
Thanks!
flightless22
flightless22's picture
Last seen: 1 hour 22 min ago
What happened to S2/S2+ spacers? I thinking stocking up some more.
MtnDon
MtnDon's picture
Last seen: 17 min 39 sec ago
Congratulations. I don’t need anything right now but have been pleased with my past purchases and the way you handled the orders.
kiriba-ru
kiriba-ru's picture
Last batch was produced two years ago. Only now they are sold out.
I used to get full rod (3m=10ft) of copper and run cnc batch that used most of this rod.
Today is not best time for another batch. Not only because Im trying to save some funds.
Raw copper prices have grown almost twice last year:
copper-prices-historical-chart-data-2021-03-07-macrotrends
Skylight
Skylight's picture
Last seen: 22 hours 6 min ago
Congratulations for your anniversary! Party Your sales thread is great. Crown Thumbs Up
I was always very satisfied with my orders from you. Keep up the good work.
PM send to order a Convoy C8TT heatsink head, S2+ aluminium triple pill, S2+ copper single pill (no lip around pcb – for 20mm boards), Brass contact rings. Many thanks.
Lionel1024
Hi, do you have a copper spacer for a Convoy S11 host for a quad MCPCB? Thanks.
Flashlight newbie with too many lights I'm trying to mod at once.
kiriba-ru
kiriba-ru's picture
No.
Since I have some 30mm copper rod, we can try to make mini-groupbuy for Cu S11 spacer.
Lionel1024
Thank you. Do I need to do anything, or we wait to see if anyone else is looking for a spacer?
Sorry, I’m new to all this.
kiriba-ru
kiriba-ru's picture
I will check my PMs, I think you are not the only one whos asked about Cu S11 recently.
Tom E
Tom E's picture
Last seen: 48 min 22 sec ago
Very much appreciated your offerings - wish I had more time for the mods. Been very happy with past orders. Congrats!! Beer
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 4 days 1 hour ago
It’s good that you are here with us. I have always been satisfied with your parts. I still have many unused items that I might use someday. Or I’ll sell them.
In the future I would like to see a solid aluminium triple pill for the S21A to keep the flashlight lightweight.
JaredM
JaredM's picture
Chatika vas Paus wrote:
It’s good that you are here with us. I have always been satisfied with your parts. I still have many unused items that I might use someday. Or I’ll sell them. In the future I would like to see a solid aluminium triple pill for the S21A to keep the flashlight lightweight.
Yes. 6063 Al would be great to see for more convoy pills.
TAK
Last seen: 1 month 1 week ago
Hi Kiriba-Ru!
I’m new to this, but very excited to maybe get my hands on a c8tt head, and also to see what new things you might be working on! I would like to order the following items please:
  • 1x Copper spacer for triple Convoy S21A ($5)
  • 2x Convoy C8TT heatsink head (bare with driver ring and o-rings) – ($12)
  • 1x Convoy C8 stainless steel bezel (modified to flat top) – ($4)
  • 2x Convoy C8 AR coated glass ($2)
I’ve also sent a PM that includes my address. Thank you.
OlegOlegOleg
OlegOlegOleg's picture
Hi Kiriba-Ru!
1. Is it in stock?
2. Just to check: is it a complete pill, that fits for triple S2+ build (no need for the spacer)?
kiriba-ru
kiriba-ru's picture
OlegOlegOleg wrote:
Hi Kiriba-Ru!
1. Is it in stock?
Sorry, all S2+ pills are sold out. I don’t think I will restock them.
kiriba-ru
kiriba-ru's picture
I think I have to share some extra information about current situation. Have not done this earlier because there are still no visible progress.
I’ve tried my best to get a ready-for-use small CNC mill (like tormach 770/1100) or used VMC (Haas minimill/Syil X7/ Scyfire VMC) but had find out that things here are even worth than I expected. Country is closing from the inside, amount of imports flowing down for many years, taxes and bureaucracy are raising each year. All this makes new import machines very expensive (like US price multiplied by 2.5-3), same time deficit (and raising costs of everything) don’t allow used machines prices drop as fast as they should (I’ve seen several 15y.o. HAASes that cost more than brand new model in States). I have looked over several hundred thousands listings, and could not choose anything because main options were CNC router or 30+ y.o. heavy mill with punch tape input or 4k ROM.
During this period, I have also made hundreds of phone conversation with people that sell/upgrade/manufacture machinery, but again, I could not expect that thing here are so bad. People just don’t want too learn using someone’s else’s experience. They offered many funny machines (like heavy 2 ton mill with direct driven small nema motors, or bf20 with modern fanuc CNC and servos), but they are not able to find out how one or other thing should be made based on worldwide experience (read-not able even to copy imported technologies).
“If the mountain won’t come to Muhammad, Muhammad will come to the mountain”. I’m going to build it myself. This is not right way. Do not repeat it. Just get tormach or used Haas.
I’m renting a small place for this needs. A place owner was not able to remove his machines from this place, so I could not start repairing work. Need to work hard next several weeks to make it suitable for my needs.
I’ve bought few small manual machines by occasion. Just find out that person I’m calling is different from the others (mentioned above). I don’t overestimate my machinist skills and I have no plans in making big customer work using them. Probable they will not pay off themself, but I’m ok with this because they are valuable and they do not losing value (because of some factors mentioned above).
There is just one small thing that can justify why I have not made big progress in 3.5 months. Things are really slow here. I understand that country is not small but since start of this year I’ve met dozen situation (both as sender and reciever) when delivery took more than 1.5 months. Each day I met situations when something that should work doesn’t. Yesterday I could not get some equipment unloaded from the truck because heightbores forklift has broken batteries, runs on AC transformer and not runs when it rains Facepalm .
I don’t know how long I can accept all this.
id30209
id30209's picture
Last seen: 3 hours 38 min ago
Well, well, well...looks like you are about to start something interesting there.
I hope it will go smooth for you and waiting for more news.
WTB Titanium 4sevens 2xAA tube
