Camelion AA Max 2500mAh (White)
Official specifications:
Frame size: AA
Dimensions (Ø x L mm): 14,1 x 50,5
Weight (g): 29,0
Electrochemical System: Nickel-Metal Hydrid
Capacity typical: 2500mAh
Capacity minimum: 2350mAh
Nominal Voltage: 1,2V
Jacket: Plastic
Retains 90% after 6 months, retains 85% after 1 year.
Maximum temperature raise at different discharge currents: 1A:+1,6°C, 2A:+4,1°C, 3A:+7,1°C, 5A:+13,6°C, 7A:+19,0°C, 10A:+18,9°C
Camelions high capacity and LSD (Low Self Discharge) NiMH batteries.
The discharge curves look fairly normal, the cells has not been used for some time and the first trace (0.1A) do not get full capacity.
Conclusion
Performance of these cells is not in top, but they work fairly good.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
