GearBest Giveaway for the suggestions brainstorming for the Unique features of the flashlight( winner out)
227 posts / 0 new
Backpacker Light
Last seen: 1 month 5 days ago
I would love to see a BLF Special Edition X-6 style light (big head for throw, small body for pocket carry), BUT in the even smaller single AA format!
Maximize the brightness and output without regards to run-time, as I can always carry extra AA Eneloops, but do include a moon mode(.5 lumen), low (10 lumen), medium (75 lumens) and then the highest high possible with a single AA.
The lighter the brighter the better.
sandalian
sandalian's picture
Last seen: 1 year 3 weeks ago
I have two suggestions:
1. Illuminated tailcap should be considered, it makes the flashlight can be easily found in the dark.
2. Optional tritium slot, even for a budget flashlight would be a plus.
I'm switching my BLF account into LumenZilla. Thanks!
Cula
Cula's picture
Last seen: 6 months 1 week ago
Courui D01 type of flashlight (host only) with extension tube or single tube for 2s3p configuration and choice of three different reflectors – smooth, triple and op.
s1m888
s1m888's picture
Flashlight with xhp50 that runs on single 18650 battery with bistro firmware Big Smile
Sal415
Last seen: 2 hours 59 min ago
How about a zoomable light with the body of your give away light that has the side by side batteries and different sized heads for either more pocket friendly 50mm?or serious throw 75mm+?
Sal415
Just noticed the battery size on the giveaway light it would also have to be 18650
Omega_17
Last seen: 1 week 14 hours ago
Very small all metal flashlight using high CRI nichia LED that can be used as a neckplace. Hat
Andrew2007
Andrew2007's picture
Last seen: 4 years 9 months ago
A thumb operated switch but not the standard push down click switch, maybe push forward to increase brightness.
I hate having to go through the modes, I should be able to move from a medium setting to high and back again without having to use the low setting or the flashing one.
The switch in the tailcap is easy to design and manufacture but it’s not in an ergonomical position.
scarnific
My ideas:
-Multi batteries, like 18650 or xAA
-Neutral tint
-A super mode, with other levels of output
-side button
Tommyz
Last seen: 5 years 1 month ago
I was away for a long time bought a few lights and played with them for a year and now need a few new flashlights and saw this..
-Offer customers different leds and Led options: Nichia high cri led option
-Simple modes, simple drivers with no advanced options for long life, stable operation
-Driver with no pwm
-Low / moonlight mode must be usable, 1 or 2 lumen
-Big heatsink if powerfull flashlight
-DTP copper mcpcb if too many amps
-Tailstandable
-No or hidden disco,flashing, sos mode
-A medium mode with long runtime and 10ish lumens
-Use double o rings, thin and clear glass lens, a strong clip
-Keep it simple to make it a budget light
Hobo
For me a flashlight should have moonlight mode, tailstand, a good ui (two button prefered), instant access to turbo and a low battery warning/shutoff.
8) Lube Threads Everyday 8)
tedh35
Last seen: 2 months 4 weeks ago
zelee
zelee's picture
Last seen: 1 week 3 days ago
4xAA flashlight with moonlight mode,hidden strobe (SOS) and got a red cone as accessory
southland
southland's picture
Make a budget version of this with BLF driver and thick copper heatsink.
Kozy
Kozy's picture
needs moonlight mode and a copper DTP Glasses
Neutral tint Beer
Halo...
Halo...'s picture
Last seen: 5 years 2 months ago
Has anyone said “hidden or no strobe / sos / flashy modes” yet?
Meh, I’ll go with that.
And 1+ ToyKeeper’s Bistro firmware. On an attiny85. And must have a quality OTC capacitor.
MG
Last seen: 4 months 4 weeks ago
I want a flashlight that changes color.
With successive button presses it will cycle through white, red, blue, green, red-blue alternating strobe.
It should also have a color change ramping mode where the color continually changes from one end of the spectrum to the other with the ability to stop at any color.
Any battery type would be ok, but preferably Lithium.
……And in the brainstorm category: The color-changing flashlight will have a bluetooth interface allowing smartphone control of all color features.
P3D
Last seen: 3 years 11 months ago
A flashlight that can use either AA or 18650 with very low moon mode and 1000+ lumens turbo mode.
Wrathbringer27
Wrathbringer27's picture
Last seen: 5 days 12 hours ago
DEDOMED!
Words can be broken,
so can bones.
MG
A decent quality (reliable) inductive rechargeable flashlight.
https://en.wikipedia.org/wiki/Inductive_charging
KeepingItLight
KeepingItLight's picture
Last seen: 1 day 20 hours ago
Neutral tint and high CRI.
I would like to see a 1×18650, Nichia 219B triple in a host that is large enough so that the optics are not partially covered by the bezel. Something like an EagleEye X6 host would work.
I also like the idea of thermal management in a flashlight like this, otherwise, heat can be a problem. Bistro might be an option.
olivedrab
olivedrab's picture
Last seen: 1 week 6 days ago
How about a built-in tripod? Wink
alberto7
Last seen: 1 week 11 hours ago
High range 18650 flashlight with cree Xp-l-HI and a second TIR opctic for flood cree xp-g2 neutral.
Kozy
Kozy's picture
I also like the idea of thermal management is a flashlight like this, otherwise, heat can be a problem. Bistro might be an option.
Great idea!
+1 Beer
bmwsancho
bmwsancho's picture
Last seen: 4 months 1 day ago
A new P60 style light. Not the same size or models – more the concept:
- interchangeable bodies and heads
- a “pill” concept that has better heat conduction than previously
- different pills with different drivers, LEDs and features
nofearek9
nofearek9's picture
Last seen: 2 hours 26 min ago
moon mode
no more than 4 modes
coppper led pcb
thick wires
usb charging
Calmaja
Last seen: 2 years 2 months ago
Additional reflector or spacer if want to change it to triple led. Will be great if can make it customized triple alumunium reflector otherwise triple carclo is fine.
4AA with 4S exchangeable with li-ion, e.g. Lumintop SD10.
Moonlight mode, max 5 modes, hidden strobe or using ToyKeeper Attiny 25 driver (using good components, it don’t cost too much).
Screw in mcpcb to pill, make it flat and using thermal paste, don’t solder/glue it for easier to change led later.
Neutral white led
Good anodize, like BLF Eagle Eye X6.
Good enough tail switch.
Andrew2007
What about a motorised zoom that’s controlled by just pressing a button and holding it down to change from throw to flood?
Having that and the infinitely variable brightness would make a great light.
A full carbon fibre light would be nice but expensive, a carbon fibre finish would also look fantastic.
Joat
Last seen: 10 months 3 weeks ago
A small 14500 light that takes a 17mm driver, the head should be no more than 22mm in diameter.
Andrew2007
I might be wrong and tell me if I am but it looks to me that Gearbest are after innovative idea’s and something that would really make a flashlight better and different to the thousands that are already out there so it stands out from the crowd for whatever reason.
It would appeal to everyone looking for a light and maybe just not just us lot that look for specific improvements like a copper mcpcb, certain tints, firmware etc. Oops
