Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 57 min ago
raccoon city wrote:
I refer you to kramer5150‘s avatar from July 2015:
Tom E wrote:
solder is soft, subject to going flat over time (not drooping)
So… you’re saying the softness of boobs might make them lose their zing after menOhmpause?
Let’s not even start on the puns related to electrical conductivity being measured in siemens.
In practical terms though, solder blobs are relatively easy to rejuvenate when necessary. Just re-melt it, maybe add a little solder, or file down the tip a bit (ouch), and it should be good as new. I’ve had to do this occasionally on blobbed drivers when the contact surface gets dirty. It may also be a good idea to clean the contact ring on a SRK-style light once in a while.
This kind of thing isn’t limited to just solder though. I also have to clean the battery (steel? zinc? nickel?) and contact post (aluminum) on L3 L10 lights periodically, since it gets thoroughly blackened during use.
I’m glad the Q8 has a thick contact ring, since it’s going to get worn over time regardless of what the battery tops are made of. With a thin ring like a regular PCB copper pour, wear is visible after just one use… but this thick brass ring will likely last pretty much forever.
sparkyDK
Last seen: 6 days 5 hours ago
I would not know, i rarely get to know one from the other sex good enough for me to ask for permission to examine her features that close.
And i am not the kind that jump at every little chance he get, that actually make me suspicious and work like a bucket of ice-water on me.
sparkyDK
On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ?
Or am i overthinking again.
teacher
teacher's picture
Last seen: 2 years 4 months ago
I think, flats tops will work with it now as is… sparkyDK. Smile
EDIT: If they are of proper length. Thumbs Up
FINAL EDIT: … Sanyo GA flat tops will work because they are raised flattops.
Q 30 flat tops or any cell with flat tops like them… WILL NOT work.
My apologies for the initial incorrect informatio I gave. Facepalm
RedForest UK
RedForest UK's picture
Last seen: 2 years 2 weeks ago
I’ve been watching this on and off since the beginning and it looks like it’s finally coming together into a really impressive light, well done and thanks to everyone involved in the design. Please put me down for one.
Do we have any rough timeframe on shipping the final version yet? Once approved are they ready to start manufacturing?
Tom E
Tom E's picture
Last seen: 6 hours 35 min ago
teacher wrote:
sparkyDK wrote:
On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ? Or am i overthinking again.
I think, flats tops will work with it now as is... sparkyDK. Smile EDIT: If they are of proper length. :THUMBS-UP:
smile Sheriously, typical flat tops won't work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA's are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
alternety
Or, if you simply use protected cells with the button already attached. As I recollect, somewhere above, it was determined that protected GAs with a good protection circuit did not seem to impact the light output vs an unprotected QA. Unless you are trying to squeeze every last lumen out of the light. But if this a concern, there are other batteries with higher amp capabilities you can blob and people can mod the light to try to make the whole power train act like a room temperature superconductor.
sparkyDK
yeah i figured it would take some figuring out where the drum stop to make sure the batteries land on a “hill” on the contact ring.
But with design ( not the Q8 ) then i am sure they could figure it out and so the resulting flashlight could use any battery.
I am fully aware this are a done deal for the Q8 and that’s just fine i will just do something to the flat tops i have gotten for it.
But in future flashlights ( not least multi cell like the Q8 ) it would be nice if they would work with any type of the particular cells its build for.
But i have been wondering even if the “hills” was smooth for the battery’s to climb easy, the design of flattops and their wrapping might suffer damage over time as the batteries would have to go up and over those “hills” several times before they land in the final resting place.
Also i have been thinking if you should lathe those hills in the contact ring, or you could make do with just punching dents into the ring.
sparkyDK
Now i am thinking ( i know i should be sleeping now but my brain will just not allow for that it seem )
How about if the 4 batteries in a light like the Q8 was staggered in a drum around a central pillar onto which you then screw on the end cap ?
This way the batteries should be stationary when the flashlight are put together, a bonus might be you can use bigger O-rings where the battery “drum” seal onto the LED end and the tail cap end, making for a bigger chance of a waterproof light and using larger more forgiving O-rings.
Off course this design will mean that the battery drum will just be held on the LED end with the friction of the O-ring when the end cap are unscrewed for battery change.
Holy sh,,,, ee now i better stop cuz now i have tail cap contact ideas too, i better go for a drive and get me some sugar water to get the creative juices going again.
ToyKeeper
ToyKeeper's picture
sparkyDK, this is an already-solved issue which came up just a few pages ago. It simply requires a different design:
http://budgetlightforum.com/comment/1133299#comment-1133299
The Q8 will not use this method though; it uses a SRK style ring instead. So… make sure the positive terminal is higher than the cell wrapper.
Mr.Scott
The Miller wrote:
PLEASE CHECK IF YOU ARE ON THE LIST OK
The Q8 list (from post #1) sorted alphabetically .
 (As of post #8341)
2 DOGS   186
264   641
2Ace   165  1119
5ar   697
7pot   982
a12luke   932
a_idiot   740
Aardvark Spleen   253  402  403
Abe87   876
Abqjohnny   51  1169
abril   50
adirondackdestroyer   545
adrianlights   255
AEDe   923
Ag76   1345
aggillator   458
aginthelaw   278
Agiri   110
aim120   430
AirBreaker   155
akhyar   387
akoposilester   56  1111  1112
akovia   937
albertopnp   365
Alcius   105
alejandrov   523
alex64   1159
AlexGT   495
Alkpwn77   204
allthumbs   218
alphazeta   335
alternety   564  565
Alux   702
amplificus   904  983  984
Andmiller   1064  1065
andrewmac   407
Andybibbville   147
Andyman?   13
Angel Martínez   128
ant0   1195
Antenne   801
Anthon   568
antiparanoico   32
AppA   1208
aprendiz   1160  1261
apt323   47  544
archi   1157
archimedes   67
aremihc   910
ARMS.AARON   1089
ARsee   1228  1229
Arufonsi   921
aslpg   398
asnidi2   1327
asot   690
Astromanic   424
AsylumSweep   863
atbglenn   567
Atom00   358  359
Autoclave   1099
Awdtsi   1221
Awkward Stretch   619
AwkwardPause   464
b1i1l1l1y1   1052
B42   685  686  1019  1020
BackpackNY   571  1084
bakalakos   202
balazs1956   1341
baldo21   260  261
Bam35   1039
bamawthu   599
banker   1013
basslovin808   446
Bastarrdo   117
Batch1   293  344
battletross   809
bawilson2   500  501
Bc412
bd52   399
BDM   1018
BDWrabbit   1244
BeardedRaleigh   662
bella-headlight   49  411  877
Bernard   232
Bevo   1086
bhuge00   1049
bigpix   84
bigrick   754
bikedave99   1174
bikenber73   14
Bill 63   752  1296
Bill_tong   896
Billcheese5   949
bionictony   1338
bkling   1067
BlackList   1350
bladesmith3   607
BLFD80   933
BlindingL5s   312
blinker   1306  1353
blinky   1209
blueb8llz   70  553  1120  1121  1122  1123
Bluzie   785
bmaddison   248
Boaz   391
BobbyMK   462
bobdotorg   1271  1272
bobofire   1313
Bogdan   370  371
bogdanr   466
Bohemian   775
bonfire   412
Bong lick   763  1075
Bonham   262
borealis   1098
BorisBar   575  1238
Boro   360  361
bossf350   803
Box   671
Brettg4215   864
Brian Metcalfe   318  319  374
BrianK   447  560  1356
BrianTheJay   950
brightlights   243
brjones   504
brno602   913
brted   249
Bruno28   513
BT100   1087  1138
Bungle88   610
Buzzy243   1179
bwl123   870
cabfrank   443  988
Caleb   203  547
Caleb-v   444
Calmaja   35
Cano   661  1151
Captainvideo   1302
caramba   748
carmantl   345  346
casi29061965   467  490
cavorite   1028
Cawi   1276
cbrake10   749
cclight   897
cdjaney   825
Chadvone   63  693
Charga   124
charles lin   1124
CheapThrills   469
cheesecheeks   816
ChibiM   1310  1321
Chicken Drumstick   131
chinooker   1260
chooma   210  351
chrisc   741  742
churchilllafemme   1230
CircaM   894
Cjlee89   951
cjoe7   146
CJW   367
clagged   991
clange50   479  480
clinicdoc   1226
Cliwilnew   795
cloggy   404
cmflippen   83
cnrffl1   577  1113
cocoschnauzer   363
contigo   1351
Coolerness   664
coolriku   517
Corzy   308
Couchmaster   245  551  552
cpd800t   406
CrashOne   372  377
Crazyeddie   98  137  487
Creepo   909
cristhemuso   388
crx88ia   683
cujo255   1191
cwb   134
cypher1024   973
cypherz   250
Cythras   956
D10ten   608
Dadpool   1161
dafarui   1339
daninho   468
DarkerInSol   615  616  617  618
darkpenguin   718  719  735  736  737  738  739  860  861  862
darol   798
darrenm   1054  1055
darrylo   507
DarthTader   830
datiLED   761
dave101   1041
DavidEF?
davidkappelt   1026
davidvns   1128
davos   1062
DB Custom   713  722  997
dbesselt   1156
DBSAR   136  169  1281
DBSS   516  779
deathless   518
Deep skull   977
DeJaVu   669
dekozn   800
Dennis   934
dentillozie   488
Dep668   687  688
derfyled   1237
derpilgerer   630
Desmo   805
devdvr   486
dezoe   1186
dhsvcs   265  1336  1337
dicksog   559
digitaltc   1323
Dimking   425
Dirt   815
Dirty_Pierre   1045
DiscoJoe   1254
djburkes   188  878
Djozz   1115  1286
dmbaty   1294
Dobtruckers   1058
DOCFAR   595
Docp723   347  433  434
Doctawho   440
dodo   88  274
dogany   813
Dogsrule   508
donpachi   1252
dotBLF   968
doubleone44   887
downlinx   74  316
doxerino   1304
Dr Forinor   873
Dradge   1248
Dralf   1015
Dregs   172
DrHook59   883
driveX   659
DrJones   75
DT101   152
dudunphy   389
Duke   381
dumptruck   971
Dusty   327  328
Dutcheee   68  322
duvallite   889
dw911   478
Dwantink   135
e10sno   405  1318  1319
Easyrr
eb1888   837  838  839
ebosh   777
ediaz   906
eebowler   774
Eggun   1104  1312
egrep   594
Eivwer   171
electricjelly   237  256
ElginAgain   1204
emarkd   109
embee   511
Enelooper   417
engber   947
ERDOS   1150
Erethryn   1259
erikk365   648
Esskay   995
Etex   829
euphxenos   408
everydaysurvivalgear   103
Evilc   65
EyeballFryer   189
Fadetoblack   1295
fantomR   636
Far Thrower   148  197
Farmboy24   1234
Farns   277
Fatlight   663
fatsteve0   1361
FBsLights   790
fcrespi   1262
fed893   307
fedcas   902
feralcomprehension   1194  1311
finges   561
fireblade893   209
firedome   324  711
Firelight2   397
fishlite5   1046
fixed it   78  1097
fixvid   1264
Flash Voyager   652
flashination   87
FlashMax   1225
Flashy Mike   239  410  448  449
Flifish48   806  1096
Flintrock   629
fluffman86   958
FmC   1182
fonfan   234  1023  1024
fonLED   725
Ford Prefect   1068
Foston Pete   453  454  644
foton   1030
Fozzy-SP   317
Frank A.   1172
Frankie Baby   342
Franz   788
Freddy61069   282
Fredylee   223  1329
FreeMagenta   1050
freeme   514
Fritz t. Cat   484
Funzel67   990
fuzun   1074
fyesilova   535
g60   290
g_sintornillos   126
gamezawy   38  336
gangstead   53  922
garrybunk   254
gboss   832
gds95   1199
gedasd   1309
geepaw   1038
gehrmo   289
geo1952   455  457
ger-slash   416
Gerrh   531  1163  1164  1285
Gerrit   106
getbully   609  1263
Gilatabar   638
giorgoskok   306  493  1092
GIR   804  818
gisewhcs   384
Gj   580  581
gleamer   432
GlinnDamar   1342
gnatx   588  824
goatfarmer   770
GoldenBatt   383  589  590
gorb507   811  812
goshdogit   11  12  40  120  121  543  556  928
gpapa693   79
gravelmonkey   1027
green_comet   601
GreenShrike   190
gregor   215
GTsuperheros   179
Gtt980   936
guerrilla154   1316
Guggga   538
GulfCoast   880
gungoat   44
Gunnerboy   252  967
Guns712   1300  1301
h2o   181  476
Hairy_Steve   340
hank   258
Hardware   1071  1200
Hauwexis   845  846  847  848
haxquiz   226  927
headburger   592
heatwaves   994  1265
hein11ag   183
Herb Tarlek   931
Hestbech   994  995
hexcode   503  672
Hezekiah   286  759
hideehoo   859
HighCaliber   177  178
hmihaylov   502
Hobo   220
hunter1   116  720  721
hurleyy   993
I_like_lamb   915
Ian2381   150
igeigeige   890
IH8MYX   546
ii_pennies   481
ikaruz_500   989
Illumenated   426
illusioned   954
Ilmatic   1253  1332
ilovejesuschrist   294  295
ImA4Wheelr   19
ISO   705  734  929  930
iwandutchy   1047
J-Dub74   461
J_R_J   675
jack-bkk   356
jacktheclipper   1108
Jailbrake   1034  1090
JakeDjanitor   46
Jalben   187
jama   635
Jambo   912
james y   1043  1044
javipiloto   1154
jaynick   1048
JayT   62
Jayzed   1214
jb1   224
jdunlap27284   164
jealous57   81
Jensa41   731  732
Jerommel   637
jerrod   512
jescereal   228
Jesjes   153  154
jfalk1   918
jhalb   297
jhullin   159  751
jingleberry   1022
Jinx   93
jkbam   550
jmoots   268
jmpaul320   95  299
jmwhite151   482  851  852  853
Joat   184
JockRobbins   717
Joe Darkness   620
joe1512   534
joeangi   756
joechina   633
Joey Adams   1021  1132
John-Galt   463
Johnhywash1   966
johnnydoe   1227
JohnnyMac   496
johnpc   955
johny723   1082
Jonandreadolan   1072
JonnyC   576
JordanZHP   1078  1196
josephqool   1061
jpcuba   684
JPLight   23  646
JPM3   263  264
JS721   216
jsmn4vu   793
Jtm94   1035
Juanesdan   118
juaquin   219
Juggeli   745
jurasik1   1231
justanotherguy   541  712  1080
Jvrthp321   691
jycheang   1009
k-wong   542  1005
Kafar
kahvitahra   796
Kalchev   400
kali stupa   1217
Kalihi   836
KawiBoy1428   230
kaybi   1033
Kazik   1315
kbro   168
keengeorge   309  310
KeepingItLight   992
Keepitsharp   175
Keisari   1211  1212
keithd   753
KenE   355
Kenjii   385
Kentuckywindage   797  872
Kepling   333
KFulton   1331
khas   628
Khuan   1148
KIKY   1340
Killforfood   272  379
Kindle   698
KingSmono   578
kiriba-ru   525
Kiukas   640
KiwiKane   174
Kkelleher   99  100  101  102
Kloepper Knife Works   194  195  196
knightstalker   1219
kntx   1073  1116  1189
knudsengj   1106
Koaksijalac   104
Kodachrome40   170  1282
KoekieMonster   161
kommessy   108
korpzgrinda   1029  1133
kotobuki   799  1143  1144
koyotee   276
Kozy   58  129
krutone   1298
Kulumatic   914
Kurt_Norway   593
Kusie   17
KutKhemist   123
Kysumi   925
LAB   259
lachesis   673
lalomt   1167
Lamont56   808
lamper   727  1171
lanceb1b   884
laststance   972
lawallac   393  394
Lazy-R-us   25  900  1249  1250
Le_Zouave   71
leaftye   694  1103  1183  1184
LEDtec   823
legan710   1088
Legolas Jr.   130
leroycp   236  266  450  451
Lexel   696  1287
Lfatman   707
Liber8   537
lichtpfadfinder   1292
Light of Earendil   700
lightbulb   281
lightknot   471  492  598
lightlight22   772  920  1040  1328
lightmog   72
lightx   757
Lilien   978
Lion42   246
lionheart_2281   33
litcrit   871
Litefighter   1320  1334  1335
LloydV   767
Loneman   510  903
longmire   1256
Lopan   1069
lovetheguitar   981
Lowtech   1042  1193
ludolf   348
luisgcan   1162
Lumenmaster17   1145  1146  1147
Lumens Industry   634
lumiere   231
Lund1660   64  439
luxlad   831
lyse99   1012
Lyubo Yanev   427  428  429  536
M4D M4X   350
M78   157  337  1007
MACS0647   313
MAD TM26   656  657
Magbrite   584
magnet   302
MagPap   794
Maiden666   92
maildroid   331
Majoroverkill   919
malamask   113
mandala   952  953
manithree   1255
Manulous   1270
ManWithoutShadow   1100  1299
Mapache
markalike   602
Marothar   1236
marsalla   475
Martini   82  726
martook   48
martytown   976
Masejoer   842
Matchoo   905
matkovicha   1185
Matomoto   1324
mattlward   16  34  214
MauiSon   42  979
maukka   225  627
Maxxsounds   681
MBuitendorp   1210
mcfarlie6996   964  965
MCT   162
Mecallie   1051
MechEngVictor   275
Medvegy   660
Melven   167
meti   470
metz3006   843
Meyer   138
MG   353
mhanlen   77
mi bill   127
Micael   858
Miguel_79   1114  1129
Miguelintegral   1175
mikeyx   622
Mindaugass   769  1081
Minimoke   30  975
miswas   760
Mitko   26  27
mitrhandir   1303
mizjif   714
Mkduffer   600
mlodyulek   1283
moemin   375
MontyPyfon   66
moridin   907
Morpheus   613
MorpheusT1   762
MortyDuck   764
MountainKing   438  445
MountainMan   786  787
mozart.f   314
Mr.Poppy   192  267  1247  1308
Mr.Scott   251  1077
mrheosuper   1110
mrkelvin   606
MRsDNF   325  326
mrstealyourgains   1014
msg1285   173
Mstevens113   114
Mt.B   392
MtnDon   158  498
mud_muncher   624
mudguts   680  716
Muto   20  242  689
mutts13   1343  1348
muzzleblast?   89
mxlu   396
MyDangus   1181
myowin   213  1235
myst999   198  728  1266  1267
nanojack   1036
narin000   524
Nathan42   946  987  1365
Navin_R_Johnson   817
neckbear   935
needmorlts   911
Neilyboy   1307
netprince   176  378
nexrace1   579
nfetterly   362  366
Nguyen   1277  1293
nickdude   591
Nickke   604
Nicolaas   857
Nicolicous   270
Night Light   1093
NightLight   369
Nightshade   574
niktak11   782
Nil   959  960
Nite Shadow   1001
Nitetime   163
nitrader0   1203
nnmnu1   1349
No Agenda   431
nofear87   382
Noki   573
noob   828  833  1025
Nord   1170
Nortson   810
novice1   338
nqcken   119  241
nskn71   1136
NuggetMcNugget   166  332
ObiWan-Kenobi   422  423
octav   666
OdorlessCurves   529  530
ohnonothimagain   1357
olivedrab   658
OrangePeel   1275  1288
orinjuse   835
Orionz23   1168
osb40000   193
OscarM   1290
Oswald3211   724
oto   888
Ozythemandias   625
Pablogy   441
PabloVerde   1037
pacbough   149
papaslightsaber   583  1125  1126
patchythepirate   704  1364
patmet   1347
patmurris   55
patmurris   1355
Paul321   139
pawwright   151
PBWilson   557  558
peabody   207
Peetz   311
Pegaso   122
Peho   112
pepe2017   1305
pepinfaxera   1158
perche   1155
peterlcole   924
peteybaby   549
petr9999   1137
Petroleum Lantern Guy   891
Phoenix_FIN   395
Pidro   465
pieman7   670
pirate joe 22   678  679  783  784
piyoman   840
plntigrado   1153
pommie   54
pook   330
pooptoast   519
powerfultorches   569
praveendk   437
presterjohn   586  715
Presumptuous   653  654  655
Primal   364
prisma   401
Prometheus   1149
ProtaBLF   419
pscal   376
puccio1969   76
Pukachi   205
pukoid   868
Pulsar13   288
qandeel   631  632
R.D.   974
radb   856
rag   283  298
Ragsy   499  1117
raiko   570
rajun50   651
Randolph   212
RapidLux   1346  1360
Rat_Racer   999
RaVeN   160
raynman   706
rdoc613   879
red72vw   521
redrider706   1359
regaia   1008
reliant_turbo   710  850
ReManG   320
reno   1118
retiro675   352  826
rexdog   442  515
rfd673   747
ricardon   300
Ricflair   323
Rick   199
rjorge   708
rmkline   436
Rob_K   244
robbobus   233
Roberrt777   185
RobertB   140
RocketTomato   766
RockHugger   1173
Romey310   969  970
RonMuller   111
Roter   649
RotorHead64   1284
Rpdos   1180
Rska   650
Rsqweezy   814
rufrydr   765
Rufusbduck   60
Rxich   866
ryukin2000   1220
sac02   645  908  1215  1216
saf99   755
Saigon   247
SamHaLeKe   485
samis   509
samnavy   73
san san   926  1130  1131
sandanbob   532
Sarge930   86
Savydude   1222
SawMaster   45
saypat   141
sb56637   191
scarnific   566
scdaf   271  296
Schkü   614
schlockproof   612
Sciencetists   257
SciFiFreak   31
Scooby   582
Scooter000   315
scootypuffjr   844
Scorpia   596
scotlarock   329  1085
Scottland   334
Scotty   746
scs   80
sebastiang   611
SebaZ74   1239  1240
SeenTheLight   301  819
SFB   1109
Sgtpev   206
Shadowcactus   916
Shadowfax   341
Sharpie   354
shimano3000   409
shimey   211
shirnask   61  733
Shoe   957
shogan   227
Shur   284
SIGShooter   368
Silent_Star   1190
Silentcropduster   667
Simplelight   961  962
slackwolf   885  886
slackwolf 3rd   1000
Sledge   980  985  986  1326
Sledgestone   677  841
slickpenguin   643  854
slimkango   52  1207
slow2go   221  222  692  1139  1140  1141  1278  1279  1280
smed1275   494
Smittymojo   768  1142
SmokinH   855
Snoballz   1031
SoCalTiger   1344
sochi111   1032
Sofa   834
sol   291  292
SolarLumen   776
solRNY   1291
somnambulism   562
Sonpham   621
southland   142  143  144  145
sp5it   94  1201
spade413   1178
sparkyDK   1188
specialk   865
Speed4goal   413
Speedsix   1083
spkzzz   474  526
Sprinkles   279  778  901
srs2000   1187
stanley-beamish   107
starcrazed   1330
stareye   540
staticx57   238
steel_1024   709
Steenbhg   701  1205  1206  1268
steepdrop   435  497
Stephen Elliott   1322
stephenk   269
steve42   1016
Stevejj   1218
SteveMidwest   1289
stevez32   822
Stittville Ed   85  998
Stoneface   758  1127
strango   96
strayz   505
Streamer   1246
strmix   676
Subterrestrial   1003
Sukoi   642  1010
Sullysat   418
Suncoaster   682
Swennie   895
Syncmasterklop   867
syracuse   349
T-boon   304
T18   390  1257
t3rminal   1213
tapir   489
tarver   132  229
Tarvos   15
tas69   380
tatasal   506
teacher   321  1134
tebeve   893
techieman33   456
Tecmo   57
tekwyzrd   37
tenohfive   802
Tete   217
Texas_Ace   472  473
The Burgh   235
The Grand Pooh-Bah   1056  1057
The Imp   1242
The Jinx   522  699
The Last Katun   90
The Miller
The_Driver   1352
thebaum   585  807
thecrc   1177
TheDude   415
TheHebrewHammer   820  821
TheJo   1053
TheMadcap   97
themaindude   343  1094  1095
Theodore41   520
theoldbill   59
TheOnlyDocc   1135
thijsco19   24
tigris99   603
timcodes   1004  1017
tindrum42   1059  1060
tinowrx   572
Tixx   371
Tjhosan   273
Tjohn   940  941  942  943  944
Tmik   287
tmxod   771
Toccata   1241
tocirahl   1362
Tom E   28  29  874  875  1223  1224
Tom_182   695  780
tomtaylor   201
tonylim   43
torchjunkie   483  597
toxiccoccyx   1107
ToyKeeper   339
tracerfire   1317
Trashman531   285
Trasnodel   729
trevglas   200
trevize   1165
treysoucie   789
tristanxoxo   240  1070
troisanh   91
tronx   674
TRoPHeuS   1152
tru3s1lv3r   39
Tunerman   1002
tungkon   1011
TurboLion   917
turbopscl   892
turpulator   1066  1363
tzmxxhh   21
Ulric   1198
unit311   849
unknown00101   548
uqs1000   357
Vagany   647
VaKo   208
Valdorg   1202
Van   491
Vanq86   1176
vas   133
vasa_visost   668
Vattern   18
velocraig   781
vex_zg   730
Viamede   948
vinte77   414
Volks1973   743
vulpes   539
vwpieces   881
Wackyvegan   156
walty   280
WarHawk-AVG   420  421
warzi1975   528
wattstar   791
websterjody   996  1105
weklund   460
Werner   10
WestBam   1333
westcoastwonders   639
whitecitadel   1354
Wieselflinkpro   125  750  1079
Wildcat   827  945
wildmermaid   1091
Wildthing   533
willmo   605  882
WillyD   303
wilwok   1076  1258
Wineslurper   554  555
wisefire   869
wishiwereaskibum   587
wkhchin81   477
Wojto   1325
WolfA   69
Wrathbringer27   41
wunderhe   115
Wyre   1269
Xandre   527
xCentrino   1314  1358
xed888   305
xelario   773
xjsnake   36
xray291   1192
xtrosity   723
XXX-Man   1197
xzel87   665
yasenf   1006  1232  1233  1273  1274
yclongthrow   898  899
YoFlash   744
Yokiamy   1245
Yourrid   1101  1102
zachary6227   1297
zak.wilson   182
Zanders   792
zara   180
zelee   22
Zeratull   703
zeroair   452
zifzif   1243
zipelgas   386
zoysiamo   1251
ZozzV6   626
×73rmin8r   1063
1008 names
1360 lights
  1. 2 DOGS, 264, 2Ace, 5ar, 7pot, a12luke, a_idiot, Aardvark Spleen, Abe87, Abqjohnny
  2. abril, adirondackdestroyer, adrianlights, AEDe, Ag76, aggillator, aginthelaw, Agiri, aim120, AirBreaker
  3. akhyar, akoposilester, akovia, albertopnp, Alcius, alejandrov, alex64, AlexGT, Alkpwn77, allthumbs
  4. alphazeta, alternety, Alux, amplificus, Andmiller, andrewmac, Andybibbville, Andyman?, Angel Martínez, ant0
  5. Antenne, Anthon, antiparanoico, AppA, aprendiz, apt323, archi, archimedes, aremihc, ARMS.AARON
  6. ARsee, Arufonsi, aslpg, asnidi2, asot, Astromanic, AsylumSweep, atbglenn, Atom00, Autoclave
  7. Awdtsi, Awkward Stretch, AwkwardPause, b1i1l1l1y1, B42, BackpackNY, bakalakos, balazs1956, baldo21, Bam35
  8. bamawthu, banker, basslovin808, Bastarrdo, Batch1, battletross, bawilson2, Bc412, bd52, BDM
  9. BDWrabbit, BeardedRaleigh, bella-headlight, Bernard, Bevo, bhuge00, bigpix, bigrick, bikedave99, bikenber73
  10. Bill 63, Bill_tong, Billcheese5, bionictony, bkling, BlackList, bladesmith3, BLFD80, BlindingL5s, blinker
  11. blinky, blueb8llz, Bluzie, bmaddison, Boaz, BobbyMK, bobdotorg, bobofire, Bogdan, bogdanr
  12. Bohemian, bonfire, Bong lick, Bonham, borealis, BorisBar, Boro, bossf350, Box, Brettg4215
  13. Brian Metcalfe, BrianK, BrianTheJay, brightlights, brjones, brno602, brted, Bruno28, BT100, Bungle88
  14. Buzzy243, bwl123, cabfrank, Caleb, Caleb-v, Calmaja, Cano, Captainvideo, caramba, carmantl
  15. casi29061965, cavorite, Cawi, cbrake10, cclight, cdjaney, Chadvone, Charga, charles lin, CheapThrills
  16. cheesecheeks, ChibiM, Chicken Drumstick, chinooker, chooma, chrisc, churchilllafemme, CircaM, Cjlee89, cjoe7
  17. CJW, clagged, clange50, clinicdoc, Cliwilnew, cloggy, cmflippen, cnrffl1, cocoschnauzer, contigo
  18. Coolerness, coolriku, Corzy, Couchmaster, cpd800t, CrashOne, Crazyeddie, Creepo, cristhemuso, crx88ia
  19. cujo255, cwb, cypher1024, cypherz, Cythras, D10ten, Dadpool, dafarui, daninho, DarkerInSol
  20. darkpenguin, darol, darrenm, darrylo, DarthTader, datiLED, dave101, DavidEF?, davidkappelt, davidvns
  21. davos, DB Custom, dbesselt, DBSAR, DBSS, deathless, Deep skull, DeJaVu, dekozn, Dennis
  22. dentillozie, Dep668, derfyled, derpilgerer, Desmo, devdvr, dezoe, dhsvcs, dicksog, digitaltc
  23. Dimking, Dirt, Dirty_Pierre, DiscoJoe, djburkes, Djozz, dmbaty, Dobtruckers, DOCFAR, Docp723
  24. Doctawho, dodo, dogany, Dogsrule, donpachi, dotBLF, doubleone44, downlinx, doxerino, Dr Forinor
  25. Dradge, Dralf, Dregs, DrHook59, driveX, DrJones, DT101, dudunphy, Duke, dumptruck
  26. Dusty, Dutcheee, duvallite, dw911, Dwantink, e10sno, Easyrr, eb1888, ebosh, ediaz
  27. eebowler, Eggun, egrep, Eivwer, electricjelly, ElginAgain, emarkd, embee, Enelooper, engber
  28. ERDOS, Erethryn, erikk365, Esskay, Etex, euphxenos, everydaysurvivalgear, Evilc, EyeballFryer, Fadetoblack
  29. fantomR, Far Thrower, Farmboy24, Farns, Fatlight, fatsteve0, FBsLights, fcrespi, fed893, fedcas
  30. feralcomprehension, finges, fireblade893, firedome, Firelight2, fishlite5, fixed it, fixvid, Flash Voyager, flashination
  31. FlashMax, Flashy Mike, Flifish48, Flintrock, fluffman86, FmC, fonfan, fonLED, Ford Prefect, Foston Pete
  32. foton, Fozzy-SP, Frank A., Frankie Baby, Franz, Freddy61069, Fredylee, FreeMagenta, freeme, Fritz t. Cat
  33. Funzel67, fuzun, fyesilova, g60, g_sintornillos, gamezawy, gangstead, garrybunk, gboss, gds95
  34. gedasd, geepaw, gehrmo, geo1952, ger-slash, Gerrh, Gerrit, getbully, Gilatabar, giorgoskok
  35. GIR, gisewhcs, Gj, gleamer, GlinnDamar, gnatx, goatfarmer, GoldenBatt, gorb507, goshdogit
  36. gpapa693, gravelmonkey, green_comet, GreenShrike, gregor, GTsuperheros, Gtt980, guerrilla154, Guggga, GulfCoast
  37. gungoat, Gunnerboy, Guns712, h2o, Hairy_Steve, hank, Hardware, Hauwexis, haxquiz, headburger
  38. heatwaves, hein11ag, Herb Tarlek, Hestbech, hexcode, Hezekiah, hideehoo, HighCaliber, hmihaylov, Hobo
  39. hunter1, hurleyy, I_like_lamb, Ian2381, igeigeige, IH8MYX, ii_pennies, ikaruz_500, Illumenated, illusioned
  40. Ilmatic, ilovejesuschrist, ImA4Wheelr, ISO, iwandutchy, J-Dub74, J_R_J, jack-bkk, jacktheclipper, Jailbrake
  41. JakeDjanitor, Jalben, jama, Jambo, james y, javipiloto, jaynick, JayT, Jayzed, jb1
  42. jdunlap27284, jealous57, Jensa41, Jerommel, jerrod, jescereal, Jesjes, jfalk1, jhalb, jhullin
  43. jingleberry, Jinx, jkbam, jmoots, jmpaul320, jmwhite151, Joat, JockRobbins, Joe Darkness, joe1512
  44. joeangi, joechina, Joey Adams, John-Galt, Johnhywash1, johnnydoe, JohnnyMac, johnpc, johny723, Jonandreadolan
  45. JonnyC, JordanZHP, josephqool, jpcuba, JPLight, JPM3, JS721, jsmn4vu, Jtm94, Juanesdan
  46. juaquin, Juggeli, jurasik1, justanotherguy, Jvrthp321, jycheang, k-wong, Kafar, kahvitahra, Kalchev
  47. kali stupa, Kalihi, KawiBoy1428, kaybi, Kazik, kbro, keengeorge, KeepingItLight, Keepitsharp, Keisari
  48. keithd, KenE, Kenjii, Kentuckywindage, Kepling, KFulton, khas, Khuan, KIKY, Killforfood
  49. Kindle, KingSmono, kiriba-ru, Kiukas, KiwiKane, Kkelleher, Kloepper Knife Works, knightstalker, kntx, knudsengj
  50. Koaksijalac, Kodachrome40, KoekieMonster, kommessy, korpzgrinda, kotobuki, koyotee, Kozy, krutone, Kulumatic
  51. Kurt_Norway, Kusie, KutKhemist, Kysumi, LAB, lachesis, lalomt, Lamont56, lamper, lanceb1b
  52. laststance, lawallac, Lazy-R-us, Le_Zouave, leaftye, LEDtec, legan710, Legolas Jr., leroycp, Lexel
  53. Lfatman, Liber8, lichtpfadfinder, Light of Earendil, lightbulb, lightknot, lightlight22, lightmog, lightx, Lilien
  54. Lion42, lionheart_2281, litcrit, Litefighter, LloydV, Loneman, longmire, Lopan, lovetheguitar, Lowtech
  55. ludolf, luisgcan, Lumenmaster17, Lumens Industry, lumiere, Lund1660, luxlad, lyse99, Lyubo Yanev, M4D M4X
  56. M78, MACS0647, MAD TM26, Magbrite, magnet, MagPap, Maiden666, maildroid, Majoroverkill, malamask
  57. mandala, manithree, Manulous, ManWithoutShadow, Mapache, markalike, Marothar, marsalla, Martini, martook
  58. martytown, Masejoer, Matchoo, matkovicha, Matomoto, mattlward, MauiSon, maukka, Maxxsounds, MBuitendorp
  59. mcfarlie6996, MCT, Mecallie, MechEngVictor, Medvegy, Melven, meti, metz3006, Meyer, MG
  60. mhanlen, mi bill, Micael, Miguel_79, Miguelintegral, mikeyx, Mindaugass, Minimoke, miswas, Mitko
  61. mitrhandir, mizjif, Mkduffer, mlodyulek, moemin, MontyPyfon, moridin, Morpheus, MorpheusT1, MortyDuck
  62. MountainKing, MountainMan, mozart.f, Mr.Poppy, Mr.Scott, mrheosuper, mrkelvin, MRsDNF, mrstealyourgains, msg1285
  63. Mstevens113, Mt.B, MtnDon, mud_muncher, mudguts, Muto, mutts13, muzzleblast?, mxlu, MyDangus
  64. myowin, myst999, nanojack, narin000, Nathan42, Navin_R_Johnson, neckbear, needmorlts, Neilyboy, netprince
  65. nexrace1, nfetterly, Nguyen, nickdude, Nickke, Nicolaas, Nicolicous, Night Light, NightLight, Nightshade
  66. niktak11, Nil, Nite Shadow, Nitetime, nitrader0, nnmnu1, No Agenda, nofear87, Noki, noob
  67. Nord, Nortson, novice1, nqcken, nskn71, NuggetMcNugget, ObiWan-Kenobi, octav, OdorlessCurves, ohnonothimagain
  68. olivedrab, OrangePeel, orinjuse, Orionz23, osb40000, OscarM, Oswald3211, oto, Ozythemandias, Pablogy
  69. PabloVerde, pacbough, papaslightsaber, patchythepirate, patmet, patmurris, patmurris , Paul321, pawwright, PBWilson
  70. peabody, Peetz, Pegaso, Peho, pepe2017, pepinfaxera, perche, peterlcole, peteybaby, petr9999
  71. Petroleum Lantern Guy, Phoenix_FIN, Pidro, pieman7, pirate joe 22, piyoman, plntigrado, pommie, pook, pooptoast
  72. powerfultorches, praveendk, presterjohn, Presumptuous, Primal, prisma, Prometheus, ProtaBLF, pscal, puccio1969
  73. Pukachi, pukoid, Pulsar13, qandeel, R.D., radb, rag, Ragsy, raiko, rajun50
  74. Randolph, RapidLux, Rat_Racer, RaVeN, raynman, rdoc613, red72vw, redrider706, regaia, reliant_turbo
  75. ReManG, reno, retiro675, rexdog, rfd673, ricardon, Ricflair, Rick, rjorge, rmkline
  76. Rob_K, robbobus, Roberrt777, RobertB, RocketTomato, RockHugger, Romey310, RonMuller, Roter, RotorHead64
  77. Rpdos, Rska, Rsqweezy, rufrydr, Rufusbduck, Rxich, ryukin2000, sac02, saf99, Saigon
  78. SamHaLeKe, samis, samnavy, san san, sandanbob, Sarge930, Savydude, SawMaster, saypat, sb56637
  79. scarnific, scdaf, Schkü, schlockproof, Sciencetists, SciFiFreak, Scooby, Scooter000, scootypuffjr, Scorpia
  80. scotlarock, Scottland, Scotty, scs, sebastiang, SebaZ74, SeenTheLight, SFB, Sgtpev, Shadowcactus
  81. Shadowfax, Sharpie, shimano3000, shimey, shirnask, Shoe, shogan, Shur, SIGShooter, Silent_Star
  82. Silentcropduster, Simplelight, slackwolf, slackwolf 3rd, Sledge, Sledgestone, slickpenguin, slimkango, slow2go, smed1275
  83. Smittymojo, SmokinH, Snoballz, SoCalTiger, sochi111, Sofa, sol, SolarLumen, solRNY, somnambulism
  84. Sonpham, southland, sp5it, spade413, sparkyDK, specialk, Speed4goal, Speedsix, spkzzz, Sprinkles
  85. srs2000, stanley-beamish, starcrazed, stareye, staticx57, steel_1024, Steenbhg, steepdrop, Stephen Elliott, stephenk
  86. steve42, Stevejj, SteveMidwest, stevez32, Stittville Ed, Stoneface, strango, strayz, Streamer, strmix
  87. Subterrestrial, Sukoi, Sullysat, Suncoaster, Swennie, Syncmasterklop, syracuse, T-boon, T18, t3rminal
  88. tapir, tarver, Tarvos, tas69, tatasal, teacher, tebeve, techieman33, Tecmo, tekwyzrd
  89. tenohfive, Tete, Texas_Ace, The Burgh, The Grand Pooh-Bah, The Imp, The Jinx, The Last Katun, The Miller, The_Driver
  90. thebaum, thecrc, TheDude, TheHebrewHammer, TheJo, TheMadcap, themaindude, Theodore41, theoldbill, TheOnlyDocc
  91. thijsco19, tigris99, timcodes, tindrum42, tinowrx, Tixx, Tjhosan, Tjohn, Tmik, tmxod
  92. Toccata, tocirahl, Tom E, Tom_182, tomtaylor, tonylim, torchjunkie, toxiccoccyx, ToyKeeper, tracerfire
  93. Trashman531, Trasnodel, trevglas, trevize, treysoucie, tristanxoxo, troisanh, tronx, TRoPHeuS, tru3s1lv3r
  94. Tunerman, tungkon, TurboLion, turbopscl, turpulator, tzmxxhh, Ulric, unit311, unknown00101, uqs1000
  95. Vagany, VaKo, Valdorg, Van, Vanq86, vas, vasa_visost, Vattern, velocraig, vex_zg
  96. Viamede, vinte77, Volks1973, vulpes, vwpieces, Wackyvegan, walty, WarHawk-AVG, warzi1975, wattstar
  97. websterjody, weklund, Werner, WestBam, westcoastwonders, whitecitadel, Wieselflinkpro, Wildcat, wildmermaid, Wildthing
  98. willmo, WillyD, wilwok, Wineslurper, wisefire, wishiwereaskibum, wkhchin81, Wojto, WolfA, Wrathbringer27
  99. wunderhe, Wyre, Xandre, xCentrino, xed888, xelario, xjsnake, xray291, xtrosity, XXX-Man
  100. xzel87, yasenf, yclongthrow, YoFlash, Yokiamy, Yourrid, zachary6227, zak.wilson, Zanders, zara
  101. zelee, Zeratull, zeroair, zifzif, zipelgas, zoysiamo, ZozzV6, ×73rmin8r,
teacher
teacher's picture
Tom E wrote:
teacher wrote:
I think, flats tops will work with it now as is… sparkyDK. Smile EDIT: If they are of proper length. Thumbs Up
smile Sheriously, typical flat tops won’t work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA’s are flat top, but unusual because the tops protrude higher than the wrapping – so they work, as long as the springs can handle the shorter length.
Thumbs Up …. My apologies sparky. I was thinking only of the GA’s (because that is what I am using) and totally left out the test of the important facts about most all other flat tops. Facepalm
Again… my apologies. I shall now put on the Dunce Hat & sit myself in the corner the remainder of the night for the incorrect info I gave… that in all likelyhood could create confusion…… Facepalm .. Crying
Thank goodness Tom caught it quickly & posted the correct info. Smile
I’ll edit my post also..
sparkyDK
Thats okay and not the cells i got for the Q8, i have a set of Sony’s VTC6 and a Set of the brown LG’s ( HG2 ), both flat top style i will have to do something about.
I am not quite sure if the GAs will be good without something done to them, as they have no button the spring should squease them less tight, so maybe a thud on the end cap would make connection go.
Then again as i understand the Q8 that shouldent matter if one or two cells momentarily get disconnected.
Man i cant wait to get my hands on this thing, just ordered a new sleeping bag tonight, so aside for a pice of tarp i am ready to go play survivalist in the forests of Denmark.
Forrest’s that will not be so dark when i am around, with or without the Q8 Wink
blinker
Last seen: 10 months 3 weeks ago
Yay! An updated list. Thanks.
Not a flashlight guru, but like them just the same.
Misspellers of the world UNTIE!!!
B42
B42's picture
Last seen: 9 months 2 weeks ago
Doh, just read about the switch to 3 LEDs, thats not happening is it? I certainly would vote against it but looks like I didn’t check back and see it in time to vote…
MRsDNF
MRsDNF's picture
Thanks Mr.Scott. Thumbs Up
teacher
teacher's picture
What are you referring to might I ask? Smile
teacher
teacher's picture
+1 to that. Your a life saver Mr. Scott….. Smile
The Miller
The Miller's picture
Last seen: 2 years 1 week ago
Yeah thanks again so much Mr.Scott!!
Wit? No switch to 3 LEDs
Modders have made smart modifications to the tail PCB so the tail can be used to load cells
The Boss1 had nubs and a good alignment where other companies go for a rotating tail PCB
Hairy_Steve
Last seen: 4 months 5 days ago
I’m number 340 on the list.
Someone from work wants a stupidly bright light and I think will qualify.
Can I be added again so I get another one?
Thanks
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 1 year 3 weeks ago
I am happy that the light is “finished”!
But now that the luminus sst-40 is out (with real low Vf) i find it really a pity that we did not go for the dualfoodprint leadboard. Is there a plan for a GB in place for a dual leadboard?
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
djozz
djozz's picture
Last seen: 11 hours 18 min ago
You can make a plan, I once had a quote from Kerui Electronics for about 8 euro per board, 50 minimum. The contact is Sundy and she is on BLF under the name “leo ou”. The boards that they make seem high quality (my N119 boards come from there).
TheOnlyDocc
I do not have the funds to backup a project like that but i started a interest list to check if we could get enought people togeter to make it happen.
http://budgetlightforum.com/node/54758
feralcomprehension
Last seen: 2 months 4 days ago
TheOnlyDocc wrote:
...I find it really a pity that we did not go for the dualfoodprint leadboard. Is there a plan for a GB in place for a dual leadboard?
Hi, FNG here.  Can you summarize the perceived advantages of what you're suggesting and outline any other changes that would be required?
Thanks!
strobed
Last seen: 1 month 4 days ago
hank
hank's picture
Last seen: 1 week 5 days ago
Pssst: the new LEDboard discussion is over there: http://budgetlightforum.com/node/54758
TheOnlyDocc
The advantages of a Dual footprint quad LED copper DTP LED board are that you can use all kind of LEDs in this light. At the moment you can only use LEDs that use a XP footprint like XPL, Nichia 309/319A, Nichia 219c. . .. But no XM-L LEDs no SST-40 no XHP50.2 . . .
The new ledboard would allow you to use this LEDs. Some (with different Voltage) would require a driver change and spring PCB mod, some like XPL2, XM-L, SST-40 and some more would only require a LED change. And you may ask why would someone do this?
Many reasons! To get a more prefered color temperatur, or LEDs with a higher CRI, or more output, better throw . . .
Simple it gives you an easy option to mod your light.
dekozn
Last seen: 1 month 2 days ago
what is a spring pcb mod?
Idiot proofing something only creates improved idiots.
hank
hank's picture
The Miller
Thanks hank!
