Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
joechina
B42 wrote:
How do I best take the cover off to look at it when I can?
Removing the switch cover
http://budgetlightforum.com/comment/1193269#comment-1193269
You can scratch the black ring, try to wrap one layer of tape arround the needle noses of the pliers
ElginAgain
Last seen: 4 months 1 week ago
Flashy Mike wrote:
It’s the improved version with ultra low moon.
Seriously:
I first would look for a short at one of the SMD components. Some excessive solder, might be. Perhaps you can upload a close up picture of the driver.
If you deactivate the switch LED – do the main LEDs still glow?
Just preformed the requested test. Deactivation of the switch LED has no affect on the constant glowing of the main LED’s.
I will now disassemble for inspection of the SMD components on the driver. I’ll be sure to get some close up photos for documentation and analysis.
stephenk
stephenk's picture
Last seen: 14 hours 5 min ago
Received my Q8 (second batch).
Construction cannot be faulted, though I haven’t turned on yet (BT VTC6s still charging).
Tripod hole is perfect!
akovia
Last seen: 7 months 1 day ago
hank wrote:
for Akovia: Go to the top of the page Choose "Search within thread" enter the words "tripod socket" (without quotation marks) That will give you a variety of possibilities several people have mentioned
Thanks!
Everything I have seen suggested so far seems pretty generic. The ones that already come with some flashlights seem more durable and of course purpose made. Was hoping there was a place to buy these.
Like this one from the Lumintop PS03 reviewed here.
So many nice lights have tripod mounts now. Hopefully someone will produce a quality lanyard screw for the aftermarket. Guess I could try contacting Lumintop.
JasonWW
JasonWW's picture
Last seen: 2 days 52 min ago
Flintrock wrote:
It definitely has the bump-on bump off feature.  Handy for slamming it down on the table to turn it off.  Not dependable for biking, but it’s not uncommon from what I can tell.
Okay, this is a puzzling thing to say. Bicycles have vertical loads (bumps on ground). Assuming the flashlight is not pointed straight up at the sky, why would the batteries ever loose contact?
B42
B42's picture
DavidEF wrote:
B42 wrote:
The Miller wrote:
B42 wrote:
Now speaking of the switch…
Hm
It would really be smart to take a look under the switch cover, there is a new cover with full lenght stuff in the box.
It seems you are the second with a cover sliding off issue, the first was a simple swap with the one provided
Well I dont currently have access to it, but I did see one of them and the cover does not appear to have moved at all. It seems the actual switch/actuator underneath the cover has partially fallen away from the external surface so that its not pressable through the cover directly, but at an angle, so now its only pressible with firmer pressure deeper inside the switch hole at an angle…the cover seems to be in place relatively normally still.
I should have access to look first hand at it soon. How do I best take the cover off to look at it when I can?
http://budgetlightforum.com/comment/1202949#comment-1202949
Tks all, I guess it could be this cover then, if it can move even further over from what I saw…I was imagining a flat switch underneath but I guess not. So it looks like there is a mobile peg type switch underneath? I don’t currently have access, but should this weekend and will try replacing the cover.
B42
B42's picture
TY for the suggestion, I wouldn’t want to scratch a gift.
ElginAgain
Got it opened up and snapped a few photos. I’m not seeing anything that I think may be causing the issue. I’ve inspected all the closely spaced pins on the different components and I don’t see any obvious solder bridges. I’ll go ahead and give it a spray down with contact cleaner to see if that helps any. Beyond cleaning, what else should I do? Is there any testing that I should do with my DMM?
JasonWW
JasonWW's picture
This was posted earlier here. Maybe it will give you a better understanding.
Flintrock
Last seen: 3 years 8 months ago
JasonWW wrote:
Flintrock wrote:
It definitely has the bump-on bump off feature.  Handy for slamming it down on the table to turn it off.  *Not dependable for biking*, but it's not uncommon from what I can tell.
With enough experience I might learn to depend on it, but there are times where I wouldn't want to find out by experimenting. I'm not sure either way if it will be good enough, but this everything bumps only up and down argument sounds a bit oversimplified for representing reality too me.  You may bicycle differently from me.  Cruising around in the park is one thing. This is a commonly reported issue for cycling too.  I wouldn't call it a flaw exactly, just not a strength.
manithree
manithree's picture
Last seen: 1 hour 57 min ago
Well, don’t take this too seriously (I don’t), but after pocket carrying it for 2 days, I’ve decided that the Q8 will not be my new EDC light.
My normal attire is cargo shorts and a polo shirt, and the left cargo pocket is usually dedicated to a tube light, either 18650 or 18350. If there’s a Q8 there, I don’t really enjoy biking (the Q8 has to go in the pannier), and the weight is quite noticeable. Shocking, right?
I’ll try just about anything in my EDC rotation, but after 2 days carrying the Q8, I’m looking forward to the return of my jaxman e2/convoy s2+ hybrid nichia 18350. Just in (the unlikely) case anybody else was wondering. Wink
When my grenade pouch comes in, I might try it again.
Zulumoose
Zulumoose's picture
You shouldn’t be carrying the Q8 around in a pocket, any fool can see that with the correct D ring installed it is meant to be a keyring light.
Beam me up!
teacher
teacher's picture
Last seen: 2 years 1 month ago
/\ … Yep….. Big Smile
pommie
ElginAgain double check for micro traces of solder between the pins of U2, on the side with U2 printed, it probably is just flux but you never know Smile
Cheers David
Nothing to see here folks, move along...
BrianK
Last seen: 1 year 1 month ago
I can’t imagine the Q8 as a EDC light unless it was in a pack. Yup, I’d choose another. Great light just not a pocket light. But maybe on the bill of a baseball cap? (just kidding!)
ToyKeeper
ToyKeeper's picture
Last seen: 57 min 32 sec ago
Flintrock wrote:
I do have bistro-HD running on it …
Ah, good. Having the hardware should make it a lot easier to develop. I gave it a try briefly and ran into several bugs right away, so I figured I’d wait until it was a little more stable.
Is that easier than long-press-off?
Anyway, I’m still waiting for my Q8 to show up. Looking forward to another toy, particularly since it has extra features none of my other lights have. Smile (no idea when it’ll be here, but hopefully soon)
Jtm94
Last seen: 1 week 2 days ago
I use the Q8 as a riding light and have had not lost contact once with my mount. I only ride on rough trails at worst and have no issues hitting cracked spots, riding over branches, or going up/down curbs. It is true that most forces of hitting something stiff, or a hard drop will not cause the light to shut off because the forces are mostly perpendicular to the batteries. It isn’t very hard to understand. It would take something like rough mountain biking and a small tree causing the wheel to jolt in an uncontrolled manner to cause disconnect. Due to the weight of the light my mount would be insufficient to handle the sudden repeated forces of such riding. I don’t think the disconnect “issue” is real because riding that would cause it would break the mount trying to hold over half a kilogram of flashlight in place. If you are doing that kind of riding and take safety seriously you should be using a light on your helmet so you can quickly survey the uneven terrain. A handlebar mounted light would be ill-advised for that kind of terrain because the handlebars won’t always be pointed straight.
JasonWW
JasonWW's picture
Yeah, it seems like if the light is pointing forward, only a hard blow of being hit in the rear by a vehicle could cause the batteries to compress the springs and shut the light off. IDK, I was just wondering. Pay no attention to me.
The Miller
The Miller's picture
For biking I would UAW magnets on the – side of the cells just to be sure.
ElginAgain, good you gained access I hope people with knowledge chime in on the clear! pics.
B42, have some sanding paper ready, the black is easy to remove and the result is something most probably like better, a Natal colored ring around the switch goes very well with the bezel.
Really curious how those switch covers look.
DrHook59
Last seen: 5 days 2 hours ago
akovia wrote:
Could someone recommend a tripod lanyard screw for this? Can’t seem to find a nice one.
Try this, akovia
http://www.blackrapid.com/FastenR-Tripod-FR-T1
Flashy Mike
Flashy Mike's picture
Last seen: 5 days 36 min ago
It’s not a bug, it’s a feature.
Flashy Mike
Seems to be another batch of boards. I don’t have this “bai hai hong” printed on mine.
At first glance I can’t see any shorts either, but soldering looks mediocre. Next i would use the multimeter to check all components for shorts, continuity and resistor values, here is a circuit diagram . You could also measure current when light is off with multimeter and power supply, this might give a hint where the current flows. Wait a few seconds after shutting down before you check until the mcu goes to sleep. And with an oscilloscope you could check Pin 5 and 6 of the mcu whether there are any spikes.
If there aren’t any new findings I would re-solder all pads and see if it helps.
DrHook59
I’m in France. My Q8 left Sept 15th and arrived yesterday via the normal route at Roissy. No duty to pay. Packaging was trashed but the light seems fine.
The Q8 is a stupendous piece of work for $40. Between that, my MT103 and my old DEFT I am done for big lights – I’ll run out of trees to melt fairly soon otherwise. I haven’t touched anything on the UI yet as it seems just fine for now. Love the ramping, takes a minute or two to get used to and you’re done. Added my standard shoulder-strap to it and I suspect it will be my regular light for night-time animal duties for a long time. It will certainly be hard to better it. Just brilliant and well worth the wait.
Thank you to all involved, especially the Miller and Tom E. Can’t wait for the FW3A now…. Big Smile
ohbreeeezy
ohbreeeezy's picture
Last seen: 1 week 3 days ago
Not sure if this was posted.
ERDOS
FLIR thermal photo after cca. 5min on turbo (stepdown disabled) with fresh 30Q and no mods.
Thank you BLF team !
sless
Last seen: 3 years 5 months ago
any plan for white light ?
Tom Tom
Last seen: 2 years 6 months ago
I’d take a careful look around R3, in case there is a dodgy joint or the resistor itself is faulty , though it seems to look OK.
This 100K resistor is there to drain the FET gate voltage to ground when the gate is not being actively driven by the MCU.
If it has become disconnected, this might explain the very slight current flowing through the LEDs when the MCU is asleep, depending on how MCU pin 6 is left during sleep.
E.g. if MCU pin is left floating tri-state (and R3 has become disconnected), only the tiniest leakage current would be enough to charge the FET gate just sufficiently to turn it on very slightly.
Check resistance measured at the FET gate pin to ground.
Should be no more than 100K (depending on whether much meter current flows through MCU pin as well). Try with meter probes both ways round, in case in one direction MCU pin protection circuit conducts. Generally black probe on ground should be OK.
Maybe afterwards try re-touching R3 solder joints anyway, if you feel up to it.
Well, that’s my hypothesis, for now, with a lot of “ifs” Wink
Otherwise maybe a leaky 7135, but you would have to disconnect it to diagnose that.
akovia
DrHook59 wrote:
Try this, akovia http://www.blackrapid.com/FastenR-Tripod-FR-T1
That is a nice one for sure.
Thanks!
Tom E
Tom E's picture
Last seen: 2 hours 16 min ago
hank wrote:
> tripod socket Someone up there *EDIT: that was Nil, at http://budgetlightforum.com/comment/1190375#comment-1190375* recommended this one. I agree it looks better than the other choices. https://www.aliexpress.com/item/Photography-studio-accessories-1-4-D-rin... !{width:15%}https://ae01.alicdn.com/kf/HTB18yIPcWmgSKJjSspiq6xyJFXaU/Jadkinsta-Metal...
I got a few of these in. They are pretty nice, heavy so seem well made, and don't need to be sanded/grinded down to fit. The ring though will flop around, so using a heavier, thickr lanyard would work well with them.
akovia
I did find this in my searching as well if anyone is interested in a static ring. I like that it's stainless steel.
https://www.aliexpress.com/item/SmallRig-Standard-1-4-20-Threaded-Screw-...
