Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
joechina
Last seen: 1 week 1 day ago
I guess Tom E. used 8sec to be able to switch quickly between RAMPING and MODES.
The sequence to change is:
Hold the button till it blinks the first settings, then one or two clicks and then hold the button till the lamp confirm with four blinks.
In retrospect I think it would also better to change the first setting to
1 click = RAMPING
2 clicks = MODES
Today it’s reversed.
Only for the reason RAMPING is mostly used and people try to switch off the lamp if it starts blinking.
Alexium
Last seen: 4 months 1 week ago
WalkIntoTheLight wrote:
High-drain cells have less “voltage sag” when driven hard, than regular cells. So, a high-drain battery will give you higher output.
Oh, I see! Didn’t realize that. Thanks.
joechina wrote:
- protected are recommended for legalreasons. Remember there are settings you can switch the protection off.
- It’s a BLF Lamp. Of course it uses more amps. If you clean all connections it should suck 18 Amps. With bypassed springs nearly 20A.
(at turn on)
Gotcha, thanks for the reply.
So the turbo mode is just shoving as much current down the LED’s throat as it the Ohm’s law will let it. Is that safe for the LEDs? Not that I’m concerned, I personally don’t intend on using that mode for prolonged periods of time, just curious if the LEDs may degrade when used like this, or Cree is just being super conservative in rating XP-L at 3 A max.
MTE C3-907 -> Convoy C8 -> Convoy S2+ -> BLF Q8 -> Sofirn SP36 -> Somebody please make me stop!
Alexium
JasonWW wrote:
If you look at the 30Q and the Sanyo GA both batteries can easily output more than 5 amps, but if you put them in a Q8 you will get a higher amp draw (higher lumens) using the 30Q compared to the Sanyo GA (maybe 500 lumen or more). A protected Sanyo GA might loose 1,000 or more lumen to a 30Q. The protection circuitry typically adds a lot of internal resistance.
Thanks for the chart. By the way, I have never seen a high-current protected battery, by the way. My local battery shop that’s known for selling original Korean and Japanese cells does not have them, and by “local” I mean it’s probably the best in the country. It only offers protected 5A cells. But I assume protected 30Qs do exist.
Assuming I will not insert the cells the wrong way into my Q8, do you think protected batteries are a must? What kind of protection do you think is the most useful for Q8 as far as preventing undesired situations?
djozz
djozz's picture
Last seen: 46 min 8 sec ago
Yes, the leds may not reach the rated 50,000 hours. But also, in the Q8 and many other modern flashlights, the leds are mounted with an extreme good heat path away from the led, that makes a huge difference while the Cree specs do not take that into account. On this forum we test leds in that environment and find what the real performance is. But we do not see yet what happens after a few thousand hours.
joechina
If a LED ever getting dim after a few years you can swap it out with a new more efficient one.
In the Q8 modding thread there are 3D printed protection rings which make sure a flat top (or reverse end) doesn’t make contact.
Or you fit something into the head which is ca. 0.2mm higher then the brass contact ring. If the nipples are higher than 0.3 the batteries make contact.
Lock the lamp out when you transport it. If its lying on the floor of a car and it rolls around, it can switch it on by its own weight.
JasonWW
JasonWW's picture
Last seen: 26 min 47 sec ago
That’s pretty much it (on a FET driver).
Turbo mode means the FET is constant closed or 100% duty cycle (I hope that’s correct) so it’s like a solid wire from the LEDs to the battery. You can partially limit current through resistance. Smaller guage wire, resistance in springs, resistance in the FET, different batteries, etc…
Other driver types, Constant Current, Buck, Boost have controllable max outputs.
JasonWW
JasonWW's picture
Alexium wrote:
Thanks for the chart. By the way, I have never seen a high-current protected battery. My local battery shop that’s known for selling original Korean and Japanese cells does not have them, and by “local” I mean it’s probably the best in the country. It only offers protected 5A cells. But I assume protected 30Qs do exist.
The protection circuits add a lot of resistance so it defeats the purpose of using a high current cell. You typically see high mAh batteries used with protection circuitry. (EDIT:Imalent has protected 30Q cells rated at 15A)
Any type of protected battery in the Q8 would probably limit it to 4,000 to 4,500 lumen I’m guessing. That’s still pretty bright. If your not after the most lumens and prefer safety, then using protected cells are a good idea.
Thus particular LG MJ1 protected cell can do 12 to 13 amps.
It’s still not going to allow a high amp draw on turbo, though due to the extra resistance.
On other driver types, the extra resistance from the protection circuitry doesn’t hurt performance at all.
Typical things the protection circuitry does is prevent:
Over charging (stop at 4.2v)
Over discharging (stop at 2.5v or similar)
Over temperature
Over current
Reverse polarity
Side note:
No batteries come from the manufacturer with protection circuitry. It is only added by other companies and the little circuit boards can vary from one company to the next. You can have the exact same battery with protection circuitry added by two different companies and have two different maximum current limits.
Zulumoose
Zulumoose's picture
Last seen: 4 months 4 weeks ago
And you probably won’t know what you are getting either – which is why I don’t own any protected batteries. Over and Under voltage protection is fine, as is reverse protection, but I don’t want a battery that will cut out at an unspecified current, or unknown temperature, without warning.
Beam me up!
WalkIntoTheLight
Based on what I’ve read in Cree’s LM80 testing (which tests LED lifetimes), it seems heat is the largest factor in determining LED lifetime, and current is a distant second. At least, within normal ranges. The LED junction point can handle temperatures of 85C-100C okay, but beyond that they start to age the LED prematurely.
No doubt over-driving the LED will cause it some additional aging, but is 20,000 hours or even 10,000 hours so bad? How often are you going to be running the LED at high output? 10,000 hours will require about 10,000 full battery cycles. Even if you drained the batteries in your light each and every night, it would still last 27 years until it dimmed to the 70% threshold. I doubt you’ll still be using the light 27 years from now.
JasonWW
JasonWW's picture
That’s not true. The key is to know what your buying and not to buy just any old protected cell.
Stores like https://liionwholesale.com and www.mtnelectronics.com give detailed info on the protection circuit of each battery. Keeppower also gives specifics on their protection circuitry. Also, you have certain light companies that add their own protection circuitry to cells such as Imalent. They have a protected version of the Samsung 30Q rated at 15A. (I forgot about this one until just now). Plus I’m sure theres a lot more I don’t know about.
As good as stores such as Banggood and Gearbest are, I would not recommend buying protected cells from them. They are so large that their stock is always being replenished and might be replaced with a slightly different protection circuit added on that has different specs. The store may not even realize the product has changed slightly.
alternety
Last seen: 1 year 3 weeks ago
joechina – YES: excellent idea.
click = RAMPING 2 clicks = MODES Today it’s reversed. Only for the reason RAMPING is mostly used and people try to switch off the lamp if it starts blinking.
I believe that will fix the only issue I have with the light. I believe in previous posts I have said the issue is being able to easily entering flashing mode and hard to get out. It is more intuitive to press the button and get ramping.
Please, don’t start on easy and hard. As I have also stated THIS IS INDEED THE FLASHLIGHT I WANTED. I HAVE FOLLOWED THE DEVELOPMENT FROM PRETTY MUCH THE BEGINNING. I bought them when everything was well known.
I did not pay close enough attention to the impact of the actual press sequences when NARSIL was being created. Even if I had paid more attention, I probably would have missed the impact of sequence I view as a problem.
The team did an incredible piece of work. It just needs to be a teeny bit more user friendly (I am talking only about the two button sequences) for sale on the open market. And that may well become the majority of the sales volume.
Contrary to some opinions, I am not an idiot (at least I think so). I am interested in some of the other functions in NARSIL. But not for a civilian, as it currently works.
alternety
An additional feature of getting a protected cell is that you will have a button on the positive end. You can find unprotected cells with buttons.
The button is useful for getting full contact in some lights, and probably chargers.
joechina
alternety
You can ask in a separate thread if somebody near you can change the firmware to your liking.
Maybe Toykeeper if you ship the lights to her.
jstay
Hi, I just received my BLF Q8, bought from banggood. It is all good except I noticed a bubble in one of the led. Is this normal? I never seen anything like this in my other torchlights. I am worried it affects output and more importantly, if it is a defect, cause a premature lifespan of my torchlight.
As shown in the picture, the bubble is quite small but very visible with naked eye, especially in moon mode. On the camera, it is harder to spot so I drew a red arrow.
Can anyone tell me what is this and should I be worried? Thanks
Click on the picture for larger view
Link to imgur: https://imgur.com/a/rOHar
PS: Not sure if this is the right place to post. Please advise if this is the wrong thread.
djozz
djozz's picture
Welcome to BLF jstay!
Is it a bubble as you say, or a black spot (as it looks like in the picture)? Perhaps you can take a picture with the light off?
If it is a clear bubble on the led dome it does not absorb light and warm up, so it does not have to affect the lifetime of the led. But you never know. Bubbles on the led dome are sometimes caused by a hot solder iron slightly touching it.
jstay
Hi djozz,
thanks for your quick response. Yeah, I am quite concerned about this so I created a blf account to ask more about it. Sad
It seems to be a bubble rather than a black spot. With the light off, it (the bubble) cannot be seen with the naked eye. On camera I am quite certain it is not possible as well.
when the light gets brighter as it is ramped up, the bubble cannot be seen as well as the light blinds it out. So, the bubble can only be seen in moon mode.
How serious is this issue, should I contact banggood? Or is this a non-issue which does not affect lifespan and performance?
thank you
JasonWW
JasonWW's picture
This sounds like a completely new issue that nobody has ever heard of before. One would assume that Cree would have noticed that before selling the led.
What can you do though? I doubt banggood would allow you to return it because of that. Maybe you can use turbo quite a bit and see if the LED burns up or not. If it burns up within the warranty period then you could have it replaced. If it survives, then it likely won’t cause any problems later on.
djozz
djozz's picture
I’m afraid that for the seller it is a non-issue until the led blows up, there is no way you can convince them that that tiny black spot is the start of a dying led. The best you can do I think, is do a test run on highest settting, when the light steps down after three minutes, ramp up to highest again and let the light get as hot as you can still touch it. If the led blows you have a case for Banggood, if it doesn’t you will have to live with a bubble in your led and some uncertainty.
jstay
Alright thanks JasonWW and djozz. How long /how many cycles should I let it run on turbo?
jstay
okay thanks ThrowMeInToDarkness. Yeah you happened to answer my question just as I was typing it!
Flashy Mike
Flashy Mike's picture
Last seen: 1 day 8 hours ago
Your bubble might also be just a tiny drop of flux which could easily be removed with Isopropylalcohol instead of completely destroying the LED.
jstay
@ Flashy Mike Yes that might be the case as well (hopefully) thanks for the idea.
Will dipping a cotton bud (also known as q-tip, ear cleaner etc) in 99% ipa and then lightly wiping the led dome do the trick without damaging?
djozz
djozz's picture
sounds good, you will not destroy anything like that. Make sure that no cotton fibers are left behind on the dome, that can burn again by the heat of the very dense radiation.
jstay
Okay , will try that. Thanks for the idea
Flashy Mike
Probably yes, but don’t touch the front of the reflector. I strongly suggest to remove the reflector before cleaning.
Q-Tip is perfect.
jstay
ok thank you for the response.
to remove the reflector for blf q8, I just need to unscrew the top portion (silver aluminum ring, o ring , glass) and the reflector can be pulled upwards directly?
or do I need to unscrew the bottom including the driver circuits etc. ?
djozz
djozz's picture
I’m afraid that you need to go all the way. Everything comes apart fine but this is it:
First unscrew the silver SS ring and remove the glass and large o-ring. Turn the head around.
Unscrew the driver and tilt it until you can get past it with a screwdriver. Inside the driver cavity first unscrew the big central screw then the two small screws. Then the reflector should fall down. Clean the led and reverse for assembly, take care to seat the reflector precisely on the the plastic centering rings around the led before tightening the screws in the driver cavity.
jstay
@djozz
ok I will do that. thanks for the detailed steps!
bushmaster
bushmaster's picture
Last seen: 1 hour 57 min ago
I so love this site.
Always a guru a click away. Smile
Keep your nose in the wind and your eyes along the skyline.
Del Gue
jstay
yeah I feel the same here. even though I’m a new member people help me voluntarily with nothing to gain. and it’s especially helpful for a newbie like me who’s worried things go wrong when yall guide me. Thank you.
update: I’ve contacted banggood about it, but they have not responded. most likely it’s a non issue, since I cycled it thrice and nothing has changed. but I’m using protected cells as the new unprotected haven’t arrived.
I’ve also bought another q8 as a spare, as I felt it’s a really good light even with this “defect”, and also since the banggood coupon code might expire soon. Hope that one is ok!
