Just Bought a Keygos KE2 off ebay (which probably my last light for a while), Anyone have this light and could compare against the KE5 or C8?
Thanks
Thanks
from which seller did you buy it?
You have a link to it?
Bought it from Cyberport888
Here's the link
I just received the KE2, It looks like The Ultrafire X2/ C8 with steel bezel.
I would still say that the KE5 is way a better light overall.
Pros
Bright, same driver as the KE5 but looks to be brighter output.
Cons
Weak rubber tail switch
When the pill is fully threaded to the body, the glass lens is moving and the Oring is loosened, Have to loosen the Pill a bit to Tighten the fit of glass and oring. still wont trust waterproofing.
Maybe I just have a bad sample.
Anyone could suggest where to get the best replacement rubber switch and replacement pill? maybe copper?
Once I receive my ultrafire C8 I could compare the difference.
thanks
