Test/Review of Nohon 3C double usb charger
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 38 min ago
DSC_4020
Official specifications:
  • Input: 100-240VAC 50/60Hz
  • Output: 5.0V 2.4A
  • Model number: TC-029
I got it from a reader
DSC_4013 DSC_4014
DSC_4021 DSC_4022 DSC_4025
DSC_4023 DSC_4024
Measurements
  • Power consumption when idle is 0.06 watt
  • Usb outputs is auto detect with Apple 2.4A as maximum.
  • Usb outputs are in parallel
Nohon%203C%20double%20usb%20charger%20top%20load%20sweep
Nohon%203C%20double%20usb%20charger%20bottom%20load%20sweep
Each output can deliver 2.5A, very nice overload protection for a 2.4A output.
Nohon%203C%20double%20usb%20charger%20load%20sweep
The total power is also 2.5A, i.e. this charger can only handle one high current device at a time.
Nohon%203C%20double%20usb%20charger%20load%20test
I could draw 2.4A for 1 hour without any problems.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp3068
M1: 52,9°C, M2: 45,8°C, HS1: 64,9°C
HS1 is the rectifier diode.
Temp3069
M1: 50,9°C, HS1: 73,0°C
HS1 must be the switcher transistor.
Temp3070
M1: 57,3°C, M2: 52,3°C, HS1: 81,0°C
Temp3071
M1: 56,6°C, HS1: 62,2°C
Temp3072
M1: 51,7°C, HS1: 69,2°C
10ohm
Noise at 0.5A load is 14mV rms and 170mVpp
5ohm
Noise at 1A load is 14mV rms and 154mVpp
2.5ohm
Noise at 2A load is 19mV rms and 177mVpp
Tear down
DSC_4280
With my vice I could press it open. This is two circuit boards against each other.
DSC_4281
On this circuit board there is a large rectifier diode (D2) and a usb auto coding chip (U2).
DSC_4283
The other circuit board is the mains side, it has a bridge rectifier, a switching transistor and a switch controller IC (Partial hidden under the yellow tape).
DSC_4282
The safety cap is mounted between the two circuit boards.
Notice the black plastic shield, it is used to isolate between mains and low volt side.
DSC_4284
Transformer and plastic shield.
DSC_4285
Again the safety capacitor can be seen and the plastic shield.
DSC_4286
Unsoldering the circuits boards from the mains plug and unsoldering one of the safety capacitors connections, makes it possible to open the two circuit boards.
There is a fuse and a inductor on the mains circuit board.
DSC_4287
Here it is without the plastic shield, notice the two output wires from the transformer with thick isolation.
DSC_4289
Here I also removed the thick layer of isolation tape.
DSC_4288
Another view on this side of the circuit boards.
DSC_4290 DSC_4293
DSC_4291
Here the fuse can be seen near “L” connection, it is hidden in black heat shrink.
DSC_4292
DSC_4294
The plastic shield.
DSC_4295
Good isolation distance here.
The distance between conductive parts on mains and low volt side must be at leat 4mm in air. Due to the complex construction it is difficult to see if it maintains it everywhere, but I believe it does.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This compact usb power supply looks good, stable output voltage, auto coding, fairly low noise and good safety, but it can only handle one power hungry phone at a time.
Notes
I got the usb power supply from a reader for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Enelooper
Enelooper's picture
Last seen: 2 years 5 days ago
Thanks for the good work!
