For sale: Translucent side switch covers for Thorfire S70.
Cost $0.75 for U.S. customers, including first class postage. Cost for mailing is too high for international customers.
I have 14 for sale. Sign up here or PM me. I will PM you with the payment instructions.
Limit one to a customer. If you need more, I suggest that you order them directly from Kaidomain: “[link]”:http://www.kaidomain.com/product/details.S024948
List
- tzmxxhh
- chooma
- Andyman
- Killforfood
- tru3s1lv3r
- jhalb
- Texas_Ace
- Mr.Scott
- randyhoang
Wait List
1.
2.
3.
4.
5.
Comments:
This replacement switch cover is approximately 10mm x 8mm, whereas the original cover is approximately 10mm x 6mm. Not an exact fit (see pictures below), but works just as well as the original as far as operating the switch is concerned.
The slightly thicker flange causes the switch retaining ring to stick up about a half-millimeter more than the original. Because the retaining ring does not snug completely down to the flashlight body, there is a slightly increased risk of water intrusion via the threads. I would recommend against intentionally dunking or using this flashlight (with the translucent switch cover) submerged underwater.
Before and after pictures of the switch (like night and day!):
Removal of the side switch retaining ring is a simple process of unscrewing it. See this link if you need further instructions: Sky Ray king ..lost button - #16 by Shaquille
You can use a pair of long-nosed pliers, snap ring pliers, or tweezers as a tool for removing the retaining ring. It is not screwed on very tightly. However, be very careful not to scratch the anodized finish of the flashlight or the retaining ring.
