Camelion AA Premium 2300mAh (White)
Official specifications:
Capacity typical: 2300mAh
Capacity minimum: 2200mAh
Nominal Voltage: 1,2V
Dimensions (Ø x L mm): 14,1 x 50,5
Weight (g): 29,0
Electrochemical System: Nickel-Metal Hydrid
Low self discharge: 90% after 6 months, 85% after 1 year.
Maximum temperature raise at different discharge currents: 1A:+1,4°C, 2A:+3,4°C, 3A:+5,9°C, 5A:+11,5°C, 7A:+17,2°C, 10A:+24,5°C
Camelions medium capacity and LSD (Low Self Discharge) NiMH batteries.
The discharge curves looks good with just about perfect tracking between the cells and some performance at high current.
Conclusion
The cells has good current performance, but capacity is a bit low. The LSD performance is not in top for medium capacity cells.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
